[petsc-users] Parallel writing in HDF5-1.12.0 when some processors have no data to write
Jed Brown
jed at jedbrown.org
Sat Jun 13 15:39:17 CDT 2020
Can you reproduce in C? You're missing three extra arguments that exist in the Fortran interface.
https://support.hdfgroup.org/HDF5/doc/RM/RM_H5D.html#Dataset-Create
Danyang Su <danyang.su at gmail.com> writes:
> Hi Jed,
> Attached is the example for your test.
> This example uses H5Sset_none to tell H5Dwrite call that there will be no data. 4-th process HAS to participate we are in a collective mode.
> The code is ported and modified based on the C example from https://support.hdfgroup.org/ftp/HDF5/examples/parallel/coll_test.c
> The compiling flags in the makefile are same as those used in my own code.
> To compile the code, please run 'make all'
> To test the code, please run 'mpiexec -n 4 ./hdf5_zero_data'. Any number of processors larger than 4 should help to detect the problem.
> The code may crash on HDF5 1.12.0 but works fine on HDF5 1.10.x.
> The following platforms have been tested:
> Macos-Mojave + GNU-8.2 + HDF5-1.12.0 -> Works fine
> Ubuntu-16.04 + GNU-5.4 + HDF5-1.12.0 -> Crashes
> Ubuntu-16.04 + GNU-7.5 + HDF5-1.12.0 -> Crashes
> Ubuntu-16.04 + GNU-5.4 + HDF5-1.10.x -> Works fine
> Centos-7 + Intel2018 + HDF5-12.0 -> Works fine
> Possible error when code crashes
> At line 6686 of file H5_gen.F90
> Fortran runtime error: Index '1' of dimension 1 of array 'buf' above upper bound of 0
> Thanks,
> Danyang
> > Hi Jed,
> > Thanks for your double check.
> > The HDF 1.10.6 version also works. But versions from 1.12.x stop working.
> I'd suggest making a reduced test case in order to submit a bug report.
> This was the relevant change in PETSc for hdf5-1.12.
> https://gitlab.com/petsc/petsc/commit/806daeb7de397195b5132278177f4d5553f9f612
> > Attached is the code section where I have problem.
> > !c write the dataset collectively
> > !!!! CODE CRASHES HERE IF SOME PROCESSORS HAVE NO DATA TO WRITE!!!!
> > call h5dwrite_f(dset_id, H5T_NATIVE_DOUBLE, dataset, hdf5_dsize, &
> > hdf5_ierr, file_space_id=filespace, &
> > mem_space_id=memspace, xfer_prp = xlist_id)
> > Please let me know if there is something wrong in the code that causes the problem.
> !c
> !c This example uses H5Sset_none to tell H5Dwrite call that
> !c there will be no data. 4-th process HAS to participate since
> !c we are in a collective mode.
> !c
> !c The code is ported and modified based on the C example
> !c from https://support.hdfgroup.org/ftp/HDF5/examples/parallel/coll_test.c
> !c by Danyang Su on June 12, 2020.
> !c
> !c To compile the code, please run 'make all'
> !c To test the code, please run 'mpiexec -n 4 ./hdf5_zero_data'
> !c
> !c IMPORTNANT NOTE
> !c The code may crash on HDF5 1.12.0 but works fine on HDF5 1.10.x.
> !c
> !c The following platforms have been tested:
> !c Macos-Mojave + GNU-8.2 + HDF5-1.12.0 -> Works fine
> !c Ubuntu-16.04 + GNU-5.4 + HDF5-1.12.0 -> Crashes
> !c Ubuntu-16.04 + GNU-7.5 + HDF5-1.12.0 -> Crashes
> !c Ubuntu-16.04 + GNU-5.4 + HDF5-1.10.x -> Works fine
> !c Centos-7 + Intel2018 + HDF5-12.0 -> Works fine
> !c
> !c Possible error when code crashes
> !c At line 6686 of file H5_gen.F90
> !c Fortran runtime error: Index '1' of dimension 1 of array 'buf' above upper bound of 0
> !c
> program hdf5_zero_data
> #include <petsc/finclude/petscsys.h>
> use petscsys
> use hdf5
> implicit none
> character(len=10), parameter :: h5File_Name = "SDS_row.h5"
> character(len=8), parameter :: DatasetName = "IntArray"
> integer, parameter :: nx = 8, ny = 5, ndim = 2
> integer :: i
> integer :: hdf5_ierr ! HDF5 error code
> PetscErrorCode :: ierr
> integer(HID_T) :: file_id ! File identifier
> integer(HID_T) :: dset_id ! Dataset identifier
> integer(HID_T) :: space_id ! Space identifier
> integer(HID_T) :: plist_id ! Property list identifier
> integer(HID_T) :: FileSpace ! File identifier
> integer(HID_T) :: MemSpace ! Dataset identifier
> integer(HSIZE_T) :: dimsf(2) ! Dataset dimensions
> integer(HSIZE_T) :: hcount(2) ! hyperslab selection parameters
> integer(HSIZE_T) :: offset(2) ! hyperslab selection parameters
> integer, allocatable :: data(:) ! Dataset to write
> integer :: mpi_size, mpi_rank;
> !c Initialize MPI.
