[petsc-users] MatFindOffBlockDiagonalEntries error
Eda Oktay eda.oktay at metu.edu.tr
Mon Jun 22 04:20:19 CDT 2020
I am so sorry for the inconvenience, the last error I sent you was a
different one, I forgot to change the codes. I am sending you the
actual error where I used MatFindOffBlockDiagonalEntries again in the
newest version.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Null argument, when expecting valid pointer
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Null argument, when expecting valid pointer
[2]PETSC ERROR: Null Object: Parameter # 1
[2]PETSC ERROR: See
https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
[2]PETSC ERROR: Petsc Release Version 3.13.2, Jun 02, 2020
[2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Null argument, when expecting valid pointer
[3]PETSC ERROR: Null Object: Parameter # 1
[3]PETSC ERROR: See
shooting.
[3]PETSC ERROR: Petsc Release Version 3.13.2, Jun 02, 2020
[3]PETSC ERROR:
./approx_cut_deneme_clustering_son_final_edgecut_without_parmetis on a
arch-linux2-c-debug named b342.wls.metu.edu.tr by edaoktay Mon Jun 22
12:11:44 2020
[1]PETSC ERROR: Null Object: Parameter # 1
[1]PETSC ERROR: See
shooting.
[1]PETSC ERROR: Petsc Release Version 3.13.2, Jun 02, 2020
[1]PETSC ERROR:
12:11:44 2020
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--download-mpich --download-openblas --download-slepc --download-metis
--download-parmetis --download-chaco --with-X=1
[1]PETSC ERROR: #1 ISGetSize() line 1101 in
/home/edaoktay/petsc-3.13.2/src/vec/is/is/interface/index.c
12:11:44 2020
[2]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
[2]PETSC ERROR: #1 ISGetSize() line 1101 in
[2]PETSC ERROR: [3]PETSC ERROR: Configure options --with-cc=gcc
--with-cxx=g++ --download-mpich --download-openblas --download-slepc
--download-metis --download-parmetis --download-chaco --with-X=1
[3]PETSC ERROR: #1 ISGetSize() line 1101 in
[3]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 229 in
/home/edaoktay/petsc-3.13.2/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 229 in
[1]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 9824 in
/home/edaoktay/petsc-3.13.2/src/mat/interface/matrix.c
[2]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 9824 in
[3]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 9824 in
I think this is again the same error when I used an older version.
Again, even though I am using a valid matrix and an index set, I don't
know why I am getting this error.
About the small test example, I couldn't understand what Junchao ment
but this is the first time I am trying to use this function and my
current matrix is quite small 72*72.
  Mat Ais;
  MatCreateSubMatrix(A,idUi,idUi,MAT_INITIAL_MATRIX,&Ais);
  ISSetPermutation(idUi);
  MatPermute(Ais,idUi,idUi,&PL);
IS offd;
MatFindOffBlockDiagonalEntries(PL,&offd);
My matrix PL is working, I know that since I viewed it before the
line: IS offd. And although it says null object for parameter 1,  I
believe that other lines below this error are about IS. Should I
create IS before using it in MatFindOffBlockDiagonalEntries?
Mark Adams <mfadams at lbl.gov>, 19 Haz 2020 Cum, 20:37 tarihinde şunu yazdı:
> This is more useful and you are getting a new error. Maybe the old error is fixed.
> It looks like you are trying to copy a matrix into another but they have different communicators.  For example, one is created with MPI_COMM_WOLD and the other with PETSC_COMM_WORLD.
> On Fri, Jun 19, 2020 at 12:48 PM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> Dear Mark,
>> I updated Petsc and again, here's the error:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Arguments must have same communicators
>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Arguments must have same communicators
>> [1]PETSC ERROR: Different communicators in the two objects: Argument #
>> 1 and 2 flag 3
>> [1]PETSC ERROR: See
>> shooting.
>> [1]PETSC ERROR: [2]PETSC ERROR: [3]PETSC ERROR: ---------------------
>> Error Message --------------------------------------------------------------
>> [3]PETSC ERROR: Arguments must have same communicators
>> [3]PETSC ERROR: Different communicators in the two objects: Argument #
>> 1 and 2 flag 3
>> [3]PETSC ERROR: See
>> shooting.
>> [3]PETSC ERROR:
>> arch-linux2-c-debug named b342.wls.metu.edu.tr by edaoktay Fri Jun 19
>> 19:44:41 2020
>> [3]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> Different communicators in the two objects: Argument # 1 and 2 flag 3
>> [0]PETSC ERROR: See
>> shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.13.2, Jun 02, 2020
>> [0]PETSC ERROR:
>> 19:44:41 2020
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> [0]PETSC ERROR: #1 MatCopy() line 4044 in
>> 19:44:41 2020
>> [1]PETSC ERROR: #1 MatCopy() line 4044 in
>> [3]PETSC ERROR: #1 MatCopy() line 4044 in
>> [0]PETSC ERROR: Nonconforming object sizes
>> [1]PETSC ERROR: Nonconforming object sizes
>> [1]PETSC ERROR: Non conforming matrix add: global sizes 1 x 72, 1 x 72
>> [3]PETSC ERROR: Nonconforming object sizes
>> [3]PETSC ERROR: Non conforming matrix add: global sizes 16 x 72, 16 x 72
>> [3]PETSC ERROR: [0]PETSC ERROR: Non conforming matrix add: global
>> sizes 52 x 72, 52 x 72
>> [0]PETSC ERROR: See
>> shooting.
