[petsc-users] TAO STCG initial perturbation
zakaryah .
zakaryah at gmail.com
Tue Jun 9 22:55:28 CDT 2020
I am using TAO to minimize the elastic strain energy for somewhat
complicated applied forces. With Newton linesearch (NLS), the STCG KSP, and
several preconditioners (none, Jacobi, lmvm), the solver finds a minimum
within an acceptable number of iterations (<50). Still, in the interest of
performance, I am wondering about what happens after the KSP encounters an
indefinite matrix (KSP_CONVERGED_CG_NEG_CURVE). After this happens, the
line search performs extremely poorly, with function values at step length
1 reaching absurdly large values. As the line search tries smaller step
lengths, the function values fall, then typically reach values representing
a decline from the previous iteration, but only with tiny step lengths
(~1e-11). The line search takes many iterations to arrive at such an
improvement. Here is an example, run with -tao_type nls -tao_nls_ksp_type
stcg -tao_nls_pc_type none -tao_nls_ksp_norm_type unpreconditioned:
0 TAO, Function value: 0.160612, Residual: 0.0736074
0 TAO, Function value: 0.121568, Residual: 0.0424117
Residual norms for tao_nls_ solve.
0 KSP Residual norm 4.241174778983e-02
1 KSP Residual norm 5.806891169509e-02
2 KSP Residual norm 6.492953448014e-02
3 KSP Residual norm 5.856559430984e-02
4 KSP Residual norm 5.262548559710e-02
5 KSP Residual norm 4.863633473400e-02
6 KSP Residual norm 4.725156347026e-02
7 KSP Residual norm 4.748458009319e-02
8 KSP Residual norm 4.885339641711e-02
9 KSP Residual norm 5.065071226354e-02
10 KSP Residual norm 5.085544070851e-02
11 KSP Residual norm 5.127093547976e-02
12 KSP Residual norm 5.155225884843e-02
13 KSP Residual norm 5.219895021408e-02
14 KSP Residual norm 6.480520610077e-02
15 KSP Residual norm 1.433515456621e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations
16
0 LS Function value: 0.121568, Step length: 0.
1 LS Function value: 5.99839e+59, Step length: 1.
stx: 0., fx: 0.121568, dgx: -1.32893e+08
sty: 0., fy: 0.121568, dgy: -1.32893e+08
2 LS Function value: 1.46445e+56, Step length: 0.25
sty: 1., fy: 5.99839e+59, dgy: 3.59903e+60
3 LS Function value: 3.57532e+52, Step length: 0.0625
sty: 0.25, fy: 1.46445e+56, dgy: 3.51468e+57
4 LS Function value: 8.7288e+48, Step length: 0.015625
sty: 0.0625, fy: 3.57532e+52, dgy: 3.4323e+54
5 LS Function value: 2.13105e+45, Step length: 0.00390625
sty: 0.015625, fy: 8.7288e+48, dgy: 3.35186e+51
6 LS Function value: 5.20277e+41, Step length: 0.000976562
sty: 0.00390625, fy: 2.13105e+45, dgy: 3.2733e+48
7 LS Function value: 1.27021e+38, Step length: 0.000244141
sty: 0.000976562, fy: 5.20277e+41, dgy: 3.19658e+45
8 LS Function value: 3.1011e+34, Step length: 6.10352e-05
sty: 0.000244141, fy: 1.27021e+38, dgy: 3.12166e+42
9 LS Function value: 7.57106e+30, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 3.1011e+34, dgy: 3.0485e+39
10 LS Function value: 1.84842e+27, Step length: 3.8147e-06
sty: 1.52588e-05, fy: 7.57106e+30, dgy: 2.97706e+36
11 LS Function value: 4.51295e+23, Step length: 9.53672e-07
sty: 3.8147e-06, fy: 1.84842e+27, dgy: 2.90731e+33
12 LS Function value: 1.10199e+20, Step length: 2.38417e-07
sty: 9.53672e-07, fy: 4.51295e+23, dgy: 2.83927e+30
13 LS Function value: 2.69231e+16, Step length: 5.96028e-08
sty: 2.38417e-07, fy: 1.10199e+20, dgy: 2.77314e+27
14 LS Function value: 6.59192e+12, Step length: 1.48993e-08
sty: 5.96028e-08, fy: 2.69231e+16, dgy: 2.70974e+24
15 LS Function value: 1.62897e+09, Step length: 3.72338e-09
sty: 1.48993e-08, fy: 6.59192e+12, dgy: 2.65254e+21
16 LS Function value: 421305., Step length: 9.29291e-10
sty: 3.72338e-09, fy: 1.62897e+09, dgy: 2.61626e+18
17 LS Function value: 141.939, Step length: 2.30343e-10
sty: 9.29291e-10, fy: 421305., dgy: 2.67496e+15
18 LS Function value: 0.213621, Step length: 5.45712e-11
sty: 2.30343e-10, fy: 141.939, dgy: 3.35874e+12
19 LS Function value: 0.120058, Step length: 1.32286e-11
sty: 5.45712e-11, fy: 0.213621, dgy: 8.60977e+09
1 TAO, Function value: 0.120058, Residual: 0.0484495
When the KSP does not encounter negative curvature, the linesearch performs
well:
3 TAO, Function value: 0.118376, Residual: 0.0545446
0 KSP Residual norm 5.454463134947e-02
1 KSP Residual norm 2.394277461960e-02
2 KSP Residual norm 6.674182971627e-03
3 KSP Residual norm 1.235116278289e-03
4 KSP Residual norm 1.714792759324e-04
5 KSP Residual norm 3.928769927518e-05
6 KSP Residual norm 8.464174666739e-06
7 KSP Residual norm 1.583763581407e-06
8 KSP Residual norm 3.251685842746e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 8
0 LS Function value: 0.118376, Step length: 0.
1 LS Function value: 0.117884, Step length: 1.
stx: 0., fx: 0.118376, dgx: -0.000530697
sty: 0., fy: 0.118376, dgy: -0.000530697
I have attached the full log for this particular solve. The points of
negative curvature do not surprise me - this is a difficult problem, with
many singularities in the Jacobian/Hessian. In fact, I am very happy with
how well STCG is performing, globally. My question is what to make of the
poor performance of the linesearch after encountering these points. As I
understand it, most of the flags for adjusting the solver after
encountering an indefinite matrix involve altering the magnitude of the
perturbation by which the Hessian is offset for calculating the update
direction. I am not clear on how to adjust the routine for determining the
initial step size. More generally, should I expect these points of negative
curvature to cause difficulties for the solver, and be satisfied with a
large number of iterations before finding an improvement at tiny step size?
I have a loosely related question about the status of the Levenberg
Marquardt solver within Tao? I remember hearing on the list that this was
being worked on, but I am not sure from the branch description whether it
is working or intended for general use. I would love to hear any updates on
that, because I think it could be useful for my problem.
Thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200609/35b53333/attachment-0001.html>
