[petsc-users] MatGetRow for global rows of a parallel matrix
Eda Oktay
eda.oktay at metu.edu.tr
Wed Jun 10 11:26:17 CDT 2020
Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 19:13 tarihinde
şunu yazdı:
> On Wed, Jun 10, 2020 at 12:07 PM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> Der Matt,
>> When I looked at the results, I found that there are some problems I
>> couldn't understand.
>> First of all, I am working on a 72*4 matrix and as I said before, I
>> want to have 72 different vectors having size 4 each, whose elements
>> consist of the elements in the same row. And of course, all vectors
>> should be in all processors (currently I am using 4 processors).
>> When I use your scatter code, the output vector is divided into 4
>> parts for 4 processors and each vector consists of 18 row vectors
>> whose elements are arranged in a way that if I want to find zeroth row
>> vector, its elements are located in 0th,18th,36th,54th elements.
> Was the global size of the vector you wrapped around the dense matrix 72*4?
Yes it is. I set up its global size to 72*4.
> If you use CreateToAll(), it will make a vector on each process which has the global size of the original vector.
Although I set 72*4, the size of the vectors in each process is 72.
Eda
> Thanks,
> Matt
>> So, isn't scatter's goal is to scatter all values to all processors?
>> Furthermore, I am trying to use my vectors in that way but isn't there
>> any possible way that I can reach my goal entirely?
>> Thanks so much for your help,
>> Eda
>> Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 18:11 tarihinde
>> şunu yazdı:
>> > On Wed, Jun 10, 2020 at 10:09 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> >> Dear Matt,
>> >> I have one last question I believe. Up to creating a dense matrix I
>> >> did what you've suggested. Thank you so much for that.
>> >> I created a new dense matrix. Now, how should I wrap each vector in a
>> >> MatDense again? I mean, what is wrapping vectors in a matrix? To put
>> >> each of them again as rows?
>> > I thought you need a dense matrix for something, since you started with one. If you
>> > do not, just do VecGetArray() on the vector from CreateToAll and use the values.
>> > Thanks,
>> > Matt
>> >> Thanks!
>> >> Eda
>> >> Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 16:16 tarihinde
>> >> şunu yazdı:
>> >> > On Wed, Jun 10, 2020 at 9:08 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> >> >> Dear Matt,
>> >> >> Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 16:03 tarihinde
>> >> >> şunu yazdı:
>> >> >> > On Wed, Jun 10, 2020 at 8:56 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> >> >> >> Hi all,
>> >> >> >> I am trying to get all the rows of a parallel matrix as individual
>> >> >> >> vectors. For instance, if I have 72*4 matrix, I want to get 72
>> >> >> >> different vectors having size 4.
>> >> >> >> As far as I understood, MatGetRow is only for local rows, so
>> >> >> >> MatGetOwnershipRange is used, however, when I tried this one, I
>> >> >> >> couldn't get the whole and desired row vectors.
>> >> >> >> In MatGetRow explanation, it is written that I should use
>> >> >> >> MatCreateSubMatrices first, then use MatGetRow. But I couldn't
>> >> >> >> understand to which extent I should create submatrices. I just need to
>> >> >> >> have all 72 rows as 72 different vectors each having 4 elements.
>> >> >> > 1) For sparse matrices, the storage is always divided by row, so that values can only be retrieved for local rows with MatGetRow()
>> >> >> > 2) Is this matrix sparse? It sounds like it is dense.
>> >> >> Matrix is dense.
>> >> >> > 3) Are you asking to get all matrix values on all processes? If so, I think the easiest thing to do is first wrap a Vec around the
>> >> >> > values, then use VecScatterToAll(), then wrap each one in a MatDense again.
>> >> >> Yes, I want all row vectors on all processes. In a dense matrix,
>> >> >> should I still wrap a Vec around the values? I know I should use
>> >> >> scatter but I couldn't even wrap a Vec around them.
>> >> > I would do
>> >> > MatGetSize(&N);
>> >> > MatGetLocalSize(&m);
>> >> > https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDenseGetArray.html
>> >> > <create vector of local size m*N>
>> >> > https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecPlaceArray.html
>> >> > https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html
>> >> > <do scatter>
>> >> > https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecResetArray.html#VecResetArray
>> >> > https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateDense.html
>> >> > <use it>
>> >> > <destroy matrix>
>> >> > <destroy vector from CreateToAll>
>> >> > Thanks,
>> >> > Matt
>> >> >> Thanks so much!
>> >> >> Eda
>> >> >> > Thanks,
>> >> >> > Matt
>> >> >> >> Thanks!
>> >> >> >> Eda
>> >> >> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> >> >> > -- Norbert Wiener
>> >> >> > https://www.cse.buffalo.edu/~knepley/
>> >> > -- Norbert Wiener
>> > -- Norbert Wiener
> -- Norbert Wiener
