[petsc-users] MatFindOffBlockDiagonalEntries error
Mark Adams mfadams at lbl.gov
Fri Jun 19 10:37:59 CDT 2020
I don't know what is going on here. There was an update to this function
about a year ago, so that might fix your problem.
We would need you to test with a current version.
On Fri, Jun 19, 2020 at 11:23 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Hi all,
> I am trying to find off block diagonal entries of a matrix and I am
> trying to use MatFindOffBlockDiagonalEntries. However, although my
> matrix is not NULL, I am getting an error message as follows:
> 1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Null argument, when expecting valid pointer
> [2]PETSC ERROR: Null Object: Parameter # 1
> [2]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [2]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
> [2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Null argument, when expecting valid pointer
> [3]PETSC ERROR: Null Object: Parameter # 1
> [3]PETSC ERROR: See
> shooting.
> [1]PETSC ERROR: Null Object: Parameter # 1
> [1]PETSC ERROR: See
> shooting.
> [1]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
> [1]PETSC ERROR:
> ./approx_cut_deneme_clustering_son_final_edgecut_without_parmetis on a
> arch-linux2-c-debug named b342.wls.metu.edu.tr by edaoktay Fri Jun 19
> 18:19:11 2020
> [1]PETSC ERROR: Configure options --download-mpich --download-openblas
> --download-slepc --download-metis --download-parmetis --download-chaco
> --with-X=1
> [1]PETSC ERROR: #1 ISGetSize() line 510 in
> /home/edaoktay/petsc-3.11.1/src/vec/is/is/interface/index.c
> [1]PETSC ERROR:
> 18:19:11 2020
> [2]PETSC ERROR: Configure options --download-mpich --download-openblas
> --with-X=1
> [2]PETSC ERROR: #1 ISGetSize() line 510 in
> [2]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 211 in
> /home/edaoktay/petsc-3.11.1/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 10502 in
> /home/edaoktay/petsc-3.11.1/src/mat/interface/matrix.c
> [3]PETSC ERROR:
> 18:19:11 2020
> [3]PETSC ERROR: Configure options --download-mpich --download-openblas
> --with-X=1
> [3]PETSC ERROR: #1 ISGetSize() line 510 in
> [3]PETSC ERROR: #2 MatFindOffBlockDiagonalEntries_MPIAIJ() line 211 in
> [3]PETSC ERROR: #3 MatFindOffBlockDiagonalEntries() line 10502 in
> And the program is still running.
> The part of my program is :
>   Mat Ais;
>   MatCreateSubMatrix(A,idUi,idUi,MAT_INITIAL_MATRIX,&Ais);
>   ISSetPermutation(idUi);
>   MatPermute(Ais,idUi,idUi,&PL);
>   IS offd;
>   MatFindOffBlockDiagonalEntries(PL,&offd);
> Since there isn't any examples for this function, I couldn't
> understand what should I do. Since it says in the error that it is
> about parameter 1, the matrix, I don't know how to solve the problem.
> My matrix PL is parallel sparse. I know there shouldn't be any problem
> in PL since I can view PL by using MatView.
> Thanks!
> Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200619/1602979c/attachment.html>