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 16
0 KSP Residual norm 4.844951838490e-02
1 KSP Residual norm 8.888378784357e-02
2 KSP Residual norm 1.314301325299e-01
3 KSP Residual norm 1.212791469268e-01
4 KSP Residual norm 8.542336549879e-02
5 KSP Residual norm 7.588563434299e-02
6 KSP Residual norm 8.363961352117e-02
7 KSP Residual norm 6.598030232548e-02
8 KSP Residual norm 5.204764990103e-02
9 KSP Residual norm 4.034278249686e-02
10 KSP Residual norm 3.749451801761e-02
11 KSP Residual norm 3.940541072499e-02
12 KSP Residual norm 4.626348059301e-02
13 KSP Residual norm 4.525805505460e-02
14 KSP Residual norm 4.683603033796e-02
15 KSP Residual norm 5.646783716895e-02
16 KSP Residual norm 7.654049549502e-02
17 KSP Residual norm 1.220539070594e-01
18 KSP Residual norm 3.872622341402e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 19
0 LS Function value: 0.120058, Step length: 0.
1 LS Function value: 9.71204e+59, Step length: 1.
stx: 0., fx: 0.120058, dgx: -1.32802e+08
sty: 0., fy: 0.120058, dgy: -1.32802e+08
2 LS Function value: 1.51751e+58, Step length: 0.5
sty: 1., fy: 9.71204e+59, dgy: 5.82723e+60
3 LS Function value: 2.3711e+56, Step length: 0.25
sty: 0.5, fy: 1.51751e+58, dgy: 1.82101e+59
4 LS Function value: 5.78883e+52, Step length: 0.0625
sty: 0.25, fy: 2.3711e+56, dgy: 5.69065e+57
5 LS Function value: 0.120058, Step length: 0.
sty: 0.0625, fy: 4.49423e+307, dgy: 4.49423e+307
1 LS Function value: 0.118425, Step length: 1.
stx: 0., fx: 0.120058, dgx: -0.00234736
sty: 0., fy: 0.120058, dgy: -0.00234736
2 TAO, Function value: 0.118425, Residual: 0.0616228
0 KSP Residual norm 6.162283660782e-02
1 KSP Residual norm 5.025826587428e-02
2 KSP Residual norm 4.542026614329e-02
3 KSP Residual norm 2.061536850833e-02
4 KSP Residual norm 7.994088483587e-03
5 KSP Residual norm 5.455810898084e-03
6 KSP Residual norm 5.537191660058e-03
7 KSP Residual norm 4.569969520333e-03
8 KSP Residual norm 5.701507221403e-03
9 KSP Residual norm 1.108170533587e-02
10 KSP Residual norm 3.103734912773e-02
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 11
0 LS Function value: 0.118425, Step length: 0.
1 LS Function value: 3.49435e+64, Step length: 1.
stx: 0., fx: 0.118425, dgx: -2.40297e+07
sty: 0., fy: 0.118425, dgy: -2.40297e+07
2 LS Function value: 8.53113e+60, Step length: 0.25
sty: 1., fy: 3.49435e+64, dgy: 2.09661e+65
3 LS Function value: 2.0828e+57, Step length: 0.0625
sty: 0.25, fy: 8.53113e+60, dgy: 2.04747e+62
4 LS Function value: 5.08495e+53, Step length: 0.015625
sty: 0.0625, fy: 2.0828e+57, dgy: 1.99948e+59
5 LS Function value: 1.24144e+50, Step length: 0.00390625
sty: 0.015625, fy: 5.08495e+53, dgy: 1.95262e+56
6 LS Function value: 3.03087e+46, Step length: 0.000976562
sty: 0.00390625, fy: 1.24144e+50, dgy: 1.90686e+53
7 LS Function value: 7.39958e+42, Step length: 0.000244141
sty: 0.000976562, fy: 3.03087e+46, dgy: 1.86217e+50
8 LS Function value: 1.80654e+39, Step length: 6.10352e-05
sty: 0.000244141, fy: 7.39958e+42, dgy: 1.81852e+47
9 LS Function value: 4.4105e+35, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 1.80654e+39, dgy: 1.7759e+44
10 LS Function value: 1.07679e+32, Step length: 3.8147e-06
sty: 1.52588e-05, fy: 4.4105e+35, dgy: 1.73428e+41
11 LS Function value: 2.6289e+28, Step length: 9.53674e-07
sty: 3.8147e-06, fy: 1.07679e+32, dgy: 1.69364e+38
12 LS Function value: 6.41853e+24, Step length: 2.38418e-07
sty: 9.53674e-07, fy: 2.6289e+28, dgy: 1.65396e+35
13 LS Function value: 1.56733e+21, Step length: 5.96041e-08
sty: 2.38418e-07, fy: 6.41853e+24, dgy: 1.61526e+32
14 LS Function value: 3.82952e+17, Step length: 1.49006e-08
sty: 5.96041e-08, fy: 1.56733e+21, dgy: 1.57766e+29
15 LS Function value: 9.37896e+13, Step length: 3.72477e-09
sty: 1.49006e-08, fy: 3.82952e+17, dgy: 1.5417e+26
16 LS Function value: 2.31877e+10, Step length: 9.308e-10
sty: 3.72477e-09, fy: 9.37896e+13, dgy: 1.50953e+23
17 LS Function value: 5.94925e+06, Step length: 2.32309e-10
sty: 9.308e-10, fy: 2.31877e+10, dgy: 1.48969e+20
18 LS Function value: 1752.87, Step length: 5.76882e-11
sty: 2.32309e-10, fy: 5.94925e+06, dgy: 1.51638e+17
19 LS Function value: 0.886813, Step length: 1.4046e-11
sty: 5.76882e-11, fy: 1752.87, dgy: 1.73482e+14
20 LS Function value: 0.11866, Step length: 3.22282e-12
sty: 1.4046e-11, fy: 0.886813, dgy: 2.8477e+11
21 LS Function value: 0.118385, Step length: 1.05823e-12
sty: 3.22282e-12, fy: 0.11866, dgy: 5.41311e+08
22 LS Function value: 0.118387, Step length: 1.84626e-12
stx: 1.05823e-12, fx: 0.118385, dgx: -3.64299e+07
23 LS Function value: 0.118376, Step length: 1.44508e-12
sty: 1.84626e-12, fy: 0.118387, dgy: 7.02578e+07
4 TAO, Function value: 0.117884, Residual: 0.0440192
0 KSP Residual norm 4.401922906725e-02
1 KSP Residual norm 9.641051329057e-02
2 KSP Residual norm 1.583253894073e-01
3 KSP Residual norm 1.257330439674e-01
4 KSP Residual norm 7.575909045394e-02
5 KSP Residual norm 7.304083212763e-02
6 KSP Residual norm 6.995426549536e-02
7 KSP Residual norm 5.885266694346e-02
8 KSP Residual norm 4.974341074311e-02
9 KSP Residual norm 3.876927941411e-02
10 KSP Residual norm 3.495606035516e-02
11 KSP Residual norm 4.044737134240e-02
12 KSP Residual norm 4.581515301677e-02
13 KSP Residual norm 5.167427719831e-02
14 KSP Residual norm 6.363360913577e-02
15 KSP Residual norm 1.041939183912e-01
16 KSP Residual norm 5.504936234465e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 17
0 LS Function value: 0.117884, Step length: 0.
1 LS Function value: 2.81045e+61, Step length: 1.
stx: 0., fx: 0.117884, dgx: -1.377e+08
sty: 0., fy: 0.117884, dgy: -1.377e+08
2 LS Function value: 6.86146e+57, Step length: 0.25
sty: 1., fy: 2.81045e+61, dgy: 1.68627e+62
3 LS Function value: 1.67516e+54, Step length: 0.0625
sty: 0.25, fy: 6.86146e+57, dgy: 1.64675e+59
4 LS Function value: 4.08975e+50, Step length: 0.015625
sty: 0.0625, fy: 1.67516e+54, dgy: 1.60815e+56
5 LS Function value: 9.98474e+46, Step length: 0.00390625
sty: 0.015625, fy: 4.08975e+50, dgy: 1.57046e+53
6 LS Function value: 2.43768e+43, Step length: 0.000976562
sty: 0.00390625, fy: 9.98474e+46, dgy: 1.53366e+50
7 LS Function value: 5.95137e+39, Step length: 0.000244141
sty: 0.000976562, fy: 2.43768e+43, dgy: 1.49771e+47
8 LS Function value: 1.45297e+36, Step length: 6.10352e-05
sty: 0.000244141, fy: 5.95137e+39, dgy: 1.46261e+44
9 LS Function value: 3.5473e+32, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 1.45297e+36, dgy: 1.42833e+41
10 LS Function value: 8.66048e+28, Step length: 3.8147e-06
sty: 1.52588e-05, fy: 3.5473e+32, dgy: 1.39485e+38
11 LS Function value: 2.11445e+25, Step length: 9.53673e-07
sty: 3.8147e-06, fy: 8.66048e+28, dgy: 1.36217e+35
12 LS Function value: 5.16294e+21, Step length: 2.38417e-07
sty: 9.53673e-07, fy: 2.11445e+25, dgy: 1.33029e+32
13 LS Function value: 1.26118e+18, Step length: 5.96032e-08
sty: 2.38417e-07, fy: 5.16294e+21, dgy: 1.29926e+29
14 LS Function value: 3.08587e+14, Step length: 1.48997e-08
sty: 5.96032e-08, fy: 1.26118e+18, dgy: 1.26939e+26
15 LS Function value: 7.60094e+10, Step length: 3.72382e-09
sty: 1.48997e-08, fy: 3.08587e+14, dgy: 1.24193e+23
16 LS Function value: 1.923e+07, Step length: 9.29851e-10
sty: 3.72382e-09, fy: 7.60094e+10, dgy: 1.2218e+20
17 LS Function value: 5418.89, Step length: 2.31341e-10
sty: 9.29851e-10, fy: 1.923e+07, dgy: 1.22903e+17
18 LS Function value: 2.32235, Step length: 5.66692e-11
sty: 2.31341e-10, fy: 5418.89, dgy: 1.35195e+14
19 LS Function value: 0.117578, Step length: 1.31782e-11
sty: 5.66692e-11, fy: 2.32235, dgy: 2.05445e+11
20 LS Function value: 0.117439, Step length: 3.24647e-12
stx: 1.31782e-11, fx: 0.117578, dgx: 4.21259e+08
21 LS Function value: 0.11689, Step length: 9.0376e-12
stx: 3.24647e-12, fx: 0.117439, dgx: -1.32157e+08
sty: 1.31782e-11, fy: 0.117578, dgy: 4.21259e+08
5 TAO, Function value: 0.11689, Residual: 0.0540029
0 KSP Residual norm 5.400285447855e-02
1 KSP Residual norm 6.512918283257e-02
2 KSP Residual norm 1.148360046903e-01
3 KSP Residual norm 1.010928121441e-01
4 KSP Residual norm 6.485971836735e-02
5 KSP Residual norm 4.615521971362e-02
6 KSP Residual norm 2.902709674424e-02
7 KSP Residual norm 2.372772308974e-02
8 KSP Residual norm 1.904925641486e-02
9 KSP Residual norm 1.414125788519e-02
10 KSP Residual norm 1.320539010507e-02
11 KSP Residual norm 9.745386363006e-03
12 KSP Residual norm 7.401766942545e-03
13 KSP Residual norm 6.631061977841e-03
14 KSP Residual norm 5.966693954459e-03
15 KSP Residual norm 4.525072276611e-03
16 KSP Residual norm 3.408340207743e-03
17 KSP Residual norm 2.663265621840e-03
18 KSP Residual norm 2.072491553175e-03
19 KSP Residual norm 1.595991076595e-03
20 KSP Residual norm 1.229477613044e-03
21 KSP Residual norm 9.694958293863e-04
22 KSP Residual norm 8.520014521104e-04
23 KSP Residual norm 1.116349147635e-03
24 KSP Residual norm 6.915586648292e-04
25 KSP Residual norm 5.380917812438e-04
26 KSP Residual norm 4.217826822653e-04
27 KSP Residual norm 3.465721535647e-04
28 KSP Residual norm 2.848873812900e-04
29 KSP Residual norm 2.352040234792e-04
30 KSP Residual norm 2.054572560776e-04
31 KSP Residual norm 2.114102507293e-04
32 KSP Residual norm 2.175918611833e-04
33 KSP Residual norm 1.793335663726e-04
34 KSP Residual norm 1.753175349029e-04
35 KSP Residual norm 1.721057550088e-04
36 KSP Residual norm 1.575663535449e-04
37 KSP Residual norm 1.459973233198e-04
38 KSP Residual norm 1.370447384535e-04
39 KSP Residual norm 1.293915582096e-04
40 KSP Residual norm 1.234029163407e-04
41 KSP Residual norm 1.206463477220e-04
42 KSP Residual norm 1.280405476277e-04
43 KSP Residual norm 1.293435255610e-04
44 KSP Residual norm 1.077166952980e-04
45 KSP Residual norm 8.606815396809e-05
46 KSP Residual norm 6.877935596819e-05
47 KSP Residual norm 5.800254104764e-05
48 KSP Residual norm 5.059424319126e-05
49 KSP Residual norm 4.620743007342e-05
50 KSP Residual norm 4.453906713597e-05
51 KSP Residual norm 4.579022713750e-05
52 KSP Residual norm 4.747062577063e-05
53 KSP Residual norm 4.430176773708e-05
54 KSP Residual norm 4.174496341629e-05
55 KSP Residual norm 4.053423032099e-05
56 KSP Residual norm 4.074769522920e-05
57 KSP Residual norm 4.097540211911e-05
58 KSP Residual norm 4.050813715814e-05
59 KSP Residual norm 4.491113841391e-05
60 KSP Residual norm 5.044406896924e-05
61 KSP Residual norm 4.057321626045e-05
62 KSP Residual norm 3.807937013197e-05
63 KSP Residual norm 4.063220626318e-05
64 KSP Residual norm 4.680126880066e-05
65 KSP Residual norm 3.156728925723e-05
66 KSP Residual norm 2.928284108412e-05
67 KSP Residual norm 2.767191407805e-05
68 KSP Residual norm 2.547955496178e-05
69 KSP Residual norm 2.346003946471e-05
70 KSP Residual norm 2.158563973916e-05
71 KSP Residual norm 1.930828049949e-05
72 KSP Residual norm 1.707079237949e-05
73 KSP Residual norm 1.530105531502e-05
74 KSP Residual norm 1.389897362252e-05
75 KSP Residual norm 1.259208011285e-05
76 KSP Residual norm 1.143495913579e-05
77 KSP Residual norm 1.103221589248e-05
78 KSP Residual norm 1.137422072151e-05
79 KSP Residual norm 9.272576209889e-06
80 KSP Residual norm 8.154830290087e-06
81 KSP Residual norm 7.968131968545e-06
82 KSP Residual norm 1.137940805856e-05
83 KSP Residual norm 7.072458465525e-06
84 KSP Residual norm 6.414641508599e-06
85 KSP Residual norm 6.022871671536e-06
86 KSP Residual norm 5.916531108532e-06
87 KSP Residual norm 7.285288130158e-06
88 KSP Residual norm 5.670946085138e-06
89 KSP Residual norm 5.007495022152e-06
90 KSP Residual norm 4.735375353673e-06
91 KSP Residual norm 4.228998466375e-06
92 KSP Residual norm 3.712713923183e-06
93 KSP Residual norm 3.470802625326e-06
94 KSP Residual norm 3.521635718081e-06
95 KSP Residual norm 2.976592260743e-06
96 KSP Residual norm 2.504143899376e-06
97 KSP Residual norm 2.210826215502e-06
98 KSP Residual norm 1.976863674880e-06
99 KSP Residual norm 1.771698640393e-06
100 KSP Residual norm 1.646734584212e-06
101 KSP Residual norm 2.113572316569e-06
102 KSP Residual norm 1.731406712704e-06
103 KSP Residual norm 1.415110112789e-06
104 KSP Residual norm 1.298382060413e-06
105 KSP Residual norm 1.155812947537e-06
106 KSP Residual norm 1.029787970406e-06
107 KSP Residual norm 9.024337186209e-07
108 KSP Residual norm 7.847415699911e-07
109 KSP Residual norm 6.907844476017e-07
110 KSP Residual norm 6.297089428124e-07
111 KSP Residual norm 5.851637885097e-07
112 KSP Residual norm 5.131306607803e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 112
0 LS Function value: 0.11689, Step length: 0.
1 LS Function value: 0.101184, Step length: 1.
stx: 0., fx: 0.11689, dgx: -0.0187944
sty: 0., fy: 0.11689, dgy: -0.0187944
6 TAO, Function value: 0.101184, Residual: 0.0298832
0 KSP Residual norm 2.988318825066e-02
1 KSP Residual norm 6.999336979013e-02
2 KSP Residual norm 9.782542410829e-02
3 KSP Residual norm 1.121643670992e-01
4 KSP Residual norm 9.184918893023e-02
5 KSP Residual norm 6.503899777002e-02
6 KSP Residual norm 4.915758222601e-02
7 KSP Residual norm 3.667363763398e-02
8 KSP Residual norm 3.333497370714e-02
9 KSP Residual norm 3.047173591261e-02
10 KSP Residual norm 2.929231917984e-02
11 KSP Residual norm 3.070821465077e-02
12 KSP Residual norm 3.156649323208e-02
13 KSP Residual norm 2.953987347450e-02
14 KSP Residual norm 2.888310053485e-02
15 KSP Residual norm 2.716126528623e-02
16 KSP Residual norm 2.393731488846e-02
17 KSP Residual norm 2.173049264768e-02
18 KSP Residual norm 1.999994344085e-02
19 KSP Residual norm 1.774628300224e-02
20 KSP Residual norm 1.867219240131e-02
21 KSP Residual norm 2.109193608629e-02
22 KSP Residual norm 2.462350370207e-02
23 KSP Residual norm 2.862405077714e-02
24 KSP Residual norm 2.535297734084e-02
25 KSP Residual norm 3.147570076541e-02
26 KSP Residual norm 4.454257840211e-02
27 KSP Residual norm 9.103909837716e-02
28 KSP Residual norm 5.047306183102e+01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 29
0 LS Function value: 0.101184, Step length: 0.
1 LS Function value: -nan., Step length: 1.
stx: 0., fx: 0.101184, dgx: -5.53499e+07
sty: 0., fy: 0.101184, dgy: -5.53499e+07
2 LS Function value: 0.101184, Step length: 0.
sty: 1., fy: 4.49423e+307, dgy: 4.49423e+307
1 LS Function value: 0.100563, Step length: 1.
stx: 0., fx: 0.101184, dgx: -0.000893005
sty: 0., fy: 0.101184, dgy: -0.000893005
7 TAO, Function value: 0.100563, Residual: 0.0498602
0 KSP Residual norm 4.986015799684e-02
1 KSP Residual norm 3.086218961281e-02
2 KSP Residual norm 3.447024083903e-02
3 KSP Residual norm 1.220840565488e-02
4 KSP Residual norm 5.252141517883e-03
5 KSP Residual norm 3.255344170709e-03
6 KSP Residual norm 3.371106805338e-03
7 KSP Residual norm 3.626200961960e-03
8 KSP Residual norm 2.820818787242e-03
9 KSP Residual norm 1.855528281325e-03
10 KSP Residual norm 1.410605305433e-03
11 KSP Residual norm 1.252300544357e-03
12 KSP Residual norm 1.092178376566e-03
13 KSP Residual norm 8.281995642347e-04
14 KSP Residual norm 5.395084724746e-04
15 KSP Residual norm 3.276036643104e-04
16 KSP Residual norm 2.208978354504e-04
17 KSP Residual norm 1.642429790532e-04
18 KSP Residual norm 1.441760086504e-04
19 KSP Residual norm 1.367381865261e-04
20 KSP Residual norm 1.073593110454e-04
21 KSP Residual norm 6.851701645549e-05
22 KSP Residual norm 4.657324024620e-05
23 KSP Residual norm 3.509348206388e-05
24 KSP Residual norm 1.678485973215e-05
25 KSP Residual norm 8.287113909059e-06
26 KSP Residual norm 4.213140670789e-06
27 KSP Residual norm 2.119353055704e-06
28 KSP Residual norm 1.074857544340e-06
29 KSP Residual norm 5.791909151134e-07
30 KSP Residual norm 3.106280949278e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 30
0 LS Function value: 0.100563, Step length: 0.
1 LS Function value: 0.0997883, Step length: 1.
stx: 0., fx: 0.100563, dgx: -0.00153491
sty: 0., fy: 0.100563, dgy: -0.00153491
2 LS Function value: 0.0998972, Step length: 0.495946
stx: 1., fx: 0.0997883, dgx: 0.00156001
8 TAO, Function value: 0.0998972, Residual: 0.0294338
0 KSP Residual norm 2.943381578075e-02
1 KSP Residual norm 6.256352440814e-02
2 KSP Residual norm 8.858013950551e-02
3 KSP Residual norm 9.354100880380e-02
4 KSP Residual norm 8.739903622566e-02
5 KSP Residual norm 6.154815724480e-02
6 KSP Residual norm 4.335485929078e-02
7 KSP Residual norm 3.208570894750e-02
8 KSP Residual norm 2.865550852665e-02
9 KSP Residual norm 3.218692592997e-02
10 KSP Residual norm 3.154406510415e-02
11 KSP Residual norm 3.218715751652e-02
12 KSP Residual norm 3.250679140589e-02
13 KSP Residual norm 3.095023214293e-02
14 KSP Residual norm 2.889394392237e-02
15 KSP Residual norm 2.681813581066e-02
16 KSP Residual norm 2.451645518319e-02
17 KSP Residual norm 2.254912274637e-02
18 KSP Residual norm 2.107067070883e-02
19 KSP Residual norm 2.759210067581e-02
20 KSP Residual norm 2.562709878509e-02
21 KSP Residual norm 2.276311654216e-02
22 KSP Residual norm 2.624260706220e-02
23 KSP Residual norm 3.138003136915e-02
24 KSP Residual norm 4.097052452638e-02
25 KSP Residual norm 6.752867136647e-02
26 KSP Residual norm 2.774250915877e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 27
0 LS Function value: 0.0998972, Step length: 0.
stx: 0., fx: 0.0998972, dgx: -6.17495e+07
sty: 0., fy: 0.0998972, dgy: -6.17495e+07
1 LS Function value: 0.0994601, Step length: 1.
stx: 0., fx: 0.0998972, dgx: -0.00086635
sty: 0., fy: 0.0998972, dgy: -0.00086635
9 TAO, Function value: 0.0994601, Residual: 0.0627203
0 KSP Residual norm 6.272030900916e-02
1 KSP Residual norm 3.112371813746e-02
2 KSP Residual norm 3.486112477484e-02
3 KSP Residual norm 1.478285537888e-02
4 KSP Residual norm 1.432448204034e-02
5 KSP Residual norm 4.472439203545e-02
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 6
0 LS Function value: 0.0994601, Step length: 0.
1 LS Function value: 1.96952e+64, Step length: 1.
stx: 0., fx: 0.0994601, dgx: -9.10643e+07
sty: 0., fy: 0.0994601, dgy: -9.10643e+07
2 LS Function value: 4.80839e+60, Step length: 0.25
sty: 1., fy: 1.96952e+64, dgy: 1.18171e+65
3 LS Function value: 1.17392e+57, Step length: 0.0625
sty: 0.25, fy: 4.80839e+60, dgy: 1.15401e+62
4 LS Function value: 2.86602e+53, Step length: 0.015625
sty: 0.0625, fy: 1.17392e+57, dgy: 1.12697e+59
5 LS Function value: 6.99713e+49, Step length: 0.00390625
sty: 0.015625, fy: 2.86602e+53, dgy: 1.10055e+56
6 LS Function value: 1.70828e+46, Step length: 0.000976562
sty: 0.00390625, fy: 6.99713e+49, dgy: 1.07476e+53
7 LS Function value: 4.17061e+42, Step length: 0.000244141
sty: 0.000976562, fy: 1.70828e+46, dgy: 1.04957e+50
8 LS Function value: 1.01822e+39, Step length: 6.10352e-05
sty: 0.000244141, fy: 4.17061e+42, dgy: 1.02497e+47
9 LS Function value: 2.48588e+35, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 1.01822e+39, dgy: 1.00095e+44
10 LS Function value: 0.0994601, Step length: 0.
sty: 1.52588e-05, fy: 4.49423e+307, dgy: 4.49423e+307
1 LS Function value: 0.101263, Step length: 1.
stx: 0., fx: 0.0994601, dgx: -0.00393384
sty: 0., fy: 0.0994601, dgy: -0.00393384
2 LS Function value: 0.0994353, Step length: 0.5
sty: 1., fy: 0.101263, dgy: 0.00527413
10 TAO, Function value: 0.0994353, Residual: 0.0723933
0 KSP Residual norm 7.239325125692e-02
1 KSP Residual norm 3.264842236815e-03
2 KSP Residual norm 1.358841152684e-04
3 KSP Residual norm 4.076006658523e-06
4 KSP Residual norm 1.374045688780e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 4
0 LS Function value: 0.0994353, Step length: 0.
1 LS Function value: 0.0993447, Step length: 1.
stx: 0., fx: 0.0994353, dgx: -9.50218e-05
sty: 0., fy: 0.0994353, dgy: -9.50218e-05
2 LS Function value: 0.0990652, Step length: 5.
stx: 1., fx: 0.0993447, dgx: -8.62629e-05
11 TAO, Function value: 0.0990652, Residual: 0.0429398
0 KSP Residual norm 4.293976414948e-02
1 KSP Residual norm 3.482999076388e-02
2 KSP Residual norm 7.550011514518e-02
3 KSP Residual norm 9.172956814513e-02
4 KSP Residual norm 9.806624446728e-02
5 KSP Residual norm 8.165837299441e-02
6 KSP Residual norm 7.792230767957e-02
7 KSP Residual norm 8.338487762871e-02
8 KSP Residual norm 1.085872886084e-01
9 KSP Residual norm 3.208725716617e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 10
0 LS Function value: 0.0990652, Step length: 0.
1 LS Function value: 5.64843e+61, Step length: 1.
stx: 0., fx: 0.0990652, dgx: -2.07706e+08
sty: 0., fy: 0.0990652, dgy: -2.07706e+08
2 LS Function value: 1.37901e+58, Step length: 0.25
sty: 1., fy: 5.64843e+61, dgy: 3.38906e+62
3 LS Function value: 3.36673e+54, Step length: 0.0625
sty: 0.25, fy: 1.37901e+58, dgy: 3.30963e+59
4 LS Function value: 8.21955e+50, Step length: 0.015625
sty: 0.0625, fy: 3.36673e+54, dgy: 3.23206e+56
5 LS Function value: 2.00673e+47, Step length: 0.00390625
sty: 0.015625, fy: 8.21955e+50, dgy: 3.15631e+53
6 LS Function value: 4.89924e+43, Step length: 0.000976562
sty: 0.00390625, fy: 2.00673e+47, dgy: 3.08233e+50
7 LS Function value: 1.1961e+40, Step length: 0.000244141
sty: 0.000976562, fy: 4.89924e+43, dgy: 3.01009e+47
8 LS Function value: 2.92017e+36, Step length: 6.10352e-05
sty: 0.000244141, fy: 1.1961e+40, dgy: 2.93954e+44
9 LS Function value: 7.12935e+32, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 2.92017e+36, dgy: 2.87065e+41
10 LS Function value: 1.74058e+29, Step length: 3.8147e-06
sty: 1.52588e-05, fy: 7.12935e+32, dgy: 2.80337e+38
11 LS Function value: 4.24963e+25, Step length: 9.53673e-07
sty: 3.8147e-06, fy: 1.74058e+29, dgy: 2.73769e+35
12 LS Function value: 1.03767e+22, Step length: 2.38417e-07
sty: 9.53673e-07, fy: 4.24963e+25, dgy: 2.67361e+32
13 LS Function value: 2.53493e+18, Step length: 5.9603e-08
sty: 2.38417e-07, fy: 1.03767e+22, dgy: 2.61128e+29
14 LS Function value: 6.2041e+14, Step length: 1.48995e-08
sty: 5.9603e-08, fy: 2.53493e+18, dgy: 2.5514e+26
15 LS Function value: 1.5297e+11, Step length: 3.72365e-09
sty: 1.48995e-08, fy: 6.2041e+14, dgy: 2.49673e+23
16 LS Function value: 3.88459e+07, Step length: 9.29684e-10
sty: 3.72365e-09, fy: 1.5297e+11, dgy: 2.45835e+20
17 LS Function value: 11067.8, Step length: 2.31185e-10
sty: 9.29684e-10, fy: 3.88459e+07, dgy: 2.48079e+17
18 LS Function value: 4.67708, Step length: 5.65509e-11
sty: 2.31185e-10, fy: 11067.8, dgy: 2.75615e+14
19 LS Function value: 0.0991776, Step length: 1.31052e-11
sty: 5.65509e-11, fy: 4.67708, dgy: 4.26014e+11
20 LS Function value: 0.0978498, Step length: 7.17299e-12
sty: 1.31052e-11, fy: 0.0991776, dgy: 8.29029e+08
12 TAO, Function value: 0.0978498, Residual: 0.0383805
0 KSP Residual norm 3.838049529329e-02
1 KSP Residual norm 4.104799670032e-02
2 KSP Residual norm 4.938791921895e-02
3 KSP Residual norm 5.469604838478e-02
4 KSP Residual norm 6.006372259852e-02
5 KSP Residual norm 4.944395630246e-02
6 KSP Residual norm 2.655210689877e-02
7 KSP Residual norm 1.815644470817e-02
8 KSP Residual norm 1.302187120108e-02
9 KSP Residual norm 9.107329952745e-03
10 KSP Residual norm 7.042457288764e-03
11 KSP Residual norm 5.444815362551e-03
12 KSP Residual norm 4.503256172252e-03
13 KSP Residual norm 3.840247386152e-03
14 KSP Residual norm 3.012453902742e-03
15 KSP Residual norm 2.556044756652e-03
16 KSP Residual norm 2.108321742002e-03
17 KSP Residual norm 1.601965217851e-03
18 KSP Residual norm 1.152626232746e-03
19 KSP Residual norm 8.965195982165e-04
20 KSP Residual norm 6.819217178252e-04
21 KSP Residual norm 5.054344452136e-04
22 KSP Residual norm 4.296893654391e-04
23 KSP Residual norm 3.678364140098e-04
24 KSP Residual norm 4.887788399733e-04
25 KSP Residual norm 3.064128031492e-04
26 KSP Residual norm 2.550193981708e-04
27 KSP Residual norm 2.552788692690e-04
28 KSP Residual norm 3.035479838299e-04
29 KSP Residual norm 1.927949597304e-04
30 KSP Residual norm 1.740836866957e-04
31 KSP Residual norm 1.690106661339e-04
32 KSP Residual norm 1.567480922634e-04
33 KSP Residual norm 1.370412550096e-04
34 KSP Residual norm 1.235082436513e-04
35 KSP Residual norm 1.094531819117e-04
36 KSP Residual norm 9.229464050676e-05
37 KSP Residual norm 8.711900575953e-05
38 KSP Residual norm 7.913782298169e-05
39 KSP Residual norm 5.759442548114e-05
40 KSP Residual norm 4.550193282518e-05
41 KSP Residual norm 3.594824027024e-05
42 KSP Residual norm 2.981668814485e-05
43 KSP Residual norm 2.471134378587e-05
44 KSP Residual norm 2.394802748084e-05
45 KSP Residual norm 2.653979472207e-05
46 KSP Residual norm 1.724795601158e-05
47 KSP Residual norm 1.474589242356e-05
48 KSP Residual norm 1.345737942134e-05
49 KSP Residual norm 1.207348932897e-05
50 KSP Residual norm 1.009591326964e-05
51 KSP Residual norm 1.220917080617e-05
52 KSP Residual norm 8.362545258160e-06
53 KSP Residual norm 6.649828398468e-06
54 KSP Residual norm 5.876803447075e-06
55 KSP Residual norm 5.087077865435e-06
56 KSP Residual norm 4.165868771843e-06
57 KSP Residual norm 3.462007153184e-06
58 KSP Residual norm 2.957111557610e-06
59 KSP Residual norm 2.494373559056e-06
60 KSP Residual norm 2.096593840383e-06
61 KSP Residual norm 1.829672825798e-06
62 KSP Residual norm 1.643121524068e-06
63 KSP Residual norm 1.513975481200e-06
64 KSP Residual norm 1.459217350465e-06
65 KSP Residual norm 2.010835774866e-06
66 KSP Residual norm 1.215710323297e-06
67 KSP Residual norm 1.048962607587e-06
68 KSP Residual norm 9.997094747731e-07
69 KSP Residual norm 1.155572428586e-06
70 KSP Residual norm 8.485710636954e-07
71 KSP Residual norm 7.061030275445e-07
72 KSP Residual norm 9.327292762046e-07
73 KSP Residual norm 6.334550315318e-07
74 KSP Residual norm 5.501693071445e-07
75 KSP Residual norm 4.545405963395e-07
76 KSP Residual norm 3.516669724468e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 76
0 LS Function value: 0.0978498, Step length: 0.
1 LS Function value: 0.0922924, Step length: 1.
stx: 0., fx: 0.0978498, dgx: -0.00630624
sty: 0., fy: 0.0978498, dgy: -0.00630624
13 TAO, Function value: 0.0922924, Residual: 0.0210473
0 KSP Residual norm 2.104731401826e-02
1 KSP Residual norm 4.762116742667e-02
2 KSP Residual norm 7.805419541658e-02
3 KSP Residual norm 9.341873721756e-02
4 KSP Residual norm 7.753680063642e-02
5 KSP Residual norm 6.607207685675e-02
6 KSP Residual norm 4.509556138225e-02
7 KSP Residual norm 3.426881469515e-02
8 KSP Residual norm 2.950794056811e-02
9 KSP Residual norm 2.629097306494e-02
10 KSP Residual norm 2.484558360009e-02
11 KSP Residual norm 2.582967158109e-02
12 KSP Residual norm 2.764499090287e-02
13 KSP Residual norm 2.802341904277e-02
14 KSP Residual norm 2.852485024089e-02
15 KSP Residual norm 2.794501907160e-02
16 KSP Residual norm 2.470291940190e-02
17 KSP Residual norm 2.292080716974e-02
18 KSP Residual norm 2.032680124976e-02
19 KSP Residual norm 1.857917699486e-02
20 KSP Residual norm 1.755293279061e-02
21 KSP Residual norm 1.677629420647e-02
22 KSP Residual norm 1.792530288920e-02
23 KSP Residual norm 1.899963434507e-02
24 KSP Residual norm 1.951185380153e-02
25 KSP Residual norm 2.156698731021e-02
26 KSP Residual norm 2.499180352098e-02
27 KSP Residual norm 2.915410223437e-02
28 KSP Residual norm 3.532178860640e-02
29 KSP Residual norm 5.045948033097e-02
30 KSP Residual norm 7.568651642299e-02
31 KSP Residual norm 1.205434866391e-01
Linear tao_nls_ solve converged due to CONVERGED_CG_NEG_CURVE iterations 32
0 LS Function value: 0.0922924, Step length: 0.
stx: 0., fx: 0.0922924, dgx: -4.65993e+07
sty: 0., fy: 0.0922924, dgy: -4.65993e+07
2 LS Function value: 0.0922924, Step length: 0.
1 LS Function value: 0.0919899, Step length: 1.
stx: 0., fx: 0.0922924, dgx: -0.000442989
sty: 0., fy: 0.0922924, dgy: -0.000442989
14 TAO, Function value: 0.0919899, Residual: 0.034581
0 KSP Residual norm 3.458101184870e-02
1 KSP Residual norm 2.193480344616e-02
2 KSP Residual norm 2.708342555381e-02
3 KSP Residual norm 1.407264194222e-02
4 KSP Residual norm 5.477097475015e-03
5 KSP Residual norm 2.465345008426e-03
6 KSP Residual norm 1.441189435782e-03
7 KSP Residual norm 8.076358589676e-04
8 KSP Residual norm 5.726730931957e-04
9 KSP Residual norm 3.435424175489e-04
10 KSP Residual norm 2.361476797000e-04
11 KSP Residual norm 1.712113103646e-04
12 KSP Residual norm 1.089823076167e-04
13 KSP Residual norm 7.523641079404e-05
14 KSP Residual norm 5.717598558250e-05
15 KSP Residual norm 3.923841622241e-05
16 KSP Residual norm 2.757399897918e-05
17 KSP Residual norm 1.759168756333e-05
18 KSP Residual norm 1.030948097443e-05
19 KSP Residual norm 5.769736169778e-06
20 KSP Residual norm 3.166108974466e-06
21 KSP Residual norm 1.849066826681e-06
22 KSP Residual norm 1.030282190249e-06
23 KSP Residual norm 5.935145110659e-07
24 KSP Residual norm 3.583391281969e-07
25 KSP Residual norm 2.103120478293e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 25
0 LS Function value: 0.0919899, Step length: 0.
1 LS Function value: 0.0910633, Step length: 1.
stx: 0., fx: 0.0919899, dgx: -0.00103175
sty: 0., fy: 0.0919899, dgy: -0.00103175
15 TAO, Function value: 0.0910633, Residual: 0.0180023
0 KSP Residual norm 1.800228508702e-02
1 KSP Residual norm 9.068321095304e-02
2 KSP Residual norm 9.283808068772e-02
3 KSP Residual norm 6.512346166228e-02
4 KSP Residual norm 4.370296977616e-02
5 KSP Residual norm 3.747074618107e-02
6 KSP Residual norm 3.000225701036e-02
7 KSP Residual norm 2.820743299845e-02
8 KSP Residual norm 2.685179051907e-02
9 KSP Residual norm 2.560451608593e-02
10 KSP Residual norm 2.643649399607e-02
11 KSP Residual norm 2.843854700871e-02
12 KSP Residual norm 2.890744781333e-02
13 KSP Residual norm 2.863583040828e-02
14 KSP Residual norm 2.756901280202e-02
15 KSP Residual norm 2.424478703160e-02
16 KSP Residual norm 2.225795689885e-02
17 KSP Residual norm 2.075177866603e-02
18 KSP Residual norm 1.874495853208e-02
19 KSP Residual norm 1.833563213764e-02
20 KSP Residual norm 1.882702118296e-02
21 KSP Residual norm 2.036901127505e-02
22 KSP Residual norm 2.197692132504e-02
23 KSP Residual norm 2.478672937404e-02
24 KSP Residual norm 2.819390292106e-02
25 KSP Residual norm 3.627960119683e-02
26 KSP Residual norm 5.228600493564e-02
27 KSP Residual norm 8.941018771950e-02
28 KSP Residual norm 2.724033285836e-01
0 LS Function value: 0.0910633, Step length: 0.
stx: 0., fx: 0.0910633, dgx: -5.0133e+07
sty: 0., fy: 0.0910633, dgy: -5.0133e+07
2 LS Function value: 0.0910633, Step length: 0.
1 LS Function value: 0.0907574, Step length: 1.
stx: 0., fx: 0.0910633, dgx: -0.000324082
sty: 0., fy: 0.0910633, dgy: -0.000324082
16 TAO, Function value: 0.0907574, Residual: 0.0190785
0 KSP Residual norm 1.907846986553e-02
1 KSP Residual norm 2.993864919749e-02
2 KSP Residual norm 1.834030942810e-02
3 KSP Residual norm 3.974075504154e-03
4 KSP Residual norm 1.525670251714e-03
5 KSP Residual norm 9.302168102960e-04
6 KSP Residual norm 7.980673364711e-04
7 KSP Residual norm 4.911592111207e-04
8 KSP Residual norm 2.359070053256e-04
9 KSP Residual norm 1.676705578307e-04
10 KSP Residual norm 9.591291567021e-05
11 KSP Residual norm 5.157180839109e-05
12 KSP Residual norm 3.088532939585e-05
13 KSP Residual norm 1.863863172393e-05
14 KSP Residual norm 1.002927489864e-05
15 KSP Residual norm 5.258525450171e-06
16 KSP Residual norm 3.277185574003e-06
17 KSP Residual norm 1.941023710434e-06
18 KSP Residual norm 1.153030802774e-06
19 KSP Residual norm 7.344864704914e-07
20 KSP Residual norm 4.656051782025e-07
21 KSP Residual norm 2.823114387057e-07
22 KSP Residual norm 1.591569325673e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 22
0 LS Function value: 0.0907574, Step length: 0.
1 LS Function value: 0.0899364, Step length: 1.
stx: 0., fx: 0.0907574, dgx: -0.000844974
sty: 0., fy: 0.0907574, dgy: -0.000844974
2 LS Function value: 0.0871243, Step length: 5.
stx: 1., fx: 0.0899364, dgx: -0.000797183
17 TAO, Function value: 0.0871243, Residual: 0.0288583
0 KSP Residual norm 2.885825081697e-02
1 KSP Residual norm 1.787381016414e-02
2 KSP Residual norm 3.823406540207e-02
3 KSP Residual norm 7.251101825671e-02
4 KSP Residual norm 6.968475840244e-02
5 KSP Residual norm 5.545284692751e-02
6 KSP Residual norm 4.011986642084e-02
7 KSP Residual norm 3.359538088814e-02
8 KSP Residual norm 2.865276564604e-02
9 KSP Residual norm 2.292818092292e-02
10 KSP Residual norm 2.300983089426e-02
11 KSP Residual norm 2.826726407450e-02
12 KSP Residual norm 2.987926720878e-02
13 KSP Residual norm 3.530692256318e-02
14 KSP Residual norm 5.118816964047e-02
15 KSP Residual norm 9.997102642267e-02
16 KSP Residual norm 1.159128427850e+00
0 LS Function value: 0.0871243, Step length: 0.
1 LS Function value: 3.5207e+60, Step length: 1.
stx: 0., fx: 0.0871243, dgx: -7.9283e+07
sty: 0., fy: 0.0871243, dgy: -7.9283e+07
2 LS Function value: 8.59546e+56, Step length: 0.25
sty: 1., fy: 3.5207e+60, dgy: 2.11242e+61
3 LS Function value: 2.0985e+53, Step length: 0.0625
sty: 0.25, fy: 8.59546e+56, dgy: 2.06291e+58
4 LS Function value: 5.12329e+49, Step length: 0.015625
sty: 0.0625, fy: 2.0985e+53, dgy: 2.01456e+55
5 LS Function value: 1.2508e+46, Step length: 0.00390625
sty: 0.015625, fy: 5.12329e+49, dgy: 1.96734e+52
6 LS Function value: 3.05372e+42, Step length: 0.000976562
sty: 0.00390625, fy: 1.2508e+46, dgy: 1.92124e+49
7 LS Function value: 7.45538e+38, Step length: 0.000244141
sty: 0.000976562, fy: 3.05372e+42, dgy: 1.87621e+46
8 LS Function value: 1.82016e+35, Step length: 6.10352e-05
sty: 0.000244141, fy: 7.45538e+38, dgy: 1.83223e+43
9 LS Function value: 4.44379e+31, Step length: 1.52588e-05
sty: 6.10352e-05, fy: 1.82016e+35, dgy: 1.78929e+40
10 LS Function value: 1.08493e+28, Step length: 3.81469e-06
sty: 1.52588e-05, fy: 4.44379e+31, dgy: 1.74736e+37
11 LS Function value: 2.64903e+24, Step length: 9.5367e-07
sty: 3.81469e-06, fy: 1.08493e+28, dgy: 1.70645e+34
12 LS Function value: 6.46988e+20, Step length: 2.38414e-07
sty: 9.5367e-07, fy: 2.64903e+24, dgy: 1.66659e+31
13 LS Function value: 1.58203e+17, Step length: 5.96005e-08
sty: 2.38414e-07, fy: 6.46988e+20, dgy: 1.62806e+28
14 LS Function value: 3.88665e+13, Step length: 1.4897e-08
sty: 5.96005e-08, fy: 1.58203e+17, dgy: 1.59197e+25
15 LS Function value: 9.72997e+09, Step length: 3.72114e-09
sty: 1.4897e-08, fy: 3.88665e+13, dgy: 1.56279e+22
16 LS Function value: 2.62659e+06, Step length: 9.27139e-10
sty: 3.72114e-09, fy: 9.72997e+09, dgy: 1.55837e+19
17 LS Function value: 941.405, Step length: 2.2856e-10
sty: 9.27139e-10, fy: 2.62659e+06, dgy: 1.6544e+16
18 LS Function value: 0.725101, Step length: 5.38881e-11
sty: 2.2856e-10, fy: 941.405, dgy: 2.23077e+13
19 LS Function value: 0.0867106, Step length: 1.14839e-11
sty: 5.38881e-11, fy: 0.725101, dgy: 5.60936e+10
20 LS Function value: 0.0867388, Step length: 5.18834e-12
stx: 1.14839e-11, fx: 0.0867106, dgx: 9.62026e+07
18 TAO, Function value: 0.0867388, Residual: 0.0244321
0 KSP Residual norm 2.443205168743e-02
1 KSP Residual norm 2.098412667069e-02
2 KSP Residual norm 3.550481833459e-02
3 KSP Residual norm 4.449498111753e-02
4 KSP Residual norm 4.744984132717e-02
5 KSP Residual norm 3.919343896916e-02
6 KSP Residual norm 2.955187338457e-02
7 KSP Residual norm 2.241122590159e-02
8 KSP Residual norm 1.622604540401e-02
9 KSP Residual norm 1.247074792844e-02
10 KSP Residual norm 1.075859597631e-02
11 KSP Residual norm 9.123144854965e-03
12 KSP Residual norm 7.985132614603e-03
13 KSP Residual norm 7.380880572793e-03
14 KSP Residual norm 6.994755809795e-03
15 KSP Residual norm 6.719142800910e-03
16 KSP Residual norm 6.834025097084e-03
17 KSP Residual norm 5.963962145241e-03
18 KSP Residual norm 5.238014004998e-03
19 KSP Residual norm 4.389508841164e-03
20 KSP Residual norm 3.601994569453e-03
21 KSP Residual norm 2.943461835063e-03
22 KSP Residual norm 2.505326372737e-03
23 KSP Residual norm 2.109494808777e-03
24 KSP Residual norm 1.873094496220e-03
25 KSP Residual norm 1.581570491324e-03
26 KSP Residual norm 1.468213054471e-03
27 KSP Residual norm 1.388993584103e-03
28 KSP Residual norm 1.199780321863e-03
29 KSP Residual norm 1.094491663719e-03
30 KSP Residual norm 9.507674076599e-04
31 KSP Residual norm 8.363266381063e-04
32 KSP Residual norm 7.234390599953e-04
33 KSP Residual norm 6.173853729052e-04
34 KSP Residual norm 5.289363732769e-04
35 KSP Residual norm 4.626176220146e-04
36 KSP Residual norm 4.151986725873e-04
37 KSP Residual norm 3.767594534228e-04
38 KSP Residual norm 3.694026843925e-04
39 KSP Residual norm 3.446645632772e-04
40 KSP Residual norm 3.024162828939e-04
41 KSP Residual norm 2.552520881171e-04
42 KSP Residual norm 2.236216926729e-04
43 KSP Residual norm 2.102056460919e-04
44 KSP Residual norm 1.886099491633e-04
45 KSP Residual norm 1.638601602017e-04
46 KSP Residual norm 1.457164558366e-04
47 KSP Residual norm 1.409569431264e-04
48 KSP Residual norm 1.291515114299e-04
49 KSP Residual norm 1.132431463990e-04
50 KSP Residual norm 1.076177919634e-04
51 KSP Residual norm 1.058367189894e-04
52 KSP Residual norm 1.002891393287e-04
53 KSP Residual norm 9.438385355118e-05
54 KSP Residual norm 9.013769617815e-05
55 KSP Residual norm 8.518449850926e-05
56 KSP Residual norm 8.183160209919e-05
57 KSP Residual norm 8.129743551771e-05
58 KSP Residual norm 7.852736007598e-05
59 KSP Residual norm 7.399090170848e-05
60 KSP Residual norm 7.083405084731e-05
61 KSP Residual norm 6.855686587362e-05
62 KSP Residual norm 6.628854223829e-05
63 KSP Residual norm 6.373858125434e-05
64 KSP Residual norm 5.955252962102e-05
65 KSP Residual norm 5.595502959016e-05
66 KSP Residual norm 5.273029818308e-05
67 KSP Residual norm 5.152508564920e-05
68 KSP Residual norm 5.164750423179e-05
69 KSP Residual norm 4.616860130697e-05
70 KSP Residual norm 4.336740952452e-05
71 KSP Residual norm 3.713874840003e-05
72 KSP Residual norm 3.231183700152e-05
73 KSP Residual norm 2.891791412701e-05
74 KSP Residual norm 2.484688885620e-05
75 KSP Residual norm 2.162171350374e-05
76 KSP Residual norm 1.960899815821e-05
77 KSP Residual norm 1.716428745834e-05
78 KSP Residual norm 1.484021101696e-05
79 KSP Residual norm 1.401693245409e-05
80 KSP Residual norm 1.350966223895e-05
81 KSP Residual norm 1.143428717858e-05
82 KSP Residual norm 9.777630210565e-06
83 KSP Residual norm 8.442757391392e-06
84 KSP Residual norm 7.373747795081e-06
85 KSP Residual norm 6.422221523504e-06
86 KSP Residual norm 5.649564526103e-06
87 KSP Residual norm 5.178762104662e-06
88 KSP Residual norm 4.980684797390e-06
89 KSP Residual norm 4.271601807602e-06
90 KSP Residual norm 3.587863603931e-06
91 KSP Residual norm 3.206925582557e-06
92 KSP Residual norm 2.897865760379e-06
93 KSP Residual norm 2.583803834558e-06
94 KSP Residual norm 2.314927961747e-06
95 KSP Residual norm 2.156994036331e-06
96 KSP Residual norm 2.093936038564e-06
97 KSP Residual norm 1.859433216891e-06
98 KSP Residual norm 1.647119655346e-06
99 KSP Residual norm 1.510774691190e-06
100 KSP Residual norm 1.487121116955e-06
101 KSP Residual norm 1.627605267029e-06
102 KSP Residual norm 1.330081441829e-06
103 KSP Residual norm 1.208810482093e-06
104 KSP Residual norm 1.118213568637e-06
105 KSP Residual norm 1.057846555641e-06
106 KSP Residual norm 1.022428137110e-06
107 KSP Residual norm 9.795011556394e-07
108 KSP Residual norm 9.420356749493e-07
109 KSP Residual norm 9.304714955541e-07
110 KSP Residual norm 9.074147785036e-07
111 KSP Residual norm 8.800538164074e-07
112 KSP Residual norm 9.056694274851e-07
113 KSP Residual norm 8.573809759637e-07
114 KSP Residual norm 7.866113308931e-07
115 KSP Residual norm 7.534842260477e-07
116 KSP Residual norm 7.280994039316e-07
117 KSP Residual norm 6.991017285709e-07
118 KSP Residual norm 6.773801519886e-07
119 KSP Residual norm 6.668570487323e-07
120 KSP Residual norm 6.375984528746e-07
121 KSP Residual norm 5.991947631821e-07
122 KSP Residual norm 5.803340196580e-07
123 KSP Residual norm 5.712932887997e-07
124 KSP Residual norm 5.202887279150e-07
125 KSP Residual norm 4.749171587413e-07
126 KSP Residual norm 4.454554160414e-07
127 KSP Residual norm 4.212596024903e-07
128 KSP Residual norm 4.048308537421e-07
129 KSP Residual norm 3.995840666130e-07
130 KSP Residual norm 3.648104838909e-07
131 KSP Residual norm 3.410422305249e-07
132 KSP Residual norm 3.693867293102e-07
133 KSP Residual norm 3.370045614642e-07
134 KSP Residual norm 2.967687471120e-07
135 KSP Residual norm 2.987846241803e-07
136 KSP Residual norm 2.611519136962e-07
137 KSP Residual norm 2.239724548782e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 137
0 LS Function value: 0.0867388, Step length: 0.
1 LS Function value: 0.0809674, Step length: 1.
stx: 0., fx: 0.0867388, dgx: -0.00689219
sty: 0., fy: 0.0867388, dgy: -0.00689219
19 TAO, Function value: 0.0809674, Residual: 0.0162138
0 KSP Residual norm 1.621375913830e-02
1 KSP Residual norm 1.472926869900e-02
2 KSP Residual norm 2.489620045278e-02
3 KSP Residual norm 3.264210913469e-02
4 KSP Residual norm 4.691607813644e-02
5 KSP Residual norm 4.864488156873e-02
6 KSP Residual norm 4.279412830955e-02
7 KSP Residual norm 3.753865445913e-02
8 KSP Residual norm 2.956096746190e-02
9 KSP Residual norm 2.227057559151e-02
10 KSP Residual norm 1.979117558582e-02
11 KSP Residual norm 1.727546980567e-02
12 KSP Residual norm 1.549831736040e-02
13 KSP Residual norm 1.509841309612e-02
14 KSP Residual norm 1.522273445772e-02
15 KSP Residual norm 1.609439823743e-02
16 KSP Residual norm 1.580719639807e-02
17 KSP Residual norm 1.610435696503e-02
18 KSP Residual norm 1.616507450818e-02
19 KSP Residual norm 1.658166234839e-02
20 KSP Residual norm 1.518837353600e-02
21 KSP Residual norm 1.388042820769e-02
22 KSP Residual norm 1.254229422319e-02
23 KSP Residual norm 1.093224683690e-02
24 KSP Residual norm 1.001314559300e-02
25 KSP Residual norm 9.365647830833e-03
26 KSP Residual norm 8.655475085946e-03
27 KSP Residual norm 8.273465941441e-03
28 KSP Residual norm 8.120959899553e-03
29 KSP Residual norm 7.824217015145e-03
30 KSP Residual norm 7.516097275515e-03
31 KSP Residual norm 7.384123911063e-03
32 KSP Residual norm 7.106892484422e-03
33 KSP Residual norm 6.902145823070e-03
34 KSP Residual norm 6.791030051755e-03
35 KSP Residual norm 6.472555108770e-03
36 KSP Residual norm 6.117263190847e-03
37 KSP Residual norm 5.589326131006e-03
38 KSP Residual norm 5.222860092445e-03
39 KSP Residual norm 5.024456109631e-03
40 KSP Residual norm 4.733854064865e-03
41 KSP Residual norm 4.568710485238e-03
42 KSP Residual norm 4.299548685102e-03
43 KSP Residual norm 4.057366882444e-03
44 KSP Residual norm 3.986768357381e-03
45 KSP Residual norm 3.809519131726e-03
46 KSP Residual norm 3.714237552070e-03
47 KSP Residual norm 3.539107717747e-03
48 KSP Residual norm 3.370390100506e-03
49 KSP Residual norm 3.358157889590e-03
50 KSP Residual norm 3.171176009816e-03
51 KSP Residual norm 3.173946444129e-03
52 KSP Residual norm 2.990008909875e-03
53 KSP Residual norm 2.677285780687e-03
54 KSP Residual norm 2.587009069929e-03
55 KSP Residual norm 2.372212085356e-03
56 KSP Residual norm 2.158974131965e-03
57 KSP Residual norm 2.047930447151e-03
58 KSP Residual norm 2.002166037376e-03
59 KSP Residual norm 1.967913538637e-03
60 KSP Residual norm 1.941164063521e-03
61 KSP Residual norm 1.976908718776e-03
62 KSP Residual norm 1.728658165032e-03
63 KSP Residual norm 1.596515506104e-03
64 KSP Residual norm 1.548359619684e-03
65 KSP Residual norm 1.453004223063e-03
66 KSP Residual norm 1.343609526689e-03
67 KSP Residual norm 1.271767580760e-03
68 KSP Residual norm 1.226754255879e-03
69 KSP Residual norm 1.147873032723e-03
70 KSP Residual norm 1.086101376524e-03
71 KSP Residual norm 1.050795883128e-03
72 KSP Residual norm 9.868412701650e-04
73 KSP Residual norm 9.353973449520e-04
74 KSP Residual norm 9.029708391749e-04
75 KSP Residual norm 8.604371341705e-04
76 KSP Residual norm 8.222866963896e-04
77 KSP Residual norm 7.796725295591e-04
78 KSP Residual norm 7.527980690896e-04
79 KSP Residual norm 7.719531411983e-04
80 KSP Residual norm 6.953712525787e-04
81 KSP Residual norm 6.333942032963e-04
82 KSP Residual norm 5.875830197250e-04
83 KSP Residual norm 5.537186923068e-04
84 KSP Residual norm 5.389118931914e-04
85 KSP Residual norm 5.076374696123e-04
86 KSP Residual norm 4.698451982996e-04
87 KSP Residual norm 4.448618929755e-04
88 KSP Residual norm 4.192194161709e-04
89 KSP Residual norm 3.985375954084e-04
90 KSP Residual norm 4.023854615544e-04
91 KSP Residual norm 4.139017126040e-04
92 KSP Residual norm 3.730307257292e-04
93 KSP Residual norm 3.326518657653e-04
94 KSP Residual norm 3.058378344981e-04
95 KSP Residual norm 2.903482238100e-04
96 KSP Residual norm 2.770146026247e-04
97 KSP Residual norm 2.671140038795e-04
98 KSP Residual norm 2.702191464576e-04
99 KSP Residual norm 2.439903758672e-04
100 KSP Residual norm 2.213485349506e-04
101 KSP Residual norm 2.083127539612e-04
102 KSP Residual norm 1.975866139856e-04
103 KSP Residual norm 1.995921856788e-04
104 KSP Residual norm 1.954061655249e-04
105 KSP Residual norm 1.706098220960e-04
106 KSP Residual norm 1.582846558607e-04
107 KSP Residual norm 1.601373565066e-04
108 KSP Residual norm 1.666442147218e-04
109 KSP Residual norm 1.471148032905e-04
110 KSP Residual norm 1.333989842713e-04
111 KSP Residual norm 1.235317840275e-04
112 KSP Residual norm 1.162957588071e-04
113 KSP Residual norm 1.092803452853e-04
114 KSP Residual norm 1.023563749302e-04
115 KSP Residual norm 9.844909355496e-05
116 KSP Residual norm 9.471395468647e-05
117 KSP Residual norm 9.123338612223e-05
118 KSP Residual norm 9.028822612359e-05
119 KSP Residual norm 8.301074912340e-05
120 KSP Residual norm 7.565221584516e-05
121 KSP Residual norm 6.980563885475e-05
122 KSP Residual norm 6.626502831360e-05
123 KSP Residual norm 6.897822827714e-05
124 KSP Residual norm 6.387776490919e-05
125 KSP Residual norm 5.649795181269e-05
126 KSP Residual norm 5.318611215633e-05
127 KSP Residual norm 5.361540672157e-05
128 KSP Residual norm 5.365505299439e-05
129 KSP Residual norm 4.715370202651e-05
130 KSP Residual norm 4.719727078023e-05
131 KSP Residual norm 4.657869315154e-05
132 KSP Residual norm 4.148490129667e-05
133 KSP Residual norm 3.919785225931e-05
134 KSP Residual norm 3.828008915271e-05
135 KSP Residual norm 3.913180022224e-05
136 KSP Residual norm 3.374370065994e-05
137 KSP Residual norm 3.103461956946e-05
138 KSP Residual norm 3.085751347389e-05
139 KSP Residual norm 2.933385030587e-05
140 KSP Residual norm 2.620221958126e-05
141 KSP Residual norm 2.421424356758e-05
142 KSP Residual norm 2.294184704873e-05
143 KSP Residual norm 2.272085213447e-05
144 KSP Residual norm 2.244823342353e-05
145 KSP Residual norm 1.989328225117e-05
146 KSP Residual norm 1.812209589374e-05
147 KSP Residual norm 1.710250816242e-05
148 KSP Residual norm 1.720545748453e-05
149 KSP Residual norm 1.723564809425e-05
150 KSP Residual norm 1.479998243349e-05
151 KSP Residual norm 1.393470739727e-05
152 KSP Residual norm 1.371702490494e-05
153 KSP Residual norm 1.334117340177e-05
154 KSP Residual norm 1.399083820869e-05
155 KSP Residual norm 1.237232625378e-05
156 KSP Residual norm 1.113608002719e-05
157 KSP Residual norm 1.036025857388e-05
158 KSP Residual norm 9.750507097203e-06
159 KSP Residual norm 9.291078212706e-06
160 KSP Residual norm 8.801083907076e-06
161 KSP Residual norm 8.299569804609e-06
162 KSP Residual norm 7.798953504282e-06
163 KSP Residual norm 7.399777170972e-06
164 KSP Residual norm 7.071340562071e-06
165 KSP Residual norm 6.836414567777e-06
166 KSP Residual norm 6.754703176097e-06
167 KSP Residual norm 6.463366170149e-06
168 KSP Residual norm 5.795644087926e-06
169 KSP Residual norm 5.474363554643e-06
170 KSP Residual norm 5.764454465144e-06
171 KSP Residual norm 5.285383091661e-06
172 KSP Residual norm 4.763196195142e-06
173 KSP Residual norm 5.152095848793e-06
174 KSP Residual norm 4.653082901866e-06
175 KSP Residual norm 4.086186712483e-06
176 KSP Residual norm 3.794861291773e-06
177 KSP Residual norm 3.569657018458e-06
178 KSP Residual norm 3.582976629071e-06
179 KSP Residual norm 3.408688148470e-06
180 KSP Residual norm 3.011549356551e-06
181 KSP Residual norm 2.859123050179e-06
182 KSP Residual norm 3.007483302729e-06
183 KSP Residual norm 2.766281841933e-06
184 KSP Residual norm 2.439884517668e-06
185 KSP Residual norm 2.438783551956e-06
186 KSP Residual norm 2.510643031105e-06
187 KSP Residual norm 2.135424046604e-06
188 KSP Residual norm 1.988150747647e-06
189 KSP Residual norm 1.949511580488e-06
190 KSP Residual norm 1.831192427254e-06
191 KSP Residual norm 1.674347480226e-06
192 KSP Residual norm 1.539890417214e-06
193 KSP Residual norm 1.424107016294e-06
194 KSP Residual norm 1.356193309816e-06
195 KSP Residual norm 1.402363423941e-06
196 KSP Residual norm 1.419456141246e-06
197 KSP Residual norm 1.244023340500e-06
198 KSP Residual norm 1.184867097718e-06
199 KSP Residual norm 1.077187213685e-06
200 KSP Residual norm 9.952581708702e-07
201 KSP Residual norm 9.871085487694e-07
202 KSP Residual norm 9.777032479241e-07
203 KSP Residual norm 8.776088744173e-07
204 KSP Residual norm 7.933278828459e-07
205 KSP Residual norm 7.328680803172e-07
206 KSP Residual norm 6.933439225574e-07
207 KSP Residual norm 6.644044235998e-07
208 KSP Residual norm 6.476611724203e-07
209 KSP Residual norm 6.253775817192e-07
210 KSP Residual norm 5.623548537876e-07
211 KSP Residual norm 5.181117822086e-07
212 KSP Residual norm 5.103747420090e-07
213 KSP Residual norm 5.684942834223e-07
214 KSP Residual norm 4.874166085899e-07
215 KSP Residual norm 4.275815604314e-07
216 KSP Residual norm 4.057050022012e-07
217 KSP Residual norm 4.141514548087e-07
218 KSP Residual norm 3.949205742070e-07
219 KSP Residual norm 3.502690905396e-07
220 KSP Residual norm 3.360994277785e-07
221 KSP Residual norm 3.280813436068e-07
222 KSP Residual norm 3.099397905134e-07
223 KSP Residual norm 2.945209646346e-07
224 KSP Residual norm 2.823546594372e-07
225 KSP Residual norm 2.676996609678e-07
226 KSP Residual norm 2.478964564277e-07
227 KSP Residual norm 2.290270722763e-07
228 KSP Residual norm 2.189266702670e-07
229 KSP Residual norm 2.271525741752e-07
230 KSP Residual norm 2.084069338265e-07
231 KSP Residual norm 1.843658554370e-07
232 KSP Residual norm 1.782107398697e-07
233 KSP Residual norm 1.825744843132e-07
234 KSP Residual norm 1.774420902334e-07
235 KSP Residual norm 1.673978126777e-07
236 KSP Residual norm 1.547080608974e-07
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 236
0 LS Function value: 0.0809674, Step length: 0.
1 LS Function value: 0.0723695, Step length: 1.
stx: 0., fx: 0.0809674, dgx: -0.0121733
sty: 0., fy: 0.0809674, dgy: -0.0121733
20 TAO, Function value: 0.0723695, Residual: 0.00674339
0 KSP Residual norm 6.743394279342e-03
1 KSP Residual norm 8.031145698634e-03
2 KSP Residual norm 7.983449565965e-03
3 KSP Residual norm 8.586847748130e-03
4 KSP Residual norm 1.210574973609e-02
5 KSP Residual norm 1.479735793403e-02
6 KSP Residual norm 1.576476274775e-02
7 KSP Residual norm 1.747409404639e-02
8 KSP Residual norm 1.934169325233e-02
9 KSP Residual norm 1.914380847899e-02
10 KSP Residual norm 1.869892808965e-02
11 KSP Residual norm 1.683617800576e-02
12 KSP Residual norm 1.469448498502e-02
13 KSP Residual norm 1.309639986035e-02
14 KSP Residual norm 1.210868315374e-02
15 KSP Residual norm 1.043678457354e-02
16 KSP Residual norm 9.340625236657e-03
17 KSP Residual norm 8.606388328567e-03
18 KSP Residual norm 7.765564892629e-03
19 KSP Residual norm 7.086746729371e-03
20 KSP Residual norm 6.882955380600e-03
21 KSP Residual norm 6.823590172361e-03
22 KSP Residual norm 6.290691190763e-03
23 KSP Residual norm 5.965723789865e-03
24 KSP Residual norm 5.954806607501e-03
25 KSP Residual norm 6.044083397239e-03
26 KSP Residual norm 6.121487702575e-03
27 KSP Residual norm 6.144924766705e-03
28 KSP Residual norm 6.073574557921e-03
29 KSP Residual norm 5.963437567910e-03
30 KSP Residual norm 5.952578468834e-03
31 KSP Residual norm 5.886331268600e-03
32 KSP Residual norm 5.567724193485e-03
33 KSP Residual norm 5.323209456259e-03
34 KSP Residual norm 5.228731426837e-03
35 KSP Residual norm 5.014736599273e-03
36 KSP Residual norm 4.762867018253e-03
37 KSP Residual norm 4.661529321769e-03
38 KSP Residual norm 4.362096998226e-03
39 KSP Residual norm 4.122504685031e-03
40 KSP Residual norm 4.024272378339e-03
41 KSP Residual norm 3.784283469237e-03
42 KSP Residual norm 3.531702600465e-03
43 KSP Residual norm 3.397738623354e-03
44 KSP Residual norm 3.306046103667e-03
45 KSP Residual norm 3.184113484056e-03
46 KSP Residual norm 3.085057906081e-03
47 KSP Residual norm 2.979186382690e-03
48 KSP Residual norm 2.859437829483e-03
49 KSP Residual norm 2.777432249445e-03
50 KSP Residual norm 2.712585249570e-03
51 KSP Residual norm 2.622956254302e-03
52 KSP Residual norm 2.520537477490e-03
53 KSP Residual norm 2.432300652996e-03
54 KSP Residual norm 2.361450534138e-03
55 KSP Residual norm 2.264029509550e-03
56 KSP Residual norm 2.144052358262e-03
57 KSP Residual norm 2.049580643376e-03
58 KSP Residual norm 1.969660754077e-03
59 KSP Residual norm 1.872241458173e-03
60 KSP Residual norm 1.805836018502e-03
61 KSP Residual norm 1.796343475662e-03
62 KSP Residual norm 1.776001741024e-03
63 KSP Residual norm 1.636474258060e-03
64 KSP Residual norm 1.512868017769e-03
65 KSP Residual norm 1.454327119061e-03
66 KSP Residual norm 1.406999938375e-03
67 KSP Residual norm 1.354488502642e-03
68 KSP Residual norm 1.299011119939e-03
69 KSP Residual norm 1.232421762563e-03
70 KSP Residual norm 1.181421037271e-03
71 KSP Residual norm 1.150255939321e-03
72 KSP Residual norm 1.102362793786e-03
73 KSP Residual norm 1.053444848859e-03
74 KSP Residual norm 1.043029802494e-03
75 KSP Residual norm 1.063076503340e-03
76 KSP Residual norm 1.004503391012e-03
77 KSP Residual norm 9.228127007466e-04
78 KSP Residual norm 8.741763725491e-04
79 KSP Residual norm 8.317937680257e-04
80 KSP Residual norm 7.887856118968e-04
81 KSP Residual norm 7.882960865872e-04
82 KSP Residual norm 8.072417565850e-04
83 KSP Residual norm 6.995780662433e-04
84 KSP Residual norm 6.429824502743e-04
85 KSP Residual norm 6.194619770444e-04
86 KSP Residual norm 5.948847158061e-04
87 KSP Residual norm 5.644215581513e-04
88 KSP Residual norm 5.399983099766e-04
89 KSP Residual norm 5.188432350401e-04
90 KSP Residual norm 4.913849985804e-04
91 KSP Residual norm 4.655727631133e-04
92 KSP Residual norm 4.472478727005e-04
93 KSP Residual norm 4.302777420459e-04
94 KSP Residual norm 4.115793544969e-04
95 KSP Residual norm 3.956674260245e-04
96 KSP Residual norm 3.926342106890e-04
97 KSP Residual norm 3.923518231611e-04
98 KSP Residual norm 3.673398891163e-04
99 KSP Residual norm 3.418645602961e-04
100 KSP Residual norm 3.247022943826e-04
101 KSP Residual norm 3.213601533994e-04
102 KSP Residual norm 3.184059584018e-04
103 KSP Residual norm 2.906787945433e-04
104 KSP Residual norm 2.712693595875e-04
105 KSP Residual norm 2.607260191332e-04
106 KSP Residual norm 2.476225072733e-04
107 KSP Residual norm 2.339049870962e-04
108 KSP Residual norm 2.236964606894e-04
109 KSP Residual norm 2.152200401165e-04
110 KSP Residual norm 2.101230772531e-04
111 KSP Residual norm 2.127334789627e-04
112 KSP Residual norm 2.139460713316e-04
113 KSP Residual norm 1.931286100659e-04
114 KSP Residual norm 1.820229510244e-04
115 KSP Residual norm 1.793569250944e-04
116 KSP Residual norm 1.777603197878e-04
117 KSP Residual norm 1.617706948238e-04
118 KSP Residual norm 1.491980908578e-04
119 KSP Residual norm 1.434612952726e-04
120 KSP Residual norm 1.390423693985e-04
121 KSP Residual norm 1.378483227422e-04
122 KSP Residual norm 1.337917548449e-04
123 KSP Residual norm 1.220805779403e-04
124 KSP Residual norm 1.148902573223e-04
125 KSP Residual norm 1.093049189600e-04
126 KSP Residual norm 1.036022862897e-04
127 KSP Residual norm 9.861497671300e-05
128 KSP Residual norm 9.489895976409e-05
129 KSP Residual norm 9.153729956604e-05
130 KSP Residual norm 9.081859697137e-05
131 KSP Residual norm 9.462248445483e-05
132 KSP Residual norm 8.741433436627e-05
133 KSP Residual norm 7.888641159381e-05
134 KSP Residual norm 7.503751248122e-05
135 KSP Residual norm 7.210586816065e-05
136 KSP Residual norm 7.324493830842e-05
137 KSP Residual norm 7.516823679117e-05
138 KSP Residual norm 6.729595461943e-05
139 KSP Residual norm 6.218970105571e-05
140 KSP Residual norm 5.879279469449e-05
141 KSP Residual norm 5.667469886889e-05
142 KSP Residual norm 5.678535469907e-05
143 KSP Residual norm 5.556662742287e-05
144 KSP Residual norm 5.151942805708e-05
145 KSP Residual norm 4.830383661594e-05
146 KSP Residual norm 4.582688345541e-05
147 KSP Residual norm 4.374368804256e-05
148 KSP Residual norm 4.210470225323e-05
149 KSP Residual norm 4.066131320298e-05
150 KSP Residual norm 3.924860487420e-05
151 KSP Residual norm 3.876598939558e-05
152 KSP Residual norm 3.854885190670e-05
153 KSP Residual norm 3.590797857002e-05
154 KSP Residual norm 3.332267191238e-05
155 KSP Residual norm 3.187504639207e-05
156 KSP Residual norm 3.081467054979e-05
157 KSP Residual norm 2.970947802200e-05
158 KSP Residual norm 2.930399038627e-05
159 KSP Residual norm 2.933284417756e-05
160 KSP Residual norm 2.756651221102e-05
161 KSP Residual norm 2.622954799233e-05
162 KSP Residual norm 2.460371783641e-05
163 KSP Residual norm 2.267985263447e-05
164 KSP Residual norm 2.124169720859e-05
165 KSP Residual norm 1.999238254372e-05
166 KSP Residual norm 1.889970728685e-05
167 KSP Residual norm 1.796897582151e-05
168 KSP Residual norm 1.729612913348e-05
169 KSP Residual norm 1.720418429129e-05
170 KSP Residual norm 1.714096457901e-05
171 KSP Residual norm 1.566721737272e-05
172 KSP Residual norm 1.474948084057e-05
173 KSP Residual norm 1.456994564373e-05
174 KSP Residual norm 1.371593056314e-05
175 KSP Residual norm 1.261296686042e-05
176 KSP Residual norm 1.188927281891e-05
177 KSP Residual norm 1.151700045632e-05
178 KSP Residual norm 1.165979442427e-05
179 KSP Residual norm 1.116138720596e-05
180 KSP Residual norm 1.005029991702e-05
181 KSP Residual norm 9.442679074519e-06
182 KSP Residual norm 9.112891149997e-06
183 KSP Residual norm 9.114293063327e-06
184 KSP Residual norm 8.763517277679e-06
185 KSP Residual norm 8.139047182698e-06
186 KSP Residual norm 8.235570688381e-06
187 KSP Residual norm 8.088393203465e-06
188 KSP Residual norm 7.193272245938e-06
189 KSP Residual norm 6.741658342438e-06
190 KSP Residual norm 6.385947521060e-06
191 KSP Residual norm 6.120283594843e-06
192 KSP Residual norm 6.026144095286e-06
193 KSP Residual norm 5.847436301869e-06
194 KSP Residual norm 5.509246004853e-06
195 KSP Residual norm 5.397319201405e-06
196 KSP Residual norm 5.415467042262e-06
197 KSP Residual norm 4.916233581957e-06
198 KSP Residual norm 4.553008027912e-06
199 KSP Residual norm 4.622757710411e-06
200 KSP Residual norm 4.575393866155e-06
201 KSP Residual norm 4.054496225413e-06
202 KSP Residual norm 3.819954184747e-06
203 KSP Residual norm 3.663703122318e-06
204 KSP Residual norm 3.614040671877e-06
205 KSP Residual norm 3.678484138432e-06
206 KSP Residual norm 3.436520031050e-06
207 KSP Residual norm 3.232906020169e-06
208 KSP Residual norm 3.186990314730e-06
209 KSP Residual norm 3.019549432250e-06
210 KSP Residual norm 2.807953256822e-06
211 KSP Residual norm 2.661741219978e-06
212 KSP Residual norm 2.607439367431e-06
213 KSP Residual norm 2.796766662012e-06
214 KSP Residual norm 2.602948383258e-06
215 KSP Residual norm 2.294318266822e-06
216 KSP Residual norm 2.195752646988e-06
217 KSP Residual norm 2.166784652379e-06
218 KSP Residual norm 2.131657566073e-06
219 KSP Residual norm 1.986868574991e-06
220 KSP Residual norm 1.858742561348e-06
221 KSP Residual norm 1.766276837486e-06
222 KSP Residual norm 1.689460026430e-06
223 KSP Residual norm 1.618395852216e-06
224 KSP Residual norm 1.549152248016e-06
225 KSP Residual norm 1.488900459638e-06
226 KSP Residual norm 1.438284910326e-06
227 KSP Residual norm 1.399548482046e-06
228 KSP Residual norm 1.363399743650e-06
229 KSP Residual norm 1.311717814854e-06
230 KSP Residual norm 1.257742314190e-06
231 KSP Residual norm 1.210495423244e-06
232 KSP Residual norm 1.156015816699e-06
233 KSP Residual norm 1.096931764102e-06
234 KSP Residual norm 1.045362171880e-06
235 KSP Residual norm 1.025134845773e-06
236 KSP Residual norm 1.054411975494e-06
237 KSP Residual norm 9.951012480695e-07
238 KSP Residual norm 9.206785831745e-07
239 KSP Residual norm 9.558793857415e-07
240 KSP Residual norm 9.295044397865e-07
241 KSP Residual norm 8.193772574699e-07
242 KSP Residual norm 7.703137959994e-07
243 KSP Residual norm 7.360025890614e-07
244 KSP Residual norm 7.302860866358e-07
245 KSP Residual norm 7.604620072339e-07
246 KSP Residual norm 6.931917322160e-07
247 KSP Residual norm 6.349419434789e-07
248 KSP Residual norm 6.107603780081e-07
249 KSP Residual norm 5.984352457458e-07
250 KSP Residual norm 5.841249285691e-07
251 KSP Residual norm 5.657444531139e-07
252 KSP Residual norm 5.719309207316e-07
253 KSP Residual norm 5.368403027109e-07
254 KSP Residual norm 4.821347822961e-07
255 KSP Residual norm 4.531564297366e-07
256 KSP Residual norm 4.501039182977e-07
257 KSP Residual norm 4.693999294911e-07
258 KSP Residual norm 4.207409385831e-07
259 KSP Residual norm 4.073236802238e-07
260 KSP Residual norm 4.209814859879e-07
261 KSP Residual norm 3.661280664564e-07
262 KSP Residual norm 3.368350962680e-07
263 KSP Residual norm 3.204013032555e-07
264 KSP Residual norm 3.057380602382e-07
265 KSP Residual norm 2.943021798433e-07
266 KSP Residual norm 2.888085065229e-07
267 KSP Residual norm 2.795562119489e-07
268 KSP Residual norm 2.629557599736e-07
269 KSP Residual norm 2.534810103990e-07
270 KSP Residual norm 2.490064293238e-07
271 KSP Residual norm 2.340193810202e-07
272 KSP Residual norm 2.225086558635e-07
273 KSP Residual norm 2.230308425354e-07
274 KSP Residual norm 2.076852427961e-07
275 KSP Residual norm 1.882430651327e-07
276 KSP Residual norm 1.767109494853e-07
277 KSP Residual norm 1.685016951822e-07
278 KSP Residual norm 1.617795477543e-07
279 KSP Residual norm 1.554946765149e-07
280 KSP Residual norm 1.505124143665e-07
281 KSP Residual norm 1.483868670402e-07
282 KSP Residual norm 1.446201519808e-07
283 KSP Residual norm 1.367235843478e-07
284 KSP Residual norm 1.288936171593e-07
285 KSP Residual norm 1.211128951802e-07
286 KSP Residual norm 1.137707538781e-07
287 KSP Residual norm 1.079306486577e-07
288 KSP Residual norm 1.051686945912e-07
289 KSP Residual norm 1.042525366196e-07
290 KSP Residual norm 9.747757681541e-08
291 KSP Residual norm 8.913320504073e-08
292 KSP Residual norm 8.339996027427e-08
293 KSP Residual norm 7.910616362748e-08
294 KSP Residual norm 7.656095858332e-08
295 KSP Residual norm 7.693552218389e-08
296 KSP Residual norm 7.834978452835e-08
297 KSP Residual norm 7.286960401494e-08
298 KSP Residual norm 6.681568561362e-08
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 298
0 LS Function value: 0.0723695, Step length: 0.
1 LS Function value: 0.0697349, Step length: 1.
stx: 0., fx: 0.0723695, dgx: -0.00384056
sty: 0., fy: 0.0723695, dgy: -0.00384056
21 TAO, Function value: 0.0697349, Residual: 0.00271122
Residual norms for tao_nls_ solve.
