[petsc-users] [Ext] Question on SLEPc + computing SVD with a "matrix free" matrix
Ernesto Prudencio EPrudencio at slb.com
Thu Jun 25 01:28:09 CDT 2020
I didn't know about this "shell matrix" concept. I will take a look.
Best,
Ernesto.
Schlumberger-Private
-----Original Message-----
Sent: Thursday, June 25, 2020 1:26 AM
To: Ernesto Prudencio <EPrudencio at slb.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [Ext] [petsc-users] Question on SLEPc + computing SVD with a "matrix free" matrix
Another alternative is to create a shell matrix C with a user context that contains both A and B, then MatMult(C) calls MatMult(A) and MatMultTranspose(C) calls MatMult(B).
> El 25 jun 2020, a las 8:23, Ernesto Prudencio <EPrudencio at slb.com> escribió:
> Thank you, Jose.
> However, in the case of a "matrix free" matrix, the APIs on PETSc seem to allow just the implementation of A.v, not of A' . w
> One could create another "matrix free" matrix B which could make the role of computing z = B . w = A' . w. But how could one force the routine MatMultTranspose(A, w, z) to call the routine for B? Here I am assuming that MatMultTranspose(A, w, z) is the routine that SLEPc calls internally in its algorithms when the user sets for implicit transpose.
> I see two possibilities (for brain storming, since I don't know if such approaches would be acceptable for the PETSc team and/or the SLEPc team):
> 1) PETSc could add an entry for a second routine that computes [ A' . w ] when calling MatMFFDSetFunction()
> 2) SLEPc could add an entry for the routine for computing [ A' . w ] when the matrix A is "matrix free"
> Thanks again,
> Ernesto.
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: Thursday, June 25, 2020 1:01 AM
> Subject: [Ext] Re: [petsc-users] Question on SLEPc + computing SVD with a "matrix free" matrix
> Yes, you have to set it with SVDSetImplicitTranspose(), but then the matrix-free matrix should implement both "A.v" and "A'.v" operations.
> Jose
>> El 24 jun 2020, a las 23:25, Ernesto Prudencio via petsc-users <petsc-users at mcs.anl.gov> escribió:
>> Hi,
>> Is it possible to compute a SVD for a “matrix free” matrix?
>> At first, it seems it would be ok with a MatCreateMFFD() and MatMFFDSetFunction(), because one could then provide the routine that computes “A . v” for any given v, which is an operation needed by SLEPc. However, one would also need to set up the SVD object in SLEPc with an implicit transpose. Would that be possible?
>> Thanks in advance,
>> Ernesto.