>> [0]PETSC ERROR: [1]PETSC ERROR: See
>> shooting.
>> [1]PETSC ERROR:
>> 19:44:41 2020
>> See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [3]PETSC ERROR:
>> 19:44:41 2020
>> [3]PETSC ERROR:
>> 19:44:41 2020
>> [0]PETSC ERROR: [1]PETSC ERROR: Configure options --with-cc=gcc
>> [1]PETSC ERROR: #2 MatAXPY() line 72 in
>> /home/edaoktay/petsc-3.13.2/src/mat/utils/axpy.c
>> Configure options --with-cc=gcc --with-cxx=g++ --download-mpich
>> [3]PETSC ERROR: #2 MatAXPY() line 72 in
>> #2 MatAXPY() line 72 in /home/edaoktay/petsc-3.13.2/src/mat/utils/axpy.c
>> Elapsed time: 2.5e-01
>> [2]PETSC ERROR: Arguments must have same communicators
>> [2]PETSC ERROR: Different communicators in the two objects: Argument #
>> 1 and 2 flag 3
>> [2]PETSC ERROR: See
>> shooting.
>> [2]PETSC ERROR:
>> 19:44:41 2020
>> [2]PETSC ERROR: #1 MatCopy() line 4044 in
>> [2]PETSC ERROR: Nonconforming object sizes
>> [2]PETSC ERROR: Non conforming matrix add: global sizes 3 x 72, 3 x 72
>> [2]PETSC ERROR: See
>> shooting.
>> [2]PETSC ERROR:
>> 19:44:41 2020
>> [2]PETSC ERROR: #2 MatAXPY() line 72 in
>> What can be the reason?
>> Mark Adams <mfadams at lbl.gov>, 19 Haz 2020 Cum, 18:41 tarihinde şunu yazdı:
>> > I don't know what is going on here. There was an update to this function about a year ago, so that might fix your problem.
>> > We would need you to test with a current version.
>> > Mark
>> > On Fri, Jun 19, 2020 at 11:23 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> >> Hi all,
>> >> I am trying to find off block diagonal entries of a matrix and I am
>> >> trying to use MatFindOffBlockDiagonalEntries. However, although my
>> >> matrix is not NULL, I am getting an error message as follows:
>> >> [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
>> >> [2]PETSC ERROR: See
>> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> >> shooting.
>> >> [2]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
>> >> [3]PETSC ERROR: See
>> >> shooting.
>> >> [1]PETSC ERROR: See
>> >> shooting.
>> >> [1]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
>> >> [1]PETSC ERROR:
>> >> 18:19:11 2020
>> >> [1]PETSC ERROR: Configure options --download-mpich --download-openblas
>> >> --download-slepc --download-metis --download-parmetis --download-chaco
>> >> --with-X=1
>> >> [1]PETSC ERROR: #1 ISGetSize() line 510 in
>> >> /home/edaoktay/petsc-3.11.1/src/vec/is/is/interface/index.c
>> >> [1]PETSC ERROR:
>> >> 18:19:11 2020
>> >> [2]PETSC ERROR: Configure options --download-mpich --download-openblas
>> >> --with-X=1
>> >> [2]PETSC ERROR: #1 ISGetSize() line 510 in
>> >> [2]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 211 in
>> >> /home/edaoktay/petsc-3.11.1/src/mat/impls/aij/mpi/mpiaij.c
>> >> [1]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 10502 in
>> >> /home/edaoktay/petsc-3.11.1/src/mat/interface/matrix.c
>> >> [3]PETSC ERROR:
>> >> 18:19:11 2020
>> >> [3]PETSC ERROR: Configure options --download-mpich --download-openblas
>> >> --with-X=1
>> >> [3]PETSC ERROR: #1 ISGetSize() line 510 in
>> >> [3]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 211 in
>> >> [3]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 10502 in
>> >> And the program is still running.
>> >> The part of my program is :
>> >>   Mat Ais;
>> >>   IS offd;
>> >> Since there isn't any examples for this function, I couldn't
>> >> understand what should I do. Since it says in the error that it is
>> >> about parameter 1, the matrix, I don't know how to solve the problem.
>> >> My matrix PL is parallel sparse. I know there shouldn't be any problem
>> >> in PL since I can view PL by using MatView.
>> >> Thanks!
>> >> Eda
