[petsc-users] FW: Parallel writing in HDF5-1.12.0 when some processors have no data to write
Danyang Su
danyang.su at gmail.com
Thu Jun 11 01:05:35 CDT 2020
Hi All,
Sorry to send the previous incomplete email accidentally.
After updating to HDF5-1.12.0, I got some problem if some processors have no data to write or not necessary to write. Since parallel writing is collective, I cannot disable those processors from writing. For the old version, there seems no such problem. So far, the problem only occurs on Linux using GNU compiler. The same code has no problem using intel compiler or latest gnu compiler on MacOS.
I have already included h5sselect_none in the code for those processors without data. But it does not take effect. The problem is documented in the following link (How do you write data when one process doesn't have or need to write data ?).
https://support.hdfgroup.org/HDF5/hdf5-quest.html#par-nodata
Similar problem has also been reported on HDF Forum by others.
https://forum.hdfgroup.org/t/bug-on-hdf5-1-12-0-fortran-parallel/6864
Any suggestion for that?
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200610/adefda98/attachment.html>