0 KSP Residual norm 2.711220953755e-03
1 KSP Residual norm 3.049701903253e-03
2 KSP Residual norm 3.022714582982e-03
3 KSP Residual norm 2.932529423873e-03
4 KSP Residual norm 3.615549086062e-03
5 KSP Residual norm 4.429897817331e-03
6 KSP Residual norm 4.761722261097e-03
7 KSP Residual norm 5.430482887586e-03
8 KSP Residual norm 6.320203899740e-03
9 KSP Residual norm 6.776923127009e-03
10 KSP Residual norm 6.832632140750e-03
11 KSP Residual norm 7.081077481151e-03
12 KSP Residual norm 7.225346985001e-03
13 KSP Residual norm 7.058074356103e-03
14 KSP Residual norm 6.831146408132e-03
15 KSP Residual norm 6.585524752240e-03
16 KSP Residual norm 6.219532195304e-03
17 KSP Residual norm 5.866658284103e-03
18 KSP Residual norm 5.562162190362e-03
19 KSP Residual norm 5.154085426863e-03
20 KSP Residual norm 4.698716113021e-03
21 KSP Residual norm 4.386186829856e-03
22 KSP Residual norm 4.091102957789e-03
23 KSP Residual norm 3.624009997332e-03
24 KSP Residual norm 3.260834350442e-03
25 KSP Residual norm 3.031051802395e-03
26 KSP Residual norm 2.793899854669e-03
27 KSP Residual norm 2.575090539065e-03
28 KSP Residual norm 2.436092602972e-03
29 KSP Residual norm 2.321460327090e-03
30 KSP Residual norm 2.201836945773e-03
31 KSP Residual norm 2.131447441233e-03
32 KSP Residual norm 2.091343618668e-03
33 KSP Residual norm 2.027795664847e-03
34 KSP Residual norm 1.983886831308e-03
35 KSP Residual norm 1.983577962205e-03
36 KSP Residual norm 2.005260226306e-03
37 KSP Residual norm 2.032252739335e-03
38 KSP Residual norm 2.064683717256e-03
39 KSP Residual norm 2.075109953200e-03
40 KSP Residual norm 2.076097065587e-03
41 KSP Residual norm 2.062939376733e-03
42 KSP Residual norm 2.029471304626e-03
43 KSP Residual norm 1.996599148315e-03
44 KSP Residual norm 1.962277650658e-03
45 KSP Residual norm 1.893277170253e-03
46 KSP Residual norm 1.790858582482e-03
47 KSP Residual norm 1.689233634131e-03
48 KSP Residual norm 1.594358476437e-03
49 KSP Residual norm 1.498341927630e-03
50 KSP Residual norm 1.411600548750e-03
51 KSP Residual norm 1.333474605969e-03
52 KSP Residual norm 1.251466590326e-03
53 KSP Residual norm 1.171388029678e-03
54 KSP Residual norm 1.100059417561e-03
55 KSP Residual norm 1.037596084485e-03
56 KSP Residual norm 9.882297955365e-04
57 KSP Residual norm 9.519751539257e-04
58 KSP Residual norm 9.188654865038e-04
59 KSP Residual norm 8.867861024770e-04
60 KSP Residual norm 8.622266059658e-04
61 KSP Residual norm 8.423953356070e-04
62 KSP Residual norm 8.126365743310e-04
63 KSP Residual norm 7.738062448970e-04
64 KSP Residual norm 7.364424893598e-04
65 KSP Residual norm 7.062047632888e-04
66 KSP Residual norm 6.808611796963e-04
67 KSP Residual norm 6.552732559312e-04
68 KSP Residual norm 6.336535982654e-04
69 KSP Residual norm 6.233342398694e-04
70 KSP Residual norm 6.206665722732e-04
71 KSP Residual norm 6.090819509585e-04
72 KSP Residual norm 5.905243927409e-04
73 KSP Residual norm 5.651576123519e-04
74 KSP Residual norm 5.309910374825e-04
75 KSP Residual norm 5.009457610529e-04
76 KSP Residual norm 4.770798073087e-04
77 KSP Residual norm 4.589698704397e-04
78 KSP Residual norm 4.418410349698e-04
79 KSP Residual norm 4.283887246924e-04
80 KSP Residual norm 4.174268411430e-04
81 KSP Residual norm 4.027336471857e-04
82 KSP Residual norm 3.857744261790e-04
83 KSP Residual norm 3.683276630646e-04
84 KSP Residual norm 3.561216556292e-04
85 KSP Residual norm 3.575513140207e-04
86 KSP Residual norm 3.508595833463e-04
87 KSP Residual norm 3.222858050153e-04
88 KSP Residual norm 3.013597212443e-04
89 KSP Residual norm 2.858261002419e-04
90 KSP Residual norm 2.726739456669e-04
91 KSP Residual norm 2.621336351215e-04
92 KSP Residual norm 2.529983528093e-04
93 KSP Residual norm 2.464029261409e-04
94 KSP Residual norm 2.449576384298e-04
95 KSP Residual norm 2.402554209331e-04
96 KSP Residual norm 2.257827007342e-04
97 KSP Residual norm 2.142920585489e-04
98 KSP Residual norm 2.083654461114e-04
99 KSP Residual norm 2.011169284610e-04
100 KSP Residual norm 1.939608990920e-04
101 KSP Residual norm 1.873222720616e-04
102 KSP Residual norm 1.802149435310e-04
103 KSP Residual norm 1.738028815321e-04
104 KSP Residual norm 1.670260101423e-04
105 KSP Residual norm 1.619740298359e-04
106 KSP Residual norm 1.601636523093e-04
107 KSP Residual norm 1.581328199611e-04
108 KSP Residual norm 1.484864786253e-04
109 KSP Residual norm 1.393731899628e-04
110 KSP Residual norm 1.322329369872e-04
111 KSP Residual norm 1.263988518362e-04
112 KSP Residual norm 1.237164819792e-04
113 KSP Residual norm 1.221684101105e-04
114 KSP Residual norm 1.174847643903e-04
115 KSP Residual norm 1.114185757825e-04
116 KSP Residual norm 1.068083620601e-04
117 KSP Residual norm 1.027625791258e-04
118 KSP Residual norm 9.896586316958e-05
119 KSP Residual norm 9.626721264018e-05
120 KSP Residual norm 9.325657455335e-05
121 KSP Residual norm 9.018532791735e-05
122 KSP Residual norm 8.707310118770e-05
123 KSP Residual norm 8.431086475402e-05
124 KSP Residual norm 8.134197934835e-05
125 KSP Residual norm 7.814122074628e-05
126 KSP Residual norm 7.513754111701e-05
127 KSP Residual norm 7.317807457951e-05
128 KSP Residual norm 7.353995382314e-05
129 KSP Residual norm 7.206615794258e-05
130 KSP Residual norm 6.656543163865e-05
131 KSP Residual norm 6.252009956883e-05
132 KSP Residual norm 5.974683047187e-05
133 KSP Residual norm 5.721230325431e-05
134 KSP Residual norm 5.455876089606e-05
135 KSP Residual norm 5.228793706401e-05
136 KSP Residual norm 5.036040103101e-05
137 KSP Residual norm 4.866527339969e-05
138 KSP Residual norm 4.707102932359e-05
139 KSP Residual norm 4.554542543846e-05
140 KSP Residual norm 4.412420751468e-05
141 KSP Residual norm 4.246816612843e-05
142 KSP Residual norm 4.040354267271e-05
143 KSP Residual norm 3.836004267277e-05
144 KSP Residual norm 3.675076639621e-05
145 KSP Residual norm 3.560259583002e-05
146 KSP Residual norm 3.476188560116e-05
147 KSP Residual norm 3.493434663017e-05
148 KSP Residual norm 3.507701096809e-05
149 KSP Residual norm 3.226844943894e-05
150 KSP Residual norm 3.005415485832e-05
151 KSP Residual norm 2.867586846175e-05
152 KSP Residual norm 2.775973983339e-05
153 KSP Residual norm 2.716029527881e-05
154 KSP Residual norm 2.609260564245e-05
155 KSP Residual norm 2.450499366128e-05
156 KSP Residual norm 2.308684453274e-05
157 KSP Residual norm 2.192504266144e-05
158 KSP Residual norm 2.086462131853e-05
159 KSP Residual norm 1.975343238780e-05
160 KSP Residual norm 1.871714514423e-05
161 KSP Residual norm 1.784763747205e-05
162 KSP Residual norm 1.705039452001e-05
163 KSP Residual norm 1.627624548681e-05
164 KSP Residual norm 1.567906926435e-05
165 KSP Residual norm 1.542940895800e-05
166 KSP Residual norm 1.526438047146e-05
167 KSP Residual norm 1.435055254331e-05
168 KSP Residual norm 1.350937685407e-05
169 KSP Residual norm 1.306391713752e-05
170 KSP Residual norm 1.283221177588e-05
171 KSP Residual norm 1.237592603396e-05
172 KSP Residual norm 1.165273057250e-05
173 KSP Residual norm 1.105680977858e-05
174 KSP Residual norm 1.066704808042e-05
175 KSP Residual norm 1.031901419906e-05
176 KSP Residual norm 1.002264529321e-05
177 KSP Residual norm 9.736316245307e-06
178 KSP Residual norm 9.381833579080e-06
179 KSP Residual norm 9.049342739191e-06
180 KSP Residual norm 8.818732926936e-06
181 KSP Residual norm 8.687402312559e-06
182 KSP Residual norm 8.482078780819e-06
183 KSP Residual norm 8.187094696654e-06
184 KSP Residual norm 8.067189773906e-06
185 KSP Residual norm 8.009723876594e-06
186 KSP Residual norm 7.576497086030e-06
187 KSP Residual norm 7.091452542809e-06
188 KSP Residual norm 6.771688641550e-06
189 KSP Residual norm 6.538077879932e-06
190 KSP Residual norm 6.295444518104e-06
191 KSP Residual norm 6.058529430414e-06
192 KSP Residual norm 5.859149955871e-06
193 KSP Residual norm 5.782432351528e-06
194 KSP Residual norm 5.863577514644e-06
195 KSP Residual norm 5.601686352869e-06
196 KSP Residual norm 5.216198371559e-06
197 KSP Residual norm 4.976589127803e-06
198 KSP Residual norm 4.860973465420e-06
199 KSP Residual norm 4.916906044828e-06
200 KSP Residual norm 4.893316214953e-06
201 KSP Residual norm 4.531477017341e-06
202 KSP Residual norm 4.264879001154e-06
203 KSP Residual norm 4.104412687727e-06
204 KSP Residual norm 3.966779930254e-06
205 KSP Residual norm 3.843178895894e-06
206 KSP Residual norm 3.746502336187e-06
207 KSP Residual norm 3.663485625892e-06
208 KSP Residual norm 3.538136838118e-06
209 KSP Residual norm 3.422386154770e-06
210 KSP Residual norm 3.410926682938e-06
211 KSP Residual norm 3.358137819423e-06
212 KSP Residual norm 3.128637523195e-06
213 KSP Residual norm 2.965365610579e-06
214 KSP Residual norm 2.857047338640e-06
215 KSP Residual norm 2.771639308896e-06
216 KSP Residual norm 2.682621667110e-06
217 KSP Residual norm 2.597695206471e-06
218 KSP Residual norm 2.517668659239e-06
219 KSP Residual norm 2.430453570354e-06
220 KSP Residual norm 2.332370142133e-06
221 KSP Residual norm 2.236190808567e-06
222 KSP Residual norm 2.146870695741e-06
223 KSP Residual norm 2.083248588078e-06
224 KSP Residual norm 2.036206057010e-06
225 KSP Residual norm 1.961576078747e-06
226 KSP Residual norm 1.856919360268e-06
227 KSP Residual norm 1.763191040837e-06
228 KSP Residual norm 1.683770866877e-06
229 KSP Residual norm 1.614232486918e-06
230 KSP Residual norm 1.549831205495e-06
231 KSP Residual norm 1.485135167096e-06
232 KSP Residual norm 1.420294131346e-06
233 KSP Residual norm 1.369552096273e-06
234 KSP Residual norm 1.357815208665e-06
235 KSP Residual norm 1.353598166503e-06
236 KSP Residual norm 1.262543759927e-06
237 KSP Residual norm 1.175836461031e-06
238 KSP Residual norm 1.122230740697e-06
239 KSP Residual norm 1.086992874333e-06
240 KSP Residual norm 1.085472851117e-06
241 KSP Residual norm 1.090887829764e-06
242 KSP Residual norm 1.006834060754e-06
243 KSP Residual norm 9.353450418344e-07
244 KSP Residual norm 8.922840719175e-07
245 KSP Residual norm 8.623452593007e-07
246 KSP Residual norm 8.461945728156e-07
247 KSP Residual norm 8.341951393874e-07
248 KSP Residual norm 7.868256919884e-07
249 KSP Residual norm 7.331866462150e-07
250 KSP Residual norm 6.940817129334e-07
251 KSP Residual norm 6.615239205691e-07
252 KSP Residual norm 6.317702325966e-07
253 KSP Residual norm 6.074458538365e-07
254 KSP Residual norm 5.904786899379e-07
255 KSP Residual norm 5.735936749565e-07
256 KSP Residual norm 5.463638643872e-07
257 KSP Residual norm 5.163245762462e-07
258 KSP Residual norm 4.891580215970e-07
259 KSP Residual norm 4.666415535858e-07
260 KSP Residual norm 4.485992444051e-07
261 KSP Residual norm 4.366474494780e-07
262 KSP Residual norm 4.269232955564e-07
263 KSP Residual norm 4.053138014304e-07
264 KSP Residual norm 3.790780421708e-07
265 KSP Residual norm 3.603288982613e-07
266 KSP Residual norm 3.564617342081e-07
267 KSP Residual norm 3.613098029096e-07
268 KSP Residual norm 3.362314778545e-07
269 KSP Residual norm 3.122195484158e-07
270 KSP Residual norm 2.975960948127e-07
271 KSP Residual norm 2.863771404707e-07
272 KSP Residual norm 2.805332409068e-07
273 KSP Residual norm 2.815610783548e-07
274 KSP Residual norm 2.704557296903e-07
275 KSP Residual norm 2.493591761312e-07
276 KSP Residual norm 2.350082848530e-07
277 KSP Residual norm 2.249728891422e-07
278 KSP Residual norm 2.151874203210e-07
279 KSP Residual norm 2.067979033564e-07
280 KSP Residual norm 2.002364460188e-07
281 KSP Residual norm 1.948304270470e-07
282 KSP Residual norm 1.894674720582e-07
283 KSP Residual norm 1.840916562484e-07
284 KSP Residual norm 1.760129581090e-07
285 KSP Residual norm 1.665419729479e-07
286 KSP Residual norm 1.595833796158e-07
287 KSP Residual norm 1.549859277004e-07
288 KSP Residual norm 1.505003845495e-07
289 KSP Residual norm 1.429309593162e-07
290 KSP Residual norm 1.344865483385e-07
291 KSP Residual norm 1.269014833396e-07
292 KSP Residual norm 1.204046528904e-07
293 KSP Residual norm 1.154247646695e-07
294 KSP Residual norm 1.110229656436e-07
295 KSP Residual norm 1.083053014645e-07
296 KSP Residual norm 1.104292819527e-07
297 KSP Residual norm 1.084827903907e-07
298 KSP Residual norm 9.851512872627e-08
299 KSP Residual norm 9.330494811219e-08
300 KSP Residual norm 9.060740240526e-08
301 KSP Residual norm 8.773709955189e-08
302 KSP Residual norm 8.406741497170e-08
303 KSP Residual norm 8.011187331253e-08
304 KSP Residual norm 7.641056943212e-08
305 KSP Residual norm 7.303959406110e-08
306 KSP Residual norm 7.042814533214e-08
307 KSP Residual norm 6.910497437356e-08
308 KSP Residual norm 6.882095619949e-08
309 KSP Residual norm 6.725131513775e-08
310 KSP Residual norm 6.360488460247e-08
311 KSP Residual norm 6.017501805187e-08
312 KSP Residual norm 5.779361372693e-08
313 KSP Residual norm 5.637097166355e-08
314 KSP Residual norm 5.465248241555e-08
315 KSP Residual norm 5.201972506923e-08
316 KSP Residual norm 4.929524198499e-08
317 KSP Residual norm 4.708807438711e-08
318 KSP Residual norm 4.522001488417e-08
319 KSP Residual norm 4.363897753140e-08
320 KSP Residual norm 4.219334645621e-08
321 KSP Residual norm 4.066851230036e-08
322 KSP Residual norm 3.910202876469e-08
323 KSP Residual norm 3.769486459140e-08
324 KSP Residual norm 3.630842882055e-08
325 KSP Residual norm 3.536729825769e-08
326 KSP Residual norm 3.537222779583e-08
327 KSP Residual norm 3.542096595284e-08
328 KSP Residual norm 3.327878333530e-08
329 KSP Residual norm 3.132869299472e-08
330 KSP Residual norm 3.008750835122e-08
331 KSP Residual norm 2.907620598227e-08
332 KSP Residual norm 2.808411337649e-08
333 KSP Residual norm 2.704123185372e-08
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 333
0 LS Function value: 0.0697349, Step length: 0.
1 LS Function value: 0.06919, Step length: 1.
stx: 0., fx: 0.0697349, dgx: -0.000859431
sty: 0., fy: 0.0697349, dgy: -0.000859431
22 TAO, Function value: 0.06919, Residual: 0.00111639
0 KSP Residual norm 1.116387257518e-03
1 KSP Residual norm 1.194086088885e-03
2 KSP Residual norm 1.059449685138e-03
3 KSP Residual norm 9.242433754978e-04
4 KSP Residual norm 1.036851464279e-03
5 KSP Residual norm 1.102989897690e-03
6 KSP Residual norm 1.099252260241e-03
7 KSP Residual norm 1.170365626322e-03
8 KSP Residual norm 1.222527343640e-03
9 KSP Residual norm 1.259168572966e-03
10 KSP Residual norm 1.293506205183e-03
11 KSP Residual norm 1.332072119021e-03
12 KSP Residual norm 1.388582057913e-03
13 KSP Residual norm 1.414993748413e-03
14 KSP Residual norm 1.435896647380e-03
15 KSP Residual norm 1.484701868594e-03
16 KSP Residual norm 1.549387625751e-03
17 KSP Residual norm 1.623912850011e-03
18 KSP Residual norm 1.703249338921e-03
19 KSP Residual norm 1.781008560774e-03
20 KSP Residual norm 1.849525048129e-03
21 KSP Residual norm 1.910348148392e-03
22 KSP Residual norm 1.933472586985e-03
23 KSP Residual norm 1.916683644719e-03
24 KSP Residual norm 1.864958159057e-03
25 KSP Residual norm 1.797695945840e-03
26 KSP Residual norm 1.730093656675e-03
27 KSP Residual norm 1.618712690456e-03
28 KSP Residual norm 1.466041208827e-03
29 KSP Residual norm 1.331619801519e-03
30 KSP Residual norm 1.204908642498e-03
31 KSP Residual norm 1.085437849844e-03
32 KSP Residual norm 9.776815458175e-04
33 KSP Residual norm 8.766187690949e-04
34 KSP Residual norm 7.897946737062e-04
35 KSP Residual norm 7.121602080694e-04
36 KSP Residual norm 6.441948150201e-04
37 KSP Residual norm 5.909330520115e-04
38 KSP Residual norm 5.435062809009e-04
39 KSP Residual norm 4.991948957123e-04
40 KSP Residual norm 4.648009079054e-04
41 KSP Residual norm 4.376714973301e-04
42 KSP Residual norm 4.131444813453e-04
43 KSP Residual norm 3.939801078980e-04
44 KSP Residual norm 3.798112680926e-04
45 KSP Residual norm 3.649931519999e-04
46 KSP Residual norm 3.518919579721e-04
47 KSP Residual norm 3.438241418189e-04
48 KSP Residual norm 3.388628974511e-04
49 KSP Residual norm 3.353178131187e-04
50 KSP Residual norm 3.320930063355e-04
51 KSP Residual norm 3.290939585646e-04
52 KSP Residual norm 3.274862535170e-04
53 KSP Residual norm 3.273255536589e-04
54 KSP Residual norm 3.278950345413e-04
55 KSP Residual norm 3.291566936181e-04
56 KSP Residual norm 3.289060020496e-04
57 KSP Residual norm 3.242685895550e-04
58 KSP Residual norm 3.180148809198e-04
59 KSP Residual norm 3.120064480283e-04
60 KSP Residual norm 3.046809279250e-04
61 KSP Residual norm 2.953374145128e-04
62 KSP Residual norm 2.845457454549e-04
63 KSP Residual norm 2.733319026654e-04
64 KSP Residual norm 2.620362304411e-04
65 KSP Residual norm 2.496821407234e-04
66 KSP Residual norm 2.370743858430e-04
67 KSP Residual norm 2.262797835044e-04
68 KSP Residual norm 2.174050211906e-04
69 KSP Residual norm 2.075565394912e-04
70 KSP Residual norm 1.964070664783e-04
71 KSP Residual norm 1.860137990325e-04
72 KSP Residual norm 1.765260597745e-04
73 KSP Residual norm 1.685330791588e-04
74 KSP Residual norm 1.638487761469e-04
75 KSP Residual norm 1.588554979052e-04
76 KSP Residual norm 1.483081907948e-04
77 KSP Residual norm 1.381518402960e-04
78 KSP Residual norm 1.307432609361e-04
79 KSP Residual norm 1.245914415698e-04
80 KSP Residual norm 1.194771535366e-04
81 KSP Residual norm 1.153166791442e-04
82 KSP Residual norm 1.116892557771e-04
83 KSP Residual norm 1.086009881755e-04
84 KSP Residual norm 1.054167306580e-04
85 KSP Residual norm 1.024609148982e-04
86 KSP Residual norm 1.004495558034e-04
87 KSP Residual norm 9.893608729761e-05
88 KSP Residual norm 9.781020497241e-05
89 KSP Residual norm 9.402249432945e-05
90 KSP Residual norm 8.889103456283e-05
91 KSP Residual norm 8.501110988110e-05
92 KSP Residual norm 8.150743677026e-05
93 KSP Residual norm 7.826338260250e-05
94 KSP Residual norm 7.528579939174e-05
95 KSP Residual norm 7.286614674274e-05
96 KSP Residual norm 7.123822182833e-05
97 KSP Residual norm 6.989189187998e-05
98 KSP Residual norm 6.789373180380e-05
99 KSP Residual norm 6.626262908167e-05
100 KSP Residual norm 6.480824466085e-05
101 KSP Residual norm 6.384408823298e-05
102 KSP Residual norm 6.252183772992e-05
103 KSP Residual norm 6.075219143751e-05
104 KSP Residual norm 5.892599371400e-05
105 KSP Residual norm 5.734965095673e-05
106 KSP Residual norm 5.597653487077e-05
107 KSP Residual norm 5.438988083907e-05
108 KSP Residual norm 5.273218605638e-05
109 KSP Residual norm 5.055102756809e-05
110 KSP Residual norm 4.878731410607e-05
111 KSP Residual norm 4.689291180525e-05
112 KSP Residual norm 4.512055641753e-05
113 KSP Residual norm 4.297823337199e-05
114 KSP Residual norm 4.086411175761e-05
115 KSP Residual norm 3.868903566002e-05
116 KSP Residual norm 3.670589278595e-05
117 KSP Residual norm 3.475668885214e-05
118 KSP Residual norm 3.313782051568e-05
119 KSP Residual norm 3.168560275206e-05
120 KSP Residual norm 3.038284436781e-05
121 KSP Residual norm 2.899811075348e-05
122 KSP Residual norm 2.779408489797e-05
123 KSP Residual norm 2.690356274165e-05
124 KSP Residual norm 2.611521278182e-05
125 KSP Residual norm 2.504770027361e-05
126 KSP Residual norm 2.404762007288e-05
127 KSP Residual norm 2.344060253160e-05
128 KSP Residual norm 2.299781860259e-05
129 KSP Residual norm 2.240173696253e-05
130 KSP Residual norm 2.160970386827e-05
131 KSP Residual norm 2.094402084710e-05
132 KSP Residual norm 2.056954245947e-05
133 KSP Residual norm 2.042114617721e-05
134 KSP Residual norm 2.043456415201e-05
135 KSP Residual norm 2.035312724638e-05
136 KSP Residual norm 1.951040337322e-05
137 KSP Residual norm 1.867975557764e-05
138 KSP Residual norm 1.831250320129e-05
139 KSP Residual norm 1.808878877361e-05
140 KSP Residual norm 1.710333217119e-05
141 KSP Residual norm 1.592883108989e-05
142 KSP Residual norm 1.506259383073e-05
143 KSP Residual norm 1.430973819428e-05
144 KSP Residual norm 1.355097830975e-05
145 KSP Residual norm 1.287732852243e-05
146 KSP Residual norm 1.235943338421e-05
147 KSP Residual norm 1.200325469618e-05
148 KSP Residual norm 1.162246284313e-05
149 KSP Residual norm 1.098766869336e-05
150 KSP Residual norm 1.041999242485e-05
151 KSP Residual norm 9.986231767194e-06
152 KSP Residual norm 9.554949603235e-06
153 KSP Residual norm 9.163517720638e-06
154 KSP Residual norm 8.838502203224e-06
155 KSP Residual norm 8.597005961357e-06
156 KSP Residual norm 8.455211194112e-06
157 KSP Residual norm 8.300338355467e-06
158 KSP Residual norm 8.018174482477e-06
159 KSP Residual norm 7.707893270524e-06
160 KSP Residual norm 7.394035697193e-06
161 KSP Residual norm 7.079700625511e-06
162 KSP Residual norm 6.799364847234e-06
163 KSP Residual norm 6.551965119700e-06
164 KSP Residual norm 6.339693709462e-06
165 KSP Residual norm 6.156870434583e-06
166 KSP Residual norm 6.013660447151e-06
167 KSP Residual norm 5.882477897524e-06
168 KSP Residual norm 5.728483899458e-06
169 KSP Residual norm 5.565216027045e-06
170 KSP Residual norm 5.393466306367e-06
171 KSP Residual norm 5.214011816804e-06
172 KSP Residual norm 5.037589396271e-06
173 KSP Residual norm 4.857902920669e-06
174 KSP Residual norm 4.690444702997e-06
175 KSP Residual norm 4.554804508490e-06
176 KSP Residual norm 4.431719059477e-06
177 KSP Residual norm 4.284487299290e-06
178 KSP Residual norm 4.115987777777e-06
179 KSP Residual norm 3.932298906707e-06
180 KSP Residual norm 3.772645835779e-06
181 KSP Residual norm 3.638376620279e-06
182 KSP Residual norm 3.544444695431e-06
183 KSP Residual norm 3.476148677357e-06
184 KSP Residual norm 3.407648959778e-06
185 KSP Residual norm 3.327370520132e-06
186 KSP Residual norm 3.243418460772e-06
187 KSP Residual norm 3.165941748150e-06
188 KSP Residual norm 3.095734020015e-06
189 KSP Residual norm 3.031397235423e-06
190 KSP Residual norm 2.966094956592e-06
191 KSP Residual norm 2.893390522851e-06
192 KSP Residual norm 2.816627394701e-06
193 KSP Residual norm 2.751798647792e-06
194 KSP Residual norm 2.714207691051e-06
195 KSP Residual norm 2.694782346256e-06
196 KSP Residual norm 2.672918559305e-06
197 KSP Residual norm 2.593160084445e-06
198 KSP Residual norm 2.466598980809e-06
199 KSP Residual norm 2.351900004127e-06
200 KSP Residual norm 2.248131441724e-06
201 KSP Residual norm 2.150061915385e-06
202 KSP Residual norm 2.067183475158e-06
203 KSP Residual norm 1.996654770213e-06
204 KSP Residual norm 1.926296999874e-06
205 KSP Residual norm 1.848332799572e-06
206 KSP Residual norm 1.773459598944e-06
207 KSP Residual norm 1.706395789223e-06
208 KSP Residual norm 1.646358482358e-06
209 KSP Residual norm 1.592065182528e-06
210 KSP Residual norm 1.550012234987e-06
211 KSP Residual norm 1.518002388500e-06
212 KSP Residual norm 1.466768695124e-06
213 KSP Residual norm 1.389627501598e-06
214 KSP Residual norm 1.319967825606e-06
215 KSP Residual norm 1.258732599328e-06
216 KSP Residual norm 1.208226237206e-06
217 KSP Residual norm 1.180848857703e-06
218 KSP Residual norm 1.185133073712e-06
219 KSP Residual norm 1.133658732082e-06
220 KSP Residual norm 1.046568662754e-06
221 KSP Residual norm 9.936278717360e-07
222 KSP Residual norm 9.634412406361e-07
223 KSP Residual norm 9.524074745290e-07
224 KSP Residual norm 9.345488902744e-07
225 KSP Residual norm 8.833615524336e-07
226 KSP Residual norm 8.330075935761e-07
227 KSP Residual norm 7.965111975570e-07
228 KSP Residual norm 7.682579007776e-07
229 KSP Residual norm 7.461318867221e-07
230 KSP Residual norm 7.317204257821e-07
231 KSP Residual norm 7.218875505228e-07
232 KSP Residual norm 7.053200253465e-07
233 KSP Residual norm 6.749619371725e-07
234 KSP Residual norm 6.441685200577e-07
235 KSP Residual norm 6.167053716769e-07
236 KSP Residual norm 5.920872320683e-07
237 KSP Residual norm 5.686793194121e-07
238 KSP Residual norm 5.462107461517e-07
239 KSP Residual norm 5.226925592644e-07
240 KSP Residual norm 4.982797621843e-07
241 KSP Residual norm 4.743678684407e-07
242 KSP Residual norm 4.544781353180e-07
243 KSP Residual norm 4.363622527373e-07
244 KSP Residual norm 4.186383153861e-07
245 KSP Residual norm 4.022766314226e-07
246 KSP Residual norm 3.898933634039e-07
247 KSP Residual norm 3.792600454230e-07
248 KSP Residual norm 3.684900291566e-07
249 KSP Residual norm 3.565022461888e-07
250 KSP Residual norm 3.431770666818e-07
251 KSP Residual norm 3.302406582832e-07
252 KSP Residual norm 3.197149781660e-07
253 KSP Residual norm 3.117421741438e-07
254 KSP Residual norm 3.006225990591e-07
255 KSP Residual norm 2.865389872395e-07
256 KSP Residual norm 2.747782067735e-07
257 KSP Residual norm 2.665469379328e-07
258 KSP Residual norm 2.617538762481e-07
259 KSP Residual norm 2.583563189275e-07
260 KSP Residual norm 2.447894421918e-07
261 KSP Residual norm 2.297027848512e-07
262 KSP Residual norm 2.200448801799e-07
263 KSP Residual norm 2.131922078483e-07
264 KSP Residual norm 2.067933715855e-07
265 KSP Residual norm 2.000156041564e-07
266 KSP Residual norm 1.938505600216e-07
267 KSP Residual norm 1.879074457881e-07
268 KSP Residual norm 1.823521932855e-07
269 KSP Residual norm 1.781856414303e-07
270 KSP Residual norm 1.748280158607e-07
271 KSP Residual norm 1.691927616841e-07
272 KSP Residual norm 1.614469891728e-07
273 KSP Residual norm 1.547742809330e-07
274 KSP Residual norm 1.496700363940e-07
275 KSP Residual norm 1.452954047765e-07
276 KSP Residual norm 1.418567892160e-07
277 KSP Residual norm 1.381629446351e-07
278 KSP Residual norm 1.338180116960e-07
279 KSP Residual norm 1.294911570960e-07
280 KSP Residual norm 1.252845407348e-07
281 KSP Residual norm 1.221451573536e-07
282 KSP Residual norm 1.200008830870e-07
283 KSP Residual norm 1.181353127193e-07
284 KSP Residual norm 1.157260629549e-07
285 KSP Residual norm 1.136460188017e-07
286 KSP Residual norm 1.122147871517e-07
287 KSP Residual norm 1.100027941554e-07
288 KSP Residual norm 1.060585633240e-07
289 KSP Residual norm 1.017820421500e-07
290 KSP Residual norm 9.792097513992e-08
291 KSP Residual norm 9.409077619432e-08
292 KSP Residual norm 9.083025782826e-08
293 KSP Residual norm 8.828399818491e-08
294 KSP Residual norm 8.584654576791e-08
295 KSP Residual norm 8.391247328767e-08
296 KSP Residual norm 8.252848185233e-08
297 KSP Residual norm 8.066160372293e-08
298 KSP Residual norm 7.790988802915e-08
299 KSP Residual norm 7.505064481543e-08
300 KSP Residual norm 7.260965311959e-08
301 KSP Residual norm 7.078410350745e-08
302 KSP Residual norm 6.966834300873e-08
303 KSP Residual norm 6.866569305804e-08
304 KSP Residual norm 6.694877688774e-08
305 KSP Residual norm 6.519839292297e-08
306 KSP Residual norm 6.419812071243e-08
307 KSP Residual norm 6.298188074213e-08
308 KSP Residual norm 6.108083386866e-08
309 KSP Residual norm 5.959025865587e-08
310 KSP Residual norm 5.908859885073e-08
311 KSP Residual norm 5.858069554233e-08
312 KSP Residual norm 5.675183947550e-08
313 KSP Residual norm 5.490389084370e-08
314 KSP Residual norm 5.408579956588e-08
315 KSP Residual norm 5.336934580319e-08
316 KSP Residual norm 5.170876571564e-08
317 KSP Residual norm 4.929015477465e-08
318 KSP Residual norm 4.720748314983e-08
319 KSP Residual norm 4.566280884465e-08
320 KSP Residual norm 4.455941308326e-08
321 KSP Residual norm 4.441806406993e-08
322 KSP Residual norm 4.553834017569e-08
323 KSP Residual norm 4.375224764630e-08
324 KSP Residual norm 4.078587826173e-08
325 KSP Residual norm 3.915291307415e-08
326 KSP Residual norm 3.823960595944e-08
327 KSP Residual norm 3.774570497566e-08
328 KSP Residual norm 3.753993322570e-08
329 KSP Residual norm 3.662896670038e-08
330 KSP Residual norm 3.483343324942e-08
331 KSP Residual norm 3.325115758550e-08
332 KSP Residual norm 3.205598865855e-08
333 KSP Residual norm 3.105696040803e-08
334 KSP Residual norm 3.022988852886e-08
335 KSP Residual norm 2.955466023448e-08
336 KSP Residual norm 2.883209474985e-08
337 KSP Residual norm 2.801721753877e-08
338 KSP Residual norm 2.703840301284e-08
339 KSP Residual norm 2.609078699815e-08
340 KSP Residual norm 2.534121923176e-08
341 KSP Residual norm 2.469264746508e-08
342 KSP Residual norm 2.402636451202e-08
343 KSP Residual norm 2.329960424155e-08
344 KSP Residual norm 2.252352276917e-08
345 KSP Residual norm 2.179797884938e-08
346 KSP Residual norm 2.119799024058e-08
347 KSP Residual norm 2.053209505370e-08
348 KSP Residual norm 1.981148839838e-08
349 KSP Residual norm 1.904946966285e-08
350 KSP Residual norm 1.827975936672e-08
351 KSP Residual norm 1.755139153092e-08
352 KSP Residual norm 1.689446857824e-08
353 KSP Residual norm 1.649812625172e-08
354 KSP Residual norm 1.637305353833e-08
355 KSP Residual norm 1.587094147753e-08
356 KSP Residual norm 1.493062207489e-08
357 KSP Residual norm 1.419019253611e-08
358 KSP Residual norm 1.355068918627e-08
359 KSP Residual norm 1.303517734133e-08
360 KSP Residual norm 1.265061510376e-08
361 KSP Residual norm 1.233810916111e-08
362 KSP Residual norm 1.214518910553e-08
363 KSP Residual norm 1.193644280481e-08
364 KSP Residual norm 1.152553701870e-08
365 KSP Residual norm 1.100617261515e-08
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 365
0 LS Function value: 0.06919, Step length: 0.
1 LS Function value: 0.0691413, Step length: 1.
stx: 0., fx: 0.06919, dgx: -8.45693e-05
sty: 0., fy: 0.06919, dgy: -8.45693e-05
23 TAO, Function value: 0.0691413, Residual: 0.000389828
0 KSP Residual norm 3.898281966765e-04
1 KSP Residual norm 4.260782235264e-04
2 KSP Residual norm 3.525588995984e-04
3 KSP Residual norm 3.154245120592e-04
4 KSP Residual norm 3.348602211243e-04
5 KSP Residual norm 3.227233898165e-04
6 KSP Residual norm 3.200878544641e-04
7 KSP Residual norm 3.255916931231e-04
8 KSP Residual norm 3.108545045604e-04
9 KSP Residual norm 2.926995326680e-04
10 KSP Residual norm 2.789969235013e-04
11 KSP Residual norm 2.597566072560e-04
12 KSP Residual norm 2.404183669778e-04
13 KSP Residual norm 2.236032695600e-04
14 KSP Residual norm 2.100254026242e-04
15 KSP Residual norm 1.936777805942e-04
16 KSP Residual norm 1.805249509742e-04
17 KSP Residual norm 1.718161610678e-04
18 KSP Residual norm 1.671335811434e-04
19 KSP Residual norm 1.640579575433e-04
20 KSP Residual norm 1.614395385096e-04
21 KSP Residual norm 1.622065218921e-04
22 KSP Residual norm 1.666757832164e-04
23 KSP Residual norm 1.725642244254e-04
24 KSP Residual norm 1.792082422207e-04
25 KSP Residual norm 1.864647756656e-04
26 KSP Residual norm 1.954865815390e-04
27 KSP Residual norm 2.068298103354e-04
28 KSP Residual norm 2.180784542754e-04
29 KSP Residual norm 2.278267330698e-04
30 KSP Residual norm 2.370889229720e-04
31 KSP Residual norm 2.447598206004e-04
32 KSP Residual norm 2.510916656310e-04
33 KSP Residual norm 2.565793685585e-04
34 KSP Residual norm 2.607051706211e-04
35 KSP Residual norm 2.606507439807e-04
36 KSP Residual norm 2.550953401501e-04
37 KSP Residual norm 2.465528545191e-04
38 KSP Residual norm 2.368096609144e-04
39 KSP Residual norm 2.256212163176e-04
40 KSP Residual norm 2.126665766128e-04
41 KSP Residual norm 1.992393499635e-04
42 KSP Residual norm 1.858617087795e-04
43 KSP Residual norm 1.732149543162e-04
44 KSP Residual norm 1.611977791226e-04
45 KSP Residual norm 1.495436218975e-04
46 KSP Residual norm 1.386381420233e-04
47 KSP Residual norm 1.283138469425e-04
48 KSP Residual norm 1.187114505932e-04
49 KSP Residual norm 1.100520115297e-04
50 KSP Residual norm 1.031216424229e-04
51 KSP Residual norm 9.753354909725e-05
52 KSP Residual norm 9.179483012318e-05
53 KSP Residual norm 8.628216475328e-05
54 KSP Residual norm 8.187093724669e-05
55 KSP Residual norm 7.853382161867e-05
56 KSP Residual norm 7.538950805364e-05
57 KSP Residual norm 7.263967771645e-05
58 KSP Residual norm 7.053600795314e-05
59 KSP Residual norm 6.858608656995e-05
60 KSP Residual norm 6.631437008542e-05
61 KSP Residual norm 6.378023166633e-05
62 KSP Residual norm 6.134910011810e-05
63 KSP Residual norm 5.842907476675e-05
64 KSP Residual norm 5.491638038659e-05
65 KSP Residual norm 5.137123921628e-05
66 KSP Residual norm 4.815466755534e-05
67 KSP Residual norm 4.546605646306e-05
68 KSP Residual norm 4.308577446980e-05
69 KSP Residual norm 4.084583525172e-05
70 KSP Residual norm 3.872304273041e-05
71 KSP Residual norm 3.684538623351e-05
72 KSP Residual norm 3.514826984255e-05
73 KSP Residual norm 3.352160920459e-05
74 KSP Residual norm 3.210195828274e-05
75 KSP Residual norm 3.083564039882e-05
76 KSP Residual norm 2.975873642305e-05
77 KSP Residual norm 2.888535385715e-05
78 KSP Residual norm 2.807651340353e-05
79 KSP Residual norm 2.726578610252e-05
80 KSP Residual norm 2.645566758288e-05
81 KSP Residual norm 2.561561208184e-05
82 KSP Residual norm 2.476008839651e-05
83 KSP Residual norm 2.396151562022e-05
84 KSP Residual norm 2.322556689482e-05
85 KSP Residual norm 2.265247424064e-05
86 KSP Residual norm 2.215470308987e-05
87 KSP Residual norm 2.156464554636e-05
88 KSP Residual norm 2.072003665699e-05
89 KSP Residual norm 1.990783313888e-05
90 KSP Residual norm 1.919556311154e-05
91 KSP Residual norm 1.864385885849e-05
92 KSP Residual norm 1.799757777651e-05
93 KSP Residual norm 1.735140238653e-05
94 KSP Residual norm 1.680659717844e-05
95 KSP Residual norm 1.644279486971e-05
96 KSP Residual norm 1.617619291910e-05
97 KSP Residual norm 1.586339077462e-05
98 KSP Residual norm 1.543088717396e-05
99 KSP Residual norm 1.498142787676e-05
100 KSP Residual norm 1.453451197974e-05
101 KSP Residual norm 1.407944389213e-05
102 KSP Residual norm 1.350361293292e-05
103 KSP Residual norm 1.306104539411e-05
104 KSP Residual norm 1.243281729264e-05
105 KSP Residual norm 1.198844345745e-05
106 KSP Residual norm 1.151042422710e-05
107 KSP Residual norm 1.139511530876e-05
108 KSP Residual norm 1.106260456727e-05
109 KSP Residual norm 1.050540682962e-05
110 KSP Residual norm 9.923802882570e-06
111 KSP Residual norm 9.569793032572e-06
112 KSP Residual norm 9.249356035945e-06
113 KSP Residual norm 8.969651535602e-06
114 KSP Residual norm 8.731548066878e-06
115 KSP Residual norm 8.552245962072e-06
116 KSP Residual norm 8.336880831734e-06
117 KSP Residual norm 8.152589114403e-06
118 KSP Residual norm 7.939725698757e-06
119 KSP Residual norm 7.800281890942e-06
120 KSP Residual norm 7.709171954693e-06
121 KSP Residual norm 7.660853613246e-06
122 KSP Residual norm 7.562876725213e-06
123 KSP Residual norm 7.451984865938e-06
124 KSP Residual norm 7.315004153865e-06
125 KSP Residual norm 7.172432069242e-06
126 KSP Residual norm 7.050531417930e-06
127 KSP Residual norm 6.902285946252e-06
128 KSP Residual norm 6.706944077121e-06
129 KSP Residual norm 6.489880201453e-06
130 KSP Residual norm 6.297649961735e-06
131 KSP Residual norm 6.100989515109e-06
132 KSP Residual norm 5.918015549613e-06
133 KSP Residual norm 5.700954025688e-06
134 KSP Residual norm 5.484355051094e-06
135 KSP Residual norm 5.305302823136e-06
136 KSP Residual norm 5.148878576909e-06
