[petsc-users] Question about HDF5 Viewer and Datasets
Lucas Banting
bantingl at myumanitoba.ca
Tue Jun 23 07:55:52 CDT 2020
Hello,
I am trying to use the HDF5 viewer to store the solution of my system at every iteration.
I am storing the solutions in order to compare two different results, one from an old sequential program and one from a new parallel program that is parallelized using the DMDA structure.
I am using matlab to compare the results.
In the sequential program, the vector for the solution is just a simple one dimensional vector made from VecCreate. In the parallel program, the vector is made from DMCreateGlobalVector.
In both versions of the program, I create the viewer as:
call PetscViewerHDF5Open(PETSC_COMM_WORLD,"filename.hdf5",&
FILE_MODE_WRITE,hdf5viewer,ierr)
When I load the files into MATLAB after words, the sequential program creates a new dataset each iteration, while the parallel version using DMCreateGlobalVector only stores a single dataset.
Is there a way I can force both viewers to create a new dataset in the same way each time vecview is called? Or is there someway I can manually create a new dataset?
I am using Open MPI 3.1.4, Petsc 3.12.4, Intel Fortran 2019.5, and hdf5/1.10.5.
Lucas Banting
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200623/43ec0f59/attachment.html>
