[petsc-users] SNES Line search: fixing the non zero solution values of dirichlet nodes during line search
Matthew Knepley
knepley at gmail.com
Mon Jun 22 12:19:25 CDT 2020
On Mon, Jun 22, 2020 at 1:13 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Jun 22, 2020, at 11:56 AM, Ashish Patel <ashish.patel at onscale.com>
> wrote:
> Thanks Stefano, Barry and Hong for your feedback.
> Stefano, the option that you suggested is helpful to freeze the dirichlet
> values. However, it did not completely solve the convergence issue for
> nonlinear problems using linesearch since the direction vector which is
> calculated before any Solve uses the residual which is not yet updated for
> the new Dirichlet values (u(t) =b(t)). The update happens only after the
> solve at SNES iteration 0. To fix this I now update the residual for nodes
> adjacent to Dirichlet nodes without depending on any Solve. The Solve stage
> only updates the solution for dirichlet nodes. Calculating the residual
> this way resolves the issue.
> Barry, Hong yes you are right, the dirichlet boundary conditions are time
> dependent. We do solve the equations implicitly and use TSIFunction and
> TSIJacobian to set up the problem. The dirichlet nodes are part of
> computational nodes. The jacobian for dirchlet nodes has diagonal 1 and
> rows & colums 0. For setting the residual in TSIFunction the residual for
> dirichlet nodes are set to (solution_value-Dirichlet_value).
> Understood. The reason the line search cannot succeed well but
> everything is fine with no line search is that you are putting into the
> Dirichlet nodes (solution_value-Dirichlet_value) for the next time-step but
> with multistage integrators and line searches the nonlinear function being
> evaluated is not simply at the new time step. hence for all those other
> function evaluations the solution you put in
> (solution_value-Dirichlet_value) is meaningless. That is your "function" on
> the Dirichlet nodes is not a function because it doesn't depend on the
> current input.
> As I indicated before there are two approaches to putting the simulation
> on solid footing. Rewriting the boundary condition as an ODE if possible so
> TS manages the handling of the boundary just like the interior points or
> telling TS you are solving a DAE, this means when you provide the IFunction
> and IJacobian you take into account that there is no U_t on the left
> handside for the boundary nodes.
There is a third strategy, which is the one employed by DMPlex for all BC,
including time dependent. It eliminates the dofs constrained by boundary
conditions
for the system. For a simple example, see TS ex45 or ex46. There,
time-dependent boundary conditions are used.
Matt
> Regards
> Ashish
> On Sun, Jun 21, 2020 at 6:23 PM Zhang, Hong <hongzhang at anl.gov> wrote:
>> Can you elaborate a bit on how you "set the RHS as increment of
>> (Dirichlet_value-solution_value)”?
>> It seems that the boundary condition is imposed as algebraic equations
>> (e.g. 0 = u(t)-b(t) ), and the boundary nodes are included in the
>> computational domain. This approach should work theoretically and is used
>> in some TS examples such as ex17.c, you might want to check if the
>> algebraic equations are implemented properly in your IFunction() and
>> IJacobian(). An alternative approach you can try is to remove the boundary
>> nodes from the unknown variables, see the example ex25.c. In this way you
>> solve ODEs instead of DAEs and do not need to worry about SNES modifying
>> certain values.
>> Hong (Mr.)
>> On Jun 19, 2020, at 5:15 PM, Ashish Patel <ashish.patel at onscale.com>
>> wrote:
>> Dear PETSc users,
>> We use PETSc as part of a finite element method program and we are trying
>> to properly implement Dirichlet boundary conditions for non-linear,
>> transient problems. We find that when we use a line search method it also
>> changes the non-zero solution value of Dirichlet nodes as it steps through
>> the line search iteration. I was wondering if there is a way to freeze
>> some index sets of a vector from changing during the line search operation?