137 KSP Residual norm 4.921064859024e-06
138 KSP Residual norm 4.640792625906e-06
139 KSP Residual norm 4.349486542279e-06
140 KSP Residual norm 4.074142506049e-06
141 KSP Residual norm 3.826975016777e-06
142 KSP Residual norm 3.590147019382e-06
143 KSP Residual norm 3.369973412422e-06
144 KSP Residual norm 3.162163421457e-06
145 KSP Residual norm 2.967952535137e-06
146 KSP Residual norm 2.791123153509e-06
147 KSP Residual norm 2.622503909049e-06
148 KSP Residual norm 2.481300518722e-06
149 KSP Residual norm 2.351042003146e-06
150 KSP Residual norm 2.237423253898e-06
151 KSP Residual norm 2.149792731039e-06
152 KSP Residual norm 2.075050583349e-06
153 KSP Residual norm 1.989922921554e-06
154 KSP Residual norm 1.905512245285e-06
155 KSP Residual norm 1.838704455775e-06
156 KSP Residual norm 1.772550603921e-06
157 KSP Residual norm 1.711020509169e-06
158 KSP Residual norm 1.662121957024e-06
159 KSP Residual norm 1.618959868894e-06
160 KSP Residual norm 1.598333531334e-06
161 KSP Residual norm 1.604891182144e-06
162 KSP Residual norm 1.602036588382e-06
163 KSP Residual norm 1.551043995876e-06
164 KSP Residual norm 1.502018951845e-06
165 KSP Residual norm 1.482260261774e-06
166 KSP Residual norm 1.476456080491e-06
167 KSP Residual norm 1.466922054531e-06
168 KSP Residual norm 1.451757384949e-06
169 KSP Residual norm 1.436994994184e-06
170 KSP Residual norm 1.424614901288e-06
171 KSP Residual norm 1.407985049212e-06
172 KSP Residual norm 1.378746013242e-06
173 KSP Residual norm 1.344118671978e-06
174 KSP Residual norm 1.305902837320e-06
175 KSP Residual norm 1.263646207007e-06
176 KSP Residual norm 1.220779074086e-06
177 KSP Residual norm 1.175826071484e-06
178 KSP Residual norm 1.135488241104e-06
179 KSP Residual norm 1.093659311449e-06
180 KSP Residual norm 1.049479417276e-06
181 KSP Residual norm 1.003554697133e-06
182 KSP Residual norm 9.548575416652e-07
183 KSP Residual norm 9.117839137442e-07
184 KSP Residual norm 8.763848087774e-07
185 KSP Residual norm 8.453236181879e-07
186 KSP Residual norm 8.064902440746e-07
187 KSP Residual norm 7.634786146138e-07
188 KSP Residual norm 7.284431911976e-07
189 KSP Residual norm 7.000993347216e-07
190 KSP Residual norm 6.765452640047e-07
191 KSP Residual norm 6.476785794558e-07
192 KSP Residual norm 6.147940610392e-07
193 KSP Residual norm 5.873266361796e-07
194 KSP Residual norm 5.689309479644e-07
195 KSP Residual norm 5.567775268249e-07
196 KSP Residual norm 5.457200724331e-07
197 KSP Residual norm 5.332536335494e-07
198 KSP Residual norm 5.191111624975e-07
199 KSP Residual norm 5.040992868663e-07
200 KSP Residual norm 4.920247764236e-07
201 KSP Residual norm 4.819808459276e-07
202 KSP Residual norm 4.720950507737e-07
203 KSP Residual norm 4.610121064467e-07
204 KSP Residual norm 4.479361302596e-07
205 KSP Residual norm 4.351127506379e-07
206 KSP Residual norm 4.261698853089e-07
207 KSP Residual norm 4.224433066789e-07
208 KSP Residual norm 4.192224560813e-07
209 KSP Residual norm 4.098856214893e-07
210 KSP Residual norm 4.003532973939e-07
211 KSP Residual norm 3.899874878041e-07
212 KSP Residual norm 3.788836855235e-07
213 KSP Residual norm 3.653957322768e-07
214 KSP Residual norm 3.528609776264e-07
215 KSP Residual norm 3.410190291363e-07
216 KSP Residual norm 3.302573088720e-07
217 KSP Residual norm 3.188514372547e-07
218 KSP Residual norm 3.074368315911e-07
219 KSP Residual norm 2.966405355714e-07
220 KSP Residual norm 2.863627157990e-07
221 KSP Residual norm 2.788118201307e-07
222 KSP Residual norm 2.745207779498e-07
223 KSP Residual norm 2.716166115827e-07
224 KSP Residual norm 2.652918365757e-07
225 KSP Residual norm 2.550987849297e-07
226 KSP Residual norm 2.449051603692e-07
227 KSP Residual norm 2.362563659602e-07
228 KSP Residual norm 2.293139033846e-07
229 KSP Residual norm 2.251136645984e-07
230 KSP Residual norm 2.227155306074e-07
231 KSP Residual norm 2.151054167176e-07
232 KSP Residual norm 2.037200433523e-07
233 KSP Residual norm 1.948628440686e-07
234 KSP Residual norm 1.895395425916e-07
235 KSP Residual norm 1.862665697368e-07
236 KSP Residual norm 1.796951923480e-07
237 KSP Residual norm 1.707631959957e-07
238 KSP Residual norm 1.639026721660e-07
239 KSP Residual norm 1.573249465123e-07
240 KSP Residual norm 1.501999960264e-07
241 KSP Residual norm 1.433870769632e-07
242 KSP Residual norm 1.374091233882e-07
243 KSP Residual norm 1.314984527665e-07
244 KSP Residual norm 1.258866493624e-07
245 KSP Residual norm 1.205266011077e-07
246 KSP Residual norm 1.155113448174e-07
247 KSP Residual norm 1.108247675954e-07
248 KSP Residual norm 1.063171582120e-07
249 KSP Residual norm 1.019798342140e-07
250 KSP Residual norm 9.711612226865e-08
251 KSP Residual norm 9.225421774003e-08
252 KSP Residual norm 8.791335152430e-08
253 KSP Residual norm 8.445235801725e-08
254 KSP Residual norm 8.155677556189e-08
255 KSP Residual norm 7.862322167000e-08
256 KSP Residual norm 7.508628648836e-08
257 KSP Residual norm 7.161066431791e-08
258 KSP Residual norm 6.869815222681e-08
259 KSP Residual norm 6.614664193412e-08
260 KSP Residual norm 6.372245117887e-08
261 KSP Residual norm 6.115115919491e-08
262 KSP Residual norm 5.881546845897e-08
263 KSP Residual norm 5.678498179911e-08
264 KSP Residual norm 5.509657813628e-08
265 KSP Residual norm 5.366305504363e-08
266 KSP Residual norm 5.227108569537e-08
267 KSP Residual norm 5.039548345879e-08
268 KSP Residual norm 4.811139744390e-08
269 KSP Residual norm 4.608229410735e-08
270 KSP Residual norm 4.450402524000e-08
271 KSP Residual norm 4.329343218860e-08
272 KSP Residual norm 4.231645138082e-08
273 KSP Residual norm 4.122840486367e-08
274 KSP Residual norm 4.029622689483e-08
275 KSP Residual norm 3.989085580379e-08
276 KSP Residual norm 4.025099760073e-08
277 KSP Residual norm 4.057448469746e-08
278 KSP Residual norm 3.998868415826e-08
279 KSP Residual norm 3.924518412760e-08
280 KSP Residual norm 3.877631199775e-08
281 KSP Residual norm 3.828649159804e-08
282 KSP Residual norm 3.772177025126e-08
283 KSP Residual norm 3.723390658925e-08
284 KSP Residual norm 3.681662988980e-08
285 KSP Residual norm 3.642232192192e-08
286 KSP Residual norm 3.595460115934e-08
287 KSP Residual norm 3.532660592330e-08
288 KSP Residual norm 3.467229987434e-08
289 KSP Residual norm 3.425098861596e-08
290 KSP Residual norm 3.382859925495e-08
291 KSP Residual norm 3.272254071820e-08
292 KSP Residual norm 3.159897496630e-08
293 KSP Residual norm 3.099830572543e-08
294 KSP Residual norm 3.069458163886e-08
295 KSP Residual norm 2.999994770743e-08
296 KSP Residual norm 2.873730715789e-08
297 KSP Residual norm 2.745438793752e-08
298 KSP Residual norm 2.628436769098e-08
299 KSP Residual norm 2.522290033571e-08
300 KSP Residual norm 2.434466522422e-08
301 KSP Residual norm 2.357979630080e-08
302 KSP Residual norm 2.298724743201e-08
303 KSP Residual norm 2.258309215111e-08
304 KSP Residual norm 2.216246314543e-08
305 KSP Residual norm 2.123228971323e-08
306 KSP Residual norm 2.004822457030e-08
307 KSP Residual norm 1.910282311443e-08
308 KSP Residual norm 1.842412305820e-08
309 KSP Residual norm 1.793021931929e-08
310 KSP Residual norm 1.745501114677e-08
311 KSP Residual norm 1.701660894876e-08
312 KSP Residual norm 1.671936926765e-08
313 KSP Residual norm 1.646864912197e-08
314 KSP Residual norm 1.621505486300e-08
315 KSP Residual norm 1.598750539343e-08
316 KSP Residual norm 1.574298393330e-08
317 KSP Residual norm 1.546453840427e-08
318 KSP Residual norm 1.507022226293e-08
319 KSP Residual norm 1.467955120116e-08
320 KSP Residual norm 1.430865106359e-08
321 KSP Residual norm 1.403474714095e-08
322 KSP Residual norm 1.375648423156e-08
323 KSP Residual norm 1.352226519817e-08
324 KSP Residual norm 1.332856735609e-08
325 KSP Residual norm 1.299779043530e-08
326 KSP Residual norm 1.245372080308e-08
327 KSP Residual norm 1.190284042934e-08
328 KSP Residual norm 1.146089554134e-08
329 KSP Residual norm 1.110265416383e-08
330 KSP Residual norm 1.076819154460e-08
331 KSP Residual norm 1.050441720500e-08
332 KSP Residual norm 1.029079116154e-08
333 KSP Residual norm 1.013276118066e-08
334 KSP Residual norm 9.907342265802e-09
335 KSP Residual norm 9.526639683167e-09
336 KSP Residual norm 9.143902802023e-09
337 KSP Residual norm 8.855927587539e-09
338 KSP Residual norm 8.609692475267e-09
339 KSP Residual norm 8.372049188436e-09
340 KSP Residual norm 8.205268848155e-09
341 KSP Residual norm 8.111926692189e-09
342 KSP Residual norm 8.017477344214e-09
343 KSP Residual norm 7.791491464387e-09
344 KSP Residual norm 7.515900475468e-09
345 KSP Residual norm 7.273701758829e-09
346 KSP Residual norm 7.041856145086e-09
347 KSP Residual norm 6.782344645633e-09
348 KSP Residual norm 6.534436936293e-09
349 KSP Residual norm 6.331824728641e-09
350 KSP Residual norm 6.122563319983e-09
351 KSP Residual norm 5.906364443527e-09
352 KSP Residual norm 5.670605930012e-09
353 KSP Residual norm 5.441953958170e-09
354 KSP Residual norm 5.238521929389e-09
355 KSP Residual norm 5.075404447809e-09
356 KSP Residual norm 4.919978357104e-09
357 KSP Residual norm 4.714768946614e-09
358 KSP Residual norm 4.509305200417e-09
359 KSP Residual norm 4.340767241167e-09
360 KSP Residual norm 4.182717828382e-09
361 KSP Residual norm 4.038445446197e-09
362 KSP Residual norm 3.875618562620e-09
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 362
0 LS Function value: 0.0691413, Step length: 0.
1 LS Function value: 0.0691394, Step length: 1.
stx: 0., fx: 0.0691413, dgx: -3.36905e-06
sty: 0., fy: 0.0691413, dgy: -3.36905e-06
24 TAO, Function value: 0.0691394, Residual: 0.000136972
0 KSP Residual norm 1.369715054972e-04
1 KSP Residual norm 1.427374650777e-04
2 KSP Residual norm 1.170547361542e-04
3 KSP Residual norm 1.200696079248e-04
4 KSP Residual norm 1.216593491442e-04
5 KSP Residual norm 1.213490903396e-04
6 KSP Residual norm 1.234258500040e-04
7 KSP Residual norm 1.258755093439e-04
8 KSP Residual norm 1.249877912703e-04
9 KSP Residual norm 1.234353435612e-04
10 KSP Residual norm 1.208435951779e-04
11 KSP Residual norm 1.161632999145e-04
12 KSP Residual norm 1.085833045757e-04
13 KSP Residual norm 1.004411572208e-04
14 KSP Residual norm 9.194947798856e-05
15 KSP Residual norm 8.256638946919e-05
16 KSP Residual norm 7.399752031762e-05
17 KSP Residual norm 6.661084091562e-05
18 KSP Residual norm 5.987395651737e-05
19 KSP Residual norm 5.334615633229e-05
20 KSP Residual norm 4.743016698481e-05
21 KSP Residual norm 4.236207237447e-05
22 KSP Residual norm 3.858375615320e-05
23 KSP Residual norm 3.563311414780e-05
24 KSP Residual norm 3.329759493202e-05
25 KSP Residual norm 3.170121767725e-05
26 KSP Residual norm 3.028575265084e-05
27 KSP Residual norm 2.912009196816e-05
28 KSP Residual norm 2.852652255743e-05
29 KSP Residual norm 2.844776382644e-05
30 KSP Residual norm 2.890731289856e-05
31 KSP Residual norm 3.010120133699e-05
32 KSP Residual norm 3.145161758921e-05
33 KSP Residual norm 3.224962621763e-05
34 KSP Residual norm 3.327879854930e-05
35 KSP Residual norm 3.446215286211e-05
36 KSP Residual norm 3.556123407045e-05
37 KSP Residual norm 3.670162266487e-05
38 KSP Residual norm 3.764180198464e-05
39 KSP Residual norm 3.836715835986e-05
40 KSP Residual norm 3.870554194276e-05
41 KSP Residual norm 3.853372448602e-05
42 KSP Residual norm 3.805620207279e-05
43 KSP Residual norm 3.733503549287e-05
44 KSP Residual norm 3.647963431672e-05
45 KSP Residual norm 3.532962795120e-05
46 KSP Residual norm 3.412269434590e-05
47 KSP Residual norm 3.299626226972e-05
48 KSP Residual norm 3.175489960804e-05
49 KSP Residual norm 3.042748439495e-05
50 KSP Residual norm 2.894164191152e-05
51 KSP Residual norm 2.744148870372e-05
52 KSP Residual norm 2.601078560028e-05
53 KSP Residual norm 2.476287622655e-05
54 KSP Residual norm 2.367278429871e-05
55 KSP Residual norm 2.256253180915e-05
56 KSP Residual norm 2.148821515202e-05
57 KSP Residual norm 2.052703577106e-05
58 KSP Residual norm 1.980182711842e-05
59 KSP Residual norm 1.917813966260e-05
60 KSP Residual norm 1.864817658151e-05
61 KSP Residual norm 1.821740092310e-05
62 KSP Residual norm 1.781240131109e-05
63 KSP Residual norm 1.734484106761e-05
64 KSP Residual norm 1.677873731902e-05
65 KSP Residual norm 1.614966960403e-05
66 KSP Residual norm 1.547215927428e-05
67 KSP Residual norm 1.479582004441e-05
68 KSP Residual norm 1.407017320473e-05
69 KSP Residual norm 1.329802211564e-05
70 KSP Residual norm 1.249580137316e-05
71 KSP Residual norm 1.168051340910e-05
72 KSP Residual norm 1.087744395060e-05
73 KSP Residual norm 1.011388512913e-05
74 KSP Residual norm 9.418978654494e-06
75 KSP Residual norm 8.819479022617e-06
76 KSP Residual norm 8.265837847848e-06
77 KSP Residual norm 7.674730265840e-06
78 KSP Residual norm 7.100341241784e-06
79 KSP Residual norm 6.619840099996e-06
80 KSP Residual norm 6.208795360303e-06
81 KSP Residual norm 5.841758912721e-06
82 KSP Residual norm 5.567604588460e-06
83 KSP Residual norm 5.403394121212e-06
84 KSP Residual norm 5.234240584307e-06
85 KSP Residual norm 4.962485687155e-06
86 KSP Residual norm 4.696253851608e-06
87 KSP Residual norm 4.432146974696e-06
88 KSP Residual norm 4.177281676427e-06
89 KSP Residual norm 3.942005452610e-06
90 KSP Residual norm 3.726896469123e-06
91 KSP Residual norm 3.550138793012e-06
92 KSP Residual norm 3.344827364759e-06
93 KSP Residual norm 3.131137013093e-06
94 KSP Residual norm 2.926565783011e-06
95 KSP Residual norm 2.759533734007e-06
96 KSP Residual norm 2.621350351432e-06
97 KSP Residual norm 2.504961062890e-06
98 KSP Residual norm 2.379175814744e-06
99 KSP Residual norm 2.270895827931e-06
100 KSP Residual norm 2.172200130831e-06
101 KSP Residual norm 2.091883825186e-06
102 KSP Residual norm 2.012143260581e-06
103 KSP Residual norm 1.943592993541e-06
104 KSP Residual norm 1.880339568256e-06
105 KSP Residual norm 1.832101695176e-06
106 KSP Residual norm 1.799196174418e-06
107 KSP Residual norm 1.770990096764e-06
108 KSP Residual norm 1.748270917788e-06
109 KSP Residual norm 1.756664809371e-06
110 KSP Residual norm 1.796687651648e-06
111 KSP Residual norm 1.797453718646e-06
112 KSP Residual norm 1.749611522865e-06
113 KSP Residual norm 1.723873964103e-06
114 KSP Residual norm 1.712630285295e-06
115 KSP Residual norm 1.714044749972e-06
116 KSP Residual norm 1.725129317033e-06
117 KSP Residual norm 1.746559653468e-06
118 KSP Residual norm 1.776898180772e-06
119 KSP Residual norm 1.819831664322e-06
120 KSP Residual norm 1.851519336954e-06
121 KSP Residual norm 1.856390623101e-06
122 KSP Residual norm 1.854949458719e-06
123 KSP Residual norm 1.863318793463e-06
124 KSP Residual norm 1.871196736244e-06
125 KSP Residual norm 1.878953713288e-06
126 KSP Residual norm 1.892344936557e-06
127 KSP Residual norm 1.900312148413e-06
128 KSP Residual norm 1.897429036721e-06
129 KSP Residual norm 1.874346070186e-06
130 KSP Residual norm 1.825339281808e-06
131 KSP Residual norm 1.772200400485e-06
132 KSP Residual norm 1.711224945342e-06
133 KSP Residual norm 1.635747750196e-06
134 KSP Residual norm 1.534131234239e-06
135 KSP Residual norm 1.430590558691e-06
136 KSP Residual norm 1.339901856433e-06
137 KSP Residual norm 1.260318178102e-06
138 KSP Residual norm 1.178697473840e-06
139 KSP Residual norm 1.102563482531e-06
140 KSP Residual norm 1.039365202406e-06
141 KSP Residual norm 9.842153889473e-07
142 KSP Residual norm 9.359309421927e-07
143 KSP Residual norm 8.910723185465e-07
144 KSP Residual norm 8.533137468572e-07
145 KSP Residual norm 8.099814580532e-07
146 KSP Residual norm 7.580002657785e-07
147 KSP Residual norm 7.119211173463e-07
148 KSP Residual norm 6.774617214522e-07
149 KSP Residual norm 6.477832209936e-07
150 KSP Residual norm 6.143074168231e-07
151 KSP Residual norm 5.815192028173e-07
152 KSP Residual norm 5.549971160383e-07
153 KSP Residual norm 5.367318003887e-07
154 KSP Residual norm 5.180966839589e-07
155 KSP Residual norm 4.865277850619e-07
156 KSP Residual norm 4.564395085916e-07
157 KSP Residual norm 4.343469869975e-07
158 KSP Residual norm 4.177791047205e-07
159 KSP Residual norm 4.039132797722e-07
160 KSP Residual norm 3.922271187426e-07
161 KSP Residual norm 3.825407597701e-07
162 KSP Residual norm 3.717440509350e-07
163 KSP Residual norm 3.611649068876e-07
164 KSP Residual norm 3.523367109002e-07
165 KSP Residual norm 3.453198978467e-07
166 KSP Residual norm 3.393506213586e-07
167 KSP Residual norm 3.324701010951e-07
168 KSP Residual norm 3.252392195117e-07
169 KSP Residual norm 3.171999817490e-07
170 KSP Residual norm 3.093676385616e-07
171 KSP Residual norm 3.011488965549e-07
172 KSP Residual norm 2.915123959489e-07
173 KSP Residual norm 2.810514880365e-07
174 KSP Residual norm 2.684156279695e-07
175 KSP Residual norm 2.547119462362e-07
176 KSP Residual norm 2.407159360858e-07
177 KSP Residual norm 2.283107761335e-07
178 KSP Residual norm 2.170842300700e-07
179 KSP Residual norm 2.075437520876e-07
180 KSP Residual norm 1.983573279902e-07
181 KSP Residual norm 1.888033501108e-07
182 KSP Residual norm 1.787232851984e-07
183 KSP Residual norm 1.698457405803e-07
184 KSP Residual norm 1.614272552660e-07
185 KSP Residual norm 1.537096831077e-07
186 KSP Residual norm 1.456389957360e-07
187 KSP Residual norm 1.398050748801e-07
188 KSP Residual norm 1.343965533620e-07
189 KSP Residual norm 1.280792062064e-07
190 KSP Residual norm 1.200110375020e-07
191 KSP Residual norm 1.119292466282e-07
192 KSP Residual norm 1.052047795990e-07
193 KSP Residual norm 9.908226087476e-08
194 KSP Residual norm 9.388059474020e-08
195 KSP Residual norm 8.963675334158e-08
196 KSP Residual norm 8.747340117899e-08
197 KSP Residual norm 8.581797288820e-08
198 KSP Residual norm 8.046986696708e-08
199 KSP Residual norm 7.522396600576e-08
200 KSP Residual norm 7.174712079691e-08
201 KSP Residual norm 6.901102011616e-08
202 KSP Residual norm 6.690569048555e-08
203 KSP Residual norm 6.510902908886e-08
204 KSP Residual norm 6.340414883560e-08
205 KSP Residual norm 6.116468862149e-08
206 KSP Residual norm 5.862959724903e-08
207 KSP Residual norm 5.665736759325e-08
208 KSP Residual norm 5.549209175987e-08
209 KSP Residual norm 5.429877181257e-08
210 KSP Residual norm 5.230105398757e-08
211 KSP Residual norm 5.036885645456e-08
212 KSP Residual norm 4.904966365541e-08
213 KSP Residual norm 4.795070243980e-08
214 KSP Residual norm 4.653891431113e-08
215 KSP Residual norm 4.514313341263e-08
216 KSP Residual norm 4.385579403783e-08
217 KSP Residual norm 4.275436735279e-08
218 KSP Residual norm 4.165737279682e-08
219 KSP Residual norm 4.043296916036e-08
220 KSP Residual norm 3.910118893599e-08
221 KSP Residual norm 3.783103170977e-08
222 KSP Residual norm 3.638741512560e-08
223 KSP Residual norm 3.471307015352e-08
224 KSP Residual norm 3.339447669209e-08
225 KSP Residual norm 3.236869920598e-08
226 KSP Residual norm 3.111706620247e-08
227 KSP Residual norm 2.986271936933e-08
228 KSP Residual norm 2.891977629545e-08
229 KSP Residual norm 2.815809908620e-08
230 KSP Residual norm 2.742180957835e-08
231 KSP Residual norm 2.667857103060e-08
232 KSP Residual norm 2.585244712323e-08
233 KSP Residual norm 2.496464673978e-08
234 KSP Residual norm 2.405981619653e-08
235 KSP Residual norm 2.314965502315e-08
236 KSP Residual norm 2.231458434452e-08
237 KSP Residual norm 2.156337873227e-08
238 KSP Residual norm 2.077769039153e-08
239 KSP Residual norm 1.998905260073e-08
240 KSP Residual norm 1.923918600966e-08
241 KSP Residual norm 1.856551607786e-08
242 KSP Residual norm 1.798385039494e-08
243 KSP Residual norm 1.749972110971e-08
244 KSP Residual norm 1.717243983139e-08
245 KSP Residual norm 1.700011898060e-08
246 KSP Residual norm 1.675575289178e-08
247 KSP Residual norm 1.633336366485e-08
248 KSP Residual norm 1.584218901373e-08
249 KSP Residual norm 1.534001951699e-08
250 KSP Residual norm 1.487462095113e-08
251 KSP Residual norm 1.443960975088e-08
252 KSP Residual norm 1.399211952487e-08
253 KSP Residual norm 1.354991892573e-08
254 KSP Residual norm 1.319014863969e-08
255 KSP Residual norm 1.284389230347e-08
256 KSP Residual norm 1.245531765808e-08
257 KSP Residual norm 1.197002734106e-08
258 KSP Residual norm 1.140409133049e-08
259 KSP Residual norm 1.087632592303e-08
260 KSP Residual norm 1.044331131911e-08
261 KSP Residual norm 1.005955273988e-08
262 KSP Residual norm 9.713849434221e-09
263 KSP Residual norm 9.441777434239e-09
264 KSP Residual norm 9.207091712794e-09
265 KSP Residual norm 8.987238595528e-09
266 KSP Residual norm 8.823177985750e-09
267 KSP Residual norm 8.701079227787e-09
268 KSP Residual norm 8.561792923106e-09
269 KSP Residual norm 8.326168190578e-09
270 KSP Residual norm 8.041000911848e-09
271 KSP Residual norm 7.801761220241e-09
272 KSP Residual norm 7.554139092007e-09
273 KSP Residual norm 7.306705618033e-09
274 KSP Residual norm 7.077583867408e-09
275 KSP Residual norm 6.891770099074e-09
276 KSP Residual norm 6.725514985579e-09
277 KSP Residual norm 6.525647478946e-09
278 KSP Residual norm 6.305604446856e-09
279 KSP Residual norm 6.081479823646e-09
280 KSP Residual norm 5.908683437780e-09
281 KSP Residual norm 5.829534365497e-09
282 KSP Residual norm 5.706402979339e-09
283 KSP Residual norm 5.402828754684e-09
284 KSP Residual norm 5.113906133755e-09
285 KSP Residual norm 4.911560713902e-09
286 KSP Residual norm 4.747777909774e-09
287 KSP Residual norm 4.672365664044e-09
288 KSP Residual norm 4.644285196856e-09
289 KSP Residual norm 4.470148031321e-09
290 KSP Residual norm 4.225547128275e-09
291 KSP Residual norm 4.052939774057e-09
292 KSP Residual norm 3.926865184193e-09
293 KSP Residual norm 3.797240602052e-09
294 KSP Residual norm 3.656875849037e-09
295 KSP Residual norm 3.542142691057e-09
296 KSP Residual norm 3.507322324056e-09
297 KSP Residual norm 3.473651609106e-09
298 KSP Residual norm 3.322624905585e-09
299 KSP Residual norm 3.179110792497e-09
300 KSP Residual norm 3.099290766449e-09
301 KSP Residual norm 3.060485499823e-09
302 KSP Residual norm 3.020595050904e-09
303 KSP Residual norm 2.988394548842e-09
304 KSP Residual norm 2.974449448775e-09
305 KSP Residual norm 2.978925959763e-09
306 KSP Residual norm 2.992613716416e-09
307 KSP Residual norm 2.987599619696e-09
308 KSP Residual norm 2.970667244988e-09
309 KSP Residual norm 2.935863764739e-09
310 KSP Residual norm 2.881801932798e-09
311 KSP Residual norm 2.838520654725e-09
312 KSP Residual norm 2.809798082630e-09
313 KSP Residual norm 2.762244607602e-09
314 KSP Residual norm 2.694172965472e-09
315 KSP Residual norm 2.621566217797e-09
316 KSP Residual norm 2.551643274637e-09
317 KSP Residual norm 2.482435577544e-09
318 KSP Residual norm 2.414032796846e-09
319 KSP Residual norm 2.338608269151e-09
320 KSP Residual norm 2.266964329768e-09
321 KSP Residual norm 2.194450850780e-09
322 KSP Residual norm 2.113320585691e-09
323 KSP Residual norm 2.022782099591e-09
324 KSP Residual norm 1.930095114779e-09
325 KSP Residual norm 1.845233250560e-09
326 KSP Residual norm 1.765756632761e-09
327 KSP Residual norm 1.689449704473e-09
328 KSP Residual norm 1.626756325544e-09
329 KSP Residual norm 1.575852491489e-09
330 KSP Residual norm 1.527842750982e-09
331 KSP Residual norm 1.478463972930e-09
332 KSP Residual norm 1.432472014086e-09
333 KSP Residual norm 1.387151879043e-09
334 KSP Residual norm 1.344838260832e-09
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 334
0 LS Function value: 0.0691394, Step length: 0.
1 LS Function value: 0.0691393, Step length: 1.
stx: 0., fx: 0.0691394, dgx: -3.27902e-07
sty: 0., fy: 0.0691394, dgy: -3.27902e-07
25 TAO, Function value: 0.0691393, Residual: 0.000151866
0 KSP Residual norm 1.518663160494e-04
1 KSP Residual norm 1.257176766664e-04
2 KSP Residual norm 8.072597050786e-05
3 KSP Residual norm 6.862727736888e-05
4 KSP Residual norm 5.564968381826e-05
5 KSP Residual norm 4.979503604791e-05
6 KSP Residual norm 4.567948444705e-05
7 KSP Residual norm 4.313861699824e-05
8 KSP Residual norm 4.156150778980e-05
9 KSP Residual norm 4.067760456724e-05
10 KSP Residual norm 4.121755141201e-05
11 KSP Residual norm 4.145275501840e-05
12 KSP Residual norm 4.162140332027e-05
13 KSP Residual norm 4.221078775255e-05
14 KSP Residual norm 4.238555358157e-05
15 KSP Residual norm 4.139566775838e-05
16 KSP Residual norm 4.065896118090e-05
17 KSP Residual norm 3.994341628002e-05
18 KSP Residual norm 3.875636148099e-05
19 KSP Residual norm 3.724346096428e-05
20 KSP Residual norm 3.558911985522e-05
21 KSP Residual norm 3.380019527237e-05
22 KSP Residual norm 3.187138259663e-05
23 KSP Residual norm 2.998110867883e-05
24 KSP Residual norm 2.812216423764e-05
25 KSP Residual norm 2.629917758665e-05
26 KSP Residual norm 2.474610460256e-05
27 KSP Residual norm 2.327338424764e-05
28 KSP Residual norm 2.159322337955e-05
29 KSP Residual norm 1.996655210135e-05
30 KSP Residual norm 1.867144700422e-05
31 KSP Residual norm 1.768035572293e-05
32 KSP Residual norm 1.695727293947e-05
33 KSP Residual norm 1.652356819271e-05
34 KSP Residual norm 1.611650412478e-05
35 KSP Residual norm 1.539299816670e-05
36 KSP Residual norm 1.475812030829e-05
37 KSP Residual norm 1.434865785976e-05
38 KSP Residual norm 1.410075772185e-05
39 KSP Residual norm 1.397808392457e-05
40 KSP Residual norm 1.388096895389e-05
41 KSP Residual norm 1.379078697979e-05
42 KSP Residual norm 1.368991065430e-05
43 KSP Residual norm 1.353444284376e-05
44 KSP Residual norm 1.327660397716e-05
45 KSP Residual norm 1.290849333899e-05
46 KSP Residual norm 1.249421269418e-05
47 KSP Residual norm 1.197622039676e-05
48 KSP Residual norm 1.135201964481e-05
49 KSP Residual norm 1.067871177097e-05
50 KSP Residual norm 9.981673791191e-06
51 KSP Residual norm 9.301208979769e-06
52 KSP Residual norm 8.617850192041e-06
53 KSP Residual norm 7.919790795683e-06
54 KSP Residual norm 7.227218417630e-06
55 KSP Residual norm 6.578921223359e-06
56 KSP Residual norm 6.002507779656e-06
57 KSP Residual norm 5.481717367013e-06
58 KSP Residual norm 4.980151046066e-06
59 KSP Residual norm 4.503461598380e-06
60 KSP Residual norm 4.074297869203e-06
61 KSP Residual norm 3.701529625722e-06
62 KSP Residual norm 3.374196999599e-06
63 KSP Residual norm 3.085859797437e-06
64 KSP Residual norm 2.838347413430e-06
65 KSP Residual norm 2.621286129237e-06
66 KSP Residual norm 2.406695167726e-06
67 KSP Residual norm 2.198327546366e-06
68 KSP Residual norm 2.022585480849e-06
69 KSP Residual norm 1.881782116683e-06
70 KSP Residual norm 1.759698310430e-06
71 KSP Residual norm 1.652584839564e-06
72 KSP Residual norm 1.553744752141e-06
73 KSP Residual norm 1.450799731351e-06
74 KSP Residual norm 1.354776155561e-06
75 KSP Residual norm 1.269644159919e-06
76 KSP Residual norm 1.183606950227e-06
77 KSP Residual norm 1.104531038468e-06
78 KSP Residual norm 1.040518865213e-06
79 KSP Residual norm 9.788023876926e-07
80 KSP Residual norm 9.271451965247e-07
81 KSP Residual norm 8.803949117943e-07
82 KSP Residual norm 8.165719167672e-07
83 KSP Residual norm 7.549757661209e-07
84 KSP Residual norm 7.062071702356e-07
85 KSP Residual norm 6.633569453089e-07
86 KSP Residual norm 6.164141745231e-07
87 KSP Residual norm 5.639568609742e-07
88 KSP Residual norm 5.189243717299e-07
89 KSP Residual norm 4.809697004119e-07
90 KSP Residual norm 4.470766623229e-07
91 KSP Residual norm 4.153858239437e-07
92 KSP Residual norm 3.852828410284e-07
93 KSP Residual norm 3.586485572035e-07
94 KSP Residual norm 3.316244555044e-07
95 KSP Residual norm 3.091803468564e-07
96 KSP Residual norm 2.881365242636e-07
97 KSP Residual norm 2.691922099966e-07
98 KSP Residual norm 2.523977115787e-07
99 KSP Residual norm 2.364344849726e-07
100 KSP Residual norm 2.243812959695e-07
101 KSP Residual norm 2.132753826803e-07
102 KSP Residual norm 2.033293257368e-07
103 KSP Residual norm 1.941827918120e-07
104 KSP Residual norm 1.837021926346e-07
105 KSP Residual norm 1.756651186327e-07
106 KSP Residual norm 1.695196920651e-07
107 KSP Residual norm 1.644904104582e-07
108 KSP Residual norm 1.568273622659e-07
109 KSP Residual norm 1.482819459034e-07
110 KSP Residual norm 1.408150634750e-07
111 KSP Residual norm 1.350494470586e-07
112 KSP Residual norm 1.303787629537e-07
113 KSP Residual norm 1.270852325294e-07
114 KSP Residual norm 1.243034312264e-07
115 KSP Residual norm 1.215097892541e-07
116 KSP Residual norm 1.168602930639e-07
117 KSP Residual norm 1.115795266794e-07
118 KSP Residual norm 1.071099374969e-07
119 KSP Residual norm 1.033777386130e-07
120 KSP Residual norm 9.971322689897e-08
121 KSP Residual norm 9.617446869692e-08
122 KSP Residual norm 9.275811813570e-08
123 KSP Residual norm 8.931599895240e-08
124 KSP Residual norm 8.654556274781e-08
125 KSP Residual norm 8.490086986812e-08
126 KSP Residual norm 8.489166014653e-08
127 KSP Residual norm 8.542511549649e-08
128 KSP Residual norm 8.315200698335e-08
129 KSP Residual norm 8.053814393295e-08
130 KSP Residual norm 7.929050202597e-08
131 KSP Residual norm 7.903061203078e-08
132 KSP Residual norm 7.943564117043e-08
133 KSP Residual norm 8.040794829039e-08
134 KSP Residual norm 8.191038362071e-08
135 KSP Residual norm 8.376296472029e-08
136 KSP Residual norm 8.596852950200e-08
137 KSP Residual norm 8.856344274769e-08
138 KSP Residual norm 9.120930734000e-08
139 KSP Residual norm 9.303734165109e-08
140 KSP Residual norm 9.409058164394e-08
141 KSP Residual norm 9.520217099851e-08
142 KSP Residual norm 9.622722621641e-08
143 KSP Residual norm 9.630537509729e-08
144 KSP Residual norm 9.553324233703e-08
145 KSP Residual norm 9.432593707351e-08
146 KSP Residual norm 9.259100868785e-08
147 KSP Residual norm 9.050980036052e-08
148 KSP Residual norm 8.792415277157e-08
149 KSP Residual norm 8.454343627720e-08
150 KSP Residual norm 8.116735341365e-08
151 KSP Residual norm 7.893449548859e-08
152 KSP Residual norm 7.735190787774e-08
153 KSP Residual norm 7.268249654355e-08
154 KSP Residual norm 6.668120676646e-08
155 KSP Residual norm 6.168893583280e-08
156 KSP Residual norm 5.730715165927e-08
157 KSP Residual norm 5.312733744096e-08
158 KSP Residual norm 4.904802544406e-08
159 KSP Residual norm 4.533045823781e-08
160 KSP Residual norm 4.209697730387e-08
161 KSP Residual norm 3.915853481595e-08
162 KSP Residual norm 3.639564265851e-08
163 KSP Residual norm 3.388298793163e-08
164 KSP Residual norm 3.162497623246e-08
165 KSP Residual norm 2.979132649825e-08
166 KSP Residual norm 2.828543334965e-08
167 KSP Residual norm 2.688372352317e-08
168 KSP Residual norm 2.552678520687e-08
169 KSP Residual norm 2.424584545742e-08
170 KSP Residual norm 2.306533830979e-08
171 KSP Residual norm 2.206330608085e-08
172 KSP Residual norm 2.119082765691e-08
173 KSP Residual norm 2.033801455521e-08
174 KSP Residual norm 1.955148784843e-08
175 KSP Residual norm 1.882762766655e-08
176 KSP Residual norm 1.822939026475e-08
177 KSP Residual norm 1.770886509597e-08
178 KSP Residual norm 1.723257278681e-08
179 KSP Residual norm 1.686681814853e-08
180 KSP Residual norm 1.659000024132e-08
181 KSP Residual norm 1.643889492751e-08
182 KSP Residual norm 1.633798470070e-08
183 KSP Residual norm 1.633309522344e-08
184 KSP Residual norm 1.644801705021e-08
185 KSP Residual norm 1.681975762906e-08
186 KSP Residual norm 1.723192526814e-08
187 KSP Residual norm 1.726226819104e-08
188 KSP Residual norm 1.713973006717e-08
189 KSP Residual norm 1.733481613893e-08
190 KSP Residual norm 1.763781550270e-08
191 KSP Residual norm 1.768486099333e-08
192 KSP Residual norm 1.737561993665e-08
193 KSP Residual norm 1.713072845091e-08
194 KSP Residual norm 1.692988619969e-08
195 KSP Residual norm 1.675386139450e-08
196 KSP Residual norm 1.644551094814e-08
197 KSP Residual norm 1.599931337612e-08
198 KSP Residual norm 1.554561100704e-08
199 KSP Residual norm 1.511422681765e-08
200 KSP Residual norm 1.475415440985e-08
201 KSP Residual norm 1.446062633827e-08
202 KSP Residual norm 1.411477439835e-08
203 KSP Residual norm 1.359539611548e-08
204 KSP Residual norm 1.302056655368e-08
205 KSP Residual norm 1.249585767552e-08
206 KSP Residual norm 1.199231347094e-08
207 KSP Residual norm 1.149725260810e-08
208 KSP Residual norm 1.102124340278e-08
209 KSP Residual norm 1.057783295845e-08
210 KSP Residual norm 1.021307208178e-08
211 KSP Residual norm 9.918257022328e-09
212 KSP Residual norm 9.489973048604e-09
213 KSP Residual norm 8.871057734813e-09
214 KSP Residual norm 8.302994599919e-09
215 KSP Residual norm 7.850359553459e-09
216 KSP Residual norm 7.475761977642e-09
217 KSP Residual norm 7.146130248860e-09
218 KSP Residual norm 6.826366641328e-09
219 KSP Residual norm 6.574754411755e-09
220 KSP Residual norm 6.419821202184e-09
221 KSP Residual norm 6.175687968731e-09
222 KSP Residual norm 5.757823354335e-09
223 KSP Residual norm 5.417388630891e-09
224 KSP Residual norm 5.197943416699e-09
225 KSP Residual norm 5.025603499363e-09
226 KSP Residual norm 4.833952906136e-09
227 KSP Residual norm 4.616661074854e-09
228 KSP Residual norm 4.417122380989e-09
229 KSP Residual norm 4.247098180643e-09
230 KSP Residual norm 4.101682019156e-09
231 KSP Residual norm 3.979669220686e-09
232 KSP Residual norm 3.880518874417e-09
233 KSP Residual norm 3.792322278728e-09
234 KSP Residual norm 3.700469470823e-09
235 KSP Residual norm 3.601149656941e-09
236 KSP Residual norm 3.527017493906e-09
237 KSP Residual norm 3.483594811297e-09
238 KSP Residual norm 3.444050282132e-09
239 KSP Residual norm 3.386951995403e-09
240 KSP Residual norm 3.325044158192e-09
241 KSP Residual norm 3.277020039010e-09
242 KSP Residual norm 3.241260093023e-09
243 KSP Residual norm 3.195338451722e-09
244 KSP Residual norm 3.114945004260e-09
245 KSP Residual norm 3.030021894052e-09
246 KSP Residual norm 2.940336953854e-09
247 KSP Residual norm 2.823311136558e-09
248 KSP Residual norm 2.699824479443e-09
249 KSP Residual norm 2.598001807103e-09
250 KSP Residual norm 2.519552673811e-09
251 KSP Residual norm 2.452540848932e-09
252 KSP Residual norm 2.378385866540e-09
253 KSP Residual norm 2.308262603198e-09
254 KSP Residual norm 2.244274452072e-09
255 KSP Residual norm 2.172065817421e-09
256 KSP Residual norm 2.099863621657e-09
257 KSP Residual norm 2.023581847076e-09
258 KSP Residual norm 1.943215909075e-09
259 KSP Residual norm 1.865543115257e-09
260 KSP Residual norm 1.794965834621e-09
261 KSP Residual norm 1.727856794270e-09
262 KSP Residual norm 1.660305436157e-09
263 KSP Residual norm 1.599887827583e-09
264 KSP Residual norm 1.544036202843e-09
265 KSP Residual norm 1.495637008995e-09
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 265
0 LS Function value: 0.0691393, Step length: 0.
1 LS Function value: 0.0691392, Step length: 1.
stx: 0., fx: 0.0691393, dgx: -1.04908e-07
sty: 0., fy: 0.0691393, dgy: -1.04908e-07
26 TAO, Function value: 0.0691392, Residual: 3.23442e-05
Residual norms for tao_nls_ solve.
