[petsc-users] Implementing periodicity using DMPlex
Shashwat Tiwari shaswat121994 at gmail.com
Mon Jun 15 04:09:54 CDT 2020
The way I'm trying to implement periodic bc is, when I loop over the
boundary faces, say, on the left boundary of the domain to compute flux and
residual, I need solution values from the two cells neighbouring the face,
i.e. the left cell and the right cell (the face normal pointing from the
left cell to the right cell and the right cell being a boundary ghost cell
for boundary faces). For the boundary to be periodic, I need the value that
I get from the right cell (boundary ghost cell) to be the solution value at
its periodic counterpart, i.e. the solution value at left cell of the face
on right boundary of the domain in this case. My question is how do I
update the value at a boundary ghost cell with the value at the real cell
which is its periodic counterpart from the other side of the domain. Is
there some kind of mapping of the boundary ghost cells to their
corresponding real cells which I can use to update the solution values at
ghost cells?
Shashwat
On Sun, Jun 14, 2020 at 5:11 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 12, 2020 at 3:19 PM Shashwat Tiwari <shaswat121994 at gmail.com>
> wrote:
>> Hi,
>> I am writing a first order 2D solver for unstructured grids with periodic
>> boundaries using DMPlex. After generating the mesh, I use
>> "DMSetPeriodicity" function to set periodicity in both directions. After
>> which I partition the mesh (DMPlexDistribute), construct ghost cells
>> (DMPlexConstructGhostCells),
> These ghost cells are for FVM boundary conditions. If you want cells to be
> shared across parallel partitions, then you want to give overlap=1
> to DMPlexDIstribute(). Is that what you want?
>   Thanks,
>      Matt
>> create a section, and set some initial values in the global vector. Then
>> I use "VecGhostUpdateBegin" to start updating the boundary ghost cell
>> values, but, I get the following error in case I use multiple processors:
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Vector is not ghosted
>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> if I run with a single process, there is no error but the values remain
>> empty (zero) and are not updated. Kindly let me know, if I am missing some
>> crucial step before I can update the ghost values in order to implement the
>> periodic bc, or if there is any other approach to achieve it. I am
>> attaching a small code to demonstrate the issue for your reference.
>> Regards,
>> Shashwat
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200615/8fec7761/attachment.html>
