[petsc-users] PETSc initialization error
Sam Guo sam.guo at cd-adapco.com
Sat Jun 20 13:49:27 CDT 2020
Thanks a lot.
On Sat, Jun 20, 2020 at 11:40 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Sam,
>    There are more problems. I am working on a fix.  Please wait an hour.
>  Thanks.
> --Junchao Zhang
> On Sat, Jun 20, 2020 at 1:12 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Junchao,
>>    I debugged: MPI_Finalize is not called for serial.
>> Barry,
>>    I tried your patch and it seems better but eventually got following
>> error:
>> [0]PETSC ERROR: #1 PetscCommDuplicate() line 160 in
>> ../../../petsc/src/sys/objects/tagm.c
>> [0]PETSC ERROR: #2 PetscHeaderCreate_Private() line 64 in
>> ../../../petsc/src/sys/objects/inherit.c
>> [0]PETSC ERROR: #3 MatCreate() line 91 in
>> ../../../petsc/src/mat/utils/gcreate.c
>> [0]PETSC ERROR: #4 MatCreateShell() line 787 in
>> ../../../petsc/src/mat/impls/shell/shell.c
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>> [0]PETSC ERROR: Null Object: Parameter # 1
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.11.3, Jun, 26, 2019
>> [0]PETSC ERROR: #6 MatShellSetOperation() line 1052 in
>> On Sat, Jun 20, 2020 at 10:24 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>    Junchao,
>>>      This is a good bug fix. It solves the problem when PETSc initialize
>>> is called many times.
>>>      There is another fix you can do to limit PETSc mpiuni running out
>>> of attributes inside a single PETSc run:
>>> int MPI_Comm_create_keyval(MPI_Copy_function
>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>  if (num_attr >= MAX_ATTR){
>>>    for (i=0; i<num_attr; i++) {
>>>      if (!attr_keyval[i].extra_state) {
>>>         /* reuse this slot */
>>>         attr_keyval[i].extra_state = extra_state;
>>>        attr_keyval[i.]del         = delete_fn;
>>>        *keyval = i;
>>>         return MPI_SUCCESS;
>>>   return MPIUni_Abort(MPI_COMM_WORLD,1);
>>>   attr_keyval[num_attr].extra_state = extra_state;
>>>   attr_keyval[num_attr].del         = delete_fn;
>>>   *keyval                           = num_attr++;
>>>   return MPI_SUCCESS;
>>>   This will work if the user creates tons of attributes but is
>>> constantly deleting some as they new ones. So long as the number
>>> outstanding at one time is < MAX_ATTR)
>>> Barry
>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>> I don't understand what your session means. Let's try this patch
>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>> index d559a513..c058265d 100644
>>> --- a/src/sys/mpiuni/mpi.c
>>> +++ b/src/sys/mpiuni/mpi.c
>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>    MPI_Comm_free(&comm);
>>>    comm = MPI_COMM_SELF;
>>> +  num_attr = 1; /* reset the counter */
>>>    MPI_was_finalized = 1;
>>>    return MPI_SUCCESS;
>>> --Junchao Zhang
>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Typo: I mean “Assuming initializer is only needed once for entire
>>>> session”
>>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Assuming finalizer is only needed once for entire session(?), I can
>>>>> put initializer into the static block to call it once but where do I call
>>>>> finalizer?
>>>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>>>>> wrote:
>>>>>> The counter num_attr should be recycled. But first try to call PETSc
>>>>>> initialize/Finalize only once to see it fixes the error.
>>>>>> --Junchao Zhang
>>>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>> wrote:
>>>>>>> To clarify, I call PETSc initialize and PETSc finalize everytime I
>>>>>>> call SLEPc:
>>>>>>>   PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>>>   SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>>>   //calling slepc
>>>>>>>   SlepcFinalize();
>>>>>>>    PetscFinalize();
>>>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>> wrote:
>>>>>>>> Dear PETSc team,
>>>>>>>>    When I called SLEPc multiple time, I eventually got following
>>>>>>>> error:
>>>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>>>> ../../../petsc/src/sys/objects/pinit.c
>>>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>>>> ../../../slepc/src/sys/slepcinit.c
>>>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>>>> PETSC ERROR: Logging has not been enabled.
>>>>>>>> You might have forgotten to call PetscInitialize().
>>>>>>>>   I debugged: it is because of following in
>>>>>>>> petsc/src/sys/mpiuni/mpi.c
>>>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>> num_attr is declared static and keeps increasing every
>>>>>>>> time MPI_Comm_create_keyval is called.
>>>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>>>> Is this a bug or I didn't use it correctly?
>>>>>>>> Thanks,
>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/95a6302c/attachment-0001.html>