>> We are using the TS framework to setup the problem and use
>> 'MatZeroRowsColumns' to set the diagonal of the jacobian to 1 for the
>> dirichlet nodes and set the RHS as increment of
>> (Dirichlet_value-solution_value). This works when the line search method is
>> turned off by using '-snes_linesearch_type basic' however using the default
>> 'bt' linesearch, the TS diverges with error shown below. In a separate
>> implementation if we overwrote the dirichlet nodes of the solution vector
>> in TS residual function with the Dirichlet values then the 'bt' line
>> search method converged to the right solution. However we would like to
>> avoid modifying the internal PETSc vector in our implementation.
>> 0 TS dt 1. time 0.
>> 0 SNES Function norm 2.378549386020e+03
>> Line search: gnorm after quadratic fit 4.369235425165e+03
>> Line search: Cubic step no good, shrinking lambda, current gnorm
>> 2.385369069060e+03 lambda=1.0000000000000002e-02
>> Line search: Cubically determined step, current gnorm
>> 2.373925008934e+03 lambda=3.8846250444606093e-03
>> 1 SNES Function norm 2.373925008934e+03
>> Line search: gnorm after quadratic fit 5.006914179995e+03
>> 2.420957096780e+03 lambda=1.0000000000000002e-02
>> 2.376034946750e+03 lambda=1.6129422079664700e-03
>> 2.374313344729e+03 lambda=4.8465026740690043e-04
>> 2.373999473242e+03 lambda=1.5857251532828948e-04
>> 2.373921668024e+03 lambda=5.8116507162753387e-05
>> 2 SNES Function norm 2.373921668024e+03
>> Line search: gnorm after quadratic fit 4.771035112853e+03
>> 2.410650718394e+03 lambda=1.0000000000000002e-02
>> 2.375104094198e+03 lambda=1.8983783738011522e-03
>> 2.374049151562e+03 lambda=7.0688528086485479e-04
>> 2.373935090907e+03 lambda=2.9132722794896019e-04
>> 2.373921032081e+03 lambda=1.2527602265373028e-04
>> 3 SNES Function norm 2.373921032081e+03
>> Line search: gnorm after quadratic fit 5.117914832660e+03
>> 2.422635362094e+03 lambda=1.0000000000000002e-02
>> 2.375923870970e+03 lambda=1.5769887508300913e-03
>> 2.374287081592e+03 lambda=4.8018017100729705e-04
>> 2.373999131160e+03 lambda=1.5908966655977892e-04
>> 2.373930608274e+03 lambda=5.7603977147935371e-05
>> 2.373922022038e+03 lambda=2.3884787050507805e-05
>> 2.373921396636e+03 lambda=1.0282405393471519e-05
>> 2.373921173719e+03 lambda=4.3868704034012554e-06
>> 2.373921091304e+03 lambda=1.8774991151727107e-06
>> 2.373921057168e+03 lambda=8.0331628193813397e-07
>> 2.373921042769e+03 lambda=3.4377811174560817e-07
>> 2.373921036645e+03 lambda=1.4712421886880395e-07
>> 2.373921034032e+03 lambda=6.2965363212312132e-08
>> 2.373921032916e+03 lambda=2.6947718250469261e-08
>> 2.373921032438e+03 lambda=1.1533043989179318e-08
>> 2.373921032233e+03 lambda=4.9359018284334258e-09
>> 2.373921032146e+03 lambda=2.1124641857409436e-09
>> 2.373921032109e+03 lambda=9.0409137304143975e-10
>> 2.373921032093e+03 lambda=3.8693264359674819e-10
>> 2.373921032086e+03 lambda=1.6559911204766632e-10
>> 2.373921032083e+03 lambda=7.0873187020534353e-11
>> 2.373921032081e+03 lambda=3.0332192901757729e-11
>> 2.373921032081e+03 lambda=1.2981600435512875e-11
>> 2.373921032081e+03 lambda=5.5559212521628090e-12
>> 2.373921032081e+03 lambda=2.3777380405336958e-12
>> 2.373921032081e+03 lambda=1.0176091649134191e-12
>> 2.373921032081e+03 lambda=4.3555419789721080e-13
>> Line search: unable to find good step length! After 27 tries
>> Line search: fnorm=2.3739210320805191e+03,
>> gnorm=2.3739210320805323e+03, ynorm=8.5698020038772756e+03,
>> minlambda=9.9999999999999998e-13, lambda=4.3555419789721080e-13, initial
>> slope=-5.6355010665542409e+06
>> SNES Object: 1 MPI processes
>> type: newtonls
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=4
>> total number of function evaluations=48
>> norm schedule ALWAYS
>> SNESLineSearch Object: 1 MPI processes
>> type: bt
>> interpolation: cubic
>> alpha=1.000000e-04
>> maxstep=1.000000e+08, minlambda=1.000000e-12
>> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>> maximum iterations=40
>> KSP Object: 1 MPI processes
>> type: preonly
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using NONE norm type for convergence test
>> PC Object: 1 MPI processes
>> type: cholesky
>> out-of-place factorization
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> factor fill ratio given 0., needed 0.
