[petsc-users] Make stream
Fande Kong
fdkong.jd at gmail.com
Wed Jun 17 00:21:09 CDT 2020
Thanks, Jed,
It is fascinating. I will try to check if I can do anything to have this
kind of improvement as well.
Fande,
On Fri, Jun 12, 2020 at 7:43 PM Jed Brown <jed at jedbrown.org> wrote:
> Jed Brown <jed at jedbrown.org> writes:
> > Fande Kong <fdkong.jd at gmail.com> writes:
> >>> There's a lot more to AMG setup than memory bandwidth (architecture
> >>> matters a lot, even between different generation CPUs).
> >> Could you elaborate a bit more on this? From my understanding, one big
> part
> >> of AMG SetUp is RAP that should be pretty much bandwidth.
> > The RAP isn't "pretty much bandwidth". See below for some
> > Skylake/POWER9/EPYC results and analysis (copied from an off-list
> > thread). I'll leave in some other bandwidth comments that may or may
> > not be relevant to you. The short story is that Skylake and EPYC are
> > both much better than POWER9 at MatPtAP despite POWER9 having similar
> > bandwidth as EPYC and thus being significantly faster than Skylake for
> > MatMult/smoothing.
> >> I'm attaching a log from my machine (Noether), which is 2-socket EPYC
> >> 7452 (32 cores each). Each socket has 8xDDR4-3200 and 128 MB of L3
> >> cache. This is the same node architecture as the new BER/E3SM machine
> >> being installed at Argonne (though that one will probably have
> >> higher-clocked and/or more cores per socket). Note that these CPUs are
> >> about $2k each while Skylake 8180 are about $10k.
> >> Some excerpts/comments below.
> > In addition to the notes below, I'd like to call out how important
> > streaming stores are on EPYC. With vanilla code or _mm256_store_pd, we
> > get the following performance
> > $ mpiexec -n 64 --bind-to core --map-by core:1
> src/benchmarks/streams/MPIVersion
> > Copy 162609.2392 Scale 159119.8259 Add 174687.6250 Triad
> 175840.1587
> > but replacing _mm256_store_pd with _mm256_stream_pd gives this
> > Copy 259951.9936 Scale 259381.0589 Add 250216.3389 Triad
> 249292.9701
> I turned on NPS4 (a BIOS setting that creates a NUMA node for each pair
> of memory channels) and get a modest performance boost.
> Copy 289645.3776 Scale 289186.2783 Add 273220.0133 Triad 272911.2263
> On this architecture, best performance comes from one process per 4-core
> CCX (shared L3).
> $ mpiexec -n 16 --bind-to core --map-by core:4
> Copy 300704.8859 Scale 304556.3380 Add 295970.1132 Triad 298891.3821
> > This is just preposterously huge, but very repeatable using gcc and
> > clang, and inspecting the assembly. This suggests that it would be
> > useful for vector kernels to have streaming and non-streaming variants.
> > That is, if I drop the vector length by 20 (so the working set is 2.3
> > MB/core instead of 46 MB in the default version), then we get 2.4 TB/s
> > Triad with _mm256_store_pd:
> > Copy 2159915.7058 Scale 2212671.7087 Add 2414758.2757 Triad
> 2402671.1178
> > and a thoroughly embarrassing 353 GB/s with _mm256_stream_pd:
> > Copy 235934.6653 Scale 237446.8507 Add 352805.7288 Triad
> 352992.9692
> > I don't know a good way to automatically determine whether to expect the
> > memory to be in cache, but we could make it a global (or per-object)
> > run-time selection.
> >>> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >>>> Thanks. The PowerPC is pretty crappy compared to Skylake.
> >>> Compare the MGSmooth times. The POWER9 is faster than the Skylake
> >>> because it has more memory bandwidth.
