[petsc-users] PETSc initialization error
Junchao Zhang
junchao.zhang at gmail.com
Thu Jun 25 21:36:55 CDT 2020
Sam,
The MPI_Comm_create_keyval() error was fixed in maint/master. From the
error message, it seems you need to configure --with-log=1
Otherwise, please send your full error stack trace and configure.log.
Thanks.
--Junchao Zhang
On Thu, Jun 25, 2020 at 2:18 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Hi Junchao,
> I now encountered the same error with parallel. I am wondering if there
> is a need for parallel fix as well.
> [1]PETSC ERROR: #1 PetscInitialize() line 969 in
> ../../../petsc/src/sys/objects/pinit.c
> PETSC ERROR: Logging has not been enabled.
> You might have forgotten to call PetscInitialize().
> On Sat, Jun 20, 2020 at 7:35 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Hi Junchao,
>> Your patch works.
>> Thanks,
>> Sam
>> On Sat, Jun 20, 2020 at 4:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> Junchao,
>>>> This is a good bug fix. It solves the problem when PETSc
>>>> initialize is called many times.
>>>> There is another fix you can do to limit PETSc mpiuni running out
>>>> of attributes inside a single PETSc run:
>>>> int MPI_Comm_create_keyval(MPI_Copy_function
>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>> if (num_attr >= MAX_ATTR){
>>>> for (i=0; i<num_attr; i++) {
>>>> if (!attr_keyval[i].extra_state) {
>>> attr_keyval[i].extra_state is provided by user (could be NULL). We can
>>> not rely on it.
>>>> /* reuse this slot */
>>>> attr_keyval[i].extra_state = extra_state;
>>>> attr_keyval[i.]del = delete_fn;
>>>> *keyval = i;
>>>> return MPI_SUCCESS;
>>>> return MPIUni_Abort(MPI_COMM_WORLD,1);
>>>> attr_keyval[num_attr].extra_state = extra_state;
>>>> attr_keyval[num_attr].del = delete_fn;
>>>> *keyval = num_attr++;
>>>> return MPI_SUCCESS;
>>>> This will work if the user creates tons of attributes but is
>>>> constantly deleting some as they new ones. So long as the number
>>>> outstanding at one time is < MAX_ATTR)
>>>> Barry
>>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>> I don't understand what your session means. Let's try this patch
>>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>>> index d559a513..c058265d 100644
>>>> --- a/src/sys/mpiuni/mpi.c
>>>> +++ b/src/sys/mpiuni/mpi.c
>>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>> MPI_Comm_free(&comm);
>>>> comm = MPI_COMM_SELF;
>>>> + num_attr = 1; /* reset the counter */
>>>> MPI_was_finalized = 1;
>>>> return MPI_SUCCESS;
>>>> --Junchao Zhang
>>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Typo: I mean “Assuming initializer is only needed once for entire
>>>>> session”
>>>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>> Assuming finalizer is only needed once for entire session(?), I can
>>>>>> put initializer into the static block to call it once but where do I call
>>>>>> finalizer?
>>>>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>>>>>> wrote:
>>>>>>> The counter num_attr should be recycled. But first try to call PETSc
>>>>>>> initialize/Finalize only once to see it fixes the error.
>>>>>>> --Junchao Zhang
>>>>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>> wrote:
>>>>>>>> To clarify, I call PETSc initialize and PETSc finalize everytime I
>>>>>>>> call SLEPc:
>>>>>>>> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>>>> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>>>> //calling slepc
>>>>>>>> SlepcFinalize();
>>>>>>>> PetscFinalize();
>>>>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>> wrote:
>>>>>>>>> Dear PETSc team,
>>>>>>>>> When I called SLEPc multiple time, I eventually got following
>>>>>>>>> error:
>>>>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>>>>> ../../../slepc/src/sys/slepcinit.c
>>>>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>>>>> I debugged: it is because of following in
>>>>>>>>> petsc/src/sys/mpiuni/mpi.c
>>>>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>>> num_attr is declared static and keeps increasing every
>>>>>>>>> time MPI_Comm_create_keyval is called.
>>>>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>>>>> Is this a bug or I didn't use it correctly?
>>>>>>>>> Thanks,
>>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200625/c0f532e2/attachment.html>