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: mumps
>> rows=38154, cols=38154
>> package used to perform factorization: mumps
>> total: nonzeros=7080060, allocated nonzeros=7080060
>> total number of mallocs used during MatSetValues calls=0
>> MUMPS run parameters:
>> SYM (matrix type): 2
>> PAR (host participation): 1
>> ICNTL(1) (output for error): 6
>> ICNTL(2) (output of diagnostic msg): 0
>> ICNTL(3) (output for global info): 0
>> ICNTL(4) (level of printing): 0
>> ICNTL(5) (input mat struct): 0
>> ICNTL(6) (matrix prescaling): 7
>> ICNTL(7) (sequential matrix ordering):7
>> ICNTL(8) (scaling strategy): 77
>> ICNTL(10) (max num of refinements): 0
>> ICNTL(11) (error analysis): 0
>> ICNTL(12) (efficiency control): 0
>> ICNTL(13) (efficiency control): 0
>> ICNTL(14) (percentage of estimated workspace increase):
>> 20
>> ICNTL(18) (input mat struct): 0
>> ICNTL(19) (Schur complement info): 0
>> ICNTL(20) (rhs sparse pattern): 0
>> ICNTL(21) (solution struct): 0
>> ICNTL(22) (in-core/out-of-core facility): 0
>> ICNTL(23) (max size of memory can be allocated locally):0
>> ICNTL(24) (detection of null pivot rows): 0
>> ICNTL(25) (computation of a null space basis): 0
>> ICNTL(26) (Schur options for rhs or solution): 0
>> ICNTL(27) (experimental parameter):
>> -32
>> ICNTL(28) (use parallel or sequential ordering): 1
>> ICNTL(29) (parallel ordering): 0
>> ICNTL(30) (user-specified set of entries in inv(A)): 0
>> ICNTL(31) (factors is discarded in the solve phase): 0
>> ICNTL(33) (compute determinant): 0
>> ICNTL(35) (activate BLR based factorization): 0
>> ICNTL(36) (choice of BLR factorization variant): 0
>> ICNTL(38) (estimated compression rate of LU factors):
>> 333
>> CNTL(1) (relative pivoting threshold): 0.01
>> CNTL(2) (stopping criterion of refinement): 1.49012e-08
>> CNTL(3) (absolute pivoting threshold): 0.
>> CNTL(4) (value of static pivoting): -1.
>> CNTL(5) (fixation for null pivots): 0.
>> CNTL(7) (dropping parameter for BLR): 0.
