[petsc-users] Implementing periodicity using DMPlex
Fri Jun 19 16:11:09 CDT 2020
On Thu, Jun 18, 2020 at 1:20 PM Shashwat Tiwari <shaswat121994 at gmail.com>
wrote:
> Thank you for the help. I followed your suggestion and removed the
> "DMPlexConstructGhostCells" function and now I am using a gmsh generated
> mesh with periodicity in both directions, and distributing the mesh with 1
> level of overlap. I can see that the periodic faces now have two
> neighbouring cells on the opposite side of the domain which I can use to
> get the periodic cell values using "DMGlobalToLocal" without the need to
> construct ghost cells. There are two main issues that I am facing now,
> regarding geometric information needed for implementing periodic bc.
> One, I may need the centroid of periodic counterpart of a cell which is
> possible to get from a "ghost" cell created on the periodic face, and
> containing the solution data from periodic counterpart. But now, I would
> need to shift the coordinates of the neighbouring cell accordingly. If you
> see the sample output given below along with the screenshot of the sample
> 2D mesh that I have used (please find attached), while reconstructing the
> left and right solution values on face 32 for a second order scheme, I need
> the centroid of a ghost cell on left side of the face which is at (x, y) =
> (-1.25, 8.75). I wanted to know if there is some way to get these shifted
> "ghost" coordinates directly from the geometric information obtained using
> "PetscFV" class. Kindly let me know if you have some suggestions regarding
> this.
I do not completely understand the question. However, I think you want
something like
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMLocalizeCoordinate.html
There are many variants of this functionality.
> Sample Output:
> face: 32, centroid = 0.000000, 8.750000, normal = 2.500000, -0.000000
> support[0] = 0, cent = 1.250000, 8.750000, area = 6.250000
> support[1] = 3, cent = 8.750000, 8.750000, area = 6.250000
> face: 33, centroid = 1.250000, 7.500000, normal = -0.000000, -2.500000
> support[1] = 4, cent = 1.250000, 6.250000, area = 6.250000
> Second, the face normals of the periodic faces obtained using the face
> geometry data from "DMPlexGetDataFVM" function seem to be in the wrong
> direction i.e., from the right cell "support[1]" to the left cell
> "support[0]", while the other faces have the opposite direction. For face:
> 32, left cell is 0 and the right cell is 3, but, the normal points the
> opposite way (cell 3 would be on the left side of cell 0 on periodic
> boundary), while, for face: 33 which is an interior face, the normal
> direction is from left to right cell.
This should be easy to check. The strange thing is that if this were
broken, you would expect other examples to fail.
> Also, I am getting incorrect normal values for some of the faces
> (including some interior faces). Here is a sample output of the same:
> face: 59, centroid = 3.750000, 2.500000, normal = 0.000000, -7.500000
> support[0] = 11, cent = 8.750000, 3.750000, area = 6.250000
> support[1] = 15, cent = 8.750000, 1.250000, area = 6.250000
> this face has the correct direction (from 11 to 15), but the value is
> wrong (all the faces are 2.5 units). This problem does not occur when I
> ignore periodicity by setting -dm_plex_gmsh_periodic to 0.
> These issues occur regardless of the number of processes. I am attaching
> the test code that I am using along with the gmsh file for your reference.
> Please suggest to me, what might be the issue here.
I will take a look.
    Matt
> Regards,
> Shashwat
> On Mon, Jun 15, 2020 at 2:54 PM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> It is enough if you use DMPlexDistribute with 1 level of overlap, set the
>> local section for your dofs,  and call DMGlobalToLocal . The local vector
>> will contain data for what you call “ghost” cells. I call them “not-owned’
>> cells.
>> On Jun 15, 2020, at 12:09 PM, Shashwat Tiwari <shaswat121994 at gmail.com>
>> wrote:
>> The way I'm trying to implement periodic bc is, when I loop over the
>> boundary faces, say, on the left boundary of the domain to compute flux and
>> residual, I need solution values from the two cells neighbouring the face,
>> i.e. the left cell and the right cell (the face normal pointing from the
>> left cell to the right cell and the right cell being a boundary ghost cell
>> for boundary faces). For the boundary to be periodic, I need the value that
>> I get from the right cell (boundary ghost cell) to be the solution value at
>> its periodic counterpart, i.e. the solution value at left cell of the face
>> on right boundary of the domain in this case. My question is how do I
>> update the value at a boundary ghost cell with the value at the real cell
>> which is its periodic counterpart from the other side of the domain. Is
>> there some kind of mapping of the boundary ghost cells to their
>> corresponding real cells which I can use to update the solution values at
>> ghost cells?
>> Regards,
>> Shashwat
>> On Sun, Jun 14, 2020 at 5:11 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Jun 12, 2020 at 3:19 PM Shashwat Tiwari <shaswat121994 at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am writing a first order 2D solver for unstructured grids with
>>>> periodic boundaries using DMPlex. After generating the mesh, I use
>>>> "DMSetPeriodicity" function to set periodicity in both directions. After
>>>> which I partition the mesh (DMPlexDistribute), construct ghost cells
>>>> (DMPlexConstructGhostCells),
>>> These ghost cells are for FVM boundary conditions. If you want cells to
>>> be shared across parallel partitions, then you want to give overlap=1
>>> to DMPlexDIstribute(). Is that what you want?
>>>   Thanks,
>>>      Matt
>>>> create a section, and set some initial values in the global vector.
>>>> Then I use "VecGhostUpdateBegin" to start updating the boundary ghost cell
>>>> values, but, I get the following error in case I use multiple processors:
>>>> [0]PETSC ERROR: Invalid argument
>>>> [0]PETSC ERROR: Vector is not ghosted
>>>> [0]PETSC ERROR: See
>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>> shooting.
>>>> if I run with a single process, there is no error but the values remain
>>>> empty (zero) and are not updated. Kindly let me know, if I am missing some
>>>> crucial step before I can update the ghost values in order to implement the
>>>> periodic bc, or if there is any other approach to achieve it. I am
>>>> attaching a small code to demonstrate the issue for your reference.
>>>> Regards,
>>>> Shashwat
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200619/2aa2fc30/attachment-0001.html>