> >>> $ rg 'MGInterp Level 4|MGSmooth Level 4' ex56*
> >>> ex56-JLSE-skylake-56ranks-converged.txt
> >>> 254:MGSmooth Level 4 68 1.0 1.8808e+00 1.2 7.93e+08 1.3 3.6e+04
> 1.9e+04 3.4e+01 8 29 10 16 3 62 60 18 54 25 22391
> >>> 256:MGInterp Level 4 68 1.0 4.0043e-01 1.8 1.45e+08 1.3 2.2e+04
> 2.5e+03 0.0e+00 1 5 6 1 0 9 11 11 4 0 19109
> >>> ex56-summit-cpu-36ranks-converged.txt
> >>> 265:MGSmooth Level 4 68 1.0 1.1531e+00 1.1 1.22e+09 1.2 2.3e+04
> 2.6e+04 3.4e+01 3 29 7 13 3 61 60 12 54 25 36519 0 0
> 0.00e+00 0 0.00e+00 0
> >>> 267:MGInterp Level 4 68 1.0 2.0749e-01 1.1 2.23e+08 1.2 1.4e+04
> 3.4e+03 0.0e+00 0 5 4 1 0 11 11 7 4 0 36925 0 0
> >>> ex56-summit-gpu-24ranks-converged.txt
> >>> 275:MGSmooth Level 4 68 1.0 1.4499e-01 1.2 1.85e+09 1.2 1.0e+04
> 5.3e+04 3.4e+01 0 29 7 13 3 26 60 12 55 25 299156 940881 115
> 2.46e+01 116 8.64e+01 100
> >>> 277:MGInterp Level 4 68 1.0 1.7674e-01 1.0 3.23e+08 1.2 6.1e+03
> 6.7e+03 0.0e+00 0 5 4 1 0 33 11 7 4 0 42715 621223 36
> 2.98e+01 136 3.95e+00 100
> >>> ex56-summit-gpu-36ranks-converged.txt
> >>> 275:MGSmooth Level 4 68 1.0 1.4877e-01 1.2 1.25e+09 1.2 2.3e+04
> 2.6e+04 3.4e+01 0 29 7 13 3 19 60 12 54 25 291548 719522 115
> 1.83e+01 116 5.80e+01 100
> >>> 277:MGInterp Level 4 68 1.0 2.4317e-01 1.0 2.20e+08 1.2 1.4e+04
> 3.4e+03 0.0e+00 0 5 4 1 0 33 11 7 4 0 31062 586044 36
> 1.99e+01 136 2.82e+00 100
> >> 258:MGSmooth Level 4 68 1.0 9.6950e-01 1.3 6.15e+08 1.3 4.0e+04
> 1.4e+04 2.0e+00 6 28 10 15 0 59 59 18 54 25 39423
> >> 260:MGInterp Level 4 68 1.0 2.5707e-01 1.5 1.23e+08 1.2 2.7e+04
> 1.9e+03 0.0e+00 1 5 7 1 0 13 12 12 5 0 29294
> >> Epyc is faster than Power9 is faster than Sklake.
> >>> The Skylake is a lot faster at PtAP. It'd be interesting to better
> >>> understand why. Perhaps it has to do with caching or aggressiveness of
> >>> out-of-order execution.