0 KSP Residual norm 3.234417226828e-05
1 KSP Residual norm 2.918994650781e-05
2 KSP Residual norm 2.259532352509e-05
3 KSP Residual norm 2.301417502224e-05
4 KSP Residual norm 2.147131420613e-05
5 KSP Residual norm 2.386687310913e-05
6 KSP Residual norm 2.648996072720e-05
7 KSP Residual norm 3.042104386720e-05
8 KSP Residual norm 3.367931056471e-05
9 KSP Residual norm 3.746402969607e-05
10 KSP Residual norm 4.142694856989e-05
11 KSP Residual norm 4.456640674414e-05
12 KSP Residual norm 4.826726292119e-05
13 KSP Residual norm 5.241781563194e-05
14 KSP Residual norm 5.538477682788e-05
15 KSP Residual norm 5.804026621047e-05
16 KSP Residual norm 6.055458107341e-05
17 KSP Residual norm 6.233777865002e-05
18 KSP Residual norm 6.304163855096e-05
19 KSP Residual norm 6.270837678169e-05
20 KSP Residual norm 6.179003362611e-05
21 KSP Residual norm 6.033926713373e-05
22 KSP Residual norm 5.886921074048e-05
23 KSP Residual norm 5.743907445763e-05
24 KSP Residual norm 5.555550448992e-05
25 KSP Residual norm 5.335876586759e-05
26 KSP Residual norm 5.130619904069e-05
27 KSP Residual norm 4.888716126521e-05
28 KSP Residual norm 4.537749816851e-05
29 KSP Residual norm 4.171026919495e-05
30 KSP Residual norm 3.855241110865e-05
31 KSP Residual norm 3.606423321692e-05
32 KSP Residual norm 3.443030672126e-05
33 KSP Residual norm 3.278289180883e-05
34 KSP Residual norm 3.021894499997e-05
35 KSP Residual norm 2.794820325576e-05
36 KSP Residual norm 2.634828964616e-05
37 KSP Residual norm 2.510776860350e-05
38 KSP Residual norm 2.409810449662e-05
39 KSP Residual norm 2.321885845712e-05
40 KSP Residual norm 2.234368882697e-05
41 KSP Residual norm 2.154351939133e-05
42 KSP Residual norm 2.083280278913e-05
43 KSP Residual norm 2.012185997158e-05
44 KSP Residual norm 1.928939483974e-05
45 KSP Residual norm 1.832150757344e-05
46 KSP Residual norm 1.732795831619e-05
47 KSP Residual norm 1.629985536599e-05
48 KSP Residual norm 1.524222711918e-05
49 KSP Residual norm 1.419755769992e-05
50 KSP Residual norm 1.319486099811e-05
51 KSP Residual norm 1.228334543135e-05
52 KSP Residual norm 1.145286432541e-05
53 KSP Residual norm 1.066878318114e-05
54 KSP Residual norm 9.940896656791e-06
55 KSP Residual norm 9.280518796691e-06
56 KSP Residual norm 8.720338162884e-06
57 KSP Residual norm 8.231405037130e-06
58 KSP Residual norm 7.761037809547e-06
59 KSP Residual norm 7.284551690565e-06
60 KSP Residual norm 6.809172256842e-06
61 KSP Residual norm 6.370188936310e-06
62 KSP Residual norm 5.967762816358e-06
63 KSP Residual norm 5.603111159668e-06
64 KSP Residual norm 5.278689462027e-06
65 KSP Residual norm 4.962460175841e-06
66 KSP Residual norm 4.610168661348e-06
67 KSP Residual norm 4.257924533821e-06
68 KSP Residual norm 3.961445567936e-06
69 KSP Residual norm 3.713923503842e-06
70 KSP Residual norm 3.474849419166e-06
71 KSP Residual norm 3.253701791033e-06
72 KSP Residual norm 3.070914555621e-06
73 KSP Residual norm 2.908181557571e-06
74 KSP Residual norm 2.777237128810e-06
75 KSP Residual norm 2.681521233617e-06
76 KSP Residual norm 2.611062319726e-06
77 KSP Residual norm 2.549924690558e-06
78 KSP Residual norm 2.443434760250e-06
79 KSP Residual norm 2.320108972969e-06
80 KSP Residual norm 2.236879844439e-06
81 KSP Residual norm 2.182163099243e-06
82 KSP Residual norm 2.120478278753e-06
83 KSP Residual norm 2.054859393046e-06
84 KSP Residual norm 1.967867559383e-06
85 KSP Residual norm 1.884423323994e-06
86 KSP Residual norm 1.803010567545e-06
87 KSP Residual norm 1.701896947862e-06
88 KSP Residual norm 1.605102310635e-06
89 KSP Residual norm 1.506396160197e-06
90 KSP Residual norm 1.397304238887e-06
91 KSP Residual norm 1.283146666108e-06
92 KSP Residual norm 1.180127787740e-06
93 KSP Residual norm 1.087306597268e-06
94 KSP Residual norm 9.935667029765e-07
95 KSP Residual norm 9.172731367786e-07
96 KSP Residual norm 8.438239445458e-07
97 KSP Residual norm 7.945464960405e-07
98 KSP Residual norm 7.333042825560e-07
99 KSP Residual norm 6.551966119811e-07
100 KSP Residual norm 5.891382716400e-07
101 KSP Residual norm 5.335106695577e-07
102 KSP Residual norm 4.851673924105e-07
103 KSP Residual norm 4.419868817609e-07
104 KSP Residual norm 3.987826823679e-07
105 KSP Residual norm 3.636775108034e-07
106 KSP Residual norm 3.323095349781e-07
107 KSP Residual norm 3.080316830228e-07
108 KSP Residual norm 2.854676922991e-07
109 KSP Residual norm 2.669936830166e-07
110 KSP Residual norm 2.494783794641e-07
111 KSP Residual norm 2.372930781943e-07
112 KSP Residual norm 2.271917553892e-07
113 KSP Residual norm 2.192712509252e-07
114 KSP Residual norm 2.059236462154e-07
115 KSP Residual norm 1.917008727185e-07
116 KSP Residual norm 1.795890425176e-07
117 KSP Residual norm 1.708185806701e-07
118 KSP Residual norm 1.638257076724e-07
119 KSP Residual norm 1.568628586611e-07
120 KSP Residual norm 1.464966025735e-07
121 KSP Residual norm 1.368662654393e-07
122 KSP Residual norm 1.276192716375e-07
123 KSP Residual norm 1.190750440253e-07
124 KSP Residual norm 1.118193449490e-07
125 KSP Residual norm 1.053500510954e-07
126 KSP Residual norm 9.932557816386e-08
127 KSP Residual norm 9.420823451359e-08
128 KSP Residual norm 9.014853320220e-08
129 KSP Residual norm 8.602765667747e-08
130 KSP Residual norm 8.083205053560e-08
131 KSP Residual norm 7.600634328557e-08
132 KSP Residual norm 7.195384811402e-08
133 KSP Residual norm 6.871002252907e-08
134 KSP Residual norm 6.606847594138e-08
135 KSP Residual norm 6.394707006973e-08
136 KSP Residual norm 6.217054736572e-08
137 KSP Residual norm 6.039434695269e-08
138 KSP Residual norm 5.893520000884e-08
139 KSP Residual norm 5.815027865021e-08
140 KSP Residual norm 5.752086279393e-08
141 KSP Residual norm 5.630288105456e-08
142 KSP Residual norm 5.529375115900e-08
143 KSP Residual norm 5.512445662376e-08
144 KSP Residual norm 5.627528719412e-08
145 KSP Residual norm 5.700756731141e-08
146 KSP Residual norm 5.589827750137e-08
147 KSP Residual norm 5.500356407398e-08
148 KSP Residual norm 5.498961246691e-08
149 KSP Residual norm 5.534656964091e-08
150 KSP Residual norm 5.591487117889e-08
151 KSP Residual norm 5.639728892705e-08
152 KSP Residual norm 5.632124681628e-08
153 KSP Residual norm 5.604343875967e-08
154 KSP Residual norm 5.591054649292e-08
155 KSP Residual norm 5.576906761131e-08
156 KSP Residual norm 5.573044479931e-08
157 KSP Residual norm 5.563177028378e-08
158 KSP Residual norm 5.519476573246e-08
159 KSP Residual norm 5.466499590450e-08
160 KSP Residual norm 5.405390877974e-08
161 KSP Residual norm 5.298509555970e-08
162 KSP Residual norm 5.145790951151e-08
163 KSP Residual norm 4.970981041670e-08
164 KSP Residual norm 4.784927131604e-08
165 KSP Residual norm 4.601314009372e-08
166 KSP Residual norm 4.414832151482e-08
167 KSP Residual norm 4.225730662747e-08
168 KSP Residual norm 4.030500514610e-08
169 KSP Residual norm 3.836504715964e-08
170 KSP Residual norm 3.640952284337e-08
171 KSP Residual norm 3.439871641430e-08
172 KSP Residual norm 3.241663582161e-08
173 KSP Residual norm 3.054744049674e-08
174 KSP Residual norm 2.877083856956e-08
175 KSP Residual norm 2.699944969158e-08
176 KSP Residual norm 2.538730458048e-08
177 KSP Residual norm 2.394872559939e-08
178 KSP Residual norm 2.268802024779e-08
179 KSP Residual norm 2.166987350062e-08
180 KSP Residual norm 2.097832015688e-08
181 KSP Residual norm 2.045402624354e-08
182 KSP Residual norm 1.940568070244e-08
183 KSP Residual norm 1.824046089049e-08
184 KSP Residual norm 1.736026559868e-08
185 KSP Residual norm 1.675887619907e-08
186 KSP Residual norm 1.631066991176e-08
187 KSP Residual norm 1.601409787504e-08
188 KSP Residual norm 1.574346566547e-08
189 KSP Residual norm 1.530569901823e-08
190 KSP Residual norm 1.475304009854e-08
191 KSP Residual norm 1.429060484940e-08
192 KSP Residual norm 1.388398866780e-08
193 KSP Residual norm 1.358340965390e-08
194 KSP Residual norm 1.328704850591e-08
195 KSP Residual norm 1.303649095265e-08
196 KSP Residual norm 1.276682592854e-08
197 KSP Residual norm 1.248965812632e-08
198 KSP Residual norm 1.220042370723e-08
199 KSP Residual norm 1.194634250308e-08
200 KSP Residual norm 1.180040319487e-08
201 KSP Residual norm 1.166848082902e-08
202 KSP Residual norm 1.128796801386e-08
203 KSP Residual norm 1.081004773740e-08
204 KSP Residual norm 1.042271102196e-08
205 KSP Residual norm 1.013285312119e-08
206 KSP Residual norm 9.953787942604e-09
207 KSP Residual norm 9.861622181758e-09
208 KSP Residual norm 9.602451912754e-09
209 KSP Residual norm 9.201857881093e-09
210 KSP Residual norm 8.902825009398e-09
211 KSP Residual norm 8.710451931656e-09
212 KSP Residual norm 8.566131589591e-09
213 KSP Residual norm 8.452107429963e-09
214 KSP Residual norm 8.333390827437e-09
215 KSP Residual norm 8.199415205024e-09
216 KSP Residual norm 8.058233285292e-09
217 KSP Residual norm 7.928543076457e-09
218 KSP Residual norm 7.798675276806e-09
219 KSP Residual norm 7.671398923819e-09
220 KSP Residual norm 7.514166050670e-09
221 KSP Residual norm 7.335159969842e-09
222 KSP Residual norm 7.155890113780e-09
223 KSP Residual norm 7.001182726713e-09
224 KSP Residual norm 6.904000293277e-09
225 KSP Residual norm 6.818762500132e-09
226 KSP Residual norm 6.648182413459e-09
227 KSP Residual norm 6.398669076853e-09
228 KSP Residual norm 6.191851303004e-09
229 KSP Residual norm 6.060248146442e-09
230 KSP Residual norm 5.973686959956e-09
231 KSP Residual norm 5.886366555588e-09
232 KSP Residual norm 5.800879704655e-09
233 KSP Residual norm 5.723057053278e-09
234 KSP Residual norm 5.627888413990e-09
235 KSP Residual norm 5.497264967251e-09
236 KSP Residual norm 5.368372951629e-09
237 KSP Residual norm 5.285001582888e-09
238 KSP Residual norm 5.242359406602e-09
239 KSP Residual norm 5.158337908053e-09
240 KSP Residual norm 4.962758163036e-09
241 KSP Residual norm 4.740963240648e-09
242 KSP Residual norm 4.545108253459e-09
243 KSP Residual norm 4.381188462489e-09
244 KSP Residual norm 4.238508696906e-09
245 KSP Residual norm 4.091840227666e-09
246 KSP Residual norm 3.916187003545e-09
247 KSP Residual norm 3.731492124165e-09
248 KSP Residual norm 3.564117678022e-09
249 KSP Residual norm 3.418683986120e-09
250 KSP Residual norm 3.287760844397e-09
251 KSP Residual norm 3.172030314199e-09
252 KSP Residual norm 3.067052959210e-09
253 KSP Residual norm 2.985643529680e-09
254 KSP Residual norm 2.924455685915e-09
255 KSP Residual norm 2.873394131188e-09
256 KSP Residual norm 2.834745685762e-09
257 KSP Residual norm 2.779897220610e-09
258 KSP Residual norm 2.696038906715e-09
259 KSP Residual norm 2.605018760067e-09
260 KSP Residual norm 2.524854300055e-09
261 KSP Residual norm 2.461113438603e-09
262 KSP Residual norm 2.406891618302e-09
263 KSP Residual norm 2.369556217385e-09
264 KSP Residual norm 2.334784017128e-09
265 KSP Residual norm 2.274139622418e-09
266 KSP Residual norm 2.183413506944e-09
267 KSP Residual norm 2.094987825309e-09
268 KSP Residual norm 2.041409508731e-09
269 KSP Residual norm 2.043871037199e-09
270 KSP Residual norm 2.062665625010e-09
271 KSP Residual norm 1.977638989467e-09
272 KSP Residual norm 1.877276391992e-09
273 KSP Residual norm 1.819486768819e-09
274 KSP Residual norm 1.783106658322e-09
275 KSP Residual norm 1.765840151958e-09
276 KSP Residual norm 1.757571823384e-09
277 KSP Residual norm 1.724976627390e-09
278 KSP Residual norm 1.667428059744e-09
279 KSP Residual norm 1.598993243835e-09
280 KSP Residual norm 1.535350247961e-09
281 KSP Residual norm 1.478598570154e-09
282 KSP Residual norm 1.424559000158e-09
283 KSP Residual norm 1.374815694882e-09
284 KSP Residual norm 1.322827012165e-09
285 KSP Residual norm 1.265608312230e-09
286 KSP Residual norm 1.213790533376e-09
287 KSP Residual norm 1.161439900851e-09
288 KSP Residual norm 1.106154903457e-09
289 KSP Residual norm 1.060453755118e-09
290 KSP Residual norm 1.019821719823e-09
291 KSP Residual norm 9.811102184207e-10
292 KSP Residual norm 9.484264130400e-10
293 KSP Residual norm 9.254138152574e-10
294 KSP Residual norm 9.015417584504e-10
295 KSP Residual norm 8.614927273138e-10
296 KSP Residual norm 8.172216315811e-10
297 KSP Residual norm 7.796814374659e-10
298 KSP Residual norm 7.462967403941e-10
299 KSP Residual norm 7.167222418579e-10
300 KSP Residual norm 6.929697257079e-10
301 KSP Residual norm 6.718875094201e-10
302 KSP Residual norm 6.502387154312e-10
303 KSP Residual norm 6.299438678745e-10
304 KSP Residual norm 6.117312680271e-10
305 KSP Residual norm 5.975589506092e-10
306 KSP Residual norm 5.827814548922e-10
307 KSP Residual norm 5.704315002691e-10
308 KSP Residual norm 5.614752920995e-10
309 KSP Residual norm 5.504226507620e-10
310 KSP Residual norm 5.321686495071e-10
311 KSP Residual norm 5.141532105511e-10
312 KSP Residual norm 4.997864353031e-10
313 KSP Residual norm 4.860964241738e-10
314 KSP Residual norm 4.735978895455e-10
315 KSP Residual norm 4.629649920207e-10
316 KSP Residual norm 4.510893120587e-10
317 KSP Residual norm 4.396044822847e-10
318 KSP Residual norm 4.304281314002e-10
319 KSP Residual norm 4.217353369170e-10
320 KSP Residual norm 4.124668817033e-10
321 KSP Residual norm 4.006105222831e-10
322 KSP Residual norm 3.890824495994e-10
323 KSP Residual norm 3.790440569389e-10
324 KSP Residual norm 3.714480912210e-10
325 KSP Residual norm 3.617346328128e-10
326 KSP Residual norm 3.502095377452e-10
327 KSP Residual norm 3.386452851654e-10
328 KSP Residual norm 3.278824692995e-10
329 KSP Residual norm 3.178187791152e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 329
0 LS Function value: 0.0691392, Step length: 0.
stx: 0., fx: 0.0691392, dgx: -9.49012e-08
sty: 0., fy: 0.0691392, dgy: -9.49012e-08
2 LS Function value: 0.0691392, Step length: 0.297235
sty: 1., fy: 0.0691394, dgy: 1.03991e-06
27 TAO, Function value: 0.0691392, Residual: 6.20716e-05
0 KSP Residual norm 6.207164296950e-05
1 KSP Residual norm 4.870239638133e-05
2 KSP Residual norm 3.408790823502e-05
3 KSP Residual norm 2.888095130127e-05
4 KSP Residual norm 2.504861751816e-05
5 KSP Residual norm 2.371230123118e-05
6 KSP Residual norm 2.327858207838e-05
7 KSP Residual norm 2.404569681595e-05
8 KSP Residual norm 2.527311314442e-05
9 KSP Residual norm 2.672851015847e-05
10 KSP Residual norm 2.905004949113e-05
11 KSP Residual norm 3.135219409509e-05
12 KSP Residual norm 3.340176597783e-05
13 KSP Residual norm 3.616214749369e-05
14 KSP Residual norm 3.927666358172e-05
15 KSP Residual norm 4.140403059493e-05
16 KSP Residual norm 4.269280282607e-05
17 KSP Residual norm 4.426956891087e-05
18 KSP Residual norm 4.542548201455e-05
19 KSP Residual norm 4.581149546611e-05
20 KSP Residual norm 4.572046307848e-05
21 KSP Residual norm 4.506624516950e-05
22 KSP Residual norm 4.424557025631e-05
23 KSP Residual norm 4.319687024479e-05
24 KSP Residual norm 4.163225481726e-05
25 KSP Residual norm 3.978619139255e-05
26 KSP Residual norm 3.792383086576e-05
27 KSP Residual norm 3.620470764580e-05
28 KSP Residual norm 3.436503219167e-05
29 KSP Residual norm 3.197310945540e-05
30 KSP Residual norm 2.922887533121e-05
31 KSP Residual norm 2.661464866145e-05
32 KSP Residual norm 2.424886768191e-05
33 KSP Residual norm 2.211120353980e-05
34 KSP Residual norm 2.023621802568e-05
35 KSP Residual norm 1.870972900428e-05
36 KSP Residual norm 1.730312447089e-05
37 KSP Residual norm 1.567845749079e-05
38 KSP Residual norm 1.414301097879e-05
39 KSP Residual norm 1.289661155197e-05
40 KSP Residual norm 1.185666622519e-05
41 KSP Residual norm 1.100120537221e-05
42 KSP Residual norm 1.033586282756e-05
43 KSP Residual norm 9.807776688677e-06
44 KSP Residual norm 9.303513451259e-06
45 KSP Residual norm 8.747925799597e-06
46 KSP Residual norm 8.197646580369e-06
47 KSP Residual norm 7.681593170030e-06
48 KSP Residual norm 7.190140687018e-06
49 KSP Residual norm 6.716638046893e-06
50 KSP Residual norm 6.267117037821e-06
51 KSP Residual norm 5.859759109712e-06
52 KSP Residual norm 5.487542072348e-06
53 KSP Residual norm 5.125079417454e-06
54 KSP Residual norm 4.768354547449e-06
55 KSP Residual norm 4.434849319674e-06
56 KSP Residual norm 4.156329118415e-06
57 KSP Residual norm 3.941777399996e-06
58 KSP Residual norm 3.777200501326e-06
59 KSP Residual norm 3.614416956937e-06
60 KSP Residual norm 3.409555241189e-06
61 KSP Residual norm 3.190479621051e-06
62 KSP Residual norm 2.988445455288e-06
63 KSP Residual norm 2.799370171558e-06
64 KSP Residual norm 2.623368903113e-06
65 KSP Residual norm 2.466703109619e-06
66 KSP Residual norm 2.318303195276e-06
67 KSP Residual norm 2.156628765537e-06
68 KSP Residual norm 1.984601978884e-06
69 KSP Residual norm 1.826865942078e-06
70 KSP Residual norm 1.677672947235e-06
71 KSP Residual norm 1.538936158198e-06
72 KSP Residual norm 1.414079153527e-06
73 KSP Residual norm 1.295625010980e-06
74 KSP Residual norm 1.194681881885e-06
75 KSP Residual norm 1.113049682749e-06
76 KSP Residual norm 1.029396561984e-06
77 KSP Residual norm 9.513755868598e-07
78 KSP Residual norm 8.917364302084e-07
79 KSP Residual norm 8.458154273030e-07
80 KSP Residual norm 8.117903441299e-07
81 KSP Residual norm 7.778704911959e-07
82 KSP Residual norm 7.379316196975e-07
83 KSP Residual norm 6.977347877653e-07
84 KSP Residual norm 6.608485013444e-07
85 KSP Residual norm 6.356219776965e-07
86 KSP Residual norm 6.205766570630e-07
87 KSP Residual norm 6.039228304723e-07
88 KSP Residual norm 5.897765764182e-07
89 KSP Residual norm 5.764193213947e-07
90 KSP Residual norm 5.609440618890e-07
91 KSP Residual norm 5.393376761912e-07
92 KSP Residual norm 5.185519458782e-07
93 KSP Residual norm 4.998965899280e-07
94 KSP Residual norm 4.791150851465e-07
95 KSP Residual norm 4.659227977942e-07
96 KSP Residual norm 4.452140935136e-07
97 KSP Residual norm 4.127311262180e-07
98 KSP Residual norm 3.805046140486e-07
99 KSP Residual norm 3.511823343617e-07
100 KSP Residual norm 3.260414946589e-07
101 KSP Residual norm 3.018501950985e-07
102 KSP Residual norm 2.763977826597e-07
103 KSP Residual norm 2.540731583568e-07
104 KSP Residual norm 2.308146010740e-07
105 KSP Residual norm 2.115927840755e-07
106 KSP Residual norm 1.930030802699e-07
107 KSP Residual norm 1.775512858830e-07
108 KSP Residual norm 1.631631230232e-07
109 KSP Residual norm 1.505392959062e-07
110 KSP Residual norm 1.389301332645e-07
111 KSP Residual norm 1.297668045645e-07
112 KSP Residual norm 1.218944885633e-07
113 KSP Residual norm 1.144432711363e-07
114 KSP Residual norm 1.060990556104e-07
115 KSP Residual norm 9.805534854088e-08
116 KSP Residual norm 9.134600734870e-08
117 KSP Residual norm 8.605227093850e-08
118 KSP Residual norm 8.245531546837e-08
119 KSP Residual norm 7.976618583618e-08
120 KSP Residual norm 7.479536962394e-08
121 KSP Residual norm 6.935675564141e-08
122 KSP Residual norm 6.508423679094e-08
123 KSP Residual norm 6.161655111675e-08
124 KSP Residual norm 5.879132258772e-08
125 KSP Residual norm 5.594030037441e-08
126 KSP Residual norm 5.291875508651e-08
127 KSP Residual norm 5.016496793775e-08
128 KSP Residual norm 4.817664281285e-08
129 KSP Residual norm 4.678675442000e-08
130 KSP Residual norm 4.554148314276e-08
131 KSP Residual norm 4.387891755553e-08
132 KSP Residual norm 4.207333810840e-08
133 KSP Residual norm 4.062670889060e-08
134 KSP Residual norm 3.964314800835e-08
135 KSP Residual norm 3.904261306892e-08
136 KSP Residual norm 3.866570690170e-08
137 KSP Residual norm 3.821786323010e-08
138 KSP Residual norm 3.771739251798e-08
139 KSP Residual norm 3.732295468132e-08
140 KSP Residual norm 3.691465928174e-08
141 KSP Residual norm 3.627260680639e-08
142 KSP Residual norm 3.558358601075e-08
143 KSP Residual norm 3.493957342658e-08
144 KSP Residual norm 3.455904290293e-08
145 KSP Residual norm 3.447305175083e-08
146 KSP Residual norm 3.467078792051e-08
147 KSP Residual norm 3.562905308650e-08
148 KSP Residual norm 3.664870524350e-08
149 KSP Residual norm 3.566840748997e-08
150 KSP Residual norm 3.465561137009e-08
151 KSP Residual norm 3.441155428207e-08
152 KSP Residual norm 3.425780038954e-08
153 KSP Residual norm 3.406098029758e-08
154 KSP Residual norm 3.396713010610e-08
155 KSP Residual norm 3.380073119785e-08
156 KSP Residual norm 3.338710250210e-08
157 KSP Residual norm 3.283503128624e-08
158 KSP Residual norm 3.221267872074e-08
159 KSP Residual norm 3.174881841429e-08
160 KSP Residual norm 3.143162046303e-08
161 KSP Residual norm 3.093769972950e-08
162 KSP Residual norm 3.011467802782e-08
163 KSP Residual norm 2.915222434886e-08
164 KSP Residual norm 2.816828567334e-08
165 KSP Residual norm 2.719124889222e-08
166 KSP Residual norm 2.617179553766e-08
167 KSP Residual norm 2.509448288201e-08
168 KSP Residual norm 2.397462775994e-08
169 KSP Residual norm 2.287942093970e-08
170 KSP Residual norm 2.183443152856e-08
171 KSP Residual norm 2.076669720150e-08
172 KSP Residual norm 1.963105399320e-08
173 KSP Residual norm 1.854074199769e-08
174 KSP Residual norm 1.759173077288e-08
175 KSP Residual norm 1.674496127909e-08
176 KSP Residual norm 1.569996221092e-08
177 KSP Residual norm 1.443822705329e-08
178 KSP Residual norm 1.330273856810e-08
179 KSP Residual norm 1.238765818192e-08
180 KSP Residual norm 1.160231817637e-08
181 KSP Residual norm 1.089171039840e-08
182 KSP Residual norm 1.023737562404e-08
183 KSP Residual norm 9.654459542317e-09
184 KSP Residual norm 9.137335587102e-09
185 KSP Residual norm 8.707154589221e-09
186 KSP Residual norm 8.334245327074e-09
187 KSP Residual norm 8.008928731795e-09
188 KSP Residual norm 7.734956749035e-09
189 KSP Residual norm 7.525206026453e-09
190 KSP Residual norm 7.352026778813e-09
191 KSP Residual norm 7.200463341764e-09
192 KSP Residual norm 7.062291663419e-09
193 KSP Residual norm 6.985942365039e-09
194 KSP Residual norm 6.949840631298e-09
195 KSP Residual norm 6.924733938522e-09
196 KSP Residual norm 6.885696905386e-09
197 KSP Residual norm 6.841713691455e-09
198 KSP Residual norm 6.809434560100e-09
199 KSP Residual norm 6.797926098661e-09
200 KSP Residual norm 6.808014026198e-09
201 KSP Residual norm 6.805498807547e-09
202 KSP Residual norm 6.734113838742e-09
203 KSP Residual norm 6.621984198175e-09
204 KSP Residual norm 6.512392102271e-09
205 KSP Residual norm 6.411649399707e-09
206 KSP Residual norm 6.316453457627e-09
207 KSP Residual norm 6.224702917395e-09
208 KSP Residual norm 6.138529686539e-09
209 KSP Residual norm 6.090033637993e-09
210 KSP Residual norm 6.095132474708e-09
211 KSP Residual norm 5.967278625457e-09
212 KSP Residual norm 5.704950510233e-09
213 KSP Residual norm 5.522197272185e-09
214 KSP Residual norm 5.423210939912e-09
215 KSP Residual norm 5.333076216162e-09
216 KSP Residual norm 5.207320994319e-09
217 KSP Residual norm 5.055438887727e-09
218 KSP Residual norm 4.906164730175e-09
219 KSP Residual norm 4.754905259667e-09
220 KSP Residual norm 4.591610542013e-09
221 KSP Residual norm 4.423656769426e-09
222 KSP Residual norm 4.272766051320e-09
223 KSP Residual norm 4.142341667612e-09
224 KSP Residual norm 4.034033989128e-09
225 KSP Residual norm 3.895902435101e-09
226 KSP Residual norm 3.717396613889e-09
227 KSP Residual norm 3.528610437721e-09
228 KSP Residual norm 3.370389091382e-09
229 KSP Residual norm 3.247595732305e-09
230 KSP Residual norm 3.152415091021e-09
231 KSP Residual norm 3.066910848832e-09
232 KSP Residual norm 3.002100350363e-09
233 KSP Residual norm 2.967713103362e-09
234 KSP Residual norm 2.915145929649e-09
235 KSP Residual norm 2.810499247724e-09
236 KSP Residual norm 2.715996703257e-09
237 KSP Residual norm 2.656986413384e-09
238 KSP Residual norm 2.600840669702e-09
239 KSP Residual norm 2.533916204908e-09
240 KSP Residual norm 2.471276640707e-09
241 KSP Residual norm 2.412717720400e-09
242 KSP Residual norm 2.346946360162e-09
243 KSP Residual norm 2.280489473057e-09
244 KSP Residual norm 2.221675448025e-09
245 KSP Residual norm 2.163405326037e-09
246 KSP Residual norm 2.089185761563e-09
247 KSP Residual norm 2.002500217781e-09
248 KSP Residual norm 1.920252602197e-09
249 KSP Residual norm 1.848293324560e-09
250 KSP Residual norm 1.784115043508e-09
251 KSP Residual norm 1.728656291432e-09
252 KSP Residual norm 1.681441494499e-09
253 KSP Residual norm 1.644681990002e-09
254 KSP Residual norm 1.609217211191e-09
255 KSP Residual norm 1.567379451601e-09
256 KSP Residual norm 1.527305416776e-09
257 KSP Residual norm 1.492459894704e-09
258 KSP Residual norm 1.462251168785e-09
259 KSP Residual norm 1.438430039087e-09
260 KSP Residual norm 1.427062606959e-09
261 KSP Residual norm 1.420556029865e-09
262 KSP Residual norm 1.378551627494e-09
263 KSP Residual norm 1.317566463420e-09
264 KSP Residual norm 1.267927458856e-09
265 KSP Residual norm 1.228735481103e-09
266 KSP Residual norm 1.201300740767e-09
267 KSP Residual norm 1.184360394015e-09
268 KSP Residual norm 1.162465234804e-09
269 KSP Residual norm 1.121917251682e-09
270 KSP Residual norm 1.080238933766e-09
271 KSP Residual norm 1.050440712043e-09
272 KSP Residual norm 1.028350471237e-09
273 KSP Residual norm 1.008601382077e-09
274 KSP Residual norm 9.928967308286e-10
275 KSP Residual norm 9.952421863052e-10
276 KSP Residual norm 1.002288537055e-09
277 KSP Residual norm 9.630484048005e-10
278 KSP Residual norm 9.162946023882e-10
279 KSP Residual norm 8.820228522479e-10
280 KSP Residual norm 8.563495213439e-10
281 KSP Residual norm 8.338396929663e-10
282 KSP Residual norm 8.134956273297e-10
283 KSP Residual norm 7.947003222506e-10
284 KSP Residual norm 7.724727225023e-10
285 KSP Residual norm 7.442358429480e-10
286 KSP Residual norm 7.179519930681e-10
287 KSP Residual norm 6.916101043054e-10
288 KSP Residual norm 6.637642439787e-10
289 KSP Residual norm 6.392690829817e-10
290 KSP Residual norm 6.181388860815e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 290
stx: 0., fx: 0.0691392, dgx: -5.61929e-08
sty: 0., fy: 0.0691392, dgy: -5.61929e-08
28 TAO, Function value: 0.0691392, Residual: 0.000124392
0 KSP Residual norm 1.243919138083e-04
1 KSP Residual norm 9.598853562990e-05
2 KSP Residual norm 6.444930874270e-05
3 KSP Residual norm 5.151675703978e-05
4 KSP Residual norm 4.031819883017e-05
5 KSP Residual norm 3.472562716378e-05
6 KSP Residual norm 3.033644845851e-05
7 KSP Residual norm 2.769552993406e-05
8 KSP Residual norm 2.601940872694e-05
9 KSP Residual norm 2.489167103989e-05
10 KSP Residual norm 2.444179412041e-05
11 KSP Residual norm 2.413650437320e-05
12 KSP Residual norm 2.401898775311e-05
13 KSP Residual norm 2.388688378050e-05
14 KSP Residual norm 2.368928819505e-05
15 KSP Residual norm 2.409143414917e-05
16 KSP Residual norm 2.489973698451e-05
17 KSP Residual norm 2.561907145707e-05
18 KSP Residual norm 2.590209789357e-05
19 KSP Residual norm 2.629022150414e-05
20 KSP Residual norm 2.672894643316e-05
21 KSP Residual norm 2.696483432870e-05
22 KSP Residual norm 2.710774887867e-05
23 KSP Residual norm 2.712790373984e-05
24 KSP Residual norm 2.682052421971e-05
25 KSP Residual norm 2.632547895187e-05
26 KSP Residual norm 2.575188871224e-05
27 KSP Residual norm 2.494530840321e-05
28 KSP Residual norm 2.382306708439e-05
29 KSP Residual norm 2.250613037147e-05
30 KSP Residual norm 2.115270136566e-05
31 KSP Residual norm 1.983480058096e-05
32 KSP Residual norm 1.849818196230e-05
33 KSP Residual norm 1.706151323717e-05
34 KSP Residual norm 1.555232444078e-05
35 KSP Residual norm 1.408289902271e-05
36 KSP Residual norm 1.270432400189e-05
37 KSP Residual norm 1.143528323914e-05
38 KSP Residual norm 1.031770420205e-05
39 KSP Residual norm 9.413118021926e-06
40 KSP Residual norm 8.688246009280e-06
41 KSP Residual norm 7.800006000882e-06
42 KSP Residual norm 6.871887257434e-06
43 KSP Residual norm 6.132374442378e-06
44 KSP Residual norm 5.545078554973e-06
45 KSP Residual norm 5.062276412426e-06
46 KSP Residual norm 4.652665477993e-06
47 KSP Residual norm 4.236813801367e-06
48 KSP Residual norm 3.783945420875e-06
49 KSP Residual norm 3.366032167710e-06
50 KSP Residual norm 3.006770151892e-06
51 KSP Residual norm 2.696005062384e-06
52 KSP Residual norm 2.417723004150e-06
53 KSP Residual norm 2.160208903565e-06
54 KSP Residual norm 1.921473333392e-06
55 KSP Residual norm 1.704574633539e-06
56 KSP Residual norm 1.518971358683e-06
57 KSP Residual norm 1.365067173323e-06
58 KSP Residual norm 1.237738384978e-06
59 KSP Residual norm 1.131072305903e-06
60 KSP Residual norm 1.042922420881e-06
61 KSP Residual norm 9.641314406829e-07
62 KSP Residual norm 8.864910112534e-07
63 KSP Residual norm 8.149507563951e-07
64 KSP Residual norm 7.590775119629e-07
65 KSP Residual norm 7.254614138290e-07
66 KSP Residual norm 6.941886923984e-07
67 KSP Residual norm 6.366811211910e-07
68 KSP Residual norm 5.830219462423e-07
69 KSP Residual norm 5.462150757116e-07
70 KSP Residual norm 5.154522959850e-07
71 KSP Residual norm 4.876808461793e-07
72 KSP Residual norm 4.637042865688e-07
73 KSP Residual norm 4.395012800685e-07
74 KSP Residual norm 4.139484784246e-07
75 KSP Residual norm 3.880291216830e-07
76 KSP Residual norm 3.598504081423e-07
77 KSP Residual norm 3.323842765900e-07
78 KSP Residual norm 3.088491112842e-07
79 KSP Residual norm 2.868458466842e-07
80 KSP Residual norm 2.669668780592e-07
81 KSP Residual norm 2.465619100889e-07
82 KSP Residual norm 2.272961194614e-07
83 KSP Residual norm 2.111519473206e-07
84 KSP Residual norm 1.946953612697e-07
85 KSP Residual norm 1.788025493229e-07
86 KSP Residual norm 1.649444827079e-07
87 KSP Residual norm 1.527625378575e-07
88 KSP Residual norm 1.425342373182e-07
89 KSP Residual norm 1.334205935953e-07
90 KSP Residual norm 1.252927848215e-07
91 KSP Residual norm 1.179792119386e-07
92 KSP Residual norm 1.121973081878e-07
93 KSP Residual norm 1.050654555067e-07
94 KSP Residual norm 9.632586990219e-08
95 KSP Residual norm 8.993660204601e-08
96 KSP Residual norm 8.480314753476e-08
97 KSP Residual norm 8.051763984462e-08
98 KSP Residual norm 7.735730482369e-08
99 KSP Residual norm 7.429669254072e-08
100 KSP Residual norm 7.184227305285e-08
101 KSP Residual norm 6.923205251665e-08
102 KSP Residual norm 6.598064032149e-08
103 KSP Residual norm 6.366219742396e-08
104 KSP Residual norm 6.131490440446e-08
105 KSP Residual norm 5.948624465811e-08
106 KSP Residual norm 5.729158459072e-08
107 KSP Residual norm 5.498255644601e-08
108 KSP Residual norm 5.268534252790e-08
109 KSP Residual norm 5.047397461135e-08
110 KSP Residual norm 4.837685335912e-08
111 KSP Residual norm 4.671237966029e-08
112 KSP Residual norm 4.526147468824e-08
113 KSP Residual norm 4.407392671549e-08
114 KSP Residual norm 4.311128027127e-08
115 KSP Residual norm 4.201028578940e-08
116 KSP Residual norm 4.072572866082e-08
117 KSP Residual norm 3.921935688079e-08
118 KSP Residual norm 3.776903357828e-08
119 KSP Residual norm 3.655971094717e-08
120 KSP Residual norm 3.561727107948e-08
121 KSP Residual norm 3.507198004135e-08
122 KSP Residual norm 3.447603239222e-08
123 KSP Residual norm 3.220921730480e-08
124 KSP Residual norm 3.008323957181e-08
125 KSP Residual norm 2.864731522184e-08
126 KSP Residual norm 2.737033676857e-08
127 KSP Residual norm 2.594017648802e-08
128 KSP Residual norm 2.458931708649e-08
129 KSP Residual norm 2.341243352765e-08
130 KSP Residual norm 2.250881820846e-08
131 KSP Residual norm 2.178189006707e-08
132 KSP Residual norm 2.100699787623e-08
133 KSP Residual norm 2.015372416577e-08
134 KSP Residual norm 1.950061248967e-08
135 KSP Residual norm 1.893837357493e-08
136 KSP Residual norm 1.822403233945e-08
137 KSP Residual norm 1.760280328619e-08
138 KSP Residual norm 1.723225781423e-08
139 KSP Residual norm 1.699024250960e-08
140 KSP Residual norm 1.678906434889e-08
141 KSP Residual norm 1.658921760292e-08
142 KSP Residual norm 1.638932495379e-08
143 KSP Residual norm 1.615127678532e-08
144 KSP Residual norm 1.598479679593e-08
145 KSP Residual norm 1.594442399283e-08
146 KSP Residual norm 1.591806579538e-08
147 KSP Residual norm 1.588564227413e-08
148 KSP Residual norm 1.585208776898e-08
149 KSP Residual norm 1.573202997142e-08
150 KSP Residual norm 1.551482804766e-08
151 KSP Residual norm 1.531241149845e-08
152 KSP Residual norm 1.517203512514e-08
153 KSP Residual norm 1.512405117799e-08
154 KSP Residual norm 1.494709857196e-08
155 KSP Residual norm 1.443987053051e-08
156 KSP Residual norm 1.388065771425e-08
157 KSP Residual norm 1.338444995704e-08
158 KSP Residual norm 1.281943564419e-08
159 KSP Residual norm 1.221554058763e-08
160 KSP Residual norm 1.167221242525e-08
161 KSP Residual norm 1.121032267440e-08
162 KSP Residual norm 1.077591035965e-08
163 KSP Residual norm 1.028039469768e-08
164 KSP Residual norm 9.710014443432e-09
165 KSP Residual norm 9.120216108941e-09
166 KSP Residual norm 8.562926309810e-09
167 KSP Residual norm 8.073213145679e-09
168 KSP Residual norm 7.653401100859e-09
169 KSP Residual norm 7.287994030094e-09
170 KSP Residual norm 6.967247478244e-09
171 KSP Residual norm 6.714202862140e-09
172 KSP Residual norm 6.541129987340e-09
173 KSP Residual norm 6.316750402093e-09
174 KSP Residual norm 6.005451415985e-09
175 KSP Residual norm 5.725683734009e-09
176 KSP Residual norm 5.489185013805e-09
177 KSP Residual norm 5.267057849304e-09
178 KSP Residual norm 5.061530591600e-09
179 KSP Residual norm 4.892440920253e-09
180 KSP Residual norm 4.739469260982e-09
181 KSP Residual norm 4.621610988363e-09
182 KSP Residual norm 4.580449056421e-09
183 KSP Residual norm 4.574093172689e-09
184 KSP Residual norm 4.419068407344e-09
185 KSP Residual norm 4.215219891333e-09
186 KSP Residual norm 4.095353742483e-09
187 KSP Residual norm 4.028919234503e-09
188 KSP Residual norm 3.982730273276e-09
189 KSP Residual norm 3.955186655898e-09
190 KSP Residual norm 3.939559497361e-09
191 KSP Residual norm 3.914144506646e-09
192 KSP Residual norm 3.858421168214e-09
193 KSP Residual norm 3.784319036247e-09
194 KSP Residual norm 3.717169024542e-09
195 KSP Residual norm 3.661304277963e-09
196 KSP Residual norm 3.599925777336e-09
197 KSP Residual norm 3.533837304288e-09
198 KSP Residual norm 3.466972405681e-09
199 KSP Residual norm 3.380036062328e-09
200 KSP Residual norm 3.276915036967e-09
201 KSP Residual norm 3.172338849418e-09
202 KSP Residual norm 3.083930723439e-09
203 KSP Residual norm 2.987739777403e-09
204 KSP Residual norm 2.877471647472e-09
205 KSP Residual norm 2.764507689262e-09
206 KSP Residual norm 2.655507309830e-09
207 KSP Residual norm 2.541255400924e-09
208 KSP Residual norm 2.420631533963e-09
209 KSP Residual norm 2.304229683933e-09
210 KSP Residual norm 2.198885017399e-09
211 KSP Residual norm 2.099285276249e-09
212 KSP Residual norm 2.006650438511e-09
213 KSP Residual norm 1.925924752138e-09
214 KSP Residual norm 1.873323061695e-09
215 KSP Residual norm 1.848001579692e-09
216 KSP Residual norm 1.789274059132e-09
217 KSP Residual norm 1.687983742960e-09
218 KSP Residual norm 1.611541277691e-09
219 KSP Residual norm 1.555819838189e-09
220 KSP Residual norm 1.500444983759e-09
221 KSP Residual norm 1.441128069787e-09
222 KSP Residual norm 1.387157217671e-09
223 KSP Residual norm 1.337777263415e-09
224 KSP Residual norm 1.293648135042e-09
225 KSP Residual norm 1.253706328712e-09
226 KSP Residual norm 1.222271580010e-09
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 226
1 LS Function value: 0.0691391, Step length: 1.
stx: 0., fx: 0.0691392, dgx: -5.95363e-08
sty: 0., fy: 0.0691392, dgy: -5.95363e-08
29 TAO, Function value: 0.0691391, Residual: 2.98657e-05
0 KSP Residual norm 2.986569367135e-05
1 KSP Residual norm 2.595526526105e-05
2 KSP Residual norm 1.990068950020e-05
3 KSP Residual norm 1.874588602695e-05
4 KSP Residual norm 1.721191778239e-05
5 KSP Residual norm 1.856204638573e-05
6 KSP Residual norm 2.041009965410e-05
7 KSP Residual norm 2.313933354203e-05
8 KSP Residual norm 2.596268625346e-05
9 KSP Residual norm 2.878721277410e-05
10 KSP Residual norm 3.196694097186e-05
11 KSP Residual norm 3.528885389747e-05
12 KSP Residual norm 3.858754455075e-05
13 KSP Residual norm 4.207841763633e-05
14 KSP Residual norm 4.392571904962e-05
15 KSP Residual norm 4.613097451407e-05
16 KSP Residual norm 4.887023147561e-05
17 KSP Residual norm 5.093432967146e-05
18 KSP Residual norm 5.181839806152e-05
19 KSP Residual norm 5.228128440104e-05
20 KSP Residual norm 5.226881147043e-05
21 KSP Residual norm 5.172899960549e-05
22 KSP Residual norm 5.101465835856e-05
23 KSP Residual norm 5.017119318362e-05
24 KSP Residual norm 4.865286014500e-05
25 KSP Residual norm 4.672749949957e-05
26 KSP Residual norm 4.464851697067e-05
27 KSP Residual norm 4.216106130358e-05
28 KSP Residual norm 3.933065082793e-05
29 KSP Residual norm 3.633402608835e-05
30 KSP Residual norm 3.327314896415e-05
31 KSP Residual norm 3.029655560928e-05
32 KSP Residual norm 2.744137629453e-05
33 KSP Residual norm 2.466312676581e-05
34 KSP Residual norm 2.204423231726e-05
35 KSP Residual norm 1.972573227358e-05
36 KSP Residual norm 1.771977947740e-05
37 KSP Residual norm 1.595528034477e-05
38 KSP Residual norm 1.441939445351e-05
39 KSP Residual norm 1.311700250434e-05
40 KSP Residual norm 1.203427041387e-05
41 KSP Residual norm 1.096531962900e-05
42 KSP Residual norm 9.858553292231e-06
43 KSP Residual norm 8.875923013598e-06
44 KSP Residual norm 8.082877884596e-06
45 KSP Residual norm 7.489168356530e-06
46 KSP Residual norm 6.915617638760e-06
47 KSP Residual norm 6.150924265951e-06
48 KSP Residual norm 5.400454749171e-06
49 KSP Residual norm 4.774769735735e-06
50 KSP Residual norm 4.241643830077e-06
51 KSP Residual norm 3.785354132251e-06
52 KSP Residual norm 3.396153705452e-06
53 KSP Residual norm 3.050270479849e-06
54 KSP Residual norm 2.732789041681e-06
55 KSP Residual norm 2.451279191412e-06
56 KSP Residual norm 2.227060534039e-06
57 KSP Residual norm 2.053081212963e-06
58 KSP Residual norm 1.900719442117e-06
59 KSP Residual norm 1.757193851978e-06
60 KSP Residual norm 1.632969909671e-06
61 KSP Residual norm 1.532639254660e-06
62 KSP Residual norm 1.450780455529e-06
63 KSP Residual norm 1.381420057580e-06
64 KSP Residual norm 1.325202434840e-06
65 KSP Residual norm 1.279950191216e-06
66 KSP Residual norm 1.220981472834e-06
67 KSP Residual norm 1.145566375755e-06
68 KSP Residual norm 1.077126201454e-06
69 KSP Residual norm 1.021288578843e-06
70 KSP Residual norm 9.680038641038e-07
71 KSP Residual norm 9.195698131525e-07
72 KSP Residual norm 8.745251715495e-07
73 KSP Residual norm 8.221506334905e-07
74 KSP Residual norm 7.701444031592e-07
75 KSP Residual norm 7.277826627396e-07
76 KSP Residual norm 6.952837218429e-07
77 KSP Residual norm 6.762212052826e-07
78 KSP Residual norm 6.313711147809e-07
79 KSP Residual norm 5.700883161495e-07
80 KSP Residual norm 5.252858782972e-07
81 KSP Residual norm 4.885795969737e-07
82 KSP Residual norm 4.582697298344e-07
83 KSP Residual norm 4.317310030577e-07
84 KSP Residual norm 4.003068193432e-07
85 KSP Residual norm 3.712293512717e-07
86 KSP Residual norm 3.480378792972e-07
87 KSP Residual norm 3.278238408495e-07
88 KSP Residual norm 3.119164852519e-07
89 KSP Residual norm 2.998585949321e-07
90 KSP Residual norm 2.895443452697e-07
91 KSP Residual norm 2.774283459752e-07
92 KSP Residual norm 2.680175233485e-07
93 KSP Residual norm 2.610465654805e-07
94 KSP Residual norm 2.498096808308e-07
95 KSP Residual norm 2.396452293554e-07
96 KSP Residual norm 2.304902008050e-07
97 KSP Residual norm 2.232826073294e-07
98 KSP Residual norm 2.190382256332e-07
99 KSP Residual norm 2.154912750879e-07
100 KSP Residual norm 2.123263422899e-07
101 KSP Residual norm 2.076268249067e-07
102 KSP Residual norm 2.003943329163e-07
103 KSP Residual norm 1.964959750018e-07
104 KSP Residual norm 1.917095137952e-07
105 KSP Residual norm 1.880945966304e-07
106 KSP Residual norm 1.840693915192e-07
107 KSP Residual norm 1.810660055430e-07
108 KSP Residual norm 1.786527568866e-07
109 KSP Residual norm 1.759239306357e-07
110 KSP Residual norm 1.729473647031e-07
111 KSP Residual norm 1.713213186822e-07
112 KSP Residual norm 1.702112582347e-07
113 KSP Residual norm 1.694723524965e-07
114 KSP Residual norm 1.683932378830e-07
115 KSP Residual norm 1.667220723653e-07
116 KSP Residual norm 1.644707737681e-07
117 KSP Residual norm 1.616536573179e-07
118 KSP Residual norm 1.582452410905e-07
119 KSP Residual norm 1.544461668646e-07
120 KSP Residual norm 1.500187836895e-07
121 KSP Residual norm 1.441641841465e-07
122 KSP Residual norm 1.386245513213e-07
123 KSP Residual norm 1.330853685464e-07
124 KSP Residual norm 1.271020366397e-07
125 KSP Residual norm 1.205702225422e-07
126 KSP Residual norm 1.144672198735e-07
127 KSP Residual norm 1.087155086061e-07
128 KSP Residual norm 1.042898177552e-07
129 KSP Residual norm 1.009533167426e-07
130 KSP Residual norm 9.830246871261e-08
131 KSP Residual norm 9.551790449286e-08
132 KSP Residual norm 9.365976519244e-08
133 KSP Residual norm 9.261581906854e-08
134 KSP Residual norm 9.014690908567e-08
135 KSP Residual norm 8.697202340979e-08
136 KSP Residual norm 8.510809933245e-08
137 KSP Residual norm 8.410946928279e-08
138 KSP Residual norm 8.339834420332e-08
139 KSP Residual norm 8.324669437299e-08
140 KSP Residual norm 8.379439549927e-08
141 KSP Residual norm 8.430018231781e-08
142 KSP Residual norm 8.390361831469e-08
143 KSP Residual norm 8.418641967091e-08
144 KSP Residual norm 8.449398110672e-08
145 KSP Residual norm 8.261830807843e-08
146 KSP Residual norm 8.028342117978e-08
147 KSP Residual norm 7.881333339787e-08
148 KSP Residual norm 7.783369413151e-08
149 KSP Residual norm 7.662920572555e-08
150 KSP Residual norm 7.520803988870e-08
151 KSP Residual norm 7.391208723800e-08
152 KSP Residual norm 7.242696329530e-08
153 KSP Residual norm 7.023156066593e-08
154 KSP Residual norm 6.777891482865e-08
155 KSP Residual norm 6.573731774839e-08
156 KSP Residual norm 6.420407819341e-08
157 KSP Residual norm 6.260445632359e-08
158 KSP Residual norm 6.044145630012e-08
159 KSP Residual norm 5.816805766145e-08
160 KSP Residual norm 5.604426179792e-08
161 KSP Residual norm 5.410105517559e-08
162 KSP Residual norm 5.219341253097e-08
163 KSP Residual norm 5.007147620614e-08
164 KSP Residual norm 4.783188671859e-08
165 KSP Residual norm 4.562051376200e-08
166 KSP Residual norm 4.352133298894e-08
167 KSP Residual norm 4.157569373668e-08
168 KSP Residual norm 3.943696913260e-08
169 KSP Residual norm 3.681342907875e-08
170 KSP Residual norm 3.425445247595e-08
171 KSP Residual norm 3.220667876445e-08
172 KSP Residual norm 3.069754014517e-08
173 KSP Residual norm 2.940182568977e-08
174 KSP Residual norm 2.783098887072e-08
175 KSP Residual norm 2.619581779821e-08
176 KSP Residual norm 2.489473944409e-08
177 KSP Residual norm 2.394671472918e-08
178 KSP Residual norm 2.327904915577e-08
179 KSP Residual norm 2.270217432290e-08
180 KSP Residual norm 2.178458683430e-08
181 KSP Residual norm 2.087803652101e-08
182 KSP Residual norm 2.026180482200e-08
183 KSP Residual norm 1.977983093770e-08
184 KSP Residual norm 1.922769654381e-08
185 KSP Residual norm 1.867132337033e-08
186 KSP Residual norm 1.826951175991e-08
187 KSP Residual norm 1.805114646616e-08
188 KSP Residual norm 1.791914094213e-08
189 KSP Residual norm 1.764199464129e-08
190 KSP Residual norm 1.714590820310e-08
191 KSP Residual norm 1.665003009872e-08
192 KSP Residual norm 1.622764964727e-08
193 KSP Residual norm 1.586720645106e-08
194 KSP Residual norm 1.555385887773e-08
195 KSP Residual norm 1.527792442082e-08
196 KSP Residual norm 1.499684275532e-08
197 KSP Residual norm 1.477251846762e-08
198 KSP Residual norm 1.463456548823e-08
199 KSP Residual norm 1.453936811347e-08
200 KSP Residual norm 1.449489136060e-08
201 KSP Residual norm 1.446815667230e-08
202 KSP Residual norm 1.434558038069e-08
203 KSP Residual norm 1.399866328430e-08
204 KSP Residual norm 1.355854840704e-08
205 KSP Residual norm 1.317003485476e-08
206 KSP Residual norm 1.287240046173e-08
207 KSP Residual norm 1.268241632281e-08
208 KSP Residual norm 1.259953842790e-08
209 KSP Residual norm 1.228784446212e-08
210 KSP Residual norm 1.156585550912e-08
211 KSP Residual norm 1.092126363767e-08
212 KSP Residual norm 1.047998985786e-08
213 KSP Residual norm 1.019915131065e-08
214 KSP Residual norm 9.982091040398e-09
215 KSP Residual norm 9.730771722168e-09
216 KSP Residual norm 9.445692835213e-09
217 KSP Residual norm 9.165463792831e-09
218 KSP Residual norm 8.905274114144e-09
219 KSP Residual norm 8.640191536690e-09
220 KSP Residual norm 8.364642414008e-09
221 KSP Residual norm 8.088454623572e-09
222 KSP Residual norm 7.835831379912e-09
223 KSP Residual norm 7.566801856292e-09
224 KSP Residual norm 7.294968786541e-09
225 KSP Residual norm 7.071422420671e-09
226 KSP Residual norm 6.933246978305e-09
227 KSP Residual norm 6.715103811148e-09
228 KSP Residual norm 6.388348903709e-09
229 KSP Residual norm 6.111242314098e-09
230 KSP Residual norm 5.887534530818e-09
231 KSP Residual norm 5.691939737065e-09
232 KSP Residual norm 5.568152171336e-09
233 KSP Residual norm 5.474695505636e-09
234 KSP Residual norm 5.271362372050e-09
235 KSP Residual norm 5.002737714046e-09
236 KSP Residual norm 4.781106943287e-09
237 KSP Residual norm 4.607040792510e-09
238 KSP Residual norm 4.438309554628e-09
239 KSP Residual norm 4.264097828137e-09
240 KSP Residual norm 4.107958255725e-09
241 KSP Residual norm 3.966681191453e-09
242 KSP Residual norm 3.814521718489e-09
243 KSP Residual norm 3.654407858209e-09
244 KSP Residual norm 3.507088586940e-09
245 KSP Residual norm 3.379796151754e-09
246 KSP Residual norm 3.276269027736e-09
247 KSP Residual norm 3.190837377562e-09
248 KSP Residual norm 3.105746714786e-09
249 KSP Residual norm 3.012500121939e-09
250 KSP Residual norm 2.916756095652e-09
251 KSP Residual norm 2.832036786955e-09
252 KSP Residual norm 2.779856707851e-09
253 KSP Residual norm 2.784675929406e-09
254 KSP Residual norm 2.803107521693e-09
255 KSP Residual norm 2.702503322505e-09
256 KSP Residual norm 2.577072439641e-09
257 KSP Residual norm 2.500748184691e-09
258 KSP Residual norm 2.444995817996e-09
259 KSP Residual norm 2.393672183276e-09
260 KSP Residual norm 2.338120619107e-09
261 KSP Residual norm 2.287150221291e-09
262 KSP Residual norm 2.242368007517e-09
263 KSP Residual norm 2.204282214026e-09
264 KSP Residual norm 2.162024549872e-09
265 KSP Residual norm 2.117089297046e-09
266 KSP Residual norm 2.086102914920e-09
267 KSP Residual norm 2.074850496906e-09
268 KSP Residual norm 2.097930710423e-09
269 KSP Residual norm 2.089287032548e-09
270 KSP Residual norm 2.007883910590e-09
271 KSP Residual norm 1.938638339347e-09
272 KSP Residual norm 1.911740221027e-09
273 KSP Residual norm 1.903592394501e-09
274 KSP Residual norm 1.853292437960e-09
275 KSP Residual norm 1.769624153321e-09
276 KSP Residual norm 1.703351861929e-09
277 KSP Residual norm 1.649031355116e-09
278 KSP Residual norm 1.601390282650e-09
279 KSP Residual norm 1.551942696196e-09
280 KSP Residual norm 1.503100477804e-09
281 KSP Residual norm 1.451310442736e-09
282 KSP Residual norm 1.389474574350e-09
283 KSP Residual norm 1.328901152718e-09
284 KSP Residual norm 1.278186679527e-09
285 KSP Residual norm 1.234145419156e-09
286 KSP Residual norm 1.198449700223e-09
287 KSP Residual norm 1.159635672120e-09
288 KSP Residual norm 1.114897573311e-09
289 KSP Residual norm 1.073669005337e-09
290 KSP Residual norm 1.038859658520e-09
291 KSP Residual norm 1.001978607708e-09
292 KSP Residual norm 9.642672387752e-10
293 KSP Residual norm 9.289908584018e-10
294 KSP Residual norm 8.946279454036e-10
295 KSP Residual norm 8.546947047084e-10
296 KSP Residual norm 8.151445130967e-10
297 KSP Residual norm 7.810102802125e-10
298 KSP Residual norm 7.546219922100e-10
299 KSP Residual norm 7.315576456805e-10
300 KSP Residual norm 7.118772377037e-10
301 KSP Residual norm 6.924469334784e-10
302 KSP Residual norm 6.770690065034e-10
303 KSP Residual norm 6.661251767766e-10
304 KSP Residual norm 6.501752931318e-10
305 KSP Residual norm 6.335959697335e-10
306 KSP Residual norm 6.167662292759e-10
307 KSP Residual norm 6.024933555753e-10
308 KSP Residual norm 5.902712175221e-10
309 KSP Residual norm 5.757304673271e-10
310 KSP Residual norm 5.571403387221e-10
311 KSP Residual norm 5.402982333906e-10
312 KSP Residual norm 5.273451916868e-10
313 KSP Residual norm 5.159299588792e-10
314 KSP Residual norm 5.079527784419e-10
315 KSP Residual norm 5.050731438446e-10
316 KSP Residual norm 4.949300070390e-10
317 KSP Residual norm 4.752313100445e-10
318 KSP Residual norm 4.563485814745e-10
319 KSP Residual norm 4.418845071846e-10
320 KSP Residual norm 4.315686484517e-10
321 KSP Residual norm 4.263463768433e-10
322 KSP Residual norm 4.238399671162e-10
323 KSP Residual norm 4.142929083200e-10
324 KSP Residual norm 3.989843941547e-10
325 KSP Residual norm 3.871260316737e-10
326 KSP Residual norm 3.772347312826e-10
327 KSP Residual norm 3.689217616731e-10
328 KSP Residual norm 3.620958258016e-10
329 KSP Residual norm 3.554100967543e-10
330 KSP Residual norm 3.505949276508e-10
331 KSP Residual norm 3.464002702944e-10
332 KSP Residual norm 3.388286100272e-10
333 KSP Residual norm 3.296250178380e-10
334 KSP Residual norm 3.251306215011e-10
335 KSP Residual norm 3.229235205434e-10
336 KSP Residual norm 3.081933899545e-10
337 KSP Residual norm 2.912778263336e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 337
0 LS Function value: 0.0691391, Step length: 0.
stx: 0., fx: 0.0691391, dgx: -6.2315e-08
sty: 0., fy: 0.0691391, dgy: -6.2315e-08
2 LS Function value: 0.0691391, Step length: 0.358118
sty: 1., fy: 0.0691392, dgy: 4.16778e-07
30 TAO, Function value: 0.0691391, Residual: 5.74416e-05
0 KSP Residual norm 5.744155984375e-05
1 KSP Residual norm 4.574098054832e-05
2 KSP Residual norm 3.206194573338e-05
3 KSP Residual norm 2.656580543878e-05
4 KSP Residual norm 2.140903603801e-05
5 KSP Residual norm 1.960244116657e-05
6 KSP Residual norm 1.867782465859e-05
7 KSP Residual norm 1.885411926172e-05
8 KSP Residual norm 1.969381764365e-05
9 KSP Residual norm 2.082184272116e-05
10 KSP Residual norm 2.210843349162e-05
11 KSP Residual norm 2.339867857942e-05
12 KSP Residual norm 2.459903809059e-05
13 KSP Residual norm 2.607222898859e-05
14 KSP Residual norm 2.749511237411e-05
15 KSP Residual norm 2.913446580297e-05
16 KSP Residual norm 3.097363109462e-05
17 KSP Residual norm 3.277562012921e-05
18 KSP Residual norm 3.425992704348e-05
19 KSP Residual norm 3.543584204851e-05
20 KSP Residual norm 3.637621663188e-05
21 KSP Residual norm 3.691508333103e-05
22 KSP Residual norm 3.666594199581e-05
23 KSP Residual norm 3.606294942902e-05
24 KSP Residual norm 3.520530428025e-05
25 KSP Residual norm 3.422462460364e-05
26 KSP Residual norm 3.332597698370e-05
27 KSP Residual norm 3.197041379491e-05
28 KSP Residual norm 3.008226342066e-05
29 KSP Residual norm 2.805170955198e-05
30 KSP Residual norm 2.608152166511e-05
31 KSP Residual norm 2.417722747892e-05
32 KSP Residual norm 2.222248064700e-05
33 KSP Residual norm 2.022787237623e-05
34 KSP Residual norm 1.829279738636e-05
35 KSP Residual norm 1.649251365359e-05
36 KSP Residual norm 1.482568854653e-05
37 KSP Residual norm 1.327889620173e-05
38 KSP Residual norm 1.186152723967e-05
39 KSP Residual norm 1.055728026849e-05
40 KSP Residual norm 9.422551042173e-06
41 KSP Residual norm 8.494568664693e-06
42 KSP Residual norm 7.784718389064e-06
43 KSP Residual norm 7.195336259481e-06
44 KSP Residual norm 6.504915794955e-06
45 KSP Residual norm 5.806226972156e-06
46 KSP Residual norm 5.244671692335e-06
47 KSP Residual norm 4.816913847470e-06
48 KSP Residual norm 4.418089555029e-06
49 KSP Residual norm 3.945002586828e-06
50 KSP Residual norm 3.474967390403e-06
51 KSP Residual norm 3.075923135629e-06
52 KSP Residual norm 2.735705472168e-06
53 KSP Residual norm 2.432306591227e-06
54 KSP Residual norm 2.157491510760e-06
55 KSP Residual norm 1.911858328936e-06
56 KSP Residual norm 1.708502772479e-06
57 KSP Residual norm 1.551736876527e-06
58 KSP Residual norm 1.428518565556e-06
59 KSP Residual norm 1.312430213751e-06
60 KSP Residual norm 1.198688274316e-06
61 KSP Residual norm 1.100508845001e-06
62 KSP Residual norm 1.019226534034e-06
63 KSP Residual norm 9.496717308195e-07
64 KSP Residual norm 8.905235972921e-07
65 KSP Residual norm 8.448546233914e-07
66 KSP Residual norm 8.122700090586e-07
67 KSP Residual norm 7.782408180783e-07
68 KSP Residual norm 7.280777632273e-07
69 KSP Residual norm 6.817993063039e-07
70 KSP Residual norm 6.479469577686e-07
71 KSP Residual norm 6.344092216777e-07
72 KSP Residual norm 6.319896253981e-07
73 KSP Residual norm 5.901444552501e-07
74 KSP Residual norm 5.428189987212e-07
75 KSP Residual norm 5.137565867272e-07
76 KSP Residual norm 4.877908202744e-07
77 KSP Residual norm 4.605077853257e-07
78 KSP Residual norm 4.359335718522e-07
79 KSP Residual norm 4.109873184155e-07
80 KSP Residual norm 3.852490403556e-07
81 KSP Residual norm 3.584022610545e-07
82 KSP Residual norm 3.354435415452e-07
83 KSP Residual norm 3.181294942547e-07
84 KSP Residual norm 2.984161662391e-07
85 KSP Residual norm 2.779916905412e-07
86 KSP Residual norm 2.607791509605e-07
87 KSP Residual norm 2.454302753683e-07
88 KSP Residual norm 2.329794315202e-07
89 KSP Residual norm 2.245576931865e-07
90 KSP Residual norm 2.189544798975e-07
91 KSP Residual norm 2.087174249510e-07
92 KSP Residual norm 1.972844830618e-07
93 KSP Residual norm 1.893134954677e-07
94 KSP Residual norm 1.808102735000e-07
95 KSP Residual norm 1.736588566413e-07
96 KSP Residual norm 1.674684018692e-07
97 KSP Residual norm 1.620287681897e-07
98 KSP Residual norm 1.582495224102e-07
99 KSP Residual norm 1.541432861232e-07
100 KSP Residual norm 1.507444440536e-07
101 KSP Residual norm 1.482524728395e-07
102 KSP Residual norm 1.441404555932e-07
103 KSP Residual norm 1.416284343134e-07
104 KSP Residual norm 1.381390813085e-07
105 KSP Residual norm 1.352716410763e-07
106 KSP Residual norm 1.325099638602e-07
107 KSP Residual norm 1.295061847603e-07
108 KSP Residual norm 1.268018504791e-07
109 KSP Residual norm 1.240575514187e-07
110 KSP Residual norm 1.221250645329e-07
111 KSP Residual norm 1.213615365086e-07
112 KSP Residual norm 1.213121758092e-07
113 KSP Residual norm 1.213128688400e-07
114 KSP Residual norm 1.211002242509e-07
115 KSP Residual norm 1.202297437737e-07
116 KSP Residual norm 1.190223855011e-07
117 KSP Residual norm 1.175740900837e-07
118 KSP Residual norm 1.157731780475e-07
119 KSP Residual norm 1.137474746189e-07
120 KSP Residual norm 1.114121922966e-07
121 KSP Residual norm 1.083203760602e-07
122 KSP Residual norm 1.054187466088e-07
123 KSP Residual norm 1.016952512521e-07
124 KSP Residual norm 9.682314410664e-08
125 KSP Residual norm 9.178472598859e-08
126 KSP Residual norm 8.759406333441e-08
127 KSP Residual norm 8.390831929696e-08
128 KSP Residual norm 8.084207260405e-08
129 KSP Residual norm 7.716476302551e-08
130 KSP Residual norm 7.320798978617e-08
131 KSP Residual norm 7.052230911474e-08
132 KSP Residual norm 7.011395257791e-08
133 KSP Residual norm 6.809807968324e-08
134 KSP Residual norm 6.357622225647e-08
135 KSP Residual norm 6.082218978235e-08
136 KSP Residual norm 5.978644611610e-08
137 KSP Residual norm 5.974199731633e-08
138 KSP Residual norm 5.951285059376e-08
139 KSP Residual norm 5.776645009279e-08
140 KSP Residual norm 5.593737049461e-08
141 KSP Residual norm 5.490739668261e-08
142 KSP Residual norm 5.421053508634e-08
143 KSP Residual norm 5.339097663976e-08
144 KSP Residual norm 5.266170206649e-08
145 KSP Residual norm 5.232576403276e-08
146 KSP Residual norm 5.209111246457e-08
147 KSP Residual norm 5.188991411813e-08
148 KSP Residual norm 5.174812886464e-08
149 KSP Residual norm 5.138581205273e-08
150 KSP Residual norm 5.074769003999e-08
151 KSP Residual norm 5.003625239760e-08
152 KSP Residual norm 4.916530987957e-08
153 KSP Residual norm 4.809424562204e-08
154 KSP Residual norm 4.704475558698e-08
155 KSP Residual norm 4.611683251267e-08
156 KSP Residual norm 4.538319166943e-08
157 KSP Residual norm 4.458327929260e-08
158 KSP Residual norm 4.336045528906e-08
159 KSP Residual norm 4.200345233499e-08
160 KSP Residual norm 4.073931929008e-08
161 KSP Residual norm 3.955478411957e-08
162 KSP Residual norm 3.829745197289e-08
163 KSP Residual norm 3.676090999631e-08
164 KSP Residual norm 3.511647400340e-08
165 KSP Residual norm 3.363362032187e-08
166 KSP Residual norm 3.249672830671e-08
167 KSP Residual norm 3.157543809402e-08
168 KSP Residual norm 2.996400829485e-08
169 KSP Residual norm 2.773609381039e-08
170 KSP Residual norm 2.587133026747e-08
171 KSP Residual norm 2.451519655352e-08
172 KSP Residual norm 2.350708863645e-08
173 KSP Residual norm 2.236461307953e-08
174 KSP Residual norm 2.094116113038e-08
175 KSP Residual norm 1.964960156116e-08
176 KSP Residual norm 1.854985015498e-08
177 KSP Residual norm 1.753766836295e-08
178 KSP Residual norm 1.664870145853e-08
179 KSP Residual norm 1.601835176039e-08
180 KSP Residual norm 1.550101674273e-08
181 KSP Residual norm 1.486243373265e-08
182 KSP Residual norm 1.421398061537e-08
183 KSP Residual norm 1.371033361676e-08
184 KSP Residual norm 1.328653580136e-08
185 KSP Residual norm 1.289907413287e-08
186 KSP Residual norm 1.256169016211e-08
187 KSP Residual norm 1.231361494535e-08
188 KSP Residual norm 1.217907478802e-08
189 KSP Residual norm 1.215209003511e-08
190 KSP Residual norm 1.202751277096e-08
191 KSP Residual norm 1.172360429191e-08
192 KSP Residual norm 1.142844067359e-08
193 KSP Residual norm 1.123626444998e-08
194 KSP Residual norm 1.115165170747e-08
195 KSP Residual norm 1.115047884510e-08
196 KSP Residual norm 1.115201543370e-08
197 KSP Residual norm 1.122388855012e-08
198 KSP Residual norm 1.138273156811e-08
199 KSP Residual norm 1.122263772400e-08
200 KSP Residual norm 1.085383138149e-08
201 KSP Residual norm 1.059878112315e-08
202 KSP Residual norm 1.045277449795e-08
203 KSP Residual norm 1.032184925205e-08
204 KSP Residual norm 1.019746331553e-08
205 KSP Residual norm 1.008810268431e-08
206 KSP Residual norm 9.909818948038e-09
207 KSP Residual norm 9.595552881197e-09
208 KSP Residual norm 9.232353327862e-09
209 KSP Residual norm 8.895403860390e-09
210 KSP Residual norm 8.554195869078e-09
211 KSP Residual norm 8.202891575064e-09
212 KSP Residual norm 7.865518280805e-09
213 KSP Residual norm 7.573644457227e-09
214 KSP Residual norm 7.293157622757e-09
215 KSP Residual norm 6.986475249545e-09
216 KSP Residual norm 6.676673363763e-09
217 KSP Residual norm 6.388765857655e-09
218 KSP Residual norm 6.125847091186e-09
219 KSP Residual norm 5.879963259178e-09
220 KSP Residual norm 5.668413371402e-09
221 KSP Residual norm 5.529159293639e-09
222 KSP Residual norm 5.390502026258e-09
223 KSP Residual norm 5.074991777512e-09
224 KSP Residual norm 4.753214067017e-09
225 KSP Residual norm 4.513181492270e-09
226 KSP Residual norm 4.287368043541e-09
227 KSP Residual norm 4.051155284028e-09
228 KSP Residual norm 3.855660541241e-09
229 KSP Residual norm 3.724774652460e-09
230 KSP Residual norm 3.644445635704e-09
231 KSP Residual norm 3.544401406353e-09
232 KSP Residual norm 3.404797102851e-09
233 KSP Residual norm 3.274344612976e-09
234 KSP Residual norm 3.165132269954e-09
235 KSP Residual norm 3.070508141450e-09
236 KSP Residual norm 2.994168141319e-09
237 KSP Residual norm 2.924508843837e-09
238 KSP Residual norm 2.839149759760e-09
239 KSP Residual norm 2.750949384651e-09
240 KSP Residual norm 2.679818707225e-09
241 KSP Residual norm 2.619889291261e-09
242 KSP Residual norm 2.555861548388e-09
243 KSP Residual norm 2.489122750488e-09
244 KSP Residual norm 2.426532724246e-09
245 KSP Residual norm 2.369913586346e-09
246 KSP Residual norm 2.326491456538e-09
247 KSP Residual norm 2.310714273344e-09
248 KSP Residual norm 2.314616812779e-09
249 KSP Residual norm 2.258060528222e-09
250 KSP Residual norm 2.153327883758e-09
251 KSP Residual norm 2.080426978381e-09
252 KSP Residual norm 2.038124355448e-09
253 KSP Residual norm 2.008059514892e-09
254 KSP Residual norm 1.981549511548e-09
255 KSP Residual norm 1.954857165103e-09
256 KSP Residual norm 1.949064522269e-09
257 KSP Residual norm 1.969841923837e-09
258 KSP Residual norm 1.926670180083e-09
259 KSP Residual norm 1.824233743638e-09
260 KSP Residual norm 1.743447674580e-09
261 KSP Residual norm 1.684234722445e-09
262 KSP Residual norm 1.629196798185e-09
263 KSP Residual norm 1.579141417325e-09
264 KSP Residual norm 1.535224543745e-09
265 KSP Residual norm 1.495644732997e-09
266 KSP Residual norm 1.455539187599e-09
267 KSP Residual norm 1.406236763883e-09
268 KSP Residual norm 1.357808233186e-09
269 KSP Residual norm 1.319667568851e-09
270 KSP Residual norm 1.284004210004e-09
271 KSP Residual norm 1.248368795368e-09
272 KSP Residual norm 1.217657448409e-09
273 KSP Residual norm 1.196184006824e-09
274 KSP Residual norm 1.171725551255e-09
275 KSP Residual norm 1.128998118072e-09
276 KSP Residual norm 1.080855302977e-09
277 KSP Residual norm 1.038247238921e-09
278 KSP Residual norm 1.002809510737e-09
279 KSP Residual norm 9.705831156651e-10
280 KSP Residual norm 9.431486490489e-10
281 KSP Residual norm 9.139969737260e-10
282 KSP Residual norm 8.751992860932e-10
283 KSP Residual norm 8.372185543618e-10
284 KSP Residual norm 8.068298463442e-10
285 KSP Residual norm 7.822848536122e-10
286 KSP Residual norm 7.651599444411e-10
287 KSP Residual norm 7.475689899568e-10
288 KSP Residual norm 7.265921274797e-10
289 KSP Residual norm 7.080985819801e-10
290 KSP Residual norm 6.932701623952e-10
291 KSP Residual norm 6.732121112410e-10
292 KSP Residual norm 6.489056705575e-10
293 KSP Residual norm 6.270663820638e-10
294 KSP Residual norm 6.094739714518e-10
295 KSP Residual norm 5.905272853908e-10
296 KSP Residual norm 5.704985658116e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 296
stx: 0., fx: 0.0691391, dgx: -3.84523e-08
sty: 0., fy: 0.0691391, dgy: -3.84523e-08
31 TAO, Function value: 0.0691391, Residual: 8.90497e-05
Residual norms for tao_nls_ solve.
