[petsc-users] Petsc options
Satish Balay
balay at mcs.anl.gov
Fri Jun 12 17:52:43 CDT 2020
You can:
specify via env variable - before running the appliation:
export PETSC_OPTIONS="-info"
mpiexec ./binary
Or add options to ~/.petscrc file [one option per line] - and then run the code.
Satish
On Fri, 12 Jun 2020, Y. Shidi wrote:
> Dear developers,
> I want to use "-info" to view the preallocation of the matrix.
> I cannot add it directly when I run the code.
> I have tried:
> PetscOptionsInsertString(), PetscOptionsSetValue().
> Neither of them works.
> So I am wondering if there is any other functions.
> Thank you for your time.
> Kind Regards,
> Shidi
