[petsc-users] [Ext] Re: configure error
Satish Balay
balay at mcs.anl.gov
Mon Jun 15 12:40:13 CDT 2020
You need regular MKL. ILP64 can be used with --with-64-bit-blas-indices option.
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --configModules=PETSc.Configure --optionsModule=config.compilerOptions --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_ARCH=linux-gnu-intel --with-precision=single --with-cc=icc --with-cxx=icc --with-fc=ifort --with-mpi-include=/opt/openmpi_4.0.3_intel2019.3/include --with-mpi-lib="-L/opt/openmpi_4.0.3_intel2019.3/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" --with-blaslapack-include=/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/include --with-blaslapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64 -Wl, --no-as-needed -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl" --with-scalapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-e
nv-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" --with-scalapack-include=/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/include --with-cmake=1 --prefix=/opt/petsc_3.10.4_intel2019.3 --known-endian=big --with-debugging=0 --COPTFLAGS=" -Ofast -xHost" --CXXOPTFLAGS=" -Ofast -xHost" --FOPTLAGS=" -Ofast -xHost" --with-x=0 --with-64-bit-indices
This is a complicated build command. What are you trying to do?
Are you sure this is what you want?
PETSc does not use scalapack. Its a dependency for MUMPS
[apart from the mixing MPI issue]
Its best to use appropriate mpicc etc wrappers so that one doesn't files from multiple MPIs..
And its probably better to use:
--with-blaslapack-dir=/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl
Satish
On Mon, 15 Jun 2020, Kun Jiao via petsc-users wrote:
> Actually, that is a question I should ask. When I use --with-64-bit-indices option to config petsc, do I need to use 64 integer option in mkl which means -lmkl_intel_ilp64, or I can use 32integer option for mkl which is -lmkl_intel_lp64?
> Schlumberger-Private
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Monday, June 15, 2020 12:29 PM
> To: Kun Jiao <KJiao at slb.com>
> Cc: petsc-users at mcs.anl.gov
> Subject: [Ext] Re: [petsc-users] configure error
> It is reporting
> ld: cannot find -lmkl_intel_ilp64
> Please send the output from
> ls /mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl
> ls /mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib
> ls /mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64
> Also you are mixing using the Intel MPI and OpenMPI, I am not sure this will work.
> On Jun 15, 2020, at 12:11 PM, Kun Jiao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi,
> Lately I run into a configure error with intel compiler+openmpi+lapack,
> Error message as:
> =============================================================================== TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:114) *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> You set a value for --with-blaslapack-lib=<lib>, but ['-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64', '-Wl,', '--no-as-needed', '-lmkl_intel_ilp64', '-lmkl_intel_thread', '-lmkl_core', '-liomp5', '-lpthread', '-lm', '-ldl'] cannot be used
> Here is my configure parameters:
> ./configure --configModules=PETSc.Configure --optionsModule=config.compilerOptions --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_ARCH=linux-gnu-intel --with-precision=single --with-cc=icc --with-cxx=icc --with-fc=ifort --with-mpi-include=/opt/openmpi_4.0.3_intel2019.3/include --with-mpi-lib="-L/opt/openmpi_4.0.3_intel2019.3/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" --with-blaslapack-include="/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/include" --with-blaslapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64 -Wl, --no-as-needed -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl" --with-scalapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.19
> And configure.log attached.
> Any suggestion will be great?
> Regards,
> Kun
> <configure.log>
