[petsc-users] PETSc initialization error
Junchao Zhang junchao.zhang at gmail.com
Sat Jun 20 18:23:36 CDT 2020
On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev> wrote:
>    Junchao,
>      This is a good bug fix. It solves the problem when PETSc initialize
> is called many times.
>      There is another fix you can do to limit PETSc mpiuni running out of
> attributes inside a single PETSc run:
> int MPI_Comm_create_keyval(MPI_Copy_function *copy_fn,MPI_Delete_function
> *delete_fn,int *keyval,void *extra_state)
>  if (num_attr >= MAX_ATTR){
>    for (i=0; i<num_attr; i++) {
>      if (!attr_keyval[i].extra_state) {
attr_keyval[i].extra_state is provided by user (could be NULL). We can not
rely on it.
>         /* reuse this slot */
>         attr_keyval[i].extra_state = extra_state;
>        attr_keyval[i.]del         = delete_fn;
>        *keyval = i;
>         return MPI_SUCCESS;
>   return MPIUni_Abort(MPI_COMM_WORLD,1);
>   attr_keyval[num_attr].extra_state = extra_state;
>   attr_keyval[num_attr].del         = delete_fn;
>   *keyval                           = num_attr++;
>   return MPI_SUCCESS;
>   This will work if the user creates tons of attributes but is constantly
> deleting some as they new ones. So long as the number outstanding at one
> time is < MAX_ATTR)
> Barry
> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> I don't understand what your session means. Let's try this patch
> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
> index d559a513..c058265d 100644
> --- a/src/sys/mpiuni/mpi.c
> +++ b/src/sys/mpiuni/mpi.c
> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>    MPI_Comm_free(&comm);
>    comm = MPI_COMM_SELF;
> +  num_attr = 1; /* reset the counter */
>    MPI_was_finalized = 1;
>    return MPI_SUCCESS;
> --Junchao Zhang
> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Typo: I mean “Assuming initializer is only needed once for entire session”
>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Assuming finalizer is only needed once for entire session(?), I can put
>>> initializer into the static block to call it once but where do I call
>>> finalizer?
>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> The counter num_attr should be recycled. But first try to call PETSc
>>>> initialize/Finalize only once to see it fixes the error.
>>>> --Junchao Zhang
>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> To clarify, I call PETSc initialize and PETSc finalize everytime I
>>>>> call SLEPc:
>>>>>   PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>   SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>   //calling slepc
>>>>>   SlepcFinalize();
>>>>>    PetscFinalize();
>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>> wrote:
>>>>>> Dear PETSc team,
>>>>>>    When I called SLEPc multiple time, I eventually got following
>>>>>> error:
>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>> ../../../petsc/src/sys/objects/pinit.c
>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>> ../../../slepc/src/sys/slepcinit.c
>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>> PETSC ERROR: Logging has not been enabled.
>>>>>> You might have forgotten to call PetscInitialize().
>>>>>>   I debugged: it is because of following in petsc/src/sys/mpiuni/mpi.c
>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>>>> num_attr is declared static and keeps increasing every
>>>>>> time MPI_Comm_create_keyval is called.
>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>> Is this a bug or I didn't use it correctly?
>>>>>> Thanks,
>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/4b0dbf5b/attachment-0001.html>
