[petsc-users] Direct linear solver in Petsc
Fri Jun 12 12:13:07 CDT 2020
On Fri, Jun 12, 2020 at 12:49 PM Qin Lu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I plan to solve a small sparse linear equation system using the direct
> solver, since the number of unknowns is small (less than 1000). Here I got
> a few questions:
> 1. Is there a general guide line on the size of the system that direct
> solver is more efficient than iterative solver?
I would say at least to 50K unknowns, maybe 100K, depending on sparsity.
> 2. Is the native Petsc direct solver (using KSPPREONLY and PCLU) designed
> to solve dense system or sparse system?
Sparse. We use LAPACK for dense.
> 3. Is the native Petsc direct solver comparable to SuperLU and MUMPS in
> performance? Do they use different algorithms?
It is likely slower than SuperLU and not as robust as MUMPS, but there is
no substitute for just running and comparing.
    Matt
> Thanks in advance for your help.
> Best Regards,
> Qin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200612/d1599256/attachment.html>
