[petsc-users] SNES Line search: fixing the non zero solution values of dirichlet nodes during line search
Stefano Zampini stefano.zampini at gmail.com
Sat Jun 20 06:40:41 CDT 2020
I think you want to use SNESLineSearchSetPostCheck, see
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESLineSearchSetPostCheck.html
Il giorno sab 20 giu 2020 alle ore 01:16 Ashish Patel <
ashish.patel at onscale.com> ha scritto:
> Dear PETSc users,
> We use PETSc as part of a finite element method program and we are trying
> to properly implement Dirichlet boundary conditions for non-linear,
> transient problems. We find that when we use a line search method it also
> changes the non-zero solution value of Dirichlet nodes as it steps through
> the line search iteration. I was wondering if  there is a way to freeze
> some index sets of a vector from changing during the line search operation?
> We are using the TS framework to setup the problem and use
> 'MatZeroRowsColumns' to set the diagonal of the jacobian to 1 for the
> dirichlet nodes and set the RHS as increment of
> (Dirichlet_value-solution_value). This works when the line search method is
> turned off by using '-snes_linesearch_type basic' however using the default
> 'bt' linesearch, the TS diverges with error shown below. In a separate
> implementation if we overwrote the dirichlet nodes of the solution vector
> in TS residual function with the Dirichlet values  then the 'bt' line
> search method converged to the right solution. However we would like to
> avoid modifying the internal PETSc vector in our implementation.
> 0 TS dt 1. time 0.
>     0 SNES Function norm 2.378549386020e+03
>         Line search: gnorm after quadratic fit 4.369235425165e+03
>         Line search: Cubic step no good, shrinking lambda, current gnorm
> 2.385369069060e+03 lambda=1.0000000000000002e-02
>         Line search: Cubically determined step, current gnorm
> 2.373925008934e+03 lambda=3.8846250444606093e-03
>     1 SNES Function norm 2.373925008934e+03
>         Line search: gnorm after quadratic fit 5.006914179995e+03
> 2.420957096780e+03 lambda=1.0000000000000002e-02
> 2.376034946750e+03 lambda=1.6129422079664700e-03
> 2.374313344729e+03 lambda=4.8465026740690043e-04
> 2.373999473242e+03 lambda=1.5857251532828948e-04
> 2.373921668024e+03 lambda=5.8116507162753387e-05
>     2 SNES Function norm 2.373921668024e+03
>         Line search: gnorm after quadratic fit 4.771035112853e+03
> 2.410650718394e+03 lambda=1.0000000000000002e-02
> 2.375104094198e+03 lambda=1.8983783738011522e-03
> 2.374049151562e+03 lambda=7.0688528086485479e-04
> 2.373935090907e+03 lambda=2.9132722794896019e-04
> 2.373921032081e+03 lambda=1.2527602265373028e-04
>     3 SNES Function norm 2.373921032081e+03
>         Line search: gnorm after quadratic fit 5.117914832660e+03
> 2.422635362094e+03 lambda=1.0000000000000002e-02
> 2.375923870970e+03 lambda=1.5769887508300913e-03
> 2.374287081592e+03 lambda=4.8018017100729705e-04
> 2.373999131160e+03 lambda=1.5908966655977892e-04
> 2.373930608274e+03 lambda=5.7603977147935371e-05
> 2.373922022038e+03 lambda=2.3884787050507805e-05
> 2.373921396636e+03 lambda=1.0282405393471519e-05
> 2.373921173719e+03 lambda=4.3868704034012554e-06
> 2.373921091304e+03 lambda=1.8774991151727107e-06
> 2.373921057168e+03 lambda=8.0331628193813397e-07
> 2.373921042769e+03 lambda=3.4377811174560817e-07
> 2.373921036645e+03 lambda=1.4712421886880395e-07
> 2.373921034032e+03 lambda=6.2965363212312132e-08
> 2.373921032916e+03 lambda=2.6947718250469261e-08
> 2.373921032438e+03 lambda=1.1533043989179318e-08
> 2.373921032233e+03 lambda=4.9359018284334258e-09
> 2.373921032146e+03 lambda=2.1124641857409436e-09
> 2.373921032109e+03 lambda=9.0409137304143975e-10
> 2.373921032093e+03 lambda=3.8693264359674819e-10
> 2.373921032086e+03 lambda=1.6559911204766632e-10
> 2.373921032083e+03 lambda=7.0873187020534353e-11
> 2.373921032081e+03 lambda=3.0332192901757729e-11
> 2.373921032081e+03 lambda=1.2981600435512875e-11
> 2.373921032081e+03 lambda=5.5559212521628090e-12
> 2.373921032081e+03 lambda=2.3777380405336958e-12