0 KSP Residual norm 8.904967389355e-05
1 KSP Residual norm 6.991115065216e-05
2 KSP Residual norm 4.796477991784e-05
3 KSP Residual norm 3.784777696713e-05
4 KSP Residual norm 2.923807179371e-05
5 KSP Residual norm 2.500636728028e-05
6 KSP Residual norm 2.199976528390e-05
7 KSP Residual norm 2.042220599032e-05
8 KSP Residual norm 1.962510383411e-05
9 KSP Residual norm 1.935486458449e-05
10 KSP Residual norm 1.909052895357e-05
11 KSP Residual norm 1.909389939278e-05
12 KSP Residual norm 1.908111684673e-05
13 KSP Residual norm 1.937618542334e-05
14 KSP Residual norm 1.987076122523e-05
15 KSP Residual norm 2.052798987946e-05
16 KSP Residual norm 2.147624764543e-05
17 KSP Residual norm 2.255799011230e-05
18 KSP Residual norm 2.361373685756e-05
19 KSP Residual norm 2.463951799808e-05
20 KSP Residual norm 2.550536688794e-05
21 KSP Residual norm 2.613807251235e-05
22 KSP Residual norm 2.624691078117e-05
23 KSP Residual norm 2.605305955930e-05
24 KSP Residual norm 2.576960256875e-05
25 KSP Residual norm 2.531529540367e-05
26 KSP Residual norm 2.480479683525e-05
27 KSP Residual norm 2.421868140016e-05
28 KSP Residual norm 2.360339360631e-05
29 KSP Residual norm 2.290949453394e-05
30 KSP Residual norm 2.191411605860e-05
31 KSP Residual norm 2.071203269823e-05
32 KSP Residual norm 1.934172824531e-05
33 KSP Residual norm 1.788439322110e-05
34 KSP Residual norm 1.644059557460e-05
35 KSP Residual norm 1.502753803967e-05
36 KSP Residual norm 1.365007429632e-05
37 KSP Residual norm 1.233283709881e-05
38 KSP Residual norm 1.108183661708e-05
39 KSP Residual norm 9.875293813679e-06
40 KSP Residual norm 8.793291184720e-06
41 KSP Residual norm 7.915548666941e-06
42 KSP Residual norm 7.262029034572e-06
43 KSP Residual norm 6.691969642512e-06
44 KSP Residual norm 5.986219233487e-06
45 KSP Residual norm 5.303996112414e-06
46 KSP Residual norm 4.750639537306e-06
47 KSP Residual norm 4.293919582394e-06
48 KSP Residual norm 3.906520946141e-06
49 KSP Residual norm 3.580876699766e-06
50 KSP Residual norm 3.259993208888e-06
51 KSP Residual norm 2.912294103934e-06
52 KSP Residual norm 2.591406227142e-06
53 KSP Residual norm 2.314916418275e-06
54 KSP Residual norm 2.071030099661e-06
55 KSP Residual norm 1.851855131975e-06
56 KSP Residual norm 1.664840369076e-06
57 KSP Residual norm 1.512089092083e-06
58 KSP Residual norm 1.386642474012e-06
59 KSP Residual norm 1.283958565871e-06
60 KSP Residual norm 1.203201865106e-06
61 KSP Residual norm 1.128227259988e-06
62 KSP Residual norm 1.047569506633e-06
63 KSP Residual norm 9.769025646569e-07
64 KSP Residual norm 9.288175520017e-07
65 KSP Residual norm 9.055133230745e-07
66 KSP Residual norm 8.734699839705e-07
67 KSP Residual norm 8.115673110535e-07
68 KSP Residual norm 7.603854582009e-07
69 KSP Residual norm 7.286891956798e-07
70 KSP Residual norm 7.030034178948e-07
71 KSP Residual norm 6.737462251809e-07
72 KSP Residual norm 6.418019786366e-07
73 KSP Residual norm 6.077561495719e-07
74 KSP Residual norm 5.740041217359e-07
75 KSP Residual norm 5.456198174292e-07
76 KSP Residual norm 5.167285027910e-07
77 KSP Residual norm 4.854934952920e-07
78 KSP Residual norm 4.551625429949e-07
79 KSP Residual norm 4.234287260301e-07
80 KSP Residual norm 3.939250224295e-07
81 KSP Residual norm 3.677218338331e-07
82 KSP Residual norm 3.466756535237e-07
83 KSP Residual norm 3.267621505719e-07
84 KSP Residual norm 2.994295816822e-07
85 KSP Residual norm 2.753891273782e-07
86 KSP Residual norm 2.591217305893e-07
87 KSP Residual norm 2.462906204585e-07
88 KSP Residual norm 2.323997991789e-07
89 KSP Residual norm 2.144669082103e-07
90 KSP Residual norm 1.985641721017e-07
91 KSP Residual norm 1.856475905835e-07
92 KSP Residual norm 1.747689047363e-07
93 KSP Residual norm 1.648456096825e-07
94 KSP Residual norm 1.529238042123e-07
95 KSP Residual norm 1.428908733508e-07
96 KSP Residual norm 1.352043527838e-07
97 KSP Residual norm 1.282459155209e-07
98 KSP Residual norm 1.230820153045e-07
99 KSP Residual norm 1.184928536065e-07
100 KSP Residual norm 1.141177712469e-07
101 KSP Residual norm 1.097971956229e-07
102 KSP Residual norm 1.044394192249e-07
103 KSP Residual norm 1.013099349941e-07
104 KSP Residual norm 9.849751684216e-08
105 KSP Residual norm 9.588879787562e-08
106 KSP Residual norm 9.309586508336e-08
107 KSP Residual norm 9.006502615363e-08
108 KSP Residual norm 8.797565776476e-08
109 KSP Residual norm 8.623541829735e-08
110 KSP Residual norm 8.539276717102e-08
111 KSP Residual norm 8.561233763859e-08
112 KSP Residual norm 8.660893793228e-08
113 KSP Residual norm 8.742716762915e-08
114 KSP Residual norm 8.788886317039e-08
115 KSP Residual norm 8.819591390026e-08
116 KSP Residual norm 8.873451127726e-08
117 KSP Residual norm 8.950862444699e-08
118 KSP Residual norm 9.046135054613e-08
119 KSP Residual norm 9.189190930412e-08
120 KSP Residual norm 9.326314718846e-08
121 KSP Residual norm 9.283830670999e-08
122 KSP Residual norm 9.148965813275e-08
123 KSP Residual norm 8.982653213712e-08
124 KSP Residual norm 8.712828256880e-08
125 KSP Residual norm 8.345125294866e-08
126 KSP Residual norm 7.986001445267e-08
127 KSP Residual norm 7.665660914764e-08
128 KSP Residual norm 7.366315776975e-08
129 KSP Residual norm 7.056940766570e-08
130 KSP Residual norm 6.744403449145e-08
131 KSP Residual norm 6.434192984250e-08
132 KSP Residual norm 6.100605208402e-08
133 KSP Residual norm 5.772852537700e-08
134 KSP Residual norm 5.505457514860e-08
135 KSP Residual norm 5.341816834616e-08
136 KSP Residual norm 5.223731762035e-08
137 KSP Residual norm 4.989312905033e-08
138 KSP Residual norm 4.711965245452e-08
139 KSP Residual norm 4.472270319220e-08
140 KSP Residual norm 4.274964295550e-08
141 KSP Residual norm 4.105561386737e-08
142 KSP Residual norm 3.950454623997e-08
143 KSP Residual norm 3.799472610157e-08
144 KSP Residual norm 3.671563758101e-08
145 KSP Residual norm 3.579963833178e-08
146 KSP Residual norm 3.498386803512e-08
147 KSP Residual norm 3.416402964726e-08
148 KSP Residual norm 3.345920321041e-08
149 KSP Residual norm 3.282871892988e-08
150 KSP Residual norm 3.225799089680e-08
151 KSP Residual norm 3.177616883721e-08
152 KSP Residual norm 3.125441486292e-08
153 KSP Residual norm 3.070317462126e-08
154 KSP Residual norm 3.022743283437e-08
155 KSP Residual norm 2.982085654865e-08
156 KSP Residual norm 2.965332987998e-08
157 KSP Residual norm 2.995102882768e-08
158 KSP Residual norm 3.046192074890e-08
159 KSP Residual norm 3.011452161474e-08
160 KSP Residual norm 2.928575791440e-08
161 KSP Residual norm 2.888884135850e-08
162 KSP Residual norm 2.867568716743e-08
163 KSP Residual norm 2.821678138356e-08
164 KSP Residual norm 2.755405748002e-08
165 KSP Residual norm 2.691680013508e-08
166 KSP Residual norm 2.628777928782e-08
167 KSP Residual norm 2.559485446530e-08
168 KSP Residual norm 2.486045018643e-08
169 KSP Residual norm 2.402866781981e-08
170 KSP Residual norm 2.318073933315e-08
171 KSP Residual norm 2.248988625853e-08
172 KSP Residual norm 2.187341204241e-08
173 KSP Residual norm 2.086786253659e-08
174 KSP Residual norm 1.957659309488e-08
175 KSP Residual norm 1.844876720389e-08
176 KSP Residual norm 1.757817356183e-08
177 KSP Residual norm 1.697020763092e-08
178 KSP Residual norm 1.647409926394e-08
179 KSP Residual norm 1.573944855377e-08
180 KSP Residual norm 1.480412942849e-08
181 KSP Residual norm 1.408967955454e-08
182 KSP Residual norm 1.355400161996e-08
183 KSP Residual norm 1.286373865670e-08
184 KSP Residual norm 1.207975010593e-08
185 KSP Residual norm 1.143016154422e-08
186 KSP Residual norm 1.090689006760e-08
187 KSP Residual norm 1.046694919752e-08
188 KSP Residual norm 1.007773018783e-08
189 KSP Residual norm 9.742817970361e-09
190 KSP Residual norm 9.459115252285e-09
191 KSP Residual norm 9.208108966194e-09
192 KSP Residual norm 8.939663888775e-09
193 KSP Residual norm 8.603377431173e-09
194 KSP Residual norm 8.275490197779e-09
195 KSP Residual norm 8.018042774333e-09
196 KSP Residual norm 7.801983637333e-09
197 KSP Residual norm 7.610690229124e-09
198 KSP Residual norm 7.453580839401e-09
199 KSP Residual norm 7.304255493710e-09
200 KSP Residual norm 7.171465714479e-09
201 KSP Residual norm 7.067472548467e-09
202 KSP Residual norm 7.026363083868e-09
203 KSP Residual norm 6.988580172106e-09
204 KSP Residual norm 6.895878472742e-09
205 KSP Residual norm 6.769235925673e-09
206 KSP Residual norm 6.647045856934e-09
207 KSP Residual norm 6.519048850429e-09
208 KSP Residual norm 6.369661844371e-09
209 KSP Residual norm 6.225399122405e-09
210 KSP Residual norm 6.099838428904e-09
211 KSP Residual norm 5.972339234575e-09
212 KSP Residual norm 5.842875553667e-09
213 KSP Residual norm 5.720379645265e-09
214 KSP Residual norm 5.622308850644e-09
215 KSP Residual norm 5.585444436903e-09
216 KSP Residual norm 5.619503758249e-09
217 KSP Residual norm 5.499483661617e-09
218 KSP Residual norm 5.226743917144e-09
219 KSP Residual norm 5.004601581323e-09
220 KSP Residual norm 4.819017499289e-09
221 KSP Residual norm 4.635205009847e-09
222 KSP Residual norm 4.459600044313e-09
223 KSP Residual norm 4.295097019204e-09
224 KSP Residual norm 4.134292657563e-09
225 KSP Residual norm 3.965968501769e-09
226 KSP Residual norm 3.802104595962e-09
227 KSP Residual norm 3.636486948940e-09
228 KSP Residual norm 3.472374879672e-09
229 KSP Residual norm 3.322499402619e-09
230 KSP Residual norm 3.197009161377e-09
231 KSP Residual norm 3.086331095287e-09
232 KSP Residual norm 3.005610892799e-09
233 KSP Residual norm 2.973385781913e-09
234 KSP Residual norm 2.869979701256e-09
235 KSP Residual norm 2.679502738122e-09
236 KSP Residual norm 2.534822519741e-09
237 KSP Residual norm 2.445357838965e-09
238 KSP Residual norm 2.378772733485e-09
239 KSP Residual norm 2.322024940518e-09
240 KSP Residual norm 2.270492329422e-09
241 KSP Residual norm 2.183679791203e-09
242 KSP Residual norm 2.066437373735e-09
243 KSP Residual norm 1.964863991004e-09
244 KSP Residual norm 1.887313192978e-09
245 KSP Residual norm 1.820339942756e-09
246 KSP Residual norm 1.764019491547e-09
247 KSP Residual norm 1.718219402900e-09
248 KSP Residual norm 1.661908001738e-09
249 KSP Residual norm 1.598936940025e-09
250 KSP Residual norm 1.548068393013e-09
251 KSP Residual norm 1.508157434803e-09
252 KSP Residual norm 1.462471326623e-09
253 KSP Residual norm 1.416318536571e-09
254 KSP Residual norm 1.383104681694e-09
255 KSP Residual norm 1.356277788152e-09
256 KSP Residual norm 1.331403406703e-09
257 KSP Residual norm 1.307187216888e-09
258 KSP Residual norm 1.286023922319e-09
259 KSP Residual norm 1.268788816842e-09
260 KSP Residual norm 1.246919970432e-09
261 KSP Residual norm 1.215363860117e-09
262 KSP Residual norm 1.177603764392e-09
263 KSP Residual norm 1.143567136594e-09
264 KSP Residual norm 1.114810324380e-09
265 KSP Residual norm 1.088935197884e-09
266 KSP Residual norm 1.067057981592e-09
267 KSP Residual norm 1.043356500387e-09
268 KSP Residual norm 1.017737055783e-09
269 KSP Residual norm 9.963177061097e-10
270 KSP Residual norm 9.767408259706e-10
271 KSP Residual norm 9.601045948419e-10
272 KSP Residual norm 9.442520284393e-10
273 KSP Residual norm 9.199912192552e-10
274 KSP Residual norm 8.834934185330e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 274
1 LS Function value: 0.069139, Step length: 1.
stx: 0., fx: 0.0691391, dgx: -3.71917e-08
sty: 0., fy: 0.0691391, dgy: -3.71917e-08
32 TAO, Function value: 0.069139, Residual: 3.70651e-05
0 KSP Residual norm 3.706507016073e-05
1 KSP Residual norm 3.018132415771e-05
2 KSP Residual norm 2.193482439073e-05
3 KSP Residual norm 1.843803366627e-05
4 KSP Residual norm 1.576332781105e-05
5 KSP Residual norm 1.524657299390e-05
6 KSP Residual norm 1.549406379596e-05
7 KSP Residual norm 1.674570969655e-05
8 KSP Residual norm 1.823597388362e-05
9 KSP Residual norm 2.025507446787e-05
10 KSP Residual norm 2.176229385004e-05
11 KSP Residual norm 2.372737560158e-05
12 KSP Residual norm 2.598002392289e-05
13 KSP Residual norm 2.826089396819e-05
14 KSP Residual norm 3.057106447366e-05
15 KSP Residual norm 3.298701339707e-05
16 KSP Residual norm 3.584420684022e-05
17 KSP Residual norm 3.827605336779e-05
18 KSP Residual norm 3.980529513724e-05
19 KSP Residual norm 4.111335015034e-05
20 KSP Residual norm 4.186448987638e-05
21 KSP Residual norm 4.211359671311e-05
22 KSP Residual norm 4.180732548398e-05
23 KSP Residual norm 4.126601761932e-05
24 KSP Residual norm 4.059135309836e-05
25 KSP Residual norm 3.956267555464e-05
26 KSP Residual norm 3.834059548963e-05
27 KSP Residual norm 3.682778893723e-05
28 KSP Residual norm 3.502868465173e-05
29 KSP Residual norm 3.307965214901e-05
30 KSP Residual norm 3.105575531123e-05
31 KSP Residual norm 2.908818260490e-05
32 KSP Residual norm 2.702832439465e-05
33 KSP Residual norm 2.478792715537e-05
34 KSP Residual norm 2.249398104842e-05
35 KSP Residual norm 2.028116992643e-05
36 KSP Residual norm 1.824115518433e-05
37 KSP Residual norm 1.639661473106e-05
38 KSP Residual norm 1.469839362573e-05
39 KSP Residual norm 1.312740221672e-05
40 KSP Residual norm 1.176501363521e-05
41 KSP Residual norm 1.067675859419e-05
42 KSP Residual norm 9.799232275552e-06
43 KSP Residual norm 8.918551492490e-06
44 KSP Residual norm 7.982966365971e-06
45 KSP Residual norm 7.144819412713e-06
46 KSP Residual norm 6.429340277259e-06
47 KSP Residual norm 5.800772546016e-06
48 KSP Residual norm 5.231787496247e-06
49 KSP Residual norm 4.738229414937e-06
50 KSP Residual norm 4.329248292647e-06
51 KSP Residual norm 3.964903074545e-06
52 KSP Residual norm 3.583234939193e-06
53 KSP Residual norm 3.211222718318e-06
54 KSP Residual norm 2.890541182387e-06
55 KSP Residual norm 2.619390295717e-06
56 KSP Residual norm 2.402052235048e-06
57 KSP Residual norm 2.239878861015e-06
58 KSP Residual norm 2.125383897279e-06
59 KSP Residual norm 2.039211886750e-06
60 KSP Residual norm 1.955028665384e-06
61 KSP Residual norm 1.872186521993e-06
62 KSP Residual norm 1.805367342845e-06
63 KSP Residual norm 1.752073683876e-06
64 KSP Residual norm 1.704806720116e-06
65 KSP Residual norm 1.661586359103e-06
66 KSP Residual norm 1.618729427128e-06
67 KSP Residual norm 1.578299744442e-06
68 KSP Residual norm 1.552439455130e-06
69 KSP Residual norm 1.534224741360e-06
70 KSP Residual norm 1.487338213153e-06
71 KSP Residual norm 1.419644595681e-06
72 KSP Residual norm 1.364551880141e-06
73 KSP Residual norm 1.306887923393e-06
74 KSP Residual norm 1.230338623496e-06
75 KSP Residual norm 1.152544231708e-06
76 KSP Residual norm 1.077714116735e-06
77 KSP Residual norm 1.006033112673e-06
78 KSP Residual norm 9.453956923528e-07
79 KSP Residual norm 8.918457864818e-07
80 KSP Residual norm 8.412936562137e-07
81 KSP Residual norm 7.831253306374e-07
82 KSP Residual norm 7.199254284898e-07
83 KSP Residual norm 6.665975246992e-07
84 KSP Residual norm 6.190948460449e-07
85 KSP Residual norm 5.805750613128e-07
86 KSP Residual norm 5.503067411311e-07
87 KSP Residual norm 5.197813842476e-07
88 KSP Residual norm 4.937089391854e-07
89 KSP Residual norm 4.744394671488e-07
90 KSP Residual norm 4.568288916900e-07
91 KSP Residual norm 4.310999831981e-07
92 KSP Residual norm 4.079648647800e-07
93 KSP Residual norm 3.962045476143e-07
94 KSP Residual norm 3.838939804358e-07
95 KSP Residual norm 3.660659958739e-07
96 KSP Residual norm 3.492513077613e-07
97 KSP Residual norm 3.350921963329e-07
98 KSP Residual norm 3.268427001883e-07
99 KSP Residual norm 3.210166532452e-07
100 KSP Residual norm 3.134480176419e-07
101 KSP Residual norm 3.059478083532e-07
102 KSP Residual norm 2.965704526634e-07
103 KSP Residual norm 2.927879823041e-07
104 KSP Residual norm 2.899988709214e-07
105 KSP Residual norm 2.878306926420e-07
106 KSP Residual norm 2.874199941633e-07
107 KSP Residual norm 2.848471007363e-07
108 KSP Residual norm 2.826492907451e-07
109 KSP Residual norm 2.790643317284e-07
110 KSP Residual norm 2.777101614280e-07
111 KSP Residual norm 2.792806886770e-07
112 KSP Residual norm 2.790838577551e-07
113 KSP Residual norm 2.747696001200e-07
114 KSP Residual norm 2.705202176768e-07
115 KSP Residual norm 2.675343653623e-07
116 KSP Residual norm 2.649000027392e-07
117 KSP Residual norm 2.614113801882e-07
118 KSP Residual norm 2.551178388743e-07
119 KSP Residual norm 2.472563476668e-07
120 KSP Residual norm 2.380659525325e-07
121 KSP Residual norm 2.278585536568e-07
122 KSP Residual norm 2.179093462711e-07
123 KSP Residual norm 2.079636443446e-07
124 KSP Residual norm 1.984343656099e-07
125 KSP Residual norm 1.876881657603e-07
126 KSP Residual norm 1.759934210465e-07
127 KSP Residual norm 1.647268076198e-07
128 KSP Residual norm 1.554528429614e-07
129 KSP Residual norm 1.476633705073e-07
130 KSP Residual norm 1.407123991097e-07
131 KSP Residual norm 1.353727277467e-07
132 KSP Residual norm 1.318108919269e-07
133 KSP Residual norm 1.273832271916e-07
134 KSP Residual norm 1.216343553735e-07
135 KSP Residual norm 1.160776546383e-07
136 KSP Residual norm 1.107189105035e-07
137 KSP Residual norm 1.061420212208e-07
138 KSP Residual norm 1.029215000808e-07
139 KSP Residual norm 1.010642408495e-07
140 KSP Residual norm 1.006359801052e-07
141 KSP Residual norm 1.002258873115e-07
142 KSP Residual norm 9.769969742260e-08
143 KSP Residual norm 9.458051686101e-08
144 KSP Residual norm 9.253624774034e-08
145 KSP Residual norm 9.116977465874e-08
146 KSP Residual norm 8.958253415354e-08
147 KSP Residual norm 8.801862139799e-08
148 KSP Residual norm 8.720870747767e-08
149 KSP Residual norm 8.678468846184e-08
150 KSP Residual norm 8.622789911051e-08
151 KSP Residual norm 8.566520588480e-08
152 KSP Residual norm 8.518326373420e-08
153 KSP Residual norm 8.475338060610e-08
154 KSP Residual norm 8.451944904624e-08
155 KSP Residual norm 8.438581055852e-08
156 KSP Residual norm 8.480951459373e-08
157 KSP Residual norm 8.623867580472e-08
158 KSP Residual norm 8.659254174084e-08
159 KSP Residual norm 8.482992041392e-08
160 KSP Residual norm 8.307777816155e-08
161 KSP Residual norm 8.198326368958e-08
162 KSP Residual norm 8.114319604324e-08
163 KSP Residual norm 8.041336257949e-08
164 KSP Residual norm 7.918796975642e-08
165 KSP Residual norm 7.732318152922e-08
166 KSP Residual norm 7.481431186656e-08
167 KSP Residual norm 7.194349817735e-08
168 KSP Residual norm 6.915484065894e-08
169 KSP Residual norm 6.648992270556e-08
170 KSP Residual norm 6.385434993983e-08
171 KSP Residual norm 6.112044666247e-08
172 KSP Residual norm 5.819225134818e-08
173 KSP Residual norm 5.501344303051e-08
174 KSP Residual norm 5.197686853158e-08
175 KSP Residual norm 4.958627761065e-08
176 KSP Residual norm 4.780290020285e-08
177 KSP Residual norm 4.585859044743e-08
178 KSP Residual norm 4.335647195517e-08
179 KSP Residual norm 4.097584367301e-08
180 KSP Residual norm 3.896520441367e-08
181 KSP Residual norm 3.714877455121e-08
182 KSP Residual norm 3.532204903372e-08
183 KSP Residual norm 3.349588212041e-08
184 KSP Residual norm 3.167527218195e-08
185 KSP Residual norm 2.997948193943e-08
186 KSP Residual norm 2.841654605491e-08
187 KSP Residual norm 2.692103264146e-08
188 KSP Residual norm 2.554998317863e-08
189 KSP Residual norm 2.435258704894e-08
190 KSP Residual norm 2.326221345241e-08
191 KSP Residual norm 2.218457523260e-08
192 KSP Residual norm 2.109972323377e-08
193 KSP Residual norm 2.018719428843e-08
194 KSP Residual norm 1.960305672038e-08
195 KSP Residual norm 1.939429061998e-08
196 KSP Residual norm 1.866602721681e-08
197 KSP Residual norm 1.752577036338e-08
198 KSP Residual norm 1.675923470911e-08
199 KSP Residual norm 1.618898509523e-08
200 KSP Residual norm 1.566073331691e-08
201 KSP Residual norm 1.514897966239e-08
202 KSP Residual norm 1.471816500784e-08
203 KSP Residual norm 1.428379529295e-08
204 KSP Residual norm 1.384201680524e-08
205 KSP Residual norm 1.348860556227e-08
206 KSP Residual norm 1.323707150379e-08
207 KSP Residual norm 1.300329686097e-08
208 KSP Residual norm 1.268913571244e-08
209 KSP Residual norm 1.238469323448e-08
210 KSP Residual norm 1.216897481289e-08
211 KSP Residual norm 1.202216052568e-08
212 KSP Residual norm 1.186470116351e-08
213 KSP Residual norm 1.166755356330e-08
214 KSP Residual norm 1.145198153086e-08
215 KSP Residual norm 1.123521216810e-08
216 KSP Residual norm 1.104683830204e-08
217 KSP Residual norm 1.091097909747e-08
218 KSP Residual norm 1.081020226600e-08
219 KSP Residual norm 1.069140951785e-08
220 KSP Residual norm 1.050232768743e-08
221 KSP Residual norm 1.027159659464e-08
222 KSP Residual norm 1.005364680799e-08
223 KSP Residual norm 9.885795489949e-09
224 KSP Residual norm 9.797732646376e-09
225 KSP Residual norm 9.746002980382e-09
226 KSP Residual norm 9.490748288909e-09
227 KSP Residual norm 9.046324068153e-09
228 KSP Residual norm 8.696432617565e-09
229 KSP Residual norm 8.461512493669e-09
230 KSP Residual norm 8.261674589785e-09
231 KSP Residual norm 8.060746676739e-09
232 KSP Residual norm 7.878657100240e-09
233 KSP Residual norm 7.703566396782e-09
234 KSP Residual norm 7.490152656024e-09
235 KSP Residual norm 7.221637520494e-09
236 KSP Residual norm 6.947483776752e-09
237 KSP Residual norm 6.720080814147e-09
238 KSP Residual norm 6.517353365686e-09
239 KSP Residual norm 6.270377695633e-09
240 KSP Residual norm 5.971803192986e-09
241 KSP Residual norm 5.664573067927e-09
242 KSP Residual norm 5.376796682092e-09
243 KSP Residual norm 5.130015473102e-09
244 KSP Residual norm 4.922893111778e-09
245 KSP Residual norm 4.746507349872e-09
246 KSP Residual norm 4.585095300798e-09
247 KSP Residual norm 4.423651965948e-09
248 KSP Residual norm 4.265997153439e-09
249 KSP Residual norm 4.111120099713e-09
250 KSP Residual norm 3.976952730839e-09
251 KSP Residual norm 3.896126697923e-09
252 KSP Residual norm 3.864960020402e-09
253 KSP Residual norm 3.742781248776e-09
254 KSP Residual norm 3.563322361475e-09
255 KSP Residual norm 3.447455316114e-09
256 KSP Residual norm 3.420173583632e-09
257 KSP Residual norm 3.359838264916e-09
258 KSP Residual norm 3.151119572527e-09
259 KSP Residual norm 2.957579548305e-09
260 KSP Residual norm 2.816365205584e-09
261 KSP Residual norm 2.720832199379e-09
262 KSP Residual norm 2.660294936716e-09
263 KSP Residual norm 2.590608027705e-09
264 KSP Residual norm 2.481254032968e-09
265 KSP Residual norm 2.375410080711e-09
266 KSP Residual norm 2.307240493937e-09
267 KSP Residual norm 2.266906998223e-09
268 KSP Residual norm 2.235126230200e-09
269 KSP Residual norm 2.201388879436e-09
270 KSP Residual norm 2.157864627928e-09
271 KSP Residual norm 2.115684403453e-09
272 KSP Residual norm 2.079252722319e-09
273 KSP Residual norm 2.042074774181e-09
274 KSP Residual norm 1.995646905808e-09
275 KSP Residual norm 1.943824909933e-09
276 KSP Residual norm 1.896125654079e-09
277 KSP Residual norm 1.845233116752e-09
278 KSP Residual norm 1.799067979359e-09
279 KSP Residual norm 1.749599764321e-09
280 KSP Residual norm 1.695520471604e-09
281 KSP Residual norm 1.643521832721e-09
282 KSP Residual norm 1.593316225950e-09
283 KSP Residual norm 1.550060628034e-09
284 KSP Residual norm 1.508572382076e-09
285 KSP Residual norm 1.469800333302e-09
286 KSP Residual norm 1.442219293231e-09
287 KSP Residual norm 1.421939614520e-09
288 KSP Residual norm 1.399021240910e-09
289 KSP Residual norm 1.372967909863e-09
290 KSP Residual norm 1.341337593941e-09
291 KSP Residual norm 1.307817650448e-09
292 KSP Residual norm 1.274210704029e-09
293 KSP Residual norm 1.234854952145e-09
294 KSP Residual norm 1.187350255486e-09
295 KSP Residual norm 1.140498145070e-09
296 KSP Residual norm 1.096227694363e-09
297 KSP Residual norm 1.058372272906e-09
298 KSP Residual norm 1.023975754175e-09
299 KSP Residual norm 9.917909611842e-10
300 KSP Residual norm 9.663391880518e-10
301 KSP Residual norm 9.469955080594e-10
302 KSP Residual norm 9.288302378341e-10
303 KSP Residual norm 9.070544239190e-10
304 KSP Residual norm 8.876132606355e-10
305 KSP Residual norm 8.756071018758e-10
306 KSP Residual norm 8.598335857724e-10
307 KSP Residual norm 8.344696694358e-10
308 KSP Residual norm 8.092861752037e-10
309 KSP Residual norm 7.878230298555e-10
310 KSP Residual norm 7.727749022005e-10
311 KSP Residual norm 7.680826868340e-10
312 KSP Residual norm 7.526447911957e-10
313 KSP Residual norm 7.150094616393e-10
314 KSP Residual norm 6.818357053992e-10
315 KSP Residual norm 6.608317272867e-10
316 KSP Residual norm 6.486484079500e-10
317 KSP Residual norm 6.485407446676e-10
318 KSP Residual norm 6.578741290036e-10
319 KSP Residual norm 6.349408900029e-10
320 KSP Residual norm 6.059472571106e-10
321 KSP Residual norm 5.934105678680e-10
322 KSP Residual norm 5.870926478878e-10
323 KSP Residual norm 5.750710946844e-10
324 KSP Residual norm 5.577367211107e-10
325 KSP Residual norm 5.432063214893e-10
326 KSP Residual norm 5.332009997093e-10
327 KSP Residual norm 5.227830162211e-10
328 KSP Residual norm 5.101858309408e-10
329 KSP Residual norm 4.949120819033e-10
330 KSP Residual norm 4.799648134145e-10
331 KSP Residual norm 4.661441465596e-10
332 KSP Residual norm 4.505184798837e-10
333 KSP Residual norm 4.337615091354e-10
334 KSP Residual norm 4.193804357379e-10
335 KSP Residual norm 4.056211300346e-10
336 KSP Residual norm 3.924753975529e-10
337 KSP Residual norm 3.822565596022e-10
338 KSP Residual norm 3.774481993084e-10
339 KSP Residual norm 3.747022216884e-10
340 KSP Residual norm 3.660344199416e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 340
0 LS Function value: 0.069139, Step length: 0.
stx: 0., fx: 0.069139, dgx: -4.30641e-08
sty: 0., fy: 0.069139, dgy: -4.30641e-08
2 LS Function value: 0.069139, Step length: 0.468265
sty: 1., fy: 0.0691391, dgy: 1.5642e-07
33 TAO, Function value: 0.069139, Residual: 6.54532e-05
0 KSP Residual norm 6.545323099273e-05
1 KSP Residual norm 5.108563743407e-05
2 KSP Residual norm 3.557973148592e-05
3 KSP Residual norm 2.807580170778e-05
4 KSP Residual norm 2.233345574421e-05
5 KSP Residual norm 1.959850575468e-05
6 KSP Residual norm 1.779377036734e-05
7 KSP Residual norm 1.728219184812e-05
8 KSP Residual norm 1.723954547954e-05
9 KSP Residual norm 1.804744887780e-05
10 KSP Residual norm 1.847335014006e-05
11 KSP Residual norm 1.924162221138e-05
12 KSP Residual norm 2.032005754828e-05
13 KSP Residual norm 2.143472926309e-05
14 KSP Residual norm 2.284022526392e-05
15 KSP Residual norm 2.438449554568e-05
16 KSP Residual norm 2.626974596937e-05
17 KSP Residual norm 2.846383506361e-05
18 KSP Residual norm 3.029676563208e-05
19 KSP Residual norm 3.166733231698e-05
20 KSP Residual norm 3.246978751627e-05
21 KSP Residual norm 3.289036858225e-05
22 KSP Residual norm 3.290668443992e-05
23 KSP Residual norm 3.264754492501e-05
24 KSP Residual norm 3.226767242790e-05
25 KSP Residual norm 3.164684921998e-05
26 KSP Residual norm 3.089126715641e-05
27 KSP Residual norm 3.008183243202e-05
28 KSP Residual norm 2.908864624217e-05
29 KSP Residual norm 2.776267286730e-05
30 KSP Residual norm 2.622837655048e-05
31 KSP Residual norm 2.468023545795e-05
32 KSP Residual norm 2.304577687114e-05
33 KSP Residual norm 2.134559217597e-05
34 KSP Residual norm 1.961792915101e-05
35 KSP Residual norm 1.785525149729e-05
36 KSP Residual norm 1.613233218039e-05
37 KSP Residual norm 1.454147651892e-05
38 KSP Residual norm 1.306727209706e-05
39 KSP Residual norm 1.165014851726e-05
40 KSP Residual norm 1.033477805186e-05
41 KSP Residual norm 9.198651529410e-06
42 KSP Residual norm 8.246687054674e-06
43 KSP Residual norm 7.467984407129e-06
44 KSP Residual norm 6.826280786238e-06
45 KSP Residual norm 6.221430122024e-06
46 KSP Residual norm 5.594413925935e-06
47 KSP Residual norm 5.003941163238e-06
48 KSP Residual norm 4.478044107279e-06
49 KSP Residual norm 4.025407504588e-06
50 KSP Residual norm 3.660642959263e-06
51 KSP Residual norm 3.388127661895e-06
52 KSP Residual norm 3.109543823460e-06
53 KSP Residual norm 2.768097172582e-06
54 KSP Residual norm 2.465565812466e-06
55 KSP Residual norm 2.220370151694e-06
56 KSP Residual norm 2.019132876584e-06
57 KSP Residual norm 1.855959201308e-06
58 KSP Residual norm 1.724303114917e-06
59 KSP Residual norm 1.618660780651e-06
60 KSP Residual norm 1.536360376438e-06
61 KSP Residual norm 1.472713069044e-06
62 KSP Residual norm 1.426111797173e-06
63 KSP Residual norm 1.392793556754e-06
64 KSP Residual norm 1.371516787104e-06
65 KSP Residual norm 1.363566994036e-06
66 KSP Residual norm 1.346069629633e-06
67 KSP Residual norm 1.298247054153e-06
68 KSP Residual norm 1.251343872722e-06
69 KSP Residual norm 1.221561725597e-06
70 KSP Residual norm 1.198402997796e-06
71 KSP Residual norm 1.176805870415e-06
72 KSP Residual norm 1.159444254142e-06
73 KSP Residual norm 1.135604368187e-06
74 KSP Residual norm 1.106292950461e-06
75 KSP Residual norm 1.077856266471e-06
76 KSP Residual norm 1.034043940103e-06
77 KSP Residual norm 9.778695849516e-07
78 KSP Residual norm 9.254389032041e-07
79 KSP Residual norm 8.765780947783e-07
80 KSP Residual norm 8.352365693030e-07
81 KSP Residual norm 7.997130999398e-07
82 KSP Residual norm 7.631401349689e-07
83 KSP Residual norm 7.221867988768e-07
84 KSP Residual norm 6.759381733536e-07
85 KSP Residual norm 6.369813477348e-07
86 KSP Residual norm 6.079418308567e-07
87 KSP Residual norm 5.813779090523e-07
88 KSP Residual norm 5.620292837414e-07
89 KSP Residual norm 5.404147165094e-07
90 KSP Residual norm 5.094813398631e-07
91 KSP Residual norm 4.801554621256e-07
92 KSP Residual norm 4.584200726177e-07
93 KSP Residual norm 4.417666607489e-07
94 KSP Residual norm 4.175343200259e-07
95 KSP Residual norm 3.936983280923e-07
96 KSP Residual norm 3.772521067928e-07
97 KSP Residual norm 3.624122764433e-07
98 KSP Residual norm 3.522416060051e-07
99 KSP Residual norm 3.440700574938e-07
100 KSP Residual norm 3.327176434595e-07
101 KSP Residual norm 3.206256703547e-07
102 KSP Residual norm 3.062418979016e-07
103 KSP Residual norm 2.965246725670e-07
104 KSP Residual norm 2.882098637630e-07
105 KSP Residual norm 2.807841537085e-07
106 KSP Residual norm 2.768714130842e-07
107 KSP Residual norm 2.711182984878e-07
108 KSP Residual norm 2.649310340716e-07
109 KSP Residual norm 2.558376029356e-07
110 KSP Residual norm 2.482901755800e-07
111 KSP Residual norm 2.435886851064e-07
112 KSP Residual norm 2.407263488350e-07
113 KSP Residual norm 2.376657413678e-07
114 KSP Residual norm 2.331070541121e-07
115 KSP Residual norm 2.269565122531e-07
116 KSP Residual norm 2.198828060798e-07
117 KSP Residual norm 2.122484254129e-07
118 KSP Residual norm 2.045085813179e-07
119 KSP Residual norm 1.974101968851e-07
120 KSP Residual norm 1.898622049265e-07
121 KSP Residual norm 1.816863863703e-07
122 KSP Residual norm 1.753790022986e-07
123 KSP Residual norm 1.698416881280e-07
124 KSP Residual norm 1.599194715301e-07
125 KSP Residual norm 1.475195275640e-07
126 KSP Residual norm 1.371461165121e-07
127 KSP Residual norm 1.282450111502e-07
128 KSP Residual norm 1.200530262083e-07
129 KSP Residual norm 1.126040243085e-07
130 KSP Residual norm 1.058497913451e-07
131 KSP Residual norm 9.965303838430e-08
132 KSP Residual norm 9.349708130102e-08
133 KSP Residual norm 8.794490277039e-08
134 KSP Residual norm 8.358802931544e-08
135 KSP Residual norm 8.037736194917e-08
136 KSP Residual norm 7.734988642395e-08
137 KSP Residual norm 7.389681490502e-08
138 KSP Residual norm 7.075310522040e-08
139 KSP Residual norm 6.817931102662e-08
140 KSP Residual norm 6.617028278567e-08
141 KSP Residual norm 6.498679236554e-08
142 KSP Residual norm 6.477825607946e-08
143 KSP Residual norm 6.406433951622e-08
144 KSP Residual norm 6.147173854709e-08
145 KSP Residual norm 5.920845245655e-08
146 KSP Residual norm 5.788541349489e-08
147 KSP Residual norm 5.704594639048e-08
148 KSP Residual norm 5.665261842113e-08
149 KSP Residual norm 5.631543288231e-08
150 KSP Residual norm 5.570516327691e-08
151 KSP Residual norm 5.511845781953e-08
152 KSP Residual norm 5.479616149330e-08
153 KSP Residual norm 5.470895445354e-08
154 KSP Residual norm 5.490270005814e-08
155 KSP Residual norm 5.515905938400e-08
156 KSP Residual norm 5.544961401828e-08
157 KSP Residual norm 5.604710424897e-08
158 KSP Residual norm 5.688264526759e-08
159 KSP Residual norm 5.793027288212e-08
160 KSP Residual norm 5.821046214822e-08
161 KSP Residual norm 5.753290816764e-08
162 KSP Residual norm 5.700129079013e-08
163 KSP Residual norm 5.698832136923e-08
164 KSP Residual norm 5.701648598165e-08
165 KSP Residual norm 5.716996375489e-08
166 KSP Residual norm 5.748191853052e-08
167 KSP Residual norm 5.681772892807e-08
168 KSP Residual norm 5.466418045106e-08
169 KSP Residual norm 5.249934624712e-08
170 KSP Residual norm 5.103645209893e-08
171 KSP Residual norm 4.998072144867e-08
172 KSP Residual norm 4.840458036348e-08
173 KSP Residual norm 4.589555856739e-08
174 KSP Residual norm 4.349145402754e-08
175 KSP Residual norm 4.149349314129e-08
176 KSP Residual norm 3.961201284061e-08
177 KSP Residual norm 3.781128264068e-08
178 KSP Residual norm 3.607121790350e-08
179 KSP Residual norm 3.450371661629e-08
180 KSP Residual norm 3.341178989266e-08
181 KSP Residual norm 3.299759583557e-08
182 KSP Residual norm 3.205358944415e-08
183 KSP Residual norm 2.990109108349e-08
184 KSP Residual norm 2.793686764613e-08
185 KSP Residual norm 2.638346995762e-08
186 KSP Residual norm 2.501006432729e-08
187 KSP Residual norm 2.379531151216e-08
188 KSP Residual norm 2.258588213461e-08
189 KSP Residual norm 2.131054511304e-08
190 KSP Residual norm 2.009451938227e-08
191 KSP Residual norm 1.899066143004e-08
192 KSP Residual norm 1.798354266493e-08
193 KSP Residual norm 1.703974031884e-08
194 KSP Residual norm 1.621306513278e-08
195 KSP Residual norm 1.545758404611e-08
196 KSP Residual norm 1.466544063222e-08
197 KSP Residual norm 1.389379285018e-08
198 KSP Residual norm 1.325912478066e-08
199 KSP Residual norm 1.268929129894e-08
200 KSP Residual norm 1.215558850704e-08
201 KSP Residual norm 1.165843474888e-08
202 KSP Residual norm 1.126473262954e-08
203 KSP Residual norm 1.087805740056e-08
204 KSP Residual norm 1.041810564157e-08
205 KSP Residual norm 9.978340522007e-09
206 KSP Residual norm 9.606701317442e-09
207 KSP Residual norm 9.278541591514e-09
208 KSP Residual norm 8.959968093517e-09
209 KSP Residual norm 8.735746421532e-09
210 KSP Residual norm 8.615120377191e-09
211 KSP Residual norm 8.386585269495e-09
212 KSP Residual norm 8.018659512833e-09
213 KSP Residual norm 7.746856926309e-09
214 KSP Residual norm 7.602229340772e-09
215 KSP Residual norm 7.510271860189e-09
216 KSP Residual norm 7.403739106992e-09
217 KSP Residual norm 7.274283387564e-09
218 KSP Residual norm 7.148656579715e-09
219 KSP Residual norm 7.028065114257e-09
220 KSP Residual norm 6.886976273954e-09
221 KSP Residual norm 6.744177237265e-09
222 KSP Residual norm 6.641156891922e-09
223 KSP Residual norm 6.625903093193e-09
224 KSP Residual norm 6.644370124907e-09
225 KSP Residual norm 6.505602346407e-09
226 KSP Residual norm 6.268175017000e-09
227 KSP Residual norm 6.061656205441e-09
228 KSP Residual norm 5.908242233017e-09
229 KSP Residual norm 5.795124462539e-09
230 KSP Residual norm 5.700960611964e-09
231 KSP Residual norm 5.615833797872e-09
232 KSP Residual norm 5.557044591441e-09
233 KSP Residual norm 5.533417672850e-09
234 KSP Residual norm 5.558848995779e-09
235 KSP Residual norm 5.579009286320e-09
236 KSP Residual norm 5.373951831561e-09
237 KSP Residual norm 5.077526882390e-09
238 KSP Residual norm 4.863708033872e-09
239 KSP Residual norm 4.699634910964e-09
240 KSP Residual norm 4.554832115050e-09
241 KSP Residual norm 4.429349677881e-09
242 KSP Residual norm 4.318069795012e-09
243 KSP Residual norm 4.186491010894e-09
244 KSP Residual norm 3.997694852128e-09
245 KSP Residual norm 3.804466013566e-09
246 KSP Residual norm 3.654116258926e-09
247 KSP Residual norm 3.529365426518e-09
248 KSP Residual norm 3.386455996101e-09
249 KSP Residual norm 3.234907998425e-09
250 KSP Residual norm 3.096135956393e-09
251 KSP Residual norm 2.981112927014e-09
252 KSP Residual norm 2.884522405383e-09
253 KSP Residual norm 2.811416270108e-09
254 KSP Residual norm 2.760277623349e-09
255 KSP Residual norm 2.690414565576e-09
256 KSP Residual norm 2.589684334264e-09
257 KSP Residual norm 2.482526703927e-09
258 KSP Residual norm 2.381848361417e-09
259 KSP Residual norm 2.277563489223e-09
260 KSP Residual norm 2.170836708053e-09
261 KSP Residual norm 2.075313328816e-09
262 KSP Residual norm 1.985691437443e-09
263 KSP Residual norm 1.899535590768e-09
264 KSP Residual norm 1.826266817726e-09
265 KSP Residual norm 1.766301535172e-09
266 KSP Residual norm 1.730433056117e-09
267 KSP Residual norm 1.701555450859e-09
268 KSP Residual norm 1.646459097787e-09
269 KSP Residual norm 1.579618233340e-09
270 KSP Residual norm 1.524474189157e-09
271 KSP Residual norm 1.482027698288e-09
272 KSP Residual norm 1.446724732870e-09
273 KSP Residual norm 1.413146963835e-09
274 KSP Residual norm 1.376675948184e-09
275 KSP Residual norm 1.340585286878e-09
276 KSP Residual norm 1.313852353937e-09
277 KSP Residual norm 1.287386721785e-09
278 KSP Residual norm 1.251471332362e-09
279 KSP Residual norm 1.203608370848e-09
280 KSP Residual norm 1.156999142643e-09
281 KSP Residual norm 1.119828498677e-09
282 KSP Residual norm 1.086070555298e-09
283 KSP Residual norm 1.055843928238e-09
284 KSP Residual norm 1.028307019476e-09
285 KSP Residual norm 1.003073696979e-09
286 KSP Residual norm 9.834254423902e-10
287 KSP Residual norm 9.658710971841e-10
288 KSP Residual norm 9.447276221663e-10
289 KSP Residual norm 9.257799859922e-10
290 KSP Residual norm 9.162568221901e-10
291 KSP Residual norm 9.184633374013e-10
292 KSP Residual norm 9.028525973792e-10
293 KSP Residual norm 8.520192986494e-10
294 KSP Residual norm 8.080477225248e-10
295 KSP Residual norm 7.798703301499e-10
296 KSP Residual norm 7.582280654354e-10
297 KSP Residual norm 7.375043595383e-10
298 KSP Residual norm 7.132149702594e-10
299 KSP Residual norm 6.889261230075e-10
300 KSP Residual norm 6.706709183879e-10
301 KSP Residual norm 6.562104538454e-10
302 KSP Residual norm 6.385077640185e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 302
stx: 0., fx: 0.069139, dgx: -3.55959e-08
sty: 0., fy: 0.069139, dgy: -3.55959e-08
34 TAO, Function value: 0.069139, Residual: 8.64191e-05
0 KSP Residual norm 8.641910585250e-05
1 KSP Residual norm 6.520242620587e-05
2 KSP Residual norm 4.504259706394e-05
3 KSP Residual norm 3.506634256376e-05
4 KSP Residual norm 2.773117708332e-05
5 KSP Residual norm 2.406366953943e-05
6 KSP Residual norm 2.126195379200e-05
7 KSP Residual norm 1.999261160013e-05
8 KSP Residual norm 1.926823924367e-05
9 KSP Residual norm 1.964981074706e-05
10 KSP Residual norm 1.989834263734e-05
11 KSP Residual norm 2.039221356633e-05
12 KSP Residual norm 2.143672245581e-05
13 KSP Residual norm 2.243857885994e-05
14 KSP Residual norm 2.369572009777e-05
15 KSP Residual norm 2.517230348130e-05
16 KSP Residual norm 2.685507511290e-05
17 KSP Residual norm 2.892305993181e-05
18 KSP Residual norm 3.090789672705e-05
19 KSP Residual norm 3.255782743436e-05
20 KSP Residual norm 3.356284061103e-05
21 KSP Residual norm 3.382950565341e-05
22 KSP Residual norm 3.358566087061e-05
23 KSP Residual norm 3.310092338340e-05
24 KSP Residual norm 3.257708702645e-05
25 KSP Residual norm 3.195177201161e-05
26 KSP Residual norm 3.122382529514e-05
27 KSP Residual norm 3.026064076028e-05
28 KSP Residual norm 2.890630912296e-05
29 KSP Residual norm 2.741124186710e-05
30 KSP Residual norm 2.599715625423e-05
31 KSP Residual norm 2.461458297641e-05
32 KSP Residual norm 2.313554601115e-05
33 KSP Residual norm 2.160621622066e-05
34 KSP Residual norm 2.003203612240e-05
35 KSP Residual norm 1.834037283437e-05
36 KSP Residual norm 1.660311366182e-05
37 KSP Residual norm 1.497725252247e-05
38 KSP Residual norm 1.349106247777e-05
39 KSP Residual norm 1.210632775473e-05
40 KSP Residual norm 1.086480791135e-05
41 KSP Residual norm 9.852075499423e-06
42 KSP Residual norm 8.902609377236e-06
43 KSP Residual norm 7.856854436163e-06
44 KSP Residual norm 6.914370298346e-06
45 KSP Residual norm 6.162679219993e-06
46 KSP Residual norm 5.545677551841e-06
47 KSP Residual norm 5.002064489691e-06
48 KSP Residual norm 4.495749459528e-06
49 KSP Residual norm 4.032341209592e-06
50 KSP Residual norm 3.622127671597e-06
51 KSP Residual norm 3.270244028886e-06
52 KSP Residual norm 2.969146581727e-06
53 KSP Residual norm 2.707565167476e-06
54 KSP Residual norm 2.482134939788e-06
55 KSP Residual norm 2.299179056928e-06
56 KSP Residual norm 2.141944607526e-06
57 KSP Residual norm 1.985623640729e-06
58 KSP Residual norm 1.851890368597e-06
59 KSP Residual norm 1.762883701672e-06
60 KSP Residual norm 1.723820287790e-06
61 KSP Residual norm 1.705666505731e-06
62 KSP Residual norm 1.665160195877e-06
63 KSP Residual norm 1.620393610766e-06
64 KSP Residual norm 1.597672351213e-06
65 KSP Residual norm 1.593255867781e-06
66 KSP Residual norm 1.593737397862e-06
67 KSP Residual norm 1.588796000833e-06
68 KSP Residual norm 1.580273850513e-06
69 KSP Residual norm 1.572958198791e-06
70 KSP Residual norm 1.564205255710e-06
71 KSP Residual norm 1.553890479121e-06
72 KSP Residual norm 1.545312009743e-06
73 KSP Residual norm 1.521414278667e-06
74 KSP Residual norm 1.482160313952e-06
75 KSP Residual norm 1.449467784650e-06
76 KSP Residual norm 1.416428450710e-06
77 KSP Residual norm 1.372078765877e-06
78 KSP Residual norm 1.316322900443e-06
79 KSP Residual norm 1.249889595608e-06
80 KSP Residual norm 1.185171765994e-06
81 KSP Residual norm 1.123944862829e-06
82 KSP Residual norm 1.068263494114e-06
83 KSP Residual norm 1.023886763602e-06
84 KSP Residual norm 9.765713977603e-07
85 KSP Residual norm 9.299688558774e-07
86 KSP Residual norm 8.851668347282e-07
87 KSP Residual norm 8.366254201082e-07
88 KSP Residual norm 7.936034507506e-07
89 KSP Residual norm 7.628330108758e-07
90 KSP Residual norm 7.417745661240e-07
91 KSP Residual norm 6.969486240803e-07
92 KSP Residual norm 6.403671114040e-07
93 KSP Residual norm 5.981302816087e-07
94 KSP Residual norm 5.616937489758e-07
95 KSP Residual norm 5.308246687300e-07
96 KSP Residual norm 5.076253121610e-07
97 KSP Residual norm 4.844226297949e-07
98 KSP Residual norm 4.628469225486e-07
99 KSP Residual norm 4.369428325311e-07
100 KSP Residual norm 4.128944256493e-07
101 KSP Residual norm 3.975602276712e-07
102 KSP Residual norm 3.835547507823e-07
103 KSP Residual norm 3.693426569922e-07
104 KSP Residual norm 3.524993481522e-07
105 KSP Residual norm 3.345509933884e-07
106 KSP Residual norm 3.234950109432e-07
107 KSP Residual norm 3.130670989686e-07
108 KSP Residual norm 3.072825989077e-07
109 KSP Residual norm 2.969561417374e-07
110 KSP Residual norm 2.844374023106e-07
111 KSP Residual norm 2.738105389838e-07
112 KSP Residual norm 2.648563955494e-07
113 KSP Residual norm 2.564101334261e-07
114 KSP Residual norm 2.488333799060e-07
115 KSP Residual norm 2.433535647864e-07
116 KSP Residual norm 2.410694675240e-07
117 KSP Residual norm 2.349670962365e-07
118 KSP Residual norm 2.229631636471e-07
119 KSP Residual norm 2.117781663251e-07
120 KSP Residual norm 2.010750279291e-07
121 KSP Residual norm 1.899895998981e-07
122 KSP Residual norm 1.792716995232e-07
123 KSP Residual norm 1.693750788040e-07
124 KSP Residual norm 1.611187098969e-07
125 KSP Residual norm 1.536863215419e-07
126 KSP Residual norm 1.455792157025e-07
127 KSP Residual norm 1.359358936953e-07
128 KSP Residual norm 1.263370930886e-07
129 KSP Residual norm 1.184751594103e-07
130 KSP Residual norm 1.128400609943e-07
131 KSP Residual norm 1.084047630010e-07
132 KSP Residual norm 1.014540468844e-07
133 KSP Residual norm 9.376450913364e-08
134 KSP Residual norm 8.778270934937e-08
135 KSP Residual norm 8.266696028069e-08
136 KSP Residual norm 7.786951853363e-08
137 KSP Residual norm 7.353821641967e-08
138 KSP Residual norm 6.970541537329e-08
139 KSP Residual norm 6.593230016676e-08
140 KSP Residual norm 6.242606968271e-08
141 KSP Residual norm 5.937227782579e-08
142 KSP Residual norm 5.660426245225e-08
143 KSP Residual norm 5.379215016121e-08
144 KSP Residual norm 5.097203894240e-08
145 KSP Residual norm 4.833132666376e-08
146 KSP Residual norm 4.582534019311e-08
147 KSP Residual norm 4.342427966517e-08
148 KSP Residual norm 4.131947407690e-08
149 KSP Residual norm 3.946483956425e-08
150 KSP Residual norm 3.779867226225e-08
151 KSP Residual norm 3.639124099830e-08
152 KSP Residual norm 3.511450007473e-08
153 KSP Residual norm 3.392319083264e-08
154 KSP Residual norm 3.289231235858e-08
155 KSP Residual norm 3.193378117654e-08
156 KSP Residual norm 3.113460003472e-08
157 KSP Residual norm 3.077744922672e-08
158 KSP Residual norm 3.060629579141e-08
159 KSP Residual norm 3.030009584154e-08
160 KSP Residual norm 2.987867290001e-08
161 KSP Residual norm 2.956018600794e-08
162 KSP Residual norm 2.940924018988e-08
163 KSP Residual norm 2.946949328323e-08
164 KSP Residual norm 2.957773982642e-08
165 KSP Residual norm 2.954800761444e-08
166 KSP Residual norm 2.940530178524e-08
167 KSP Residual norm 2.927185203382e-08
168 KSP Residual norm 2.941139729868e-08
169 KSP Residual norm 2.972954929837e-08
170 KSP Residual norm 2.939028504954e-08
171 KSP Residual norm 2.862109122660e-08
172 KSP Residual norm 2.839895158399e-08
173 KSP Residual norm 2.870432486222e-08
174 KSP Residual norm 2.857128429150e-08
175 KSP Residual norm 2.773825513266e-08
176 KSP Residual norm 2.707282254269e-08
177 KSP Residual norm 2.672221390118e-08
178 KSP Residual norm 2.652442004370e-08
179 KSP Residual norm 2.636860484932e-08
180 KSP Residual norm 2.627936779792e-08
181 KSP Residual norm 2.628151324187e-08
182 KSP Residual norm 2.622466611194e-08
183 KSP Residual norm 2.588501023315e-08
184 KSP Residual norm 2.518318969697e-08
185 KSP Residual norm 2.439077881791e-08
186 KSP Residual norm 2.356152665369e-08
187 KSP Residual norm 2.272659742059e-08
188 KSP Residual norm 2.188218924253e-08
189 KSP Residual norm 2.106158410903e-08
190 KSP Residual norm 2.033512489145e-08
191 KSP Residual norm 1.966914137009e-08
192 KSP Residual norm 1.898167625392e-08
193 KSP Residual norm 1.820576819510e-08
194 KSP Residual norm 1.740489663237e-08
195 KSP Residual norm 1.671800469233e-08
196 KSP Residual norm 1.607880653208e-08
197 KSP Residual norm 1.536041001115e-08
198 KSP Residual norm 1.466910575082e-08
199 KSP Residual norm 1.405697039820e-08
200 KSP Residual norm 1.354549077870e-08
201 KSP Residual norm 1.298489213423e-08
202 KSP Residual norm 1.236209668722e-08
203 KSP Residual norm 1.174534370619e-08
204 KSP Residual norm 1.111341352899e-08
205 KSP Residual norm 1.053875581106e-08
206 KSP Residual norm 1.012377311646e-08
207 KSP Residual norm 9.852416763476e-09
208 KSP Residual norm 9.366662708414e-09
209 KSP Residual norm 8.758252807536e-09
210 KSP Residual norm 8.282742016298e-09
211 KSP Residual norm 7.857633880688e-09
212 KSP Residual norm 7.403628465354e-09
213 KSP Residual norm 6.997905908687e-09
214 KSP Residual norm 6.670244639939e-09
215 KSP Residual norm 6.383099639548e-09
216 KSP Residual norm 6.100158266986e-09
217 KSP Residual norm 5.824562371657e-09
218 KSP Residual norm 5.570706008570e-09
219 KSP Residual norm 5.340819293524e-09
220 KSP Residual norm 5.119199784355e-09
221 KSP Residual norm 4.928511756599e-09
222 KSP Residual norm 4.821880404612e-09
223 KSP Residual norm 4.794984980069e-09
224 KSP Residual norm 4.589980292040e-09
225 KSP Residual norm 4.308599217434e-09
226 KSP Residual norm 4.129547216637e-09
227 KSP Residual norm 3.989930038037e-09
228 KSP Residual norm 3.846414447552e-09
229 KSP Residual norm 3.707520074542e-09
230 KSP Residual norm 3.591648410578e-09
231 KSP Residual norm 3.501437886578e-09
232 KSP Residual norm 3.432914449087e-09
233 KSP Residual norm 3.370222122513e-09
234 KSP Residual norm 3.308840315268e-09
235 KSP Residual norm 3.251898679187e-09
236 KSP Residual norm 3.189368452523e-09
237 KSP Residual norm 3.112994038028e-09
238 KSP Residual norm 3.032596245836e-09
239 KSP Residual norm 2.953182862426e-09
240 KSP Residual norm 2.870806068180e-09
241 KSP Residual norm 2.790253331135e-09
242 KSP Residual norm 2.714083495113e-09
243 KSP Residual norm 2.648397578486e-09
244 KSP Residual norm 2.596793567610e-09
245 KSP Residual norm 2.544633316550e-09
246 KSP Residual norm 2.487423749513e-09
247 KSP Residual norm 2.434030269326e-09
248 KSP Residual norm 2.384547143663e-09
249 KSP Residual norm 2.355852489076e-09
250 KSP Residual norm 2.352535862386e-09
251 KSP Residual norm 2.325024820612e-09
252 KSP Residual norm 2.250504826584e-09
253 KSP Residual norm 2.179890442626e-09
254 KSP Residual norm 2.132476469227e-09
255 KSP Residual norm 2.096804251010e-09
256 KSP Residual norm 2.068901652224e-09
257 KSP Residual norm 2.025955847693e-09
258 KSP Residual norm 1.950674714977e-09
259 KSP Residual norm 1.863374828887e-09
260 KSP Residual norm 1.780887686460e-09
261 KSP Residual norm 1.709644507061e-09
262 KSP Residual norm 1.644325661833e-09
263 KSP Residual norm 1.583994922734e-09
264 KSP Residual norm 1.533830168704e-09
265 KSP Residual norm 1.480403618566e-09
266 KSP Residual norm 1.424589568004e-09
267 KSP Residual norm 1.367254047960e-09
268 KSP Residual norm 1.313602476721e-09
269 KSP Residual norm 1.273066561299e-09
270 KSP Residual norm 1.236044130973e-09
271 KSP Residual norm 1.201855480812e-09
272 KSP Residual norm 1.174742593071e-09
273 KSP Residual norm 1.150579463304e-09
274 KSP Residual norm 1.109310384785e-09
275 KSP Residual norm 1.057711539906e-09
276 KSP Residual norm 1.021176684580e-09
277 KSP Residual norm 1.011522303063e-09
278 KSP Residual norm 9.951334487975e-10
279 KSP Residual norm 9.285969238819e-10
280 KSP Residual norm 8.702228768154e-10
281 KSP Residual norm 8.326289197611e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 281
stx: 0., fx: 0.069139, dgx: -4.31256e-08
sty: 0., fy: 0.069139, dgy: -4.31256e-08
35 TAO, Function value: 0.069139, Residual: 7.92529e-05
0 KSP Residual norm 7.925285017473e-05
1 KSP Residual norm 5.743642484722e-05
2 KSP Residual norm 4.087227133774e-05
3 KSP Residual norm 3.214100426392e-05
4 KSP Residual norm 2.645739345814e-05
5 KSP Residual norm 2.390306274815e-05
6 KSP Residual norm 2.163139498758e-05
7 KSP Residual norm 2.082286524600e-05
8 KSP Residual norm 2.086013666654e-05
9 KSP Residual norm 2.204779591937e-05
10 KSP Residual norm 2.391694837937e-05
11 KSP Residual norm 2.603891991087e-05
12 KSP Residual norm 2.867828541353e-05
13 KSP Residual norm 3.166349367146e-05
14 KSP Residual norm 3.401565566081e-05
15 KSP Residual norm 3.599023161282e-05
16 KSP Residual norm 3.812050076652e-05
17 KSP Residual norm 4.078147602428e-05
18 KSP Residual norm 4.333126112604e-05
19 KSP Residual norm 4.504038087712e-05
20 KSP Residual norm 4.558255868571e-05
21 KSP Residual norm 4.515128517152e-05
22 KSP Residual norm 4.414287427691e-05
23 KSP Residual norm 4.287949703605e-05
24 KSP Residual norm 4.168185655995e-05
25 KSP Residual norm 4.054093543476e-05
26 KSP Residual norm 3.930412543404e-05
27 KSP Residual norm 3.764459539073e-05
28 KSP Residual norm 3.565182674339e-05
29 KSP Residual norm 3.376416612379e-05
30 KSP Residual norm 3.201933333880e-05
31 KSP Residual norm 3.025986096023e-05
32 KSP Residual norm 2.839474143876e-05
33 KSP Residual norm 2.650701388145e-05
34 KSP Residual norm 2.457305250547e-05
35 KSP Residual norm 2.247485928993e-05
36 KSP Residual norm 2.032047342938e-05
37 KSP Residual norm 1.837768852976e-05
38 KSP Residual norm 1.671787766288e-05
39 KSP Residual norm 1.516967448624e-05
40 KSP Residual norm 1.353190318482e-05
41 KSP Residual norm 1.188690113212e-05
42 KSP Residual norm 1.039299711631e-05
43 KSP Residual norm 9.116516940898e-06
44 KSP Residual norm 8.041287205404e-06
45 KSP Residual norm 7.153605127092e-06
46 KSP Residual norm 6.421398709018e-06
47 KSP Residual norm 5.803811192191e-06
48 KSP Residual norm 5.255883537948e-06
49 KSP Residual norm 4.766055513534e-06
50 KSP Residual norm 4.358821953432e-06
51 KSP Residual norm 4.050546063436e-06
52 KSP Residual norm 3.752430482240e-06
53 KSP Residual norm 3.421193729811e-06
54 KSP Residual norm 3.142599858729e-06
55 KSP Residual norm 2.940458300481e-06
56 KSP Residual norm 2.802227207172e-06
57 KSP Residual norm 2.725502008400e-06
58 KSP Residual norm 2.724929166128e-06
59 KSP Residual norm 2.772689286938e-06
60 KSP Residual norm 2.757588489101e-06
61 KSP Residual norm 2.717674287184e-06
62 KSP Residual norm 2.735366296608e-06
63 KSP Residual norm 2.789482756255e-06
64 KSP Residual norm 2.853547951106e-06
65 KSP Residual norm 2.918268933930e-06
66 KSP Residual norm 2.976244206497e-06
67 KSP Residual norm 3.014910985436e-06
68 KSP Residual norm 3.030587178558e-06
69 KSP Residual norm 3.030438429452e-06
70 KSP Residual norm 3.017065922244e-06
71 KSP Residual norm 2.989780493331e-06
72 KSP Residual norm 2.959173454314e-06
73 KSP Residual norm 2.904141257422e-06
74 KSP Residual norm 2.824378072090e-06
75 KSP Residual norm 2.755586854531e-06
76 KSP Residual norm 2.686581241694e-06
77 KSP Residual norm 2.594497124367e-06
78 KSP Residual norm 2.476389326210e-06
79 KSP Residual norm 2.339067058470e-06
80 KSP Residual norm 2.205837451514e-06
81 KSP Residual norm 2.081973751090e-06
82 KSP Residual norm 1.971593291511e-06
83 KSP Residual norm 1.881600082642e-06
84 KSP Residual norm 1.781689789438e-06
85 KSP Residual norm 1.679174058614e-06
86 KSP Residual norm 1.582167496144e-06
87 KSP Residual norm 1.479544760892e-06
88 KSP Residual norm 1.379073332866e-06
89 KSP Residual norm 1.280936932474e-06
90 KSP Residual norm 1.194502235946e-06
91 KSP Residual norm 1.107792508781e-06
92 KSP Residual norm 1.027677361902e-06
93 KSP Residual norm 9.636478515759e-07
94 KSP Residual norm 8.981406050240e-07
95 KSP Residual norm 8.322100410782e-07
96 KSP Residual norm 7.688580766482e-07
97 KSP Residual norm 7.050005728328e-07
98 KSP Residual norm 6.565441350430e-07
99 KSP Residual norm 6.158516534444e-07
100 KSP Residual norm 5.778402276723e-07
101 KSP Residual norm 5.413872803269e-07
102 KSP Residual norm 5.066143302212e-07
103 KSP Residual norm 4.821773519616e-07
104 KSP Residual norm 4.670024378167e-07
105 KSP Residual norm 4.415098135658e-07
106 KSP Residual norm 4.141004592998e-07
107 KSP Residual norm 3.872263022423e-07
108 KSP Residual norm 3.699818123499e-07
109 KSP Residual norm 3.534062909536e-07
110 KSP Residual norm 3.411745302943e-07
111 KSP Residual norm 3.337405059691e-07
112 KSP Residual norm 3.197159533206e-07
113 KSP Residual norm 2.979457931726e-07
114 KSP Residual norm 2.814928022642e-07
115 KSP Residual norm 2.666243752639e-07
116 KSP Residual norm 2.494022921584e-07
117 KSP Residual norm 2.335950438739e-07
118 KSP Residual norm 2.217365127740e-07
119 KSP Residual norm 2.125183785340e-07
120 KSP Residual norm 2.047845481727e-07
121 KSP Residual norm 1.960076838724e-07
122 KSP Residual norm 1.865370342578e-07
123 KSP Residual norm 1.772211837149e-07
124 KSP Residual norm 1.700933033381e-07
125 KSP Residual norm 1.659388331644e-07
126 KSP Residual norm 1.639257570987e-07
127 KSP Residual norm 1.559262854313e-07
128 KSP Residual norm 1.441151486424e-07
129 KSP Residual norm 1.351173729002e-07
130 KSP Residual norm 1.280867407464e-07
131 KSP Residual norm 1.218354898975e-07
132 KSP Residual norm 1.159283053654e-07
133 KSP Residual norm 1.104502782780e-07
134 KSP Residual norm 1.052534706177e-07
135 KSP Residual norm 1.002513991924e-07
136 KSP Residual norm 9.560336391718e-08
137 KSP Residual norm 9.167334639759e-08
138 KSP Residual norm 8.842484622405e-08
139 KSP Residual norm 8.493709841413e-08
140 KSP Residual norm 8.090116624768e-08
141 KSP Residual norm 7.700944624303e-08
142 KSP Residual norm 7.342064321052e-08
143 KSP Residual norm 6.983167024515e-08
144 KSP Residual norm 6.626586949019e-08
145 KSP Residual norm 6.302769939494e-08
146 KSP Residual norm 6.007956798874e-08
147 KSP Residual norm 5.727741469665e-08
148 KSP Residual norm 5.463269252065e-08
149 KSP Residual norm 5.197600865948e-08
150 KSP Residual norm 4.931292629884e-08
151 KSP Residual norm 4.687729675480e-08
152 KSP Residual norm 4.464213047589e-08
153 KSP Residual norm 4.253599054541e-08
154 KSP Residual norm 4.062940030594e-08
155 KSP Residual norm 3.883304178990e-08
156 KSP Residual norm 3.713643030433e-08
157 KSP Residual norm 3.582139648539e-08
158 KSP Residual norm 3.459353100053e-08
159 KSP Residual norm 3.330506183714e-08
160 KSP Residual norm 3.223229457142e-08
161 KSP Residual norm 3.164178693698e-08
162 KSP Residual norm 3.129579963894e-08
163 KSP Residual norm 3.025331645394e-08
164 KSP Residual norm 2.864190066800e-08
165 KSP Residual norm 2.734952826236e-08
166 KSP Residual norm 2.649342347956e-08
167 KSP Residual norm 2.573787638342e-08
168 KSP Residual norm 2.481270490518e-08
169 KSP Residual norm 2.385461787244e-08
170 KSP Residual norm 2.296920915906e-08
171 KSP Residual norm 2.212748337415e-08
172 KSP Residual norm 2.141971323147e-08
173 KSP Residual norm 2.090667790760e-08
174 KSP Residual norm 2.062652011209e-08
175 KSP Residual norm 2.047510506992e-08
176 KSP Residual norm 2.017321830577e-08
177 KSP Residual norm 1.969224880418e-08
178 KSP Residual norm 1.930667469778e-08
179 KSP Residual norm 1.906847489887e-08
180 KSP Residual norm 1.889291746169e-08
181 KSP Residual norm 1.875463751422e-08
182 KSP Residual norm 1.856888599406e-08
183 KSP Residual norm 1.831531212533e-08
184 KSP Residual norm 1.796876154289e-08
185 KSP Residual norm 1.763293116928e-08
186 KSP Residual norm 1.741600973331e-08
187 KSP Residual norm 1.728755180620e-08
188 KSP Residual norm 1.710648350276e-08
189 KSP Residual norm 1.681857510747e-08
190 KSP Residual norm 1.658537363392e-08
191 KSP Residual norm 1.648433044783e-08
192 KSP Residual norm 1.645957416923e-08
193 KSP Residual norm 1.646076134727e-08
194 KSP Residual norm 1.653566384360e-08
195 KSP Residual norm 1.664353444188e-08
196 KSP Residual norm 1.640215061791e-08
197 KSP Residual norm 1.595746728640e-08
198 KSP Residual norm 1.570050479778e-08
199 KSP Residual norm 1.551393000689e-08
200 KSP Residual norm 1.524290676870e-08
201 KSP Residual norm 1.486073517388e-08
202 KSP Residual norm 1.455992163312e-08
203 KSP Residual norm 1.440712277142e-08
204 KSP Residual norm 1.433971502519e-08
205 KSP Residual norm 1.411719399819e-08
206 KSP Residual norm 1.347957704930e-08
207 KSP Residual norm 1.286978113157e-08
208 KSP Residual norm 1.243111899302e-08
209 KSP Residual norm 1.211387922082e-08
210 KSP Residual norm 1.177150206150e-08
211 KSP Residual norm 1.135223970478e-08
212 KSP Residual norm 1.091686256577e-08
213 KSP Residual norm 1.055265326448e-08
214 KSP Residual norm 1.025765327461e-08
215 KSP Residual norm 9.984888397235e-09
216 KSP Residual norm 9.774137076125e-09
217 KSP Residual norm 9.731390567033e-09
218 KSP Residual norm 9.494183985112e-09
219 KSP Residual norm 8.862225679973e-09
220 KSP Residual norm 8.339654193592e-09
221 KSP Residual norm 7.951524415470e-09
222 KSP Residual norm 7.621645258547e-09
223 KSP Residual norm 7.324209179124e-09
224 KSP Residual norm 7.039018174987e-09
225 KSP Residual norm 6.764941567527e-09
226 KSP Residual norm 6.488544970221e-09
227 KSP Residual norm 6.206243913118e-09
228 KSP Residual norm 5.945629650120e-09
229 KSP Residual norm 5.723038262232e-09
230 KSP Residual norm 5.520961834318e-09
231 KSP Residual norm 5.330906266336e-09
232 KSP Residual norm 5.150712177587e-09
233 KSP Residual norm 4.950742614194e-09
234 KSP Residual norm 4.732346994431e-09
235 KSP Residual norm 4.526338866045e-09
236 KSP Residual norm 4.353111835704e-09
237 KSP Residual norm 4.234629085609e-09
238 KSP Residual norm 4.161634506970e-09
239 KSP Residual norm 4.048431639830e-09
240 KSP Residual norm 3.868910891934e-09
241 KSP Residual norm 3.699216062807e-09
242 KSP Residual norm 3.560172587232e-09
243 KSP Residual norm 3.440425432462e-09
244 KSP Residual norm 3.345564442094e-09
245 KSP Residual norm 3.266112737545e-09
246 KSP Residual norm 3.191799255054e-09
247 KSP Residual norm 3.122444569020e-09
248 KSP Residual norm 3.049274659308e-09
249 KSP Residual norm 2.986714524481e-09
250 KSP Residual norm 2.929211448361e-09
251 KSP Residual norm 2.857339664513e-09
252 KSP Residual norm 2.776030160767e-09
253 KSP Residual norm 2.701431998494e-09
254 KSP Residual norm 2.637678474666e-09
255 KSP Residual norm 2.577189779196e-09
256 KSP Residual norm 2.524977324702e-09
257 KSP Residual norm 2.478394928740e-09
258 KSP Residual norm 2.429548446185e-09
259 KSP Residual norm 2.377557155066e-09
260 KSP Residual norm 2.321739104580e-09
261 KSP Residual norm 2.270993769113e-09
262 KSP Residual norm 2.215820761266e-09
263 KSP Residual norm 2.156923661556e-09
264 KSP Residual norm 2.123614058054e-09
265 KSP Residual norm 2.143427184012e-09
266 KSP Residual norm 2.147519926139e-09
267 KSP Residual norm 2.026105126640e-09
268 KSP Residual norm 1.933392312768e-09
269 KSP Residual norm 1.897239816468e-09
270 KSP Residual norm 1.871028148874e-09
271 KSP Residual norm 1.830888894595e-09
272 KSP Residual norm 1.776070822675e-09
273 KSP Residual norm 1.718553369389e-09
274 KSP Residual norm 1.666464191789e-09
275 KSP Residual norm 1.616608455457e-09
276 KSP Residual norm 1.583774452691e-09
277 KSP Residual norm 1.566915034219e-09
278 KSP Residual norm 1.547495039470e-09
279 KSP Residual norm 1.488061887043e-09
280 KSP Residual norm 1.415136055833e-09
281 KSP Residual norm 1.362365995817e-09
282 KSP Residual norm 1.320205691620e-09
283 KSP Residual norm 1.288435409286e-09
284 KSP Residual norm 1.267832625723e-09
285 KSP Residual norm 1.247617450737e-09
286 KSP Residual norm 1.205460138694e-09
287 KSP Residual norm 1.160053285188e-09
288 KSP Residual norm 1.122782106917e-09
289 KSP Residual norm 1.094564960441e-09
290 KSP Residual norm 1.076309668308e-09
291 KSP Residual norm 1.067519863413e-09
292 KSP Residual norm 1.046145640488e-09
293 KSP Residual norm 1.004853319640e-09
294 KSP Residual norm 9.647338552797e-10
295 KSP Residual norm 9.323972702758e-10
296 KSP Residual norm 9.025756419788e-10
297 KSP Residual norm 8.703704403962e-10
298 KSP Residual norm 8.405152264648e-10
299 KSP Residual norm 8.134611217781e-10
300 KSP Residual norm 7.911109639259e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 300
stx: 0., fx: 0.069139, dgx: -5.76226e-08
sty: 0., fy: 0.069139, dgy: -5.76226e-08
36 TAO, Function value: 0.069139, Residual: 0.000170766
Residual norms for tao_nls_ solve.