> call PetscInitialize(Petsc_Null_Character,ierr)
> CHKERRQ(ierr)
> call MPI_Comm_rank(Petsc_Comm_World,mpi_rank,ierr)
> CHKERRQ(ierr)
> call MPI_Comm_size(Petsc_Comm_World,mpi_size,ierr)
> CHKERRQ(ierr)
> !c initialize fortran interface
> call h5open_f(hdf5_ierr)
> !c Set up file access property list with parallel I/O access.
> call h5pcreate_f(H5P_FILE_ACCESS_F, plist_id, hdf5_ierr)
> call h5pset_fapl_mpio_f(plist_id, Petsc_Comm_World, &
> MPI_INFO_NULL, hdf5_ierr)
> !c Create a new file collectively and release property list identifier.
> call h5fcreate_f(h5File_Name, H5F_ACC_TRUNC_F, file_id, &
> hdf5_ierr, access_prp = plist_id)
> call h5pclose_f(plist_id, hdf5_ierr)
> !c Create the dataspace for the dataset.
> dimsf(1) = nx
> dimsf(2) = ny
> call h5screate_simple_f(ndim, dimsf, FileSpace, hdf5_ierr)
> !c Create the dataset with default properties and close filespace.
> call h5dcreate_f(file_id, DatasetName, H5T_NATIVE_INTEGER, &
> FileSpace, dset_id, hdf5_ierr)
> call h5sclose_f(FileSpace, hdf5_ierr)
> !c Each process defines dataset in memory and writes it to the hyperslab
> !c in the file.
> if (mpi_rank == 3) then
> hcount(1) = 0
> hcount(2) = dimsf(2)
> else
> hcount(1) = dimsf(1)/mpi_size
> end if
> offset(1) = mpi_rank*hcount(1)
> offset(2) = 0
> call h5screate_simple_f(ndim, hcount, MemSpace, hdf5_ierr)
> call h5sselect_none_f(MemSpace,hdf5_ierr)
> end if
> !c Select hyperslab in the file.
> call h5dget_space_f(dset_id,FileSpace,hdf5_ierr)
> call h5sselect_hyperslab_f(FileSpace, H5S_SELECT_SET_F, &
> offset, hcount, hdf5_ierr)
> call h5sselect_none_f(FileSpace,hdf5_ierr)
> end if
> !c Initialize data buffer.
> allocate(data(0))
> write(*,*) 'Null data space for processor ',mpi_rank
> else
> allocate(data(hcount(1)*hcount(2)))
> write(*,*) 'Data space for processor ',mpi_rank, 'size',size(data)
> do i = 1, hcount(1)*hcount(2)
> data(i) = mpi_rank+10
> end do
> end if
> !c Create property list for collective dataset write.
> call h5pcreate_f(H5P_DATASET_XFER_F, plist_id, hdf5_ierr)
> call h5pset_dxpl_mpio_f(plist_id, H5FD_MPIO_COLLECTIVE_F, &
> hdf5_ierr)
> call h5dwrite_f(dset_id, H5T_NATIVE_INTEGER, data, hcount, &
> hdf5_ierr, file_space_id=FileSpace, &
> mem_space_id=MemSpace, xfer_prp = plist_id)
> !c free data.
> deallocate(data)
> !c Close/release resources.
> call h5dclose_f(dset_id, hdf5_ierr)
> call h5sclose_f(MemSpace, hdf5_ierr)
> call h5fclose_f(file_id, hdf5_ierr)
> call PetscFinalize(ierr)
> CHKERRQ(ierr)
> return
> end program hdf5_zero_data