> >>> $ rg 'PtAP' ex56*
> >>> 164:MatPtAP 4 1.0 1.4214e+00 1.0 3.94e+08 1.5 1.1e+04
> 7.4e+04 4.4e+01 6 13 3 20 4 8 28 8 39 5 13754
> >>> 165:MatPtAPSymbolic 4 1.0 8.3981e-01 1.0 0.00e+00 0.0 6.5e+03
> 7.3e+04 2.8e+01 4 0 2 12 2 5 0 5 23 3 0
> >>> 166:MatPtAPNumeric 4 1.0 5.8402e-01 1.0 3.94e+08 1.5 4.5e+03
> 7.5e+04 1.6e+01 2 13 1 8 1 3 28 3 16 2 33474
> >>> 164:MatPtAP 4 1.0 3.9077e+00 1.0 5.89e+08 1.4 1.6e+04
> 7.4e+04 4.4e+01 9 13 5 26 4 11 28 12 46 5 4991 0 0
> >>> 165:MatPtAPSymbolic 4 1.0 1.9525e+00 1.0 0.00e+00 0.0 1.2e+04
> 7.3e+04 2.8e+01 5 0 4 19 3 5 0 9 34 3 0 0 0
> >>> 166:MatPtAPNumeric 4 1.0 1.9621e+00 1.0 5.89e+08 1.4 4.0e+03
> 7.5e+04 1.6e+01 5 13 1 7 1 5 28 3 12 2 9940 0 0
> >>> 167:MatPtAP 4 1.0 5.7210e+00 1.0 8.48e+08 1.3 7.5e+03
> 1.3e+05 4.4e+01 8 13 5 25 4 11 28 12 46 5 3415 0 16
> 3.36e+01 4 6.30e-02 0
> >>> 168:MatPtAPSymbolic 4 1.0 2.8717e+00 1.0 0.00e+00 0.0 5.5e+03
> 1.3e+05 2.8e+01 4 0 4 19 3 5 0 9 34 3 0 0 0
> >>> 169:MatPtAPNumeric 4 1.0 2.8537e+00 1.0 8.48e+08 1.3 2.0e+03
> 1.3e+05 1.6e+01 4 13 1 7 1 5 28 3 12 2 6846 0 16
> >>> 167:MatPtAP 4 1.0 4.0340e+00 1.0 5.89e+08 1.4 1.6e+04
> 7.4e+04 4.4e+01 8 13 5 26 4 11 28 12 46 5 4835 0 16
> 2.30e+01 4 5.18e-02 0
> >>> 168:MatPtAPSymbolic 4 1.0 2.0355e+00 1.0 0.00e+00 0.0 1.2e+04
> 7.3e+04 2.8e+01 4 0 4 19 3 5 0 9 34 3 0 0 0
> >>> 169:MatPtAPNumeric 4 1.0 2.0050e+00 1.0 5.89e+08 1.4 4.0e+03
> 7.5e+04 1.6e+01 4 13 1 7 1 5 28 3 12 2 9728 0 16
> >> 153:MatPtAPSymbolic 4 1.0 7.6053e-01 1.0 0.00e+00 0.0 7.6e+03
> 5.8e+04 2.8e+01 5 0 2 12 2 6 0 5 22 3 0
> >> 154:MatPtAPNumeric 4 1.0 6.5172e-01 1.0 3.21e+08 1.4 6.4e+03
> 4.8e+04 2.4e+01 4 14 2 8 2 5 27 4 16 2 28861
> >> Epyc similar to Skylake here.
> >>> I'd really like to compare an EPYC for these operations. I bet it's
> >>> pretty good. (More bandwidth than Skylake, bigger caches, but no
> >>> AVX512.)
> >>>> So the biggest consumer is MatPtAP I guess that should be done
> first.
> >>>> It would be good to have these results exclude the Jacobian and
> Function evaluation which really dominate the time and add clutter making
> it difficult to see the problems with the rest of SNESSolve.
> >>>> Did you notice:
> >>>> it is terrible! Well over half of the KSPSolve time is in this one
> relatively minor routine. All of the interps are terribly slow. Is it
> related to the transpose multiple or something?
> >>> Yes, it's definitely the MatMultTranspose, which must be about 3x more
> >>> expensive than restriction even on the CPU. PCMG/PCGAMG should
> >>> explicitly transpose (unless the user sets an option to aggressively
> >>> minimize memory usage).