>> RINFO(1) (local estimated flops for the elimination after
>> analysis):
>> [0] 2.73979e+09
>> RINFO(2) (local estimated flops for the assembly after
>> factorization):
>> [0] 1.08826e+07
>> RINFO(3) (local estimated flops for the elimination after
>> factorization):
>> [0] 2.73979e+09
>> INFO(15) (estimated size of (in MB) MUMPS internal data
>> for running numerical factorization):
>> [0] 94
>> INFO(16) (size of (in MB) MUMPS internal data used during
>> [0] 94
>> INFO(23) (num of pivots eliminated on this processor
>> after factorization):
>> [0] 38154
>> RINFOG(1) (global estimated flops for the elimination
>> after analysis): 2.73979e+09
>> RINFOG(2) (global estimated flops for the assembly after
>> factorization): 1.08826e+07
>> RINFOG(3) (global estimated flops for the elimination
>> after factorization): 2.73979e+09
>> (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>> (0.,0.)*(2^0)
>> INFOG(3) (estimated real workspace for factors on all
>> processors after analysis): 8377336
>> INFOG(4) (estimated integer workspace for factors on all
>> processors after analysis): 447902
>> INFOG(5) (estimated maximum front size in the complete
>> tree): 990
>> INFOG(6) (number of nodes in the complete tree): 2730
>> INFOG(7) (ordering option effectively use after
>> analysis): 5
>> INFOG(8) (structural symmetry in percent of the permuted
>> matrix after analysis): 100
>> INFOG(9) (total real/complex workspace to store the
>> matrix factors after factorization): 8377336
>> INFOG(10) (total integer space store the matrix factors
>> after factorization): 447902
>> INFOG(11) (order of largest frontal matrix after
>> factorization): 990
>> INFOG(12) (number of off-diagonal pivots): 10
>> INFOG(13) (number of delayed pivots after factorization):
>> 0
>> INFOG(14) (number of memory compress after
>> factorization): 0
>> INFOG(15) (number of steps of iterative refinement after
>> solution): 0
>> INFOG(16) (estimated size (in MB) of all MUMPS internal
>> data for factorization after analysis: value on the most memory consuming
>> processor): 94
>> INFOG(17) (estimated size of all MUMPS internal data for
>> factorization after analysis: sum over all processors): 94
>> INFOG(18) (size of all MUMPS internal data allocated
>> during factorization: value on the most memory consuming processor): 94
>> INFOG(19) (size of all MUMPS internal data allocated
>> during factorization: sum over all processors): 94
>> INFOG(20) (estimated number of entries in the factors):
>> 7080060
>> INFOG(21) (size in MB of memory effectively used during
>> factorization - value on the most memory consuming processor): 80
>> INFOG(22) (size in MB of memory effectively used during
>> factorization - sum over all processors): 80
>> INFOG(23) (after analysis: value of ICNTL(6) effectively
>> used): 0
>> INFOG(24) (after analysis: value of ICNTL(12) effectively
>> used): 1
>> INFOG(25) (after factorization: number of pivots modified
>> by static pivoting): 0
>> INFOG(28) (after factorization: number of null pivots
>> encountered): 0
>> INFOG(29) (after factorization: effective number of
>> entries in the factors (sum over all processors)): 7080060
>> INFOG(30, 31) (after solution: size in Mbytes of memory
>> used during solution phase): 92, 92
>> INFOG(32) (after analysis: type of analysis done): 1
>> INFOG(33) (value used for ICNTL(8)): 7
>> INFOG(34) (exponent of the determinant if determinant is
>> requested): 0
>> INFOG(35) (after factorization: number of entries taking
>> into account BLR factor compression - sum over all processors): 7080060
>> INFOG(36) (after analysis: estimated size of all MUMPS
>> internal data for running BLR in-core - value on the most memory consuming
>> processor): 0
>> INFOG(37) (after analysis: estimated size of all MUMPS
>> internal data for running BLR in-core - sum over all processors): 0
>> INFOG(38) (after analysis: estimated size of all MUMPS
>> internal data for running BLR out-of-core - value on the most memory
>> consuming processor): 0
>> INFOG(39) (after analysis: estimated size of all MUMPS
>> internal data for running BLR out-of-core - sum over all processors): 0
>> linear system matrix = precond matrix:
>> type: seqaij
>> total: nonzeros=973446, allocated nonzeros=973446
>> not using I-node routines
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
>> increase -ts_max_snes_failures or make negative to attempt recovery
>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
>> Thanks,
>> Ashish
>> Scientific Computing Division
>> OnScale
>> CA, USA
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200622/b4093557/attachment-0001.html>
