[petsc-users] matcreate and assembly issue
    Karl Lin
    karl.linkui at gmail.com
    Thu Jun 11 11:51:59 CDT 2020
Hi, Matthew
Thanks for the suggestion, just did another run and here are some detailed
stack traces, maybe will provide some more insight:
 *** Process received signal ***
Signal: Aborted (6)
Signal code:  (-6)
/lib64/libpthread.so.0(+0xf5f0)[0x2b56c46dc5f0]
 [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b56c5486337]
 [ 2] /lib64/libc.so.6(abort+0x148)[0x2b56c5487a28]
 [ 3] /libpetsc.so.3.10(PetscTraceBackErrorHandler+0xc4)[0x2b56c1e6a2d4]
 [ 4] /libpetsc.so.3.10(PetscError+0x1b5)[0x2b56c1e69f65]
 [ 5] /libpetsc.so.3.10(PetscCommBuildTwoSidedFReq+0x19f0)[0x2b56c1e03cf0]
 [ 6] /libpetsc.so.3.10(+0x77db17)[0x2b56c2425b17]
 [ 7] /libpetsc.so.3.10(+0x77a164)[0x2b56c2422164]
 [ 8] /libpetsc.so.3.10(MatAssemblyBegin_MPIAIJ+0x36)[0x2b56c23912b6]
 [ 9] /libpetsc.so.3.10(MatAssemblyBegin+0xca)[0x2b56c1feccda]
By reconfiguring, you mean recompiling petsc with that option, correct?
Thank you.
Karl
On Thu, Jun 11, 2020 at 10:56 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 11, 2020 at 11:51 AM Karl Lin <karl.linkui at gmail.com> wrote:
>> Hi, there
>> We have written a program using Petsc to solve large sparse matrix
>> system. It has been working fine for a while. Recently we encountered a
>> problem when the size of the sparse matrix is larger than 10TB. We used
>> several hundred nodes and 2200 processes. The program always crashes during
>> MatAssemblyBegin.Upon a closer look, there seems to be something unusual.
>> We have a little memory check during loading the matrix to keep track of
>> rss. The printout of rss in the log shows normal increase up to rank 2160,
>> i.e., if we load in a portion of matrix that is 1GB, after MatSetValues for
>> that portion, rss will increase roughly about that number. From rank 2161
>> onwards, the rss in every rank doesn't increase after matrix loaded. Then
>> comes MatAssemblyBegin, the program crashed on rank 2160.
>> Is there a upper limit on the number of processes Petsc can handle? or is
>> there a upper limit in terms of the size of the matrix petsc can handle?
>> Thank you very much for any info.
> It sounds like you overflowed int somewhere. We try and check for this,
> but catching every place is hard. Try reconfiguring with
>   --with-64-bit-indices
>   Thanks,
>      Matt
>> Regards,
>> Karl
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200611/a85946fa/attachment.html>