> >>> $ rg 'MGInterp|MultTrans' ex56*
> >>> 222:MatMultTranspose 136 1.0 3.5105e-01 3.7 7.91e+07 1.3 2.5e+04
> 1.3e+03 0.0e+00 1 3 7 1 0 5 6 13 3 0 11755
> >>> 247:MGInterp Level 1 68 1.0 3.3894e-04 2.2 2.35e+05 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 693
> >>> 250:MGInterp Level 2 68 1.0 1.1212e-0278.0 1.17e+06 0.0 1.8e+03
> 7.7e+02 0.0e+00 0 0 1 0 0 0 0 1 0 0 2172
> >>> 253:MGInterp Level 3 68 1.0 6.7105e-02 5.3 1.23e+07 1.8 2.7e+04
> 4.2e+02 0.0e+00 0 0 8 0 0 1 1 14 1 0 8594
> >>> 229:MatMultTranspose 136 1.0 1.4832e-01 1.4 1.21e+08 1.2 1.9e+04
> 1.5e+03 0.0e+00 0 3 6 1 0 6 6 10 3 0 27842 0 0
> >>> 258:MGInterp Level 1 68 1.0 2.9145e-04 1.5 1.08e+05 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 370 0 0
> >>> 261:MGInterp Level 2 68 1.0 5.7095e-03 1.5 9.16e+05 2.5 2.4e+03
> 7.1e+02 0.0e+00 0 0 1 0 0 0 0 1 0 0 4093 0 0
> >>> 264:MGInterp Level 3 68 1.0 3.5654e-02 2.8 1.77e+07 1.5 2.3e+04
> 3.9e+02 0.0e+00 0 0 7 0 0 1 1 12 1 0 16095 0 0
> >>> 236:MatMultTranspose 136 1.0 2.1445e-01 1.0 1.72e+08 1.2 9.5e+03
> 2.6e+03 0.0e+00 0 3 6 1 0 39 6 11 3 0 18719 451131 8
> 3.11e+01 272 2.19e+00 100
> >>> 268:MGInterp Level 1 68 1.0 4.0388e-03 2.8 1.08e+05 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 27 79 37
> 5.84e-04 68 6.80e-05 100
> >>> 271:MGInterp Level 2 68 1.0 2.9033e-02 2.9 1.25e+06 1.9 1.6e+03
> 7.8e+02 0.0e+00 0 0 1 0 0 5 0 2 0 0 812 11539 36
> 1.14e-01 136 5.41e-02 100
> >>> 274:MGInterp Level 3 68 1.0 4.9503e-02 1.1 2.50e+07 1.4 1.1e+04
> 6.3e+02 0.0e+00 0 0 7 0 0 9 1 13 1 0 11476 100889 36
> 2.29e+00 136 3.74e-01 100
> >>> 236:MatMultTranspose 136 1.0 2.9692e-01 1.0 1.17e+08 1.2 1.9e+04
> 1.5e+03 0.0e+00 1 3 6 1 0 40 6 10 3 0 13521 336701 8
> 2.08e+01 272 1.59e+00 100
> >>> 268:MGInterp Level 1 68 1.0 3.8752e-03 2.5 1.03e+05 0.0 0.0e+00
> 3.95e-04 68 4.53e-05 100
> >>> 271:MGInterp Level 2 68 1.0 3.5465e-02 2.2 9.12e+05 2.5 2.4e+03
> 7.1e+02 0.0e+00 0 0 1 0 0 4 0 1 0 0 655 5989 36
> 8.16e-02 136 4.89e-02 100
> >>> 274:MGInterp Level 3 68 1.0 6.7101e-02 1.1 1.75e+07 1.5 2.3e+04
> 3.9e+02 0.0e+00 0 0 7 0 0 9 1 12 1 0 8455 56175 36
> 1.55e+00 136 3.03e-01 100
> >> 223:MatMultTranspose 136 1.0 2.0702e-01 2.9 6.59e+07 1.2 2.7e+04
> 1.1e+03 0.0e+00 1 3 7 1 0 7 6 12 3 0 19553
> >> 251:MGInterp Level 1 68 1.0 2.8062e-04 1.5 9.79e+04 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 349
> >> 254:MGInterp Level 2 68 1.0 6.2506e-0331.9 9.69e+05 0.0 2.1e+03
> 6.3e+02 0.0e+00 0 0 1 0 0 0 0 1 0 0 3458
> >> 257:MGInterp Level 3 68 1.0 4.8159e-02 6.5 9.62e+06 1.5 2.5e+04
> 4.2e+02 0.0e+00 0 0 6 0 0 1 1 11 1 0 11199
> >> Power9 still has an edge here.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200616/0410abb9/attachment-0001.html>
