[petsc-users] PETSc initialization error
Sam Guo sam.guo at cd-adapco.com
Fri Jun 26 15:14:43 CDT 2020
To clarify, we have a mpi wrapper (so we can switch to different mpi at
runtime). I compile petsc using our mpi wrapper.
If I just call PETSc initialize once without calling finallize, it is ok.
My question to you is that: can I skip finalize?
Our program calls mpi_finalize at end anyway.
On Fri, Jun 26, 2020 at 1:09 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Hi Junchao,
>    Attached please find the configure.log.
>    I also attach the pinit.c which contains your patch (I am currently
> using 3.11.3. I've applied your patch to 3.11.3). Your patch fixes the
> serial version. The error now is about the parallel.
>    Here is the error log:
> [1]PETSC ERROR: #1 PetscInitialize() line 969 in
> ../../../petsc/src/sys/objects/pinit.c
> [1]PETSC ERROR: #2 checkError() line 56 in
> ../../../physics/src/eigensolver/SLEPc.cpp
> [1]PETSC ERROR: #3 PetscInitialize() line 966 in
> [1]PETSC ERROR: #4 SlepcInitialize() line 262 in
> ../../../slepc/src/sys/slepcinit.c
> [0]PETSC ERROR: #1 PetscInitialize() line 969 in
> [0]PETSC ERROR: #2 checkError() line 56 in
> [0]PETSC ERROR: #3 PetscInitialize() line 966 in
> [0]PETSC ERROR: #4 SlepcInitialize() line 262 in
> PETSC ERROR: Logging has not been enabled.
> You might have forgotten to call PetscInitialize().
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 56.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> Thanks,
> Sam
> On Thu, Jun 25, 2020 at 7:37 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Sam,
>>    The MPI_Comm_create_keyval() error was fixed in maint/master. From the
>> error message, it seems you need to configure --with-log=1
>>    Otherwise, please send your full error stack trace and configure.log.
>>   Thanks.
>> --Junchao Zhang
>> On Thu, Jun 25, 2020 at 2:18 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Hi Junchao,
>>>    I now encountered the same error with parallel. I am wondering if
>>> there is a need for parallel fix as well.
>>> On Sat, Jun 20, 2020 at 7:35 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Hi Junchao,
>>>>    Your patch works.
>>>> Thanks,
>>>> Sam
>>>> On Sat, Jun 20, 2020 at 4:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>    Junchao,
>>>>>>      This is a good bug fix. It solves the problem when PETSc
>>>>>> initialize is called many times.
>>>>>>      There is another fix you can do to limit PETSc mpiuni running
>>>>>> out of attributes inside a single PETSc run:
>>>>>> int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>>>>  if (num_attr >= MAX_ATTR){
>>>>>>    for (i=0; i<num_attr; i++) {
>>>>>>      if (!attr_keyval[i].extra_state) {
>>>>> attr_keyval[i].extra_state is provided by user (could be NULL). We can
>>>>> not rely on it.
>>>>>>         /* reuse this slot */
>>>>>>         attr_keyval[i].extra_state = extra_state;
>>>>>>        attr_keyval[i.]del         = delete_fn;
>>>>>>        *keyval = i;
>>>>>>         return MPI_SUCCESS;
>>>>>>   return MPIUni_Abort(MPI_COMM_WORLD,1);
>>>>>>   attr_keyval[num_attr].extra_state = extra_state;
>>>>>>   attr_keyval[num_attr].del         = delete_fn;
>>>>>>   *keyval                           = num_attr++;
>>>>>>   return MPI_SUCCESS;
>>>>>>   This will work if the user creates tons of attributes but is
>>>>>> constantly deleting some as they new ones. So long as the number
>>>>>> outstanding at one time is < MAX_ATTR)
>>>>>> Barry
>>>>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>>>>>> wrote:
>>>>>> I don't understand what your session means. Let's try this patch
>>>>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>>>>> index d559a513..c058265d 100644
>>>>>> --- a/src/sys/mpiuni/mpi.c
>>>>>> +++ b/src/sys/mpiuni/mpi.c
>>>>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>>>>    MPI_Comm_free(&comm);
>>>>>>    comm = MPI_COMM_SELF;
>>>>>> +  num_attr = 1; /* reset the counter */
>>>>>>    MPI_was_finalized = 1;
>>>>>>    return MPI_SUCCESS;
>>>>>> --Junchao Zhang
>>>>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>> wrote:
>>>>>>> Typo: I mean “Assuming initializer is only needed once for entire
>>>>>>> session”
>>>>>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>>> Assuming finalizer is only needed once for entire session(?), I can
>>>>>>>> put initializer into the static block to call it once but where do I call
>>>>>>>> finalizer?
>>>>>>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> The counter num_attr should be recycled. But first try to call
>>>>>>>>> PETSc initialize/Finalize only once to see it fixes the error.
>>>>>>>>> --Junchao Zhang
>>>>>>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>> wrote:
>>>>>>>>>> To clarify, I call PETSc initialize and PETSc finalize
>>>>>>>>>> everytime I call SLEPc:
>>>>>>>>>>   PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>>>>>>   SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>>>>>>   //calling slepc
>>>>>>>>>>   SlepcFinalize();
>>>>>>>>>>    PetscFinalize();
>>>>>>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Dear PETSc team,
>>>>>>>>>>>    When I called SLEPc multiple time, I eventually got following
>>>>>>>>>>> error:
>>>>>>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>>>>>>>   I debugged: it is because of following in
>>>>>>>>>>> petsc/src/sys/mpiuni/mpi.c
>>>>>>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>>>>> num_attr is declared static and keeps increasing every
>>>>>>>>>>> time MPI_Comm_create_keyval is called.
>>>>>>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>>>>>>> Is this a bug or I didn't use it correctly?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200626/b87437f7/attachment.html>