> 2.373921032081e+03 lambda=1.0176091649134191e-12
> 2.373921032081e+03 lambda=4.3555419789721080e-13
>         Line search: unable to find good step length! After 27 tries
>         Line search: fnorm=2.3739210320805191e+03,
> gnorm=2.3739210320805323e+03, ynorm=8.5698020038772756e+03,
> minlambda=9.9999999999999998e-13, lambda=4.3555419789721080e-13, initial
> slope=-5.6355010665542409e+06
> SNES Object: 1 MPI processes
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=4
>   total number of function evaluations=48
>   norm schedule ALWAYS
>   SNESLineSearch Object: 1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object: 1 MPI processes
>     type: preonly
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>     left preconditioning
>     using NONE norm type for convergence test
>   PC Object: 1 MPI processes
>     type: cholesky
>       out-of-place factorization
>       tolerance for zero pivot 2.22045e-14
>       matrix ordering: natural
>       factor fill ratio given 0., needed 0.
>         Factored matrix follows:
>           Mat Object: 1 MPI processes
>             type: mumps
>             rows=38154, cols=38154
>             package used to perform factorization: mumps
>             total: nonzeros=7080060, allocated nonzeros=7080060
>             total number of mallocs used during MatSetValues calls=0
>               MUMPS run parameters:
>                 SYM (matrix type):                   2
>                 PAR (host participation):            1
>                 ICNTL(1) (output for error):         6
>                 ICNTL(2) (output of diagnostic msg): 0
>                 ICNTL(3) (output for global info):   0
>                 ICNTL(4) (level of printing):        0
>                 ICNTL(5) (input mat struct):         0
>                 ICNTL(6) (matrix prescaling):        7
>                 ICNTL(7) (sequential matrix ordering):7
>                 ICNTL(8) (scaling strategy):        77
>                 ICNTL(10) (max num of refinements):  0
>                 ICNTL(11) (error analysis):          0
>                 ICNTL(12) (efficiency control):                         0
>                 ICNTL(13) (efficiency control):                         0
>                 ICNTL(14) (percentage of estimated workspace increase): 20
>                 ICNTL(18) (input mat struct):                           0
>                 ICNTL(19) (Schur complement info):                      0
>                 ICNTL(20) (rhs sparse pattern):                         0
>                 ICNTL(21) (solution struct):                            0
>                 ICNTL(22) (in-core/out-of-core facility):               0
>                 ICNTL(23) (max size of memory can be allocated locally):0
>                 ICNTL(24) (detection of null pivot rows):               0
>                 ICNTL(25) (computation of a null space basis):          0
>                 ICNTL(26) (Schur options for rhs or solution):          0
>                 ICNTL(27) (experimental parameter):
> -32
>                 ICNTL(28) (use parallel or sequential ordering):        1
>                 ICNTL(29) (parallel ordering):                          0
>                 ICNTL(30) (user-specified set of entries in inv(A)):    0
>                 ICNTL(31) (factors is discarded in the solve phase):    0
>                 ICNTL(33) (compute determinant):                        0
>                 ICNTL(35) (activate BLR based factorization):           0
>                 ICNTL(36) (choice of BLR factorization variant):        0
>                 ICNTL(38) (estimated compression rate of LU factors):
> 333
>                 CNTL(1) (relative pivoting threshold):      0.01
>                 CNTL(2) (stopping criterion of refinement): 1.49012e-08
>                 CNTL(3) (absolute pivoting threshold):      0.
>                 CNTL(4) (value of static pivoting):         -1.
>                 CNTL(5) (fixation for null pivots):         0.
>                 CNTL(7) (dropping parameter for BLR):       0.
