[petsc-users] Problem with GPU configure at NERSC
Barry Smith bsmith at petsc.dev
Thu Jun 18 18:30:45 CDT 2020
  Mark,
  When it calls the C compiler it prints
Preprocess stderr before filtering:No supported cpu target is set, CRAY_CPU_TARGET=x86-64 will be used.
Load a valid targeting module or set CRAY_CPU_TARGET
the C compiler is outputting its message on stderr and that is triggering the configure failure. Since PETSc does not know this is a harmless error message.
I will update the filter code to ignore this "error message" but you should just set that environmental variable before you run configure or use the modules in a different way.
Barry
> On Jun 18, 2020, at 3:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I am trying to configure the GPU nodes at NERSC and the instructions are pretty slim.
> Any idea what is wrong here?
> Thanks,
> Mark
> <configure.log>