0 KSP Residual norm 1.707657585701e-04
1 KSP Residual norm 1.167873028639e-04
2 KSP Residual norm 8.415828438964e-05
3 KSP Residual norm 6.420990086943e-05
4 KSP Residual norm 4.929556126222e-05
5 KSP Residual norm 4.122760027054e-05
6 KSP Residual norm 3.426375647212e-05
7 KSP Residual norm 2.968254762197e-05
8 KSP Residual norm 2.746305896855e-05
9 KSP Residual norm 2.616378100156e-05
10 KSP Residual norm 2.574383968986e-05
11 KSP Residual norm 2.571226031871e-05
12 KSP Residual norm 2.610485773584e-05
13 KSP Residual norm 2.698481645302e-05
14 KSP Residual norm 2.791341612805e-05
15 KSP Residual norm 2.902216914128e-05
16 KSP Residual norm 3.022476117873e-05
17 KSP Residual norm 3.156757670508e-05
18 KSP Residual norm 3.223843944385e-05
19 KSP Residual norm 3.213806269218e-05
20 KSP Residual norm 3.179135923942e-05
21 KSP Residual norm 3.110031162668e-05
22 KSP Residual norm 3.004310945655e-05
23 KSP Residual norm 2.876145935711e-05
24 KSP Residual norm 2.756091322005e-05
25 KSP Residual norm 2.655862790693e-05
26 KSP Residual norm 2.563174313708e-05
27 KSP Residual norm 2.461257897371e-05
28 KSP Residual norm 2.342276899174e-05
29 KSP Residual norm 2.227966580818e-05
30 KSP Residual norm 2.125331754566e-05
31 KSP Residual norm 2.026992240444e-05
32 KSP Residual norm 1.926475329308e-05
33 KSP Residual norm 1.822947393600e-05
34 KSP Residual norm 1.711133931038e-05
35 KSP Residual norm 1.581258813141e-05
36 KSP Residual norm 1.437412302975e-05
37 KSP Residual norm 1.297183725925e-05
38 KSP Residual norm 1.163618503388e-05
39 KSP Residual norm 1.030748531183e-05
40 KSP Residual norm 9.037582426467e-06
41 KSP Residual norm 7.906845081692e-06
42 KSP Residual norm 6.941571092584e-06
43 KSP Residual norm 6.164503543172e-06
44 KSP Residual norm 5.591736260497e-06
45 KSP Residual norm 5.134164461140e-06
46 KSP Residual norm 4.623271554924e-06
47 KSP Residual norm 4.133588216217e-06
48 KSP Residual norm 3.741917347771e-06
49 KSP Residual norm 3.416791042368e-06
50 KSP Residual norm 3.142629321298e-06
51 KSP Residual norm 2.930136834211e-06
52 KSP Residual norm 2.787442840592e-06
53 KSP Residual norm 2.705690665068e-06
54 KSP Residual norm 2.580349972411e-06
55 KSP Residual norm 2.407321435787e-06
56 KSP Residual norm 2.293024292513e-06
57 KSP Residual norm 2.231853980662e-06
58 KSP Residual norm 2.179432659986e-06
59 KSP Residual norm 2.127252223652e-06
60 KSP Residual norm 2.095446446442e-06
61 KSP Residual norm 2.080311266014e-06
62 KSP Residual norm 2.079410239300e-06
63 KSP Residual norm 2.091797054534e-06
64 KSP Residual norm 2.108369511585e-06
65 KSP Residual norm 2.114785292623e-06
66 KSP Residual norm 2.105026965491e-06
67 KSP Residual norm 2.081677237537e-06
68 KSP Residual norm 2.053053444407e-06
69 KSP Residual norm 2.024031789971e-06
70 KSP Residual norm 1.982170278186e-06
71 KSP Residual norm 1.919060671423e-06
72 KSP Residual norm 1.831348880795e-06
73 KSP Residual norm 1.723519808074e-06
74 KSP Residual norm 1.610621110992e-06
75 KSP Residual norm 1.511153288409e-06
76 KSP Residual norm 1.420818637955e-06
77 KSP Residual norm 1.336166900773e-06
78 KSP Residual norm 1.258594852395e-06
79 KSP Residual norm 1.176505006853e-06
80 KSP Residual norm 1.093257250053e-06
81 KSP Residual norm 1.017611873143e-06
82 KSP Residual norm 9.556077304892e-07
83 KSP Residual norm 9.078453488418e-07
84 KSP Residual norm 8.614518122797e-07
85 KSP Residual norm 8.258836490512e-07
86 KSP Residual norm 7.973275706333e-07
87 KSP Residual norm 7.627615805304e-07
88 KSP Residual norm 7.231925347081e-07
89 KSP Residual norm 6.850275136454e-07
90 KSP Residual norm 6.575755442377e-07
91 KSP Residual norm 6.333200762457e-07
92 KSP Residual norm 6.127038625838e-07
93 KSP Residual norm 5.997202646703e-07
94 KSP Residual norm 5.844127292855e-07
95 KSP Residual norm 5.725243789829e-07
96 KSP Residual norm 5.664068429427e-07
97 KSP Residual norm 5.545515732311e-07
98 KSP Residual norm 5.418172629095e-07
99 KSP Residual norm 5.301366468431e-07
100 KSP Residual norm 5.186301661820e-07
101 KSP Residual norm 5.061366382481e-07
102 KSP Residual norm 4.939821747572e-07
103 KSP Residual norm 4.906025809768e-07
104 KSP Residual norm 4.986268040898e-07
105 KSP Residual norm 4.791509945207e-07
106 KSP Residual norm 4.499551523455e-07
107 KSP Residual norm 4.283227077413e-07
108 KSP Residual norm 4.143797452870e-07
109 KSP Residual norm 3.996659170469e-07
110 KSP Residual norm 3.844585144529e-07
111 KSP Residual norm 3.688688863523e-07
112 KSP Residual norm 3.510366442037e-07
113 KSP Residual norm 3.313899240908e-07
114 KSP Residual norm 3.119807344110e-07
115 KSP Residual norm 2.946106228152e-07
116 KSP Residual norm 2.797857640627e-07
117 KSP Residual norm 2.651171084253e-07
118 KSP Residual norm 2.502218726204e-07
119 KSP Residual norm 2.352022922858e-07
120 KSP Residual norm 2.225572664963e-07
121 KSP Residual norm 2.115521164502e-07
122 KSP Residual norm 2.031880226274e-07
123 KSP Residual norm 1.921992368889e-07
124 KSP Residual norm 1.788205638542e-07
125 KSP Residual norm 1.668927116885e-07
126 KSP Residual norm 1.568732072441e-07
127 KSP Residual norm 1.478269808254e-07
128 KSP Residual norm 1.396461251644e-07
129 KSP Residual norm 1.326271760198e-07
130 KSP Residual norm 1.268032211284e-07
131 KSP Residual norm 1.222771941767e-07
132 KSP Residual norm 1.172479380978e-07
133 KSP Residual norm 1.112524241170e-07
134 KSP Residual norm 1.060370386411e-07
135 KSP Residual norm 1.027091640210e-07
136 KSP Residual norm 1.011284262197e-07
137 KSP Residual norm 1.009302934881e-07
138 KSP Residual norm 1.008634018783e-07
139 KSP Residual norm 9.981373376464e-08
140 KSP Residual norm 9.852203848790e-08
141 KSP Residual norm 9.792679176115e-08
142 KSP Residual norm 9.791052940320e-08
143 KSP Residual norm 9.803615279412e-08
144 KSP Residual norm 9.817002455532e-08
145 KSP Residual norm 9.871905471904e-08
146 KSP Residual norm 9.959021399558e-08
147 KSP Residual norm 1.007005037125e-07
148 KSP Residual norm 1.024647536368e-07
149 KSP Residual norm 1.046866273783e-07
150 KSP Residual norm 1.067347576037e-07
151 KSP Residual norm 1.092095960517e-07
152 KSP Residual norm 1.123323527602e-07
153 KSP Residual norm 1.141506822591e-07
154 KSP Residual norm 1.136828803471e-07
155 KSP Residual norm 1.130298573719e-07
156 KSP Residual norm 1.120837810302e-07
157 KSP Residual norm 1.102593902006e-07
158 KSP Residual norm 1.083626465945e-07
159 KSP Residual norm 1.061634449570e-07
160 KSP Residual norm 1.036390982937e-07
161 KSP Residual norm 1.014162604764e-07
162 KSP Residual norm 9.885672105835e-08
163 KSP Residual norm 9.618613328330e-08
164 KSP Residual norm 9.339305581197e-08
165 KSP Residual norm 9.049776379532e-08
166 KSP Residual norm 8.733090940797e-08
167 KSP Residual norm 8.312464577028e-08
168 KSP Residual norm 7.823524911565e-08
169 KSP Residual norm 7.386390012231e-08
170 KSP Residual norm 7.007590863583e-08
171 KSP Residual norm 6.636362325774e-08
172 KSP Residual norm 6.258866535258e-08
173 KSP Residual norm 5.899783334304e-08
174 KSP Residual norm 5.587473328144e-08
175 KSP Residual norm 5.321021239028e-08
176 KSP Residual norm 5.075035833881e-08
177 KSP Residual norm 4.771431832438e-08
178 KSP Residual norm 4.430614171717e-08
179 KSP Residual norm 4.123638630487e-08
180 KSP Residual norm 3.848735199687e-08
181 KSP Residual norm 3.602847834289e-08
182 KSP Residual norm 3.369353533599e-08
183 KSP Residual norm 3.150448768313e-08
184 KSP Residual norm 2.944102963422e-08
185 KSP Residual norm 2.747594884921e-08
186 KSP Residual norm 2.576834205748e-08
187 KSP Residual norm 2.439486921143e-08
188 KSP Residual norm 2.333954790482e-08
189 KSP Residual norm 2.250313431017e-08
190 KSP Residual norm 2.173706205248e-08
191 KSP Residual norm 2.097181116780e-08
192 KSP Residual norm 2.011251314287e-08
193 KSP Residual norm 1.924273420177e-08
194 KSP Residual norm 1.851705545873e-08
195 KSP Residual norm 1.794883380969e-08
196 KSP Residual norm 1.742672225104e-08
197 KSP Residual norm 1.685353704929e-08
198 KSP Residual norm 1.632820667072e-08
199 KSP Residual norm 1.587600304949e-08
200 KSP Residual norm 1.565288665860e-08
201 KSP Residual norm 1.575284307828e-08
202 KSP Residual norm 1.549216005367e-08
203 KSP Residual norm 1.461822740573e-08
204 KSP Residual norm 1.397639896695e-08
205 KSP Residual norm 1.366276669589e-08
206 KSP Residual norm 1.350108054272e-08
207 KSP Residual norm 1.337683241572e-08
208 KSP Residual norm 1.319557296010e-08
209 KSP Residual norm 1.313421360883e-08
210 KSP Residual norm 1.325449593565e-08
211 KSP Residual norm 1.329066154748e-08
212 KSP Residual norm 1.303957624654e-08
213 KSP Residual norm 1.279946632806e-08
214 KSP Residual norm 1.268723145893e-08
215 KSP Residual norm 1.256941224314e-08
216 KSP Residual norm 1.238617189525e-08
217 KSP Residual norm 1.215440787816e-08
218 KSP Residual norm 1.192379465294e-08
219 KSP Residual norm 1.171066328695e-08
220 KSP Residual norm 1.152015703672e-08
221 KSP Residual norm 1.134379097132e-08
222 KSP Residual norm 1.112719359812e-08
223 KSP Residual norm 1.084715975125e-08
224 KSP Residual norm 1.052547454562e-08
225 KSP Residual norm 1.021485345315e-08
226 KSP Residual norm 9.900372549234e-09
227 KSP Residual norm 9.575039866368e-09
228 KSP Residual norm 9.266923174078e-09
229 KSP Residual norm 8.987713571030e-09
230 KSP Residual norm 8.692757849371e-09
231 KSP Residual norm 8.368465123732e-09
232 KSP Residual norm 8.071281300885e-09
233 KSP Residual norm 7.823599497009e-09
234 KSP Residual norm 7.585596253786e-09
235 KSP Residual norm 7.332240183808e-09
236 KSP Residual norm 7.084600215520e-09
237 KSP Residual norm 6.891430674061e-09
238 KSP Residual norm 6.786074861194e-09
239 KSP Residual norm 6.692372652028e-09
240 KSP Residual norm 6.467608487430e-09
241 KSP Residual norm 6.168619694736e-09
242 KSP Residual norm 5.901912253007e-09
243 KSP Residual norm 5.670374875985e-09
244 KSP Residual norm 5.469686818086e-09
245 KSP Residual norm 5.274299140643e-09
246 KSP Residual norm 5.090256167267e-09
247 KSP Residual norm 4.958934652715e-09
248 KSP Residual norm 4.889503892318e-09
249 KSP Residual norm 4.861603010998e-09
250 KSP Residual norm 4.699060059681e-09
251 KSP Residual norm 4.416342977392e-09
252 KSP Residual norm 4.181683813108e-09
253 KSP Residual norm 3.992818153591e-09
254 KSP Residual norm 3.827854777131e-09
255 KSP Residual norm 3.676228561571e-09
256 KSP Residual norm 3.558026713967e-09
257 KSP Residual norm 3.475895419347e-09
258 KSP Residual norm 3.383161584288e-09
259 KSP Residual norm 3.247542242359e-09
260 KSP Residual norm 3.104678467003e-09
261 KSP Residual norm 2.983731689526e-09
262 KSP Residual norm 2.868973895929e-09
263 KSP Residual norm 2.756312536227e-09
264 KSP Residual norm 2.660342188698e-09
265 KSP Residual norm 2.562210414582e-09
266 KSP Residual norm 2.472810823933e-09
267 KSP Residual norm 2.387780625518e-09
268 KSP Residual norm 2.299690912190e-09
269 KSP Residual norm 2.227358091571e-09
270 KSP Residual norm 2.168218680359e-09
271 KSP Residual norm 2.121285817997e-09
272 KSP Residual norm 2.062126960885e-09
273 KSP Residual norm 1.982045578001e-09
274 KSP Residual norm 1.903488492532e-09
275 KSP Residual norm 1.836928547672e-09
276 KSP Residual norm 1.781312157776e-09
277 KSP Residual norm 1.732294003257e-09
278 KSP Residual norm 1.692950447277e-09
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 278
1 LS Function value: 0.0691389, Step length: 1.
stx: 0., fx: 0.069139, dgx: -8.10552e-08
sty: 0., fy: 0.069139, dgy: -8.10552e-08
37 TAO, Function value: 0.0691389, Residual: 3.92409e-05
0 KSP Residual norm 3.924091132336e-05
1 KSP Residual norm 3.159588903333e-05
2 KSP Residual norm 2.680847184859e-05
3 KSP Residual norm 2.169658368750e-05
4 KSP Residual norm 2.082560831984e-05
5 KSP Residual norm 2.246740364175e-05
6 KSP Residual norm 2.379841655164e-05
7 KSP Residual norm 2.669543774025e-05
8 KSP Residual norm 3.031867134564e-05
9 KSP Residual norm 3.343934345392e-05
10 KSP Residual norm 3.713504156680e-05
11 KSP Residual norm 4.082063419284e-05
12 KSP Residual norm 4.431079877962e-05
13 KSP Residual norm 4.755775646106e-05
14 KSP Residual norm 4.946044573727e-05
15 KSP Residual norm 5.114368081534e-05
16 KSP Residual norm 5.305034709701e-05
17 KSP Residual norm 5.433506419230e-05
18 KSP Residual norm 5.463993333681e-05
19 KSP Residual norm 5.458019430764e-05
20 KSP Residual norm 5.466572640803e-05
21 KSP Residual norm 5.401698543639e-05
22 KSP Residual norm 5.272065175588e-05
23 KSP Residual norm 5.177301633917e-05
24 KSP Residual norm 5.095228398117e-05
25 KSP Residual norm 4.949164230359e-05
26 KSP Residual norm 4.754164892346e-05
27 KSP Residual norm 4.555997114297e-05
28 KSP Residual norm 4.344177005248e-05
29 KSP Residual norm 4.109273104438e-05
30 KSP Residual norm 3.839098195784e-05
31 KSP Residual norm 3.549908867075e-05
32 KSP Residual norm 3.261548113105e-05
33 KSP Residual norm 2.996916379797e-05
34 KSP Residual norm 2.775013293640e-05
35 KSP Residual norm 2.578824176074e-05
36 KSP Residual norm 2.346942322672e-05
37 KSP Residual norm 2.090695184492e-05
38 KSP Residual norm 1.865024270052e-05
39 KSP Residual norm 1.680958711451e-05
40 KSP Residual norm 1.528786310090e-05
41 KSP Residual norm 1.396209603227e-05
42 KSP Residual norm 1.278937897456e-05
43 KSP Residual norm 1.178390478297e-05
44 KSP Residual norm 1.094397721581e-05
45 KSP Residual norm 1.026245877782e-05
46 KSP Residual norm 9.691103801495e-06
47 KSP Residual norm 9.204094895478e-06
48 KSP Residual norm 8.823290122583e-06
49 KSP Residual norm 8.555903837513e-06
50 KSP Residual norm 8.257066124473e-06
51 KSP Residual norm 7.857181241400e-06
52 KSP Residual norm 7.560375148993e-06
53 KSP Residual norm 7.433738214878e-06
54 KSP Residual norm 7.494258161375e-06
55 KSP Residual norm 7.818562225430e-06
56 KSP Residual norm 8.009692432934e-06
57 KSP Residual norm 7.769541607854e-06
58 KSP Residual norm 7.689620507611e-06
59 KSP Residual norm 7.736725490907e-06
60 KSP Residual norm 7.781579669300e-06
61 KSP Residual norm 7.777328036654e-06
62 KSP Residual norm 7.695967819753e-06
63 KSP Residual norm 7.520616918367e-06
64 KSP Residual norm 7.284395410821e-06
65 KSP Residual norm 7.018726530927e-06
66 KSP Residual norm 6.720388647905e-06
67 KSP Residual norm 6.373396909536e-06
68 KSP Residual norm 6.029727902108e-06
69 KSP Residual norm 5.715214271558e-06
70 KSP Residual norm 5.383237001522e-06
71 KSP Residual norm 5.021627696359e-06
72 KSP Residual norm 4.683618936244e-06
73 KSP Residual norm 4.376836951880e-06
74 KSP Residual norm 4.117707364556e-06
75 KSP Residual norm 3.939010737751e-06
76 KSP Residual norm 3.771161230191e-06
77 KSP Residual norm 3.545421932318e-06
78 KSP Residual norm 3.323560457881e-06
79 KSP Residual norm 3.155045757958e-06
80 KSP Residual norm 3.033636461703e-06
81 KSP Residual norm 2.938750765557e-06
82 KSP Residual norm 2.854798826881e-06
83 KSP Residual norm 2.783628526563e-06
84 KSP Residual norm 2.705309347462e-06
85 KSP Residual norm 2.629201237899e-06
86 KSP Residual norm 2.546951205553e-06
87 KSP Residual norm 2.469169356127e-06
88 KSP Residual norm 2.434070801217e-06
89 KSP Residual norm 2.414313901551e-06
90 KSP Residual norm 2.408115915811e-06
91 KSP Residual norm 2.388705408173e-06
92 KSP Residual norm 2.370774598300e-06
93 KSP Residual norm 2.381054865115e-06
94 KSP Residual norm 2.386727201073e-06
95 KSP Residual norm 2.402458656873e-06
96 KSP Residual norm 2.415020716690e-06
97 KSP Residual norm 2.416186210172e-06
98 KSP Residual norm 2.434605258561e-06
99 KSP Residual norm 2.435970501531e-06
100 KSP Residual norm 2.424472937930e-06
101 KSP Residual norm 2.404426773496e-06
102 KSP Residual norm 2.370208359348e-06
103 KSP Residual norm 2.333591624146e-06
104 KSP Residual norm 2.309240291533e-06
105 KSP Residual norm 2.320458759365e-06
106 KSP Residual norm 2.233089782691e-06
107 KSP Residual norm 2.098807113975e-06
108 KSP Residual norm 2.011209469131e-06
109 KSP Residual norm 1.912028448982e-06
110 KSP Residual norm 1.824265866449e-06
111 KSP Residual norm 1.755756916616e-06
112 KSP Residual norm 1.700342170367e-06
113 KSP Residual norm 1.642705335816e-06
114 KSP Residual norm 1.593420953281e-06
115 KSP Residual norm 1.550524748981e-06
116 KSP Residual norm 1.498768796001e-06
117 KSP Residual norm 1.441101287538e-06
118 KSP Residual norm 1.395997737659e-06
119 KSP Residual norm 1.362624946537e-06
120 KSP Residual norm 1.303944800517e-06
121 KSP Residual norm 1.214649891239e-06
122 KSP Residual norm 1.128279068078e-06
123 KSP Residual norm 1.052921869537e-06
124 KSP Residual norm 9.907817180777e-07
125 KSP Residual norm 9.328307101049e-07
126 KSP Residual norm 8.688736068153e-07
127 KSP Residual norm 7.958917512809e-07
128 KSP Residual norm 7.361225474413e-07
129 KSP Residual norm 6.935773828936e-07
130 KSP Residual norm 6.506458802861e-07
131 KSP Residual norm 5.988776170164e-07
132 KSP Residual norm 5.555169038983e-07
133 KSP Residual norm 5.254157594628e-07
134 KSP Residual norm 5.016168693054e-07
135 KSP Residual norm 4.782635180747e-07
136 KSP Residual norm 4.535505009199e-07
137 KSP Residual norm 4.297857244934e-07
138 KSP Residual norm 4.079458619665e-07
139 KSP Residual norm 3.884332533839e-07
140 KSP Residual norm 3.696153176142e-07
141 KSP Residual norm 3.509459119069e-07
142 KSP Residual norm 3.325811798637e-07
143 KSP Residual norm 3.140172261874e-07
144 KSP Residual norm 2.941599764029e-07
145 KSP Residual norm 2.750910456826e-07
146 KSP Residual norm 2.571693525666e-07
147 KSP Residual norm 2.400655130442e-07
148 KSP Residual norm 2.237792969833e-07
149 KSP Residual norm 2.091956167525e-07
150 KSP Residual norm 1.959476057154e-07
151 KSP Residual norm 1.843236104748e-07
152 KSP Residual norm 1.743213178428e-07
153 KSP Residual norm 1.649789780075e-07
154 KSP Residual norm 1.576138362677e-07
155 KSP Residual norm 1.555204673073e-07
156 KSP Residual norm 1.545015706350e-07
157 KSP Residual norm 1.441146107235e-07
158 KSP Residual norm 1.351436698122e-07
159 KSP Residual norm 1.296631785749e-07
160 KSP Residual norm 1.256031523036e-07
161 KSP Residual norm 1.225362450471e-07
162 KSP Residual norm 1.196248949689e-07
163 KSP Residual norm 1.166104826641e-07
164 KSP Residual norm 1.127187694211e-07
165 KSP Residual norm 1.079954463166e-07
166 KSP Residual norm 1.033283789691e-07
167 KSP Residual norm 9.932930337503e-08
168 KSP Residual norm 9.611995528521e-08
169 KSP Residual norm 9.325532035022e-08
170 KSP Residual norm 9.000501548197e-08
171 KSP Residual norm 8.705215024878e-08
172 KSP Residual norm 8.525544429438e-08
173 KSP Residual norm 8.434403016601e-08
174 KSP Residual norm 8.381499947888e-08
175 KSP Residual norm 8.291905513150e-08
176 KSP Residual norm 8.155393708863e-08
177 KSP Residual norm 8.023300041365e-08
178 KSP Residual norm 7.945713047814e-08
179 KSP Residual norm 7.874557890331e-08
180 KSP Residual norm 7.762857535268e-08
181 KSP Residual norm 7.641624084555e-08
182 KSP Residual norm 7.528501454651e-08
183 KSP Residual norm 7.455823174954e-08
184 KSP Residual norm 7.397461161219e-08
185 KSP Residual norm 7.332166173297e-08
186 KSP Residual norm 7.268423402239e-08
187 KSP Residual norm 7.221215375001e-08
188 KSP Residual norm 7.160517182541e-08
189 KSP Residual norm 7.101520457912e-08
190 KSP Residual norm 7.061957179468e-08
191 KSP Residual norm 7.057063823456e-08
192 KSP Residual norm 7.029530685468e-08
193 KSP Residual norm 6.955782192685e-08
194 KSP Residual norm 6.884194034901e-08
195 KSP Residual norm 6.826716999262e-08
196 KSP Residual norm 6.763824423487e-08
197 KSP Residual norm 6.684813321254e-08
198 KSP Residual norm 6.602813632744e-08
199 KSP Residual norm 6.503123599846e-08
200 KSP Residual norm 6.375320499297e-08
201 KSP Residual norm 6.237274003757e-08
202 KSP Residual norm 6.138235732902e-08
203 KSP Residual norm 6.138912996254e-08
204 KSP Residual norm 6.111911518239e-08
205 KSP Residual norm 5.810025173867e-08
206 KSP Residual norm 5.539015720286e-08
207 KSP Residual norm 5.494012987503e-08
208 KSP Residual norm 5.500784645239e-08
209 KSP Residual norm 5.227843587816e-08
210 KSP Residual norm 4.952589901694e-08
211 KSP Residual norm 4.775986064511e-08
212 KSP Residual norm 4.623609878863e-08
213 KSP Residual norm 4.474327207154e-08
214 KSP Residual norm 4.336242675191e-08
215 KSP Residual norm 4.192925345877e-08
216 KSP Residual norm 4.042981431518e-08
217 KSP Residual norm 3.892737608809e-08
218 KSP Residual norm 3.745419450203e-08
219 KSP Residual norm 3.602869996758e-08
220 KSP Residual norm 3.463819517987e-08
221 KSP Residual norm 3.333540287651e-08
222 KSP Residual norm 3.214432404228e-08
223 KSP Residual norm 3.123741213725e-08
224 KSP Residual norm 3.028735590016e-08
225 KSP Residual norm 2.888963824032e-08
226 KSP Residual norm 2.737075227880e-08
227 KSP Residual norm 2.614742539006e-08
228 KSP Residual norm 2.512374086339e-08
229 KSP Residual norm 2.408363704756e-08
230 KSP Residual norm 2.296350728133e-08
231 KSP Residual norm 2.187712163427e-08
232 KSP Residual norm 2.087336551888e-08
233 KSP Residual norm 1.993000837977e-08
234 KSP Residual norm 1.905487307549e-08
235 KSP Residual norm 1.832596190520e-08
236 KSP Residual norm 1.769826238990e-08
237 KSP Residual norm 1.711076397427e-08
238 KSP Residual norm 1.663040637874e-08
239 KSP Residual norm 1.629559898657e-08
240 KSP Residual norm 1.592639442892e-08
241 KSP Residual norm 1.539808347298e-08
242 KSP Residual norm 1.485220469809e-08
243 KSP Residual norm 1.434138245903e-08
244 KSP Residual norm 1.387754076609e-08
245 KSP Residual norm 1.341715955749e-08
246 KSP Residual norm 1.295564714711e-08
247 KSP Residual norm 1.256599594403e-08
248 KSP Residual norm 1.218553437189e-08
249 KSP Residual norm 1.180014279099e-08
250 KSP Residual norm 1.137395503650e-08
251 KSP Residual norm 1.082869413642e-08
252 KSP Residual norm 1.024892688793e-08
253 KSP Residual norm 9.748278359024e-09
254 KSP Residual norm 9.371411413738e-09
255 KSP Residual norm 9.129541073063e-09
256 KSP Residual norm 9.160409129689e-09
257 KSP Residual norm 9.130467154404e-09
258 KSP Residual norm 8.515979373687e-09
259 KSP Residual norm 8.048653142042e-09
260 KSP Residual norm 7.768372617688e-09
261 KSP Residual norm 7.571948228546e-09
262 KSP Residual norm 7.391276808031e-09
263 KSP Residual norm 7.191581490295e-09
264 KSP Residual norm 6.993752409868e-09
265 KSP Residual norm 6.760738452993e-09
266 KSP Residual norm 6.558613465550e-09
267 KSP Residual norm 6.380845951088e-09
268 KSP Residual norm 6.213650010628e-09
269 KSP Residual norm 6.071694331454e-09
270 KSP Residual norm 5.913169048931e-09
271 KSP Residual norm 5.707594304179e-09
272 KSP Residual norm 5.471543018045e-09
273 KSP Residual norm 5.261698584148e-09
274 KSP Residual norm 5.074476274979e-09
275 KSP Residual norm 4.893666184240e-09
276 KSP Residual norm 4.711910444419e-09
277 KSP Residual norm 4.556080449975e-09
278 KSP Residual norm 4.426410404099e-09
279 KSP Residual norm 4.297557408507e-09
280 KSP Residual norm 4.119929142459e-09
281 KSP Residual norm 3.964677214119e-09
282 KSP Residual norm 3.856581166798e-09
283 KSP Residual norm 3.773958603397e-09
284 KSP Residual norm 3.697448281057e-09
285 KSP Residual norm 3.629454897386e-09
286 KSP Residual norm 3.579227360844e-09
287 KSP Residual norm 3.541511691688e-09
288 KSP Residual norm 3.497738539088e-09
289 KSP Residual norm 3.462377239542e-09
290 KSP Residual norm 3.441835612413e-09
291 KSP Residual norm 3.368004788789e-09
292 KSP Residual norm 3.213811188403e-09
293 KSP Residual norm 3.061379890361e-09
294 KSP Residual norm 2.946288666505e-09
295 KSP Residual norm 2.851493539112e-09
296 KSP Residual norm 2.765293075161e-09
297 KSP Residual norm 2.681158942503e-09
298 KSP Residual norm 2.607752428072e-09
299 KSP Residual norm 2.540005837295e-09
300 KSP Residual norm 2.468474451432e-09
301 KSP Residual norm 2.387610749450e-09
302 KSP Residual norm 2.309297325862e-09
303 KSP Residual norm 2.245751974908e-09
304 KSP Residual norm 2.217709022616e-09
305 KSP Residual norm 2.238177233036e-09
306 KSP Residual norm 2.258352291550e-09
307 KSP Residual norm 2.156855615727e-09
308 KSP Residual norm 2.048373899686e-09
309 KSP Residual norm 1.988633994813e-09
310 KSP Residual norm 1.942299397991e-09
311 KSP Residual norm 1.895815057275e-09
312 KSP Residual norm 1.863919348005e-09
313 KSP Residual norm 1.846018260376e-09
314 KSP Residual norm 1.822965506684e-09
315 KSP Residual norm 1.775214655158e-09
316 KSP Residual norm 1.705872509080e-09
317 KSP Residual norm 1.639004678464e-09
318 KSP Residual norm 1.585096041812e-09
319 KSP Residual norm 1.548189837892e-09
320 KSP Residual norm 1.516849654853e-09
321 KSP Residual norm 1.476455845943e-09
322 KSP Residual norm 1.418660698980e-09
323 KSP Residual norm 1.361728969855e-09
324 KSP Residual norm 1.312707416274e-09
325 KSP Residual norm 1.273496005044e-09
326 KSP Residual norm 1.240315949318e-09
327 KSP Residual norm 1.215563821705e-09
328 KSP Residual norm 1.202356572134e-09
329 KSP Residual norm 1.190112894978e-09
330 KSP Residual norm 1.170033035545e-09
331 KSP Residual norm 1.153182683134e-09
332 KSP Residual norm 1.143607958664e-09
333 KSP Residual norm 1.124139497114e-09
334 KSP Residual norm 1.084888815782e-09
335 KSP Residual norm 1.045874646565e-09
336 KSP Residual norm 1.011632382101e-09
337 KSP Residual norm 9.832435043945e-10
338 KSP Residual norm 9.673057380653e-10
339 KSP Residual norm 9.530652023295e-10
340 KSP Residual norm 9.177831672136e-10
341 KSP Residual norm 8.720385050482e-10
342 KSP Residual norm 8.328865727355e-10
343 KSP Residual norm 7.997482635430e-10
344 KSP Residual norm 7.682856547373e-10
345 KSP Residual norm 7.392079011127e-10
346 KSP Residual norm 7.100396271068e-10
347 KSP Residual norm 6.835039802313e-10
348 KSP Residual norm 6.616949398721e-10
349 KSP Residual norm 6.445447460209e-10
350 KSP Residual norm 6.321444816311e-10
351 KSP Residual norm 6.242579007434e-10
352 KSP Residual norm 6.197896704245e-10
353 KSP Residual norm 6.218783067693e-10
354 KSP Residual norm 6.252127172904e-10
355 KSP Residual norm 6.108735991856e-10
356 KSP Residual norm 5.911201668078e-10
357 KSP Residual norm 5.706482326950e-10
358 KSP Residual norm 5.497385106675e-10
359 KSP Residual norm 5.297110405976e-10
360 KSP Residual norm 5.100372958560e-10
361 KSP Residual norm 4.909924840123e-10
362 KSP Residual norm 4.717046645839e-10
363 KSP Residual norm 4.540728943079e-10
364 KSP Residual norm 4.396411156695e-10
365 KSP Residual norm 4.290067951976e-10
366 KSP Residual norm 4.224291447189e-10
367 KSP Residual norm 4.130623988227e-10
368 KSP Residual norm 3.960244713361e-10
369 KSP Residual norm 3.782239567988e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 369
0 LS Function value: 0.0691389, Step length: 0.
1 LS Function value: 0.069139, Step length: 1.
stx: 0., fx: 0.0691389, dgx: -7.7208e-08
sty: 0., fy: 0.0691389, dgy: -7.7208e-08
2 LS Function value: 0.0691389, Step length: 0.336196
sty: 1., fy: 0.069139, dgy: 5.83052e-07
38 TAO, Function value: 0.0691389, Residual: 6.8474e-05
0 KSP Residual norm 6.847403875890e-05
1 KSP Residual norm 5.021763929289e-05
2 KSP Residual norm 3.924616826055e-05
3 KSP Residual norm 2.896535855276e-05
4 KSP Residual norm 2.312203529870e-05
5 KSP Residual norm 2.127788423731e-05
6 KSP Residual norm 1.985724703851e-05
7 KSP Residual norm 1.949569563816e-05
8 KSP Residual norm 2.054135290421e-05
9 KSP Residual norm 2.178312649540e-05
10 KSP Residual norm 2.347188872404e-05
11 KSP Residual norm 2.556183629351e-05
12 KSP Residual norm 2.791464834356e-05
13 KSP Residual norm 3.025893275227e-05
14 KSP Residual norm 3.190417270595e-05
15 KSP Residual norm 3.298122277692e-05
16 KSP Residual norm 3.380453656987e-05
17 KSP Residual norm 3.431204653659e-05
18 KSP Residual norm 3.441747698275e-05
19 KSP Residual norm 3.386490693860e-05
20 KSP Residual norm 3.328729702156e-05
21 KSP Residual norm 3.292427672769e-05
22 KSP Residual norm 3.214823633524e-05
23 KSP Residual norm 3.092519763310e-05
24 KSP Residual norm 2.984696332855e-05
25 KSP Residual norm 2.884522960782e-05
26 KSP Residual norm 2.761633126675e-05
27 KSP Residual norm 2.640992530306e-05
28 KSP Residual norm 2.531669884811e-05
29 KSP Residual norm 2.426423683229e-05
30 KSP Residual norm 2.307097034442e-05
31 KSP Residual norm 2.166796847988e-05
32 KSP Residual norm 2.007777710218e-05
33 KSP Residual norm 1.840910922068e-05
34 KSP Residual norm 1.678889342028e-05
35 KSP Residual norm 1.523753008677e-05
36 KSP Residual norm 1.374305624848e-05
37 KSP Residual norm 1.234806639108e-05
38 KSP Residual norm 1.109764350319e-05
39 KSP Residual norm 1.000491263823e-05
40 KSP Residual norm 9.085713371047e-06
41 KSP Residual norm 8.355197148921e-06
42 KSP Residual norm 7.754631257663e-06
43 KSP Residual norm 7.081258676780e-06
44 KSP Residual norm 6.380678511422e-06
45 KSP Residual norm 5.821489888154e-06
46 KSP Residual norm 5.382633559063e-06
47 KSP Residual norm 5.014695476155e-06
48 KSP Residual norm 4.689829374242e-06
49 KSP Residual norm 4.403399321393e-06
50 KSP Residual norm 4.169910525861e-06
51 KSP Residual norm 3.998527117966e-06
52 KSP Residual norm 3.885805471665e-06
53 KSP Residual norm 3.749345209268e-06
54 KSP Residual norm 3.536823027246e-06
55 KSP Residual norm 3.358186680917e-06
56 KSP Residual norm 3.270001428473e-06
57 KSP Residual norm 3.245674966461e-06
58 KSP Residual norm 3.214285498573e-06
59 KSP Residual norm 3.153587773201e-06
60 KSP Residual norm 3.101055787871e-06
61 KSP Residual norm 3.063255522704e-06
62 KSP Residual norm 3.023901127842e-06
63 KSP Residual norm 2.970569554467e-06
64 KSP Residual norm 2.906528221827e-06
65 KSP Residual norm 2.832610623287e-06
66 KSP Residual norm 2.738492907139e-06
67 KSP Residual norm 2.610571164216e-06
68 KSP Residual norm 2.466444485140e-06
69 KSP Residual norm 2.312894496658e-06
70 KSP Residual norm 2.133985737217e-06
71 KSP Residual norm 1.946066652990e-06
72 KSP Residual norm 1.781883577445e-06
73 KSP Residual norm 1.643965371726e-06
74 KSP Residual norm 1.526309097601e-06
75 KSP Residual norm 1.415592057182e-06
76 KSP Residual norm 1.287593852413e-06
77 KSP Residual norm 1.158759628410e-06
78 KSP Residual norm 1.052241057831e-06
79 KSP Residual norm 9.667577222206e-07
80 KSP Residual norm 8.980232507478e-07
81 KSP Residual norm 8.402624264469e-07
82 KSP Residual norm 7.858473739181e-07
83 KSP Residual norm 7.365458184581e-07
84 KSP Residual norm 6.888593239699e-07
85 KSP Residual norm 6.446843142207e-07
86 KSP Residual norm 6.021244104973e-07
87 KSP Residual norm 5.613233264290e-07
88 KSP Residual norm 5.309440274525e-07
89 KSP Residual norm 5.063267839357e-07
90 KSP Residual norm 4.868391929899e-07
91 KSP Residual norm 4.669081535272e-07
92 KSP Residual norm 4.493303695223e-07
93 KSP Residual norm 4.391618630402e-07
94 KSP Residual norm 4.303375786786e-07
95 KSP Residual norm 4.255945809855e-07
96 KSP Residual norm 4.235472760231e-07
97 KSP Residual norm 4.227982254709e-07
98 KSP Residual norm 4.276633841079e-07
99 KSP Residual norm 4.330254119372e-07
100 KSP Residual norm 4.430035892362e-07
101 KSP Residual norm 4.553946478420e-07
102 KSP Residual norm 4.553718399805e-07
103 KSP Residual norm 4.467522534715e-07
104 KSP Residual norm 4.458258368338e-07
105 KSP Residual norm 4.458594476470e-07
106 KSP Residual norm 4.455633095627e-07
107 KSP Residual norm 4.434666899370e-07
108 KSP Residual norm 4.428317303796e-07
109 KSP Residual norm 4.360813519172e-07
110 KSP Residual norm 4.270788286966e-07
111 KSP Residual norm 4.190389554313e-07
112 KSP Residual norm 4.126859103236e-07
113 KSP Residual norm 4.060720858341e-07
114 KSP Residual norm 4.000883900815e-07
115 KSP Residual norm 3.941936969889e-07
116 KSP Residual norm 3.874097861027e-07
117 KSP Residual norm 3.803766977583e-07
118 KSP Residual norm 3.746444101652e-07
119 KSP Residual norm 3.682825811053e-07
120 KSP Residual norm 3.570248272659e-07
121 KSP Residual norm 3.428589289954e-07
122 KSP Residual norm 3.290421244734e-07
123 KSP Residual norm 3.154838137227e-07
124 KSP Residual norm 3.030182830592e-07
125 KSP Residual norm 2.902808576458e-07
126 KSP Residual norm 2.768790515801e-07
127 KSP Residual norm 2.616358500822e-07
128 KSP Residual norm 2.483944165009e-07
129 KSP Residual norm 2.362192967292e-07
130 KSP Residual norm 2.206757478847e-07
131 KSP Residual norm 2.038643579038e-07
132 KSP Residual norm 1.897759416835e-07
133 KSP Residual norm 1.791754599223e-07
134 KSP Residual norm 1.713066706719e-07
135 KSP Residual norm 1.651270610306e-07
136 KSP Residual norm 1.576630415962e-07
137 KSP Residual norm 1.486300450659e-07
138 KSP Residual norm 1.404121025882e-07
139 KSP Residual norm 1.336280448783e-07
140 KSP Residual norm 1.275254824379e-07
141 KSP Residual norm 1.220632069320e-07
142 KSP Residual norm 1.175587393405e-07
143 KSP Residual norm 1.137054880268e-07
144 KSP Residual norm 1.093600671891e-07
145 KSP Residual norm 1.047305744770e-07
146 KSP Residual norm 1.002750032568e-07
147 KSP Residual norm 9.600143452037e-08
148 KSP Residual norm 9.183028843934e-08
149 KSP Residual norm 8.858986442100e-08
150 KSP Residual norm 8.649833971284e-08
151 KSP Residual norm 8.477457151089e-08
152 KSP Residual norm 8.109826032381e-08
153 KSP Residual norm 7.625414288590e-08
154 KSP Residual norm 7.176270391295e-08
155 KSP Residual norm 6.784432050322e-08
156 KSP Residual norm 6.477991979503e-08
157 KSP Residual norm 6.267008371611e-08
158 KSP Residual norm 6.133111570852e-08
159 KSP Residual norm 6.016533448872e-08
160 KSP Residual norm 5.902334823957e-08
161 KSP Residual norm 5.820885325501e-08
162 KSP Residual norm 5.756584637355e-08
163 KSP Residual norm 5.689480678052e-08
164 KSP Residual norm 5.592294627938e-08
165 KSP Residual norm 5.461883381447e-08
166 KSP Residual norm 5.329800068245e-08
167 KSP Residual norm 5.233678518400e-08
168 KSP Residual norm 5.149258871489e-08
169 KSP Residual norm 5.067183259594e-08
170 KSP Residual norm 4.978986455981e-08
171 KSP Residual norm 4.899792314774e-08
172 KSP Residual norm 4.851332392273e-08
173 KSP Residual norm 4.821593099921e-08
174 KSP Residual norm 4.808058493370e-08
175 KSP Residual norm 4.806605715639e-08
176 KSP Residual norm 4.816635163078e-08
177 KSP Residual norm 4.829495377863e-08
178 KSP Residual norm 4.851102463479e-08
179 KSP Residual norm 4.825644474065e-08
180 KSP Residual norm 4.724669691763e-08
181 KSP Residual norm 4.617975704887e-08
182 KSP Residual norm 4.516648197689e-08
183 KSP Residual norm 4.423735285380e-08
184 KSP Residual norm 4.337709459869e-08
185 KSP Residual norm 4.267161642143e-08
186 KSP Residual norm 4.211127720064e-08
187 KSP Residual norm 4.158622126329e-08
188 KSP Residual norm 4.092680895589e-08
189 KSP Residual norm 4.021911623332e-08
190 KSP Residual norm 3.949026991404e-08
191 KSP Residual norm 3.888275118584e-08
192 KSP Residual norm 3.829800557585e-08
193 KSP Residual norm 3.754051906744e-08
194 KSP Residual norm 3.661423049773e-08
195 KSP Residual norm 3.563518153799e-08
196 KSP Residual norm 3.484683971190e-08
197 KSP Residual norm 3.440260216994e-08
198 KSP Residual norm 3.416622663973e-08
199 KSP Residual norm 3.301081634649e-08
200 KSP Residual norm 3.110537368994e-08
201 KSP Residual norm 2.943704779523e-08
202 KSP Residual norm 2.806886459980e-08
203 KSP Residual norm 2.682090919785e-08
204 KSP Residual norm 2.556216575498e-08
205 KSP Residual norm 2.439170097125e-08
206 KSP Residual norm 2.349554327666e-08
207 KSP Residual norm 2.307984276617e-08
208 KSP Residual norm 2.250225463693e-08
209 KSP Residual norm 2.122124118238e-08
210 KSP Residual norm 2.008300581216e-08
211 KSP Residual norm 1.923668300998e-08
212 KSP Residual norm 1.846323161411e-08
213 KSP Residual norm 1.774807662713e-08
214 KSP Residual norm 1.722086751046e-08
215 KSP Residual norm 1.681675870722e-08
216 KSP Residual norm 1.636595204089e-08
217 KSP Residual norm 1.571778165726e-08
218 KSP Residual norm 1.501310254541e-08
219 KSP Residual norm 1.431676534467e-08
220 KSP Residual norm 1.358328609450e-08
221 KSP Residual norm 1.285983804475e-08
222 KSP Residual norm 1.223116523262e-08
223 KSP Residual norm 1.172042547046e-08
224 KSP Residual norm 1.130563917929e-08
225 KSP Residual norm 1.098003242395e-08
226 KSP Residual norm 1.069473597322e-08
227 KSP Residual norm 1.031335833920e-08
228 KSP Residual norm 9.781456943909e-09
229 KSP Residual norm 9.315099553742e-09
230 KSP Residual norm 8.980174711642e-09
231 KSP Residual norm 8.700470908839e-09
232 KSP Residual norm 8.442378832754e-09
233 KSP Residual norm 8.215749503310e-09
234 KSP Residual norm 8.018209483035e-09
235 KSP Residual norm 7.812311263712e-09
236 KSP Residual norm 7.488882064026e-09
237 KSP Residual norm 7.124051740244e-09
238 KSP Residual norm 6.834096095869e-09
239 KSP Residual norm 6.612332338243e-09
240 KSP Residual norm 6.432109394428e-09
241 KSP Residual norm 6.305950000006e-09
242 KSP Residual norm 6.188832890869e-09
243 KSP Residual norm 6.034460933372e-09
244 KSP Residual norm 5.890603592499e-09
245 KSP Residual norm 5.783851151035e-09
246 KSP Residual norm 5.727388501109e-09
247 KSP Residual norm 5.799642832629e-09
248 KSP Residual norm 5.842210471521e-09
249 KSP Residual norm 5.540649537456e-09
250 KSP Residual norm 5.222386437002e-09
251 KSP Residual norm 5.008960504590e-09
252 KSP Residual norm 4.849463576338e-09
253 KSP Residual norm 4.728814871973e-09
254 KSP Residual norm 4.638958631652e-09
255 KSP Residual norm 4.472716107424e-09
256 KSP Residual norm 4.236565396185e-09
257 KSP Residual norm 4.042579382144e-09
258 KSP Residual norm 3.891613439325e-09
259 KSP Residual norm 3.768078236297e-09
260 KSP Residual norm 3.644830969796e-09
261 KSP Residual norm 3.538956926029e-09
262 KSP Residual norm 3.456663376362e-09
263 KSP Residual norm 3.385726682570e-09
264 KSP Residual norm 3.315791253213e-09
265 KSP Residual norm 3.212712106336e-09
266 KSP Residual norm 3.117279824406e-09
267 KSP Residual norm 3.039644108186e-09
268 KSP Residual norm 2.964090265734e-09
269 KSP Residual norm 2.887081131431e-09
270 KSP Residual norm 2.805420637610e-09
271 KSP Residual norm 2.728688332515e-09
272 KSP Residual norm 2.653519940514e-09
273 KSP Residual norm 2.562018472590e-09
274 KSP Residual norm 2.456065469302e-09
275 KSP Residual norm 2.360468124088e-09
276 KSP Residual norm 2.276279692991e-09
277 KSP Residual norm 2.192908138368e-09
278 KSP Residual norm 2.102158201219e-09
279 KSP Residual norm 2.032585645265e-09
280 KSP Residual norm 1.985289206565e-09
281 KSP Residual norm 1.950534119224e-09
282 KSP Residual norm 1.903983772456e-09
283 KSP Residual norm 1.848287745952e-09
284 KSP Residual norm 1.800071842203e-09
285 KSP Residual norm 1.762026532426e-09
286 KSP Residual norm 1.745525631902e-09
287 KSP Residual norm 1.748164891136e-09
288 KSP Residual norm 1.727765529272e-09
289 KSP Residual norm 1.668052344934e-09
290 KSP Residual norm 1.612924763495e-09
291 KSP Residual norm 1.568428263610e-09
292 KSP Residual norm 1.521234236351e-09
293 KSP Residual norm 1.471595877461e-09
294 KSP Residual norm 1.433285143613e-09
295 KSP Residual norm 1.423636922863e-09
296 KSP Residual norm 1.439034138743e-09
297 KSP Residual norm 1.393033151364e-09
298 KSP Residual norm 1.315713507670e-09
299 KSP Residual norm 1.279217917229e-09
300 KSP Residual norm 1.260383069787e-09
301 KSP Residual norm 1.231084825935e-09
302 KSP Residual norm 1.181598946651e-09
303 KSP Residual norm 1.132381860431e-09
304 KSP Residual norm 1.094007958339e-09
305 KSP Residual norm 1.067500208291e-09
306 KSP Residual norm 1.050263028795e-09
307 KSP Residual norm 1.028340167771e-09
308 KSP Residual norm 9.989588258776e-10
309 KSP Residual norm 9.734467533932e-10
310 KSP Residual norm 9.514201754635e-10
311 KSP Residual norm 9.316925388041e-10
312 KSP Residual norm 9.137992220181e-10
313 KSP Residual norm 9.001541872600e-10
314 KSP Residual norm 8.864292796355e-10
315 KSP Residual norm 8.749058428626e-10
316 KSP Residual norm 8.613232589002e-10
317 KSP Residual norm 8.380683817788e-10
318 KSP Residual norm 8.111033071476e-10
319 KSP Residual norm 7.892946595877e-10
320 KSP Residual norm 7.700411159942e-10
321 KSP Residual norm 7.479859490327e-10
322 KSP Residual norm 7.195150134743e-10
323 KSP Residual norm 6.906801460987e-10
324 KSP Residual norm 6.645517925225e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 324
stx: 0., fx: 0.0691389, dgx: -3.69502e-08
sty: 0., fy: 0.0691389, dgy: -3.69502e-08
39 TAO, Function value: 0.0691389, Residual: 7.66474e-05
0 KSP Residual norm 7.664742837647e-05
1 KSP Residual norm 5.540964281783e-05
2 KSP Residual norm 4.100402539521e-05
3 KSP Residual norm 3.006777836498e-05
4 KSP Residual norm 2.225322814242e-05
5 KSP Residual norm 1.854353508582e-05
6 KSP Residual norm 1.574078676271e-05
7 KSP Residual norm 1.393275069080e-05
8 KSP Residual norm 1.297113401654e-05
9 KSP Residual norm 1.257482576112e-05
10 KSP Residual norm 1.256890080138e-05
11 KSP Residual norm 1.279005839083e-05
12 KSP Residual norm 1.328276040551e-05
13 KSP Residual norm 1.395982495077e-05
14 KSP Residual norm 1.468780534643e-05
15 KSP Residual norm 1.533423349143e-05
16 KSP Residual norm 1.581409399326e-05
17 KSP Residual norm 1.618752319992e-05
18 KSP Residual norm 1.655381648524e-05
19 KSP Residual norm 1.676993942619e-05
20 KSP Residual norm 1.698468134561e-05
21 KSP Residual norm 1.712836640892e-05
22 KSP Residual norm 1.690727322590e-05
23 KSP Residual norm 1.646015462131e-05
24 KSP Residual norm 1.600270067184e-05
25 KSP Residual norm 1.559652523159e-05
26 KSP Residual norm 1.515256604057e-05
27 KSP Residual norm 1.469304847731e-05
28 KSP Residual norm 1.426660877495e-05
29 KSP Residual norm 1.385723946697e-05
30 KSP Residual norm 1.339087852916e-05
31 KSP Residual norm 1.287251607836e-05
32 KSP Residual norm 1.225875250205e-05
33 KSP Residual norm 1.152813248389e-05
34 KSP Residual norm 1.075093023008e-05
35 KSP Residual norm 9.979399544656e-06
36 KSP Residual norm 9.212899950447e-06
37 KSP Residual norm 8.431607708837e-06
38 KSP Residual norm 7.651143634384e-06
39 KSP Residual norm 6.902121689407e-06
40 KSP Residual norm 6.203052492080e-06
41 KSP Residual norm 5.560391450180e-06
42 KSP Residual norm 4.983916242287e-06
43 KSP Residual norm 4.468007689912e-06
44 KSP Residual norm 4.009094639564e-06
45 KSP Residual norm 3.618902207730e-06
46 KSP Residual norm 3.308049388784e-06
47 KSP Residual norm 3.071402318923e-06
48 KSP Residual norm 2.867215167130e-06
49 KSP Residual norm 2.646487936562e-06
50 KSP Residual norm 2.425803301151e-06
51 KSP Residual norm 2.233917117427e-06
52 KSP Residual norm 2.104410459649e-06
53 KSP Residual norm 2.011855513443e-06
54 KSP Residual norm 1.847579911835e-06
55 KSP Residual norm 1.685769478506e-06
56 KSP Residual norm 1.582234796692e-06
57 KSP Residual norm 1.518399520887e-06
58 KSP Residual norm 1.481704762295e-06
59 KSP Residual norm 1.468890089098e-06
60 KSP Residual norm 1.484979492834e-06
61 KSP Residual norm 1.540720574205e-06
62 KSP Residual norm 1.612922008321e-06
63 KSP Residual norm 1.640445426407e-06
64 KSP Residual norm 1.666220282999e-06
65 KSP Residual norm 1.723679208945e-06
66 KSP Residual norm 1.789760319671e-06
67 KSP Residual norm 1.843263598831e-06