>                 RINFO(1) (local estimated flops for the elimination after
> analysis):
>                   [0] 2.73979e+09
>                 RINFO(2) (local estimated flops for the assembly after
> factorization):
>                   [0]  1.08826e+07
>                 RINFO(3) (local estimated flops for the elimination after
> factorization):
>                   [0]  2.73979e+09
>                 INFO(15) (estimated size of (in MB) MUMPS internal data
> for running numerical factorization):
>                 [0] 94
>                 INFO(16) (size of (in MB) MUMPS internal data used during
>                   [0] 94
>                 INFO(23) (num of pivots eliminated on this processor after
> factorization):
>                   [0] 38154
>                 RINFOG(1) (global estimated flops for the elimination
> after analysis): 2.73979e+09
>                 RINFOG(2) (global estimated flops for the assembly after
> factorization): 1.08826e+07
>                 RINFOG(3) (global estimated flops for the elimination
> after factorization): 2.73979e+09
>                 (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
> (0.,0.)*(2^0)
>                 INFOG(3) (estimated real workspace for factors on all
> processors after analysis): 8377336
>                 INFOG(4) (estimated integer workspace for factors on all
> processors after analysis): 447902
>                 INFOG(5) (estimated maximum front size in the complete
> tree): 990
>                 INFOG(6) (number of nodes in the complete tree): 2730
>                 INFOG(7) (ordering option effectively use after analysis):
> 5
>                 INFOG(8) (structural symmetry in percent of the permuted
> matrix after analysis): 100
>                 INFOG(9) (total real/complex workspace to store the matrix
> factors after factorization): 8377336
>                 INFOG(10) (total integer space store the matrix factors
> after factorization): 447902
>                 INFOG(11) (order of largest frontal matrix after
> factorization): 990
>                 INFOG(12) (number of off-diagonal pivots): 10
>                 INFOG(13) (number of delayed pivots after factorization):
> 0
>                 INFOG(14) (number of memory compress after factorization):
> 0
>                 INFOG(15) (number of steps of iterative refinement after
> solution): 0
>                 INFOG(16) (estimated size (in MB) of all MUMPS internal
> data for factorization after analysis: value on the most memory consuming
> processor): 94
>                 INFOG(17) (estimated size of all MUMPS internal data for
> factorization after analysis: sum over all processors): 94
>                 INFOG(18) (size of all MUMPS internal data allocated
> during factorization: value on the most memory consuming processor): 94
>                 INFOG(19) (size of all MUMPS internal data allocated
> during factorization: sum over all processors): 94
>                 INFOG(20) (estimated number of entries in the factors):
> 7080060
>                 INFOG(21) (size in MB of memory effectively used during
> factorization - value on the most memory consuming processor): 80
>                 INFOG(22) (size in MB of memory effectively used during
> factorization - sum over all processors): 80
>                 INFOG(23) (after analysis: value of ICNTL(6) effectively
> used): 0
>                 INFOG(24) (after analysis: value of ICNTL(12) effectively
> used): 1
>                 INFOG(25) (after factorization: number of pivots modified
> by static pivoting): 0
>                 INFOG(28) (after factorization: number of null pivots
> encountered): 0
>                 INFOG(29) (after factorization: effective number of
> entries in the factors (sum over all processors)): 7080060
>                 INFOG(30, 31) (after solution: size in Mbytes of memory
> used during solution phase): 92, 92
>                 INFOG(32) (after analysis: type of analysis done): 1
>                 INFOG(33) (value used for ICNTL(8)): 7
>                 INFOG(34) (exponent of the determinant if determinant is
> requested): 0
>                 INFOG(35) (after factorization: number of entries taking
> into account BLR factor compression - sum over all processors): 7080060
>                 INFOG(36) (after analysis: estimated size of all MUMPS
> internal data for running BLR in-core - value on the most memory consuming
> processor): 0
>                 INFOG(37) (after analysis: estimated size of all MUMPS
> internal data for running BLR in-core - sum over all processors): 0
>                 INFOG(38) (after analysis: estimated size of all MUMPS
> internal data for running BLR out-of-core - value on the most memory
> consuming processor): 0
>                 INFOG(39) (after analysis: estimated size of all MUMPS
> internal data for running BLR out-of-core - sum over all processors): 0
>     linear system matrix = precond matrix:
>       type: seqaij
>       total: nonzeros=973446, allocated nonzeros=973446
>         not using I-node routines
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR:
> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
> increase -ts_max_snes_failures or make negative to attempt recovery
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> Thanks,
> Ashish
> Scientific Computing Division
> OnScale
> CA, USA
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/1d4fae12/attachment-0001.html>
