[petsc-users] Debugging suggestions: GAMG
Jed Brown
jed at jedbrown.org
Sat Jun 13 07:58:47 CDT 2020
Mark Adams <mfadams at lbl.gov> writes:
> That is odd. Are these problems symmetric positive definite?
> Eigen estimates are a pain in practice but I've never seen this. Hypre has
> (better) smoothers that don't need this and the AMG algorithm does not need
> them either. I think ML does pretty much the same thing as me.
We could certainly offer an "l1 Jacobi" for operator smoothing; it's
effectively using the Gershgorin bound, though it can be very
pessimistic.
At a minimum, it would be useful diagnostic information and we could
stop the Krylov estimate early if its maxbound (which includes safety
and is non-increasing with iteration) exceeds the Gershgorin bound.
> If SPD then you definitely want '-pc_gamg_esteig_ksp_type cg'. CG converges
> faster and is more robust.
Mark, this comes up a lot. Should we select it by default if MAT_SPD is set?
> Even if not strictly SPD like with large
> deformation or plasticity CG is probably better. You can run with -info and
> grep on GAMG to see what eigen (high) estimates it came up with for each
> level. They should be >1 and < 4, or so.
> I wonder if your LAPACK is funky. You might try a fresh build (delete the
> "arch" directory) and download LAPACK, but this problem will go away with
> CG.
Sanjay, you could use the debugger to print out the small dense matrix
that LAPACK is choking on. It isn't supposed to divide by zero ever.