68 KSP Residual norm 1.900084466968e-06
69 KSP Residual norm 1.968877572970e-06
70 KSP Residual norm 1.999739816120e-06
71 KSP Residual norm 1.977034465772e-06
72 KSP Residual norm 1.947851345707e-06
73 KSP Residual norm 1.914930132476e-06
74 KSP Residual norm 1.860844795588e-06
75 KSP Residual norm 1.807851033707e-06
76 KSP Residual norm 1.760902066444e-06
77 KSP Residual norm 1.691195937830e-06
78 KSP Residual norm 1.582223319742e-06
79 KSP Residual norm 1.466885345064e-06
80 KSP Residual norm 1.368954318426e-06
81 KSP Residual norm 1.283965458565e-06
82 KSP Residual norm 1.198447779067e-06
83 KSP Residual norm 1.112744529300e-06
84 KSP Residual norm 1.031303130055e-06
85 KSP Residual norm 9.703628899075e-07
86 KSP Residual norm 9.142856877745e-07
87 KSP Residual norm 8.436478231528e-07
88 KSP Residual norm 7.790600310091e-07
89 KSP Residual norm 7.233822265174e-07
90 KSP Residual norm 6.729907949532e-07
91 KSP Residual norm 6.215236058236e-07
92 KSP Residual norm 5.757273325734e-07
93 KSP Residual norm 5.404156036079e-07
94 KSP Residual norm 5.056581641429e-07
95 KSP Residual norm 4.723694856602e-07
96 KSP Residual norm 4.381141755548e-07
97 KSP Residual norm 4.055694336905e-07
98 KSP Residual norm 3.823865417906e-07
99 KSP Residual norm 3.664837625481e-07
100 KSP Residual norm 3.462096412261e-07
101 KSP Residual norm 3.142614626370e-07
102 KSP Residual norm 2.876007202933e-07
103 KSP Residual norm 2.677686506777e-07
104 KSP Residual norm 2.509871650855e-07
105 KSP Residual norm 2.353293710370e-07
106 KSP Residual norm 2.227233035577e-07
107 KSP Residual norm 2.114171681049e-07
108 KSP Residual norm 2.013242940690e-07
109 KSP Residual norm 1.886658588038e-07
110 KSP Residual norm 1.760851197982e-07
111 KSP Residual norm 1.646389389624e-07
112 KSP Residual norm 1.539991544168e-07
113 KSP Residual norm 1.443539234716e-07
114 KSP Residual norm 1.355713241776e-07
115 KSP Residual norm 1.264486241769e-07
116 KSP Residual norm 1.174824887376e-07
117 KSP Residual norm 1.095061588697e-07
118 KSP Residual norm 1.036888163160e-07
119 KSP Residual norm 1.005938754044e-07
120 KSP Residual norm 9.772457039829e-08
121 KSP Residual norm 9.267864099332e-08
122 KSP Residual norm 8.775226838332e-08
123 KSP Residual norm 8.433318379820e-08
124 KSP Residual norm 8.199199210531e-08
125 KSP Residual norm 7.993169162142e-08
126 KSP Residual norm 7.767141316919e-08
127 KSP Residual norm 7.445504085490e-08
128 KSP Residual norm 7.072823362563e-08
129 KSP Residual norm 6.688185769042e-08
130 KSP Residual norm 6.330033790479e-08
131 KSP Residual norm 6.023063884778e-08
132 KSP Residual norm 5.754040195068e-08
133 KSP Residual norm 5.491125146055e-08
134 KSP Residual norm 5.206075128118e-08
135 KSP Residual norm 4.966994880227e-08
136 KSP Residual norm 4.808022268602e-08
137 KSP Residual norm 4.614231603839e-08
138 KSP Residual norm 4.344630870709e-08
139 KSP Residual norm 4.110131533668e-08
140 KSP Residual norm 3.931704291842e-08
141 KSP Residual norm 3.800076028785e-08
142 KSP Residual norm 3.710146895851e-08
143 KSP Residual norm 3.643824038658e-08
144 KSP Residual norm 3.576795101313e-08
145 KSP Residual norm 3.510848709616e-08
146 KSP Residual norm 3.426121473919e-08
147 KSP Residual norm 3.325979579913e-08
148 KSP Residual norm 3.243532238984e-08
149 KSP Residual norm 3.209760120822e-08
150 KSP Residual norm 3.178076173045e-08
151 KSP Residual norm 3.087720317110e-08
152 KSP Residual norm 2.939241770650e-08
153 KSP Residual norm 2.777220821048e-08
154 KSP Residual norm 2.623842035039e-08
155 KSP Residual norm 2.496971375419e-08
156 KSP Residual norm 2.399634049025e-08
157 KSP Residual norm 2.316173072728e-08
158 KSP Residual norm 2.232899878675e-08
159 KSP Residual norm 2.156280456737e-08
160 KSP Residual norm 2.087400506251e-08
161 KSP Residual norm 2.029202051622e-08
162 KSP Residual norm 1.977854510906e-08
163 KSP Residual norm 1.935389934449e-08
164 KSP Residual norm 1.909704877943e-08
165 KSP Residual norm 1.891889313560e-08
166 KSP Residual norm 1.852948701810e-08
167 KSP Residual norm 1.791053101463e-08
168 KSP Residual norm 1.726362714259e-08
169 KSP Residual norm 1.670135919320e-08
170 KSP Residual norm 1.619539388794e-08
171 KSP Residual norm 1.568416823684e-08
172 KSP Residual norm 1.520400598536e-08
173 KSP Residual norm 1.476892103989e-08
174 KSP Residual norm 1.437234374171e-08
175 KSP Residual norm 1.398717697765e-08
176 KSP Residual norm 1.359731316270e-08
177 KSP Residual norm 1.322896833939e-08
178 KSP Residual norm 1.291249475108e-08
179 KSP Residual norm 1.258212305717e-08
180 KSP Residual norm 1.219516345602e-08
181 KSP Residual norm 1.181616126615e-08
182 KSP Residual norm 1.147418921282e-08
183 KSP Residual norm 1.114085569859e-08
184 KSP Residual norm 1.079494986915e-08
185 KSP Residual norm 1.048886522922e-08
186 KSP Residual norm 1.021164526834e-08
187 KSP Residual norm 9.895959321567e-09
188 KSP Residual norm 9.567928379198e-09
189 KSP Residual norm 9.333636205600e-09
190 KSP Residual norm 9.152473171211e-09
191 KSP Residual norm 8.985835618806e-09
192 KSP Residual norm 8.824195538666e-09
193 KSP Residual norm 8.670473583171e-09
194 KSP Residual norm 8.624591672922e-09
195 KSP Residual norm 8.772852203705e-09
196 KSP Residual norm 8.652090777173e-09
197 KSP Residual norm 8.133155585774e-09
198 KSP Residual norm 7.774055983198e-09
199 KSP Residual norm 7.544863538086e-09
200 KSP Residual norm 7.321050109608e-09
201 KSP Residual norm 7.079254106777e-09
202 KSP Residual norm 6.862561635678e-09
203 KSP Residual norm 6.695421858607e-09
204 KSP Residual norm 6.550179435846e-09
205 KSP Residual norm 6.411015598388e-09
206 KSP Residual norm 6.266683795965e-09
207 KSP Residual norm 6.140182828505e-09
208 KSP Residual norm 6.026918815329e-09
209 KSP Residual norm 5.921862398065e-09
210 KSP Residual norm 5.829475811402e-09
211 KSP Residual norm 5.772753711891e-09
212 KSP Residual norm 5.759366132391e-09
213 KSP Residual norm 5.675590342096e-09
214 KSP Residual norm 5.490125490872e-09
215 KSP Residual norm 5.315880538576e-09
216 KSP Residual norm 5.175151362497e-09
217 KSP Residual norm 5.043247311963e-09
218 KSP Residual norm 4.918941566285e-09
219 KSP Residual norm 4.810749751098e-09
220 KSP Residual norm 4.714896912079e-09
221 KSP Residual norm 4.640666867153e-09
222 KSP Residual norm 4.560161829436e-09
223 KSP Residual norm 4.437676947637e-09
224 KSP Residual norm 4.290707382321e-09
225 KSP Residual norm 4.160512245481e-09
226 KSP Residual norm 4.055186565096e-09
227 KSP Residual norm 3.969948314491e-09
228 KSP Residual norm 3.888256522098e-09
229 KSP Residual norm 3.772576049831e-09
230 KSP Residual norm 3.632234479376e-09
231 KSP Residual norm 3.500347559378e-09
232 KSP Residual norm 3.384274369799e-09
233 KSP Residual norm 3.287655055150e-09
234 KSP Residual norm 3.212664120588e-09
235 KSP Residual norm 3.169439017413e-09
236 KSP Residual norm 3.135706476384e-09
237 KSP Residual norm 3.052442247016e-09
238 KSP Residual norm 2.929538648670e-09
239 KSP Residual norm 2.820023719295e-09
240 KSP Residual norm 2.720958235612e-09
241 KSP Residual norm 2.645964123999e-09
242 KSP Residual norm 2.613074150908e-09
243 KSP Residual norm 2.652247058322e-09
244 KSP Residual norm 2.647571408765e-09
245 KSP Residual norm 2.491066810750e-09
246 KSP Residual norm 2.381626477577e-09
247 KSP Residual norm 2.333555309973e-09
248 KSP Residual norm 2.315690707213e-09
249 KSP Residual norm 2.268023949036e-09
250 KSP Residual norm 2.182077353478e-09
251 KSP Residual norm 2.108708629506e-09
252 KSP Residual norm 2.060215544826e-09
253 KSP Residual norm 2.018526089550e-09
254 KSP Residual norm 1.983262331630e-09
255 KSP Residual norm 1.951387595117e-09
256 KSP Residual norm 1.909308911204e-09
257 KSP Residual norm 1.857123526752e-09
258 KSP Residual norm 1.797572865818e-09
259 KSP Residual norm 1.746754527345e-09
260 KSP Residual norm 1.704171893916e-09
261 KSP Residual norm 1.674631355179e-09
262 KSP Residual norm 1.630793672296e-09
263 KSP Residual norm 1.558572498721e-09
264 KSP Residual norm 1.490438026373e-09
265 KSP Residual norm 1.431210303235e-09
266 KSP Residual norm 1.386505771979e-09
267 KSP Residual norm 1.348155903532e-09
268 KSP Residual norm 1.309551785357e-09
269 KSP Residual norm 1.269927018543e-09
270 KSP Residual norm 1.232500846325e-09
271 KSP Residual norm 1.200903394702e-09
272 KSP Residual norm 1.167927173841e-09
273 KSP Residual norm 1.136553935976e-09
274 KSP Residual norm 1.102357382903e-09
275 KSP Residual norm 1.064927523189e-09
276 KSP Residual norm 1.026751053839e-09
277 KSP Residual norm 9.873400187997e-10
278 KSP Residual norm 9.430177466700e-10
279 KSP Residual norm 9.036835948275e-10
280 KSP Residual norm 8.700061915444e-10
281 KSP Residual norm 8.403728838219e-10
282 KSP Residual norm 8.061263336824e-10
283 KSP Residual norm 7.676044477637e-10
284 KSP Residual norm 7.319984710454e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 284
stx: 0., fx: 0.0691389, dgx: -1.85747e-08
sty: 0., fy: 0.0691389, dgy: -1.85747e-08
40 TAO, Function value: 0.0691389, Residual: 1.74531e-05
0 KSP Residual norm 1.745305240262e-05
1 KSP Residual norm 1.407567229897e-05
2 KSP Residual norm 1.068983293646e-05
3 KSP Residual norm 8.389464807009e-06
4 KSP Residual norm 7.083170062341e-06
5 KSP Residual norm 6.822282734774e-06
6 KSP Residual norm 6.923179802178e-06
7 KSP Residual norm 7.372093320828e-06
8 KSP Residual norm 7.971773335637e-06
9 KSP Residual norm 8.779404910937e-06
10 KSP Residual norm 9.716311412018e-06
11 KSP Residual norm 1.057528788943e-05
12 KSP Residual norm 1.142087987054e-05
13 KSP Residual norm 1.217905136270e-05
14 KSP Residual norm 1.290032438267e-05
15 KSP Residual norm 1.362142208415e-05
16 KSP Residual norm 1.427453218204e-05
17 KSP Residual norm 1.474461901126e-05
18 KSP Residual norm 1.500523037380e-05
19 KSP Residual norm 1.513301514979e-05
20 KSP Residual norm 1.513459250831e-05
21 KSP Residual norm 1.503369224325e-05
22 KSP Residual norm 1.478600125666e-05
23 KSP Residual norm 1.439197794882e-05
24 KSP Residual norm 1.388975454721e-05
25 KSP Residual norm 1.338784100774e-05
26 KSP Residual norm 1.293547182921e-05
27 KSP Residual norm 1.244071222702e-05
28 KSP Residual norm 1.179846182434e-05
29 KSP Residual norm 1.100512778358e-05
30 KSP Residual norm 1.013823825619e-05
31 KSP Residual norm 9.292793856575e-06
32 KSP Residual norm 8.463109111623e-06
33 KSP Residual norm 7.645877519732e-06
34 KSP Residual norm 6.890993528288e-06
35 KSP Residual norm 6.224897552149e-06
36 KSP Residual norm 5.628268036255e-06
37 KSP Residual norm 5.085431830567e-06
38 KSP Residual norm 4.624505918779e-06
39 KSP Residual norm 4.282808698463e-06
40 KSP Residual norm 4.016600656538e-06
41 KSP Residual norm 3.675344007858e-06
42 KSP Residual norm 3.331921349867e-06
43 KSP Residual norm 3.079781080738e-06
44 KSP Residual norm 2.901199110841e-06
45 KSP Residual norm 2.764592070939e-06
46 KSP Residual norm 2.651878987110e-06
47 KSP Residual norm 2.553994852948e-06
48 KSP Residual norm 2.467293755017e-06
49 KSP Residual norm 2.392250679557e-06
50 KSP Residual norm 2.326293919373e-06
51 KSP Residual norm 2.265610587219e-06
52 KSP Residual norm 2.216094165634e-06
53 KSP Residual norm 2.208232192598e-06
54 KSP Residual norm 2.279045128367e-06
55 KSP Residual norm 2.306114053387e-06
56 KSP Residual norm 2.222171830666e-06
57 KSP Residual norm 2.214437787649e-06
58 KSP Residual norm 2.278198382843e-06
59 KSP Residual norm 2.386011187633e-06
60 KSP Residual norm 2.521311177146e-06
61 KSP Residual norm 2.637767913718e-06
62 KSP Residual norm 2.692324070372e-06
63 KSP Residual norm 2.724684780872e-06
64 KSP Residual norm 2.766262227173e-06
65 KSP Residual norm 2.816430163434e-06
66 KSP Residual norm 2.853311857826e-06
67 KSP Residual norm 2.829125444629e-06
68 KSP Residual norm 2.752789448150e-06
69 KSP Residual norm 2.658799456502e-06
70 KSP Residual norm 2.541008279504e-06
71 KSP Residual norm 2.407847632672e-06
72 KSP Residual norm 2.287905120213e-06
73 KSP Residual norm 2.175507614623e-06
74 KSP Residual norm 2.059293086629e-06
75 KSP Residual norm 1.964242794145e-06
76 KSP Residual norm 1.885041057850e-06
77 KSP Residual norm 1.785968037746e-06
78 KSP Residual norm 1.666716717604e-06
79 KSP Residual norm 1.556472259595e-06
80 KSP Residual norm 1.462848347963e-06
81 KSP Residual norm 1.384556871729e-06
82 KSP Residual norm 1.304451436153e-06
83 KSP Residual norm 1.221546514130e-06
84 KSP Residual norm 1.144741422282e-06
85 KSP Residual norm 1.085260431400e-06
86 KSP Residual norm 1.026501503312e-06
87 KSP Residual norm 9.508245173403e-07
88 KSP Residual norm 8.801636632567e-07
89 KSP Residual norm 8.247167029907e-07
90 KSP Residual norm 7.747102059990e-07
91 KSP Residual norm 7.197430118305e-07
92 KSP Residual norm 6.723142821000e-07
93 KSP Residual norm 6.356018657477e-07
94 KSP Residual norm 6.052924202341e-07
95 KSP Residual norm 5.824208192384e-07
96 KSP Residual norm 5.592860436578e-07
97 KSP Residual norm 5.360643776474e-07
98 KSP Residual norm 5.148378548891e-07
99 KSP Residual norm 4.945104725316e-07
100 KSP Residual norm 4.770023431310e-07
101 KSP Residual norm 4.531288290036e-07
102 KSP Residual norm 4.299983281194e-07
103 KSP Residual norm 4.101913169868e-07
104 KSP Residual norm 3.972676568088e-07
105 KSP Residual norm 3.893397658064e-07
106 KSP Residual norm 3.643557149259e-07
107 KSP Residual norm 3.344134512934e-07
108 KSP Residual norm 3.103628376273e-07
109 KSP Residual norm 2.866486422159e-07
110 KSP Residual norm 2.652276921273e-07
111 KSP Residual norm 2.451140846784e-07
112 KSP Residual norm 2.271850665918e-07
113 KSP Residual norm 2.121948842363e-07
114 KSP Residual norm 1.998846929641e-07
115 KSP Residual norm 1.891436167580e-07
116 KSP Residual norm 1.793631691659e-07
117 KSP Residual norm 1.706541100437e-07
118 KSP Residual norm 1.651156859417e-07
119 KSP Residual norm 1.630082060730e-07
120 KSP Residual norm 1.608764303774e-07
121 KSP Residual norm 1.546882799654e-07
122 KSP Residual norm 1.470018165687e-07
123 KSP Residual norm 1.407121232204e-07
124 KSP Residual norm 1.355543631204e-07
125 KSP Residual norm 1.306641752361e-07
126 KSP Residual norm 1.252291103668e-07
127 KSP Residual norm 1.180346899208e-07
128 KSP Residual norm 1.101312523213e-07
129 KSP Residual norm 1.031221119601e-07
130 KSP Residual norm 9.796194204799e-08
131 KSP Residual norm 9.361775587046e-08
132 KSP Residual norm 8.682912170912e-08
133 KSP Residual norm 7.962277224322e-08
134 KSP Residual norm 7.423226416993e-08
135 KSP Residual norm 7.024166913207e-08
136 KSP Residual norm 6.714803043371e-08
137 KSP Residual norm 6.444456845147e-08
138 KSP Residual norm 6.180272674425e-08
139 KSP Residual norm 5.920258693764e-08
140 KSP Residual norm 5.695970970615e-08
141 KSP Residual norm 5.534309246596e-08
142 KSP Residual norm 5.418658191336e-08
143 KSP Residual norm 5.317290252995e-08
144 KSP Residual norm 5.204101032048e-08
145 KSP Residual norm 5.111276911716e-08
146 KSP Residual norm 5.027374488891e-08
147 KSP Residual norm 4.945157279532e-08
148 KSP Residual norm 4.849772439882e-08
149 KSP Residual norm 4.727559517530e-08
150 KSP Residual norm 4.569027414422e-08
151 KSP Residual norm 4.414549176550e-08
152 KSP Residual norm 4.263605212776e-08
153 KSP Residual norm 4.068531941302e-08
154 KSP Residual norm 3.873746063425e-08
155 KSP Residual norm 3.764236171710e-08
156 KSP Residual norm 3.757557014909e-08
157 KSP Residual norm 3.706676579542e-08
158 KSP Residual norm 3.538974010737e-08
159 KSP Residual norm 3.438343389988e-08
160 KSP Residual norm 3.408152039831e-08
161 KSP Residual norm 3.339309328571e-08
162 KSP Residual norm 3.235448636124e-08
163 KSP Residual norm 3.158493378498e-08
164 KSP Residual norm 3.108000240650e-08
165 KSP Residual norm 3.061524926275e-08
166 KSP Residual norm 3.004716995933e-08
167 KSP Residual norm 2.933476659719e-08
168 KSP Residual norm 2.849120617342e-08
169 KSP Residual norm 2.762412079669e-08
170 KSP Residual norm 2.678558571853e-08
171 KSP Residual norm 2.589958143544e-08
172 KSP Residual norm 2.497004056709e-08
173 KSP Residual norm 2.404746767155e-08
174 KSP Residual norm 2.320630218765e-08
175 KSP Residual norm 2.249284883623e-08
176 KSP Residual norm 2.184043575595e-08
177 KSP Residual norm 2.119190407955e-08
178 KSP Residual norm 2.055517078468e-08
179 KSP Residual norm 1.992006145709e-08
180 KSP Residual norm 1.923462416777e-08
181 KSP Residual norm 1.852645403623e-08
182 KSP Residual norm 1.788013141684e-08
183 KSP Residual norm 1.725653909203e-08
184 KSP Residual norm 1.662600253560e-08
185 KSP Residual norm 1.605941777735e-08
186 KSP Residual norm 1.560222225050e-08
187 KSP Residual norm 1.523942568643e-08
188 KSP Residual norm 1.479966629716e-08
189 KSP Residual norm 1.427559659611e-08
190 KSP Residual norm 1.379226135110e-08
191 KSP Residual norm 1.335657538119e-08
192 KSP Residual norm 1.295187400451e-08
193 KSP Residual norm 1.253744847110e-08
194 KSP Residual norm 1.214435032867e-08
195 KSP Residual norm 1.177018141158e-08
196 KSP Residual norm 1.143459508620e-08
197 KSP Residual norm 1.116562059571e-08
198 KSP Residual norm 1.099846699623e-08
199 KSP Residual norm 1.091204359814e-08
200 KSP Residual norm 1.067502789520e-08
201 KSP Residual norm 1.022851611882e-08
202 KSP Residual norm 9.812636304276e-09
203 KSP Residual norm 9.509356603734e-09
204 KSP Residual norm 9.259334297431e-09
205 KSP Residual norm 9.092126305345e-09
206 KSP Residual norm 9.069541747029e-09
207 KSP Residual norm 9.212925647429e-09
208 KSP Residual norm 9.008917291812e-09
209 KSP Residual norm 8.512139967697e-09
210 KSP Residual norm 8.181328361649e-09
211 KSP Residual norm 7.949642143434e-09
212 KSP Residual norm 7.745118852506e-09
213 KSP Residual norm 7.562272544586e-09
214 KSP Residual norm 7.396894256577e-09
215 KSP Residual norm 7.243439831181e-09
216 KSP Residual norm 7.092526173503e-09
217 KSP Residual norm 6.932362666085e-09
218 KSP Residual norm 6.723989449384e-09
219 KSP Residual norm 6.487208125166e-09
220 KSP Residual norm 6.252580855487e-09
221 KSP Residual norm 6.062277793552e-09
222 KSP Residual norm 5.904812647222e-09
223 KSP Residual norm 5.762720828346e-09
224 KSP Residual norm 5.615969823888e-09
225 KSP Residual norm 5.476217125993e-09
226 KSP Residual norm 5.325792212368e-09
227 KSP Residual norm 5.162661473744e-09
228 KSP Residual norm 5.005359395157e-09
229 KSP Residual norm 4.864597817327e-09
230 KSP Residual norm 4.716379220038e-09
231 KSP Residual norm 4.564842549359e-09
232 KSP Residual norm 4.414884442206e-09
233 KSP Residual norm 4.271342906674e-09
234 KSP Residual norm 4.125028372629e-09
235 KSP Residual norm 3.998623943879e-09
236 KSP Residual norm 3.904037868696e-09
237 KSP Residual norm 3.778562160882e-09
238 KSP Residual norm 3.596267464887e-09
239 KSP Residual norm 3.432848920564e-09
240 KSP Residual norm 3.296390693941e-09
241 KSP Residual norm 3.187711266877e-09
242 KSP Residual norm 3.097701989111e-09
243 KSP Residual norm 3.029556210330e-09
244 KSP Residual norm 2.993441962887e-09
245 KSP Residual norm 2.979879159956e-09
246 KSP Residual norm 2.946012464681e-09
247 KSP Residual norm 2.861029561118e-09
248 KSP Residual norm 2.766982281895e-09
249 KSP Residual norm 2.686121188939e-09
250 KSP Residual norm 2.619084118293e-09
251 KSP Residual norm 2.562539581169e-09
252 KSP Residual norm 2.511119495458e-09
253 KSP Residual norm 2.471822039507e-09
254 KSP Residual norm 2.442996764035e-09
255 KSP Residual norm 2.393280928022e-09
256 KSP Residual norm 2.326872525797e-09
257 KSP Residual norm 2.273042747707e-09
258 KSP Residual norm 2.184678545879e-09
259 KSP Residual norm 2.082901888379e-09
260 KSP Residual norm 2.009446366927e-09
261 KSP Residual norm 1.951113196366e-09
262 KSP Residual norm 1.886176120047e-09
263 KSP Residual norm 1.824563973928e-09
264 KSP Residual norm 1.769822568229e-09
265 KSP Residual norm 1.715830450317e-09
266 KSP Residual norm 1.671807726711e-09
267 KSP Residual norm 1.633322466893e-09
268 KSP Residual norm 1.601328534357e-09
269 KSP Residual norm 1.570587531019e-09
270 KSP Residual norm 1.543819927354e-09
271 KSP Residual norm 1.513272913020e-09
272 KSP Residual norm 1.475351960148e-09
273 KSP Residual norm 1.434438114529e-09
274 KSP Residual norm 1.395323378473e-09
275 KSP Residual norm 1.352004534646e-09
276 KSP Residual norm 1.299139387865e-09
277 KSP Residual norm 1.243119257394e-09
278 KSP Residual norm 1.193470911306e-09
279 KSP Residual norm 1.159120849637e-09
280 KSP Residual norm 1.124202871916e-09
281 KSP Residual norm 1.071359566398e-09
282 KSP Residual norm 1.021789740606e-09
283 KSP Residual norm 9.885345177026e-10
284 KSP Residual norm 9.626930827252e-10
285 KSP Residual norm 9.260619383610e-10
286 KSP Residual norm 8.840156833035e-10
287 KSP Residual norm 8.483531514083e-10
288 KSP Residual norm 8.175730947290e-10
289 KSP Residual norm 7.865670370059e-10
290 KSP Residual norm 7.613913348062e-10
291 KSP Residual norm 7.379176037873e-10
292 KSP Residual norm 7.118292194805e-10
293 KSP Residual norm 6.818621052428e-10
294 KSP Residual norm 6.534669243713e-10
295 KSP Residual norm 6.306185776897e-10
296 KSP Residual norm 6.084483154673e-10
297 KSP Residual norm 5.870520122425e-10
298 KSP Residual norm 5.678470295369e-10
299 KSP Residual norm 5.539645222731e-10
300 KSP Residual norm 5.434771704068e-10
301 KSP Residual norm 5.278161954278e-10
302 KSP Residual norm 5.044729569925e-10
303 KSP Residual norm 4.816170616598e-10
304 KSP Residual norm 4.644944205772e-10
305 KSP Residual norm 4.498665003092e-10
306 KSP Residual norm 4.380983274797e-10
307 KSP Residual norm 4.345677066269e-10
308 KSP Residual norm 4.303572236437e-10
309 KSP Residual norm 4.063944493103e-10
310 KSP Residual norm 3.822632656023e-10
311 KSP Residual norm 3.675943124794e-10
312 KSP Residual norm 3.580323001068e-10
313 KSP Residual norm 3.527457095350e-10
314 KSP Residual norm 3.463933439564e-10
315 KSP Residual norm 3.351618292447e-10
316 KSP Residual norm 3.256988977902e-10
317 KSP Residual norm 3.187664249554e-10
318 KSP Residual norm 3.115074856224e-10
319 KSP Residual norm 3.031471996680e-10
320 KSP Residual norm 2.954043092552e-10
321 KSP Residual norm 2.884532656632e-10
322 KSP Residual norm 2.813306651267e-10
323 KSP Residual norm 2.743551347016e-10
324 KSP Residual norm 2.664802522962e-10
325 KSP Residual norm 2.584787056522e-10
326 KSP Residual norm 2.507561770121e-10
327 KSP Residual norm 2.431765930374e-10
328 KSP Residual norm 2.364397365038e-10
329 KSP Residual norm 2.308914789943e-10
330 KSP Residual norm 2.252407101438e-10
331 KSP Residual norm 2.196557789848e-10
332 KSP Residual norm 2.133097768070e-10
333 KSP Residual norm 2.064590219585e-10
334 KSP Residual norm 2.009944761397e-10
335 KSP Residual norm 1.962064999765e-10
336 KSP Residual norm 1.908767568835e-10
337 KSP Residual norm 1.848495369168e-10
338 KSP Residual norm 1.795289441155e-10
339 KSP Residual norm 1.745835846470e-10
340 KSP Residual norm 1.706578015852e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 340
1 LS Function value: 0.0691388, Step length: 1.
stx: 0., fx: 0.0691389, dgx: -6.05376e-09
sty: 0., fy: 0.0691389, dgy: -6.05376e-09
41 TAO, Function value: 0.0691388, Residual: 2.22711e-05
Residual norms for tao_nls_ solve.
0 KSP Residual norm 2.227112186456e-05
1 KSP Residual norm 1.758285725655e-05
2 KSP Residual norm 1.206416220112e-05
3 KSP Residual norm 9.158817976392e-06
4 KSP Residual norm 6.775236331092e-06
5 KSP Residual norm 5.385351604914e-06
6 KSP Residual norm 4.491881687527e-06
7 KSP Residual norm 3.901386673346e-06
8 KSP Residual norm 3.441404442652e-06
9 KSP Residual norm 3.156136115249e-06
10 KSP Residual norm 3.002620664766e-06
11 KSP Residual norm 2.864358860847e-06
12 KSP Residual norm 2.765321930276e-06
13 KSP Residual norm 2.697360576616e-06
14 KSP Residual norm 2.668106607983e-06
15 KSP Residual norm 2.673256198371e-06
16 KSP Residual norm 2.724828401905e-06
17 KSP Residual norm 2.820141246499e-06
18 KSP Residual norm 2.936153861277e-06
19 KSP Residual norm 3.065756634611e-06
20 KSP Residual norm 3.201673782661e-06
21 KSP Residual norm 3.343963084798e-06
22 KSP Residual norm 3.469443922102e-06
23 KSP Residual norm 3.576208535562e-06
24 KSP Residual norm 3.680960569832e-06
25 KSP Residual norm 3.794964927086e-06
26 KSP Residual norm 3.907398163554e-06
27 KSP Residual norm 3.998782167180e-06
28 KSP Residual norm 4.072728948740e-06
29 KSP Residual norm 4.118169005655e-06
30 KSP Residual norm 4.143891075252e-06
31 KSP Residual norm 4.172919434706e-06
32 KSP Residual norm 4.188931477255e-06
33 KSP Residual norm 4.168614253022e-06
34 KSP Residual norm 4.115343569030e-06
35 KSP Residual norm 4.030355233212e-06
36 KSP Residual norm 3.891297790759e-06
37 KSP Residual norm 3.698476287399e-06
38 KSP Residual norm 3.480060033634e-06
39 KSP Residual norm 3.256045778207e-06
40 KSP Residual norm 3.051932174571e-06
41 KSP Residual norm 2.895205768171e-06
42 KSP Residual norm 2.716449528320e-06
43 KSP Residual norm 2.455258418863e-06
44 KSP Residual norm 2.225060165351e-06
45 KSP Residual norm 2.046004604515e-06
46 KSP Residual norm 1.893097634198e-06
47 KSP Residual norm 1.755039846044e-06
48 KSP Residual norm 1.631727801695e-06
49 KSP Residual norm 1.528590505802e-06
50 KSP Residual norm 1.456741901942e-06
51 KSP Residual norm 1.428226254866e-06
52 KSP Residual norm 1.377536954862e-06
53 KSP Residual norm 1.266343181189e-06
54 KSP Residual norm 1.174364795256e-06
55 KSP Residual norm 1.106625810571e-06
56 KSP Residual norm 1.052219818064e-06
57 KSP Residual norm 1.009907142779e-06
58 KSP Residual norm 9.794246617419e-07
59 KSP Residual norm 9.598621638180e-07
60 KSP Residual norm 9.483513890699e-07
61 KSP Residual norm 9.462703525756e-07
62 KSP Residual norm 9.551218102116e-07
63 KSP Residual norm 9.627803834554e-07
64 KSP Residual norm 9.536416413329e-07
65 KSP Residual norm 9.360722154760e-07
66 KSP Residual norm 9.173231576286e-07
67 KSP Residual norm 8.944364645710e-07
68 KSP Residual norm 8.731090027701e-07
69 KSP Residual norm 8.585085187799e-07
70 KSP Residual norm 8.453841719710e-07
71 KSP Residual norm 8.260580974979e-07
72 KSP Residual norm 7.971534869201e-07
73 KSP Residual norm 7.581949188063e-07
74 KSP Residual norm 7.140024435922e-07
75 KSP Residual norm 6.731207625809e-07
76 KSP Residual norm 6.336888289063e-07
77 KSP Residual norm 5.952590794603e-07
78 KSP Residual norm 5.645593333436e-07
79 KSP Residual norm 5.347433880319e-07
80 KSP Residual norm 5.060225392952e-07
81 KSP Residual norm 4.832020564289e-07
82 KSP Residual norm 4.602365060866e-07
83 KSP Residual norm 4.328835298711e-07
84 KSP Residual norm 4.052441716010e-07
85 KSP Residual norm 3.857472006944e-07
86 KSP Residual norm 3.720463152550e-07
87 KSP Residual norm 3.574289958291e-07
88 KSP Residual norm 3.410642516556e-07
89 KSP Residual norm 3.263734857899e-07
90 KSP Residual norm 3.158516338311e-07
91 KSP Residual norm 3.061575583085e-07
92 KSP Residual norm 2.988783653188e-07
93 KSP Residual norm 2.936078960902e-07
94 KSP Residual norm 2.913901137543e-07
95 KSP Residual norm 2.939114374982e-07
96 KSP Residual norm 2.985724685512e-07
97 KSP Residual norm 2.987296876518e-07
98 KSP Residual norm 2.929923803065e-07
99 KSP Residual norm 2.875424629412e-07
100 KSP Residual norm 2.869324751220e-07
101 KSP Residual norm 2.859236778319e-07
102 KSP Residual norm 2.821100542975e-07
103 KSP Residual norm 2.768560752284e-07
104 KSP Residual norm 2.705891842016e-07
105 KSP Residual norm 2.651995373355e-07
106 KSP Residual norm 2.593649698582e-07
107 KSP Residual norm 2.532854523247e-07
108 KSP Residual norm 2.465075331779e-07
109 KSP Residual norm 2.357188881127e-07
110 KSP Residual norm 2.239304674120e-07
111 KSP Residual norm 2.116456515500e-07
112 KSP Residual norm 1.997819606952e-07
113 KSP Residual norm 1.884601545443e-07
114 KSP Residual norm 1.768165782634e-07
115 KSP Residual norm 1.641549674704e-07
116 KSP Residual norm 1.518308288484e-07
117 KSP Residual norm 1.407860457492e-07
118 KSP Residual norm 1.323946510351e-07
119 KSP Residual norm 1.263340452014e-07
120 KSP Residual norm 1.203548952917e-07
121 KSP Residual norm 1.128944478936e-07
122 KSP Residual norm 1.059616198783e-07
123 KSP Residual norm 9.988628201079e-08
124 KSP Residual norm 9.330131630668e-08
125 KSP Residual norm 8.637261379132e-08
126 KSP Residual norm 8.017138893190e-08
127 KSP Residual norm 7.456508271334e-08
128 KSP Residual norm 6.967271313953e-08
129 KSP Residual norm 6.534666444331e-08
130 KSP Residual norm 6.130524753878e-08
131 KSP Residual norm 5.724645621671e-08
132 KSP Residual norm 5.283716141276e-08
133 KSP Residual norm 4.862557367604e-08
134 KSP Residual norm 4.509046864444e-08
135 KSP Residual norm 4.219171181052e-08
136 KSP Residual norm 3.957295969656e-08
137 KSP Residual norm 3.704783342357e-08
138 KSP Residual norm 3.462107402644e-08
139 KSP Residual norm 3.217363621724e-08
140 KSP Residual norm 2.988679707982e-08
141 KSP Residual norm 2.803857766192e-08
142 KSP Residual norm 2.654088651210e-08
143 KSP Residual norm 2.517907087893e-08
144 KSP Residual norm 2.394167972165e-08
145 KSP Residual norm 2.304546452217e-08
146 KSP Residual norm 2.237719706295e-08
147 KSP Residual norm 2.174004368337e-08
148 KSP Residual norm 2.098648802175e-08
149 KSP Residual norm 2.016745839698e-08
150 KSP Residual norm 1.939937780576e-08
151 KSP Residual norm 1.865459064501e-08
152 KSP Residual norm 1.782316456990e-08
153 KSP Residual norm 1.699177193544e-08
154 KSP Residual norm 1.621772419844e-08
155 KSP Residual norm 1.557314357257e-08
156 KSP Residual norm 1.502805571544e-08
157 KSP Residual norm 1.453688210040e-08
158 KSP Residual norm 1.408304736061e-08
159 KSP Residual norm 1.365695603548e-08
160 KSP Residual norm 1.324514913528e-08
161 KSP Residual norm 1.283389751093e-08
162 KSP Residual norm 1.243332025133e-08
163 KSP Residual norm 1.209321964806e-08
164 KSP Residual norm 1.183088729459e-08
165 KSP Residual norm 1.162581102259e-08
166 KSP Residual norm 1.142807420178e-08
167 KSP Residual norm 1.114066839292e-08
168 KSP Residual norm 1.075230862796e-08
169 KSP Residual norm 1.040422359770e-08
170 KSP Residual norm 1.014942531086e-08
171 KSP Residual norm 9.954022209454e-09
172 KSP Residual norm 9.832995034909e-09
173 KSP Residual norm 9.761504167180e-09
174 KSP Residual norm 9.671345151208e-09
175 KSP Residual norm 9.540448369473e-09
176 KSP Residual norm 9.398955708564e-09
177 KSP Residual norm 9.319129743529e-09
178 KSP Residual norm 9.289530173190e-09
179 KSP Residual norm 9.243409882063e-09
180 KSP Residual norm 9.151797698558e-09
181 KSP Residual norm 9.044434229181e-09
182 KSP Residual norm 8.952852806960e-09
183 KSP Residual norm 8.851952077376e-09
184 KSP Residual norm 8.710015458635e-09
185 KSP Residual norm 8.521434799882e-09
186 KSP Residual norm 8.305599363801e-09
187 KSP Residual norm 8.124979353143e-09
188 KSP Residual norm 8.019864579837e-09
189 KSP Residual norm 8.056557270691e-09
190 KSP Residual norm 8.097009591275e-09
191 KSP Residual norm 7.858009591646e-09
192 KSP Residual norm 7.592106842000e-09
193 KSP Residual norm 7.405235935704e-09
194 KSP Residual norm 7.307736389905e-09
195 KSP Residual norm 7.283074659402e-09
196 KSP Residual norm 7.209530002302e-09
197 KSP Residual norm 6.971034133241e-09
198 KSP Residual norm 6.715402258452e-09
199 KSP Residual norm 6.534883218229e-09
200 KSP Residual norm 6.407025856999e-09
201 KSP Residual norm 6.336625675947e-09
202 KSP Residual norm 6.261463732648e-09
203 KSP Residual norm 6.060117743311e-09
204 KSP Residual norm 5.765853401760e-09
205 KSP Residual norm 5.485814744119e-09
206 KSP Residual norm 5.239748429286e-09
207 KSP Residual norm 5.017658759868e-09
208 KSP Residual norm 4.796757356203e-09
209 KSP Residual norm 4.587011979211e-09
210 KSP Residual norm 4.388293986108e-09
211 KSP Residual norm 4.194275837300e-09
212 KSP Residual norm 4.006737045820e-09
213 KSP Residual norm 3.834626812321e-09
214 KSP Residual norm 3.681263516305e-09
215 KSP Residual norm 3.547937252931e-09
216 KSP Residual norm 3.433171093683e-09
217 KSP Residual norm 3.338443565329e-09
218 KSP Residual norm 3.241687508869e-09
219 KSP Residual norm 3.128946689059e-09
220 KSP Residual norm 3.004247904944e-09
221 KSP Residual norm 2.901970244821e-09
222 KSP Residual norm 2.825527487783e-09
223 KSP Residual norm 2.751972163110e-09
224 KSP Residual norm 2.651247349629e-09
225 KSP Residual norm 2.543774178581e-09
226 KSP Residual norm 2.444120301395e-09
227 KSP Residual norm 2.347868635544e-09
228 KSP Residual norm 2.254901453641e-09
229 KSP Residual norm 2.172517605661e-09
230 KSP Residual norm 2.093764129305e-09
231 KSP Residual norm 2.020899129224e-09
232 KSP Residual norm 1.964135445661e-09
233 KSP Residual norm 1.939493373728e-09
234 KSP Residual norm 1.907533099767e-09
235 KSP Residual norm 1.830700441668e-09
236 KSP Residual norm 1.765577231800e-09
237 KSP Residual norm 1.757064677992e-09
238 KSP Residual norm 1.741901834539e-09
239 KSP Residual norm 1.650455310602e-09
240 KSP Residual norm 1.563503768047e-09
241 KSP Residual norm 1.504762112591e-09
242 KSP Residual norm 1.456702215498e-09
243 KSP Residual norm 1.416030475428e-09
244 KSP Residual norm 1.392932771294e-09
245 KSP Residual norm 1.384562032682e-09
246 KSP Residual norm 1.347760088223e-09
247 KSP Residual norm 1.279857006362e-09
248 KSP Residual norm 1.223883507927e-09
249 KSP Residual norm 1.183169785901e-09
250 KSP Residual norm 1.152559791915e-09
251 KSP Residual norm 1.131591714517e-09
252 KSP Residual norm 1.112194821964e-09
253 KSP Residual norm 1.081982411879e-09
254 KSP Residual norm 1.047662566657e-09
255 KSP Residual norm 1.020240576623e-09
256 KSP Residual norm 9.922479363765e-10
257 KSP Residual norm 9.602961074472e-10
258 KSP Residual norm 9.305308638136e-10
259 KSP Residual norm 9.102172403116e-10
260 KSP Residual norm 8.936459327534e-10
261 KSP Residual norm 8.723421388674e-10
262 KSP Residual norm 8.422074543886e-10
263 KSP Residual norm 8.116763248415e-10
264 KSP Residual norm 7.828270939363e-10
265 KSP Residual norm 7.539742094911e-10
266 KSP Residual norm 7.281771338702e-10
267 KSP Residual norm 7.037199500323e-10
268 KSP Residual norm 6.823830025041e-10
269 KSP Residual norm 6.627405663277e-10
270 KSP Residual norm 6.466151726455e-10
271 KSP Residual norm 6.310209520136e-10
272 KSP Residual norm 6.148871571668e-10
273 KSP Residual norm 5.999376638652e-10
274 KSP Residual norm 5.861318259061e-10
275 KSP Residual norm 5.741834737114e-10
276 KSP Residual norm 5.686112901196e-10
277 KSP Residual norm 5.654995492580e-10
278 KSP Residual norm 5.485709078557e-10
279 KSP Residual norm 5.245761917163e-10
280 KSP Residual norm 5.048322264938e-10
281 KSP Residual norm 4.890067342030e-10
282 KSP Residual norm 4.754532053101e-10
283 KSP Residual norm 4.640634645588e-10
284 KSP Residual norm 4.575900554931e-10
285 KSP Residual norm 4.595866205505e-10
286 KSP Residual norm 4.495965892199e-10
287 KSP Residual norm 4.232545675397e-10
288 KSP Residual norm 4.036609509847e-10
289 KSP Residual norm 3.884588893249e-10
290 KSP Residual norm 3.755771171024e-10
291 KSP Residual norm 3.640046883608e-10
292 KSP Residual norm 3.522419817713e-10
293 KSP Residual norm 3.394474320330e-10
294 KSP Residual norm 3.277961212513e-10
295 KSP Residual norm 3.200973030211e-10
296 KSP Residual norm 3.138018220043e-10
297 KSP Residual norm 3.041114054105e-10
298 KSP Residual norm 2.909329194691e-10
299 KSP Residual norm 2.804080160059e-10
300 KSP Residual norm 2.711850046286e-10
301 KSP Residual norm 2.633592935991e-10
302 KSP Residual norm 2.557809179371e-10
303 KSP Residual norm 2.485603866968e-10
304 KSP Residual norm 2.421804884608e-10
305 KSP Residual norm 2.354996014027e-10
306 KSP Residual norm 2.287449294454e-10
307 KSP Residual norm 2.221477743293e-10
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 307
0 LS Function value: 0.0691388, Step length: 0.
stx: 0., fx: 0.0691388, dgx: -1.60069e-09
sty: 0., fy: 0.0691388, dgy: -1.60069e-09
42 TAO, Function value: 0.0691388, Residual: 2.12559e-06
0 KSP Residual norm 2.125587305991e-06
1 KSP Residual norm 1.842111664435e-06
2 KSP Residual norm 1.297688459386e-06
3 KSP Residual norm 1.077501023608e-06
4 KSP Residual norm 9.129975292545e-07
5 KSP Residual norm 8.557585626815e-07
6 KSP Residual norm 8.745965528233e-07
7 KSP Residual norm 9.098670227820e-07
8 KSP Residual norm 9.604530404050e-07
9 KSP Residual norm 1.052176172959e-06
10 KSP Residual norm 1.155994618727e-06
11 KSP Residual norm 1.245378109797e-06
12 KSP Residual norm 1.357774719157e-06
13 KSP Residual norm 1.478302923318e-06
14 KSP Residual norm 1.596772116071e-06
15 KSP Residual norm 1.729424132883e-06
16 KSP Residual norm 1.870649495246e-06
17 KSP Residual norm 2.011296639429e-06
18 KSP Residual norm 2.111264727884e-06
19 KSP Residual norm 2.200473098952e-06
20 KSP Residual norm 2.290647930688e-06
21 KSP Residual norm 2.360293143481e-06
22 KSP Residual norm 2.397501314590e-06
23 KSP Residual norm 2.405247215932e-06
24 KSP Residual norm 2.410341154694e-06
25 KSP Residual norm 2.380241944090e-06
26 KSP Residual norm 2.318530843227e-06
27 KSP Residual norm 2.242418842763e-06
28 KSP Residual norm 2.152468900671e-06
29 KSP Residual norm 2.043630313282e-06
30 KSP Residual norm 1.916402817980e-06
31 KSP Residual norm 1.784626074908e-06
32 KSP Residual norm 1.647406455193e-06
33 KSP Residual norm 1.508849247270e-06
34 KSP Residual norm 1.374792800288e-06
35 KSP Residual norm 1.250758364929e-06
36 KSP Residual norm 1.134548855577e-06
37 KSP Residual norm 1.023677125758e-06
38 KSP Residual norm 9.208774659484e-07
39 KSP Residual norm 8.298940385483e-07
40 KSP Residual norm 7.527684397370e-07
41 KSP Residual norm 6.887408016624e-07
42 KSP Residual norm 6.347003613865e-07
43 KSP Residual norm 5.891348404372e-07
44 KSP Residual norm 5.541072794032e-07
45 KSP Residual norm 5.323917222434e-07
46 KSP Residual norm 5.198164249344e-07
47 KSP Residual norm 5.007454339332e-07
48 KSP Residual norm 4.761615103744e-07
49 KSP Residual norm 4.587073260808e-07
50 KSP Residual norm 4.475244883284e-07
51 KSP Residual norm 4.403223887021e-07
52 KSP Residual norm 4.377649708311e-07
53 KSP Residual norm 4.371351194506e-07
54 KSP Residual norm 4.337504223436e-07
55 KSP Residual norm 4.323952298884e-07
56 KSP Residual norm 4.384355657753e-07
57 KSP Residual norm 4.473594869194e-07
58 KSP Residual norm 4.520344930793e-07
59 KSP Residual norm 4.545719480154e-07
60 KSP Residual norm 4.601672697984e-07
61 KSP Residual norm 4.704593041749e-07
62 KSP Residual norm 4.840479942604e-07
63 KSP Residual norm 4.955780317755e-07
64 KSP Residual norm 4.995043799936e-07
65 KSP Residual norm 4.942387104003e-07
66 KSP Residual norm 4.836009268230e-07
67 KSP Residual norm 4.681966566003e-07
68 KSP Residual norm 4.502657260737e-07
69 KSP Residual norm 4.320073326978e-07
70 KSP Residual norm 4.113636342500e-07
71 KSP Residual norm 3.897768434647e-07
72 KSP Residual norm 3.724704391061e-07
73 KSP Residual norm 3.574795594835e-07
74 KSP Residual norm 3.380486309426e-07
75 KSP Residual norm 3.169463312477e-07
76 KSP Residual norm 2.980205760026e-07
77 KSP Residual norm 2.809430420484e-07
78 KSP Residual norm 2.669937295205e-07
79 KSP Residual norm 2.534000483777e-07
80 KSP Residual norm 2.416276188062e-07
81 KSP Residual norm 2.330694854274e-07
82 KSP Residual norm 2.247906908886e-07
83 KSP Residual norm 2.150122562449e-07
84 KSP Residual norm 2.027227644729e-07
85 KSP Residual norm 1.897266454865e-07
86 KSP Residual norm 1.773872023671e-07
87 KSP Residual norm 1.649339718417e-07
88 KSP Residual norm 1.542258090852e-07
89 KSP Residual norm 1.452160177262e-07
90 KSP Residual norm 1.364223645248e-07
91 KSP Residual norm 1.277032969845e-07
92 KSP Residual norm 1.203632801110e-07
93 KSP Residual norm 1.140753253416e-07
94 KSP Residual norm 1.082818582844e-07
95 KSP Residual norm 1.035247517527e-07
96 KSP Residual norm 9.961086220192e-08
97 KSP Residual norm 9.685945818358e-08
98 KSP Residual norm 9.496918417083e-08
99 KSP Residual norm 9.344714482031e-08
100 KSP Residual norm 9.202382550188e-08
101 KSP Residual norm 9.021493407018e-08
102 KSP Residual norm 8.892541946558e-08
103 KSP Residual norm 8.743609441247e-08
104 KSP Residual norm 8.673510434491e-08
105 KSP Residual norm 8.514556544762e-08
106 KSP Residual norm 8.168124791866e-08
107 KSP Residual norm 7.673082384211e-08
108 KSP Residual norm 7.154644083946e-08
109 KSP Residual norm 6.701041671476e-08
110 KSP Residual norm 6.308430489266e-08
111 KSP Residual norm 5.914220113278e-08
112 KSP Residual norm 5.497581666691e-08
113 KSP Residual norm 5.090126478915e-08
114 KSP Residual norm 4.746756998492e-08
115 KSP Residual norm 4.456810747146e-08
116 KSP Residual norm 4.165738717289e-08
117 KSP Residual norm 3.872274961513e-08
118 KSP Residual norm 3.638319681651e-08
119 KSP Residual norm 3.455538362131e-08
120 KSP Residual norm 3.295275182282e-08
121 KSP Residual norm 3.132761115844e-08
122 KSP Residual norm 2.974680242531e-08
123 KSP Residual norm 2.823799216800e-08
124 KSP Residual norm 2.690616928403e-08
125 KSP Residual norm 2.565205961960e-08
126 KSP Residual norm 2.437710865538e-08
127 KSP Residual norm 2.305117300420e-08
128 KSP Residual norm 2.166603592572e-08
129 KSP Residual norm 2.030625967689e-08
130 KSP Residual norm 1.901234933316e-08
131 KSP Residual norm 1.786641636673e-08
132 KSP Residual norm 1.668575532497e-08
133 KSP Residual norm 1.540164147541e-08
134 KSP Residual norm 1.421020782945e-08
135 KSP Residual norm 1.316691396032e-08
136 KSP Residual norm 1.222149503344e-08
137 KSP Residual norm 1.140998630942e-08
138 KSP Residual norm 1.076673264046e-08
139 KSP Residual norm 1.033065364265e-08
140 KSP Residual norm 1.003308708260e-08
141 KSP Residual norm 9.672840139025e-09
142 KSP Residual norm 9.315371038461e-09
143 KSP Residual norm 9.085424378714e-09
144 KSP Residual norm 8.799778443663e-09
145 KSP Residual norm 8.480826938230e-09
146 KSP Residual norm 8.242771715419e-09
147 KSP Residual norm 8.101639936352e-09
148 KSP Residual norm 8.085245895629e-09
149 KSP Residual norm 8.150788068337e-09
150 KSP Residual norm 8.008697945689e-09
151 KSP Residual norm 7.754429202503e-09
152 KSP Residual norm 7.597518212556e-09
153 KSP Residual norm 7.530957842044e-09
154 KSP Residual norm 7.505785100761e-09
155 KSP Residual norm 7.418387657863e-09
156 KSP Residual norm 7.261769074920e-09
157 KSP Residual norm 7.197304365609e-09
158 KSP Residual norm 7.325376685595e-09
159 KSP Residual norm 7.566114784186e-09
160 KSP Residual norm 7.413089755747e-09
161 KSP Residual norm 7.158149776501e-09
162 KSP Residual norm 7.078182129015e-09
163 KSP Residual norm 7.062740978358e-09
164 KSP Residual norm 7.021590829924e-09
165 KSP Residual norm 6.957313851361e-09
166 KSP Residual norm 6.890685025062e-09
167 KSP Residual norm 6.806306843048e-09
168 KSP Residual norm 6.691806127634e-09
169 KSP Residual norm 6.561840778678e-09
170 KSP Residual norm 6.427119314448e-09
171 KSP Residual norm 6.284091223749e-09
172 KSP Residual norm 6.144562330195e-09
173 KSP Residual norm 5.992724846217e-09
174 KSP Residual norm 5.807892057405e-09
175 KSP Residual norm 5.607091422529e-09
176 KSP Residual norm 5.422439545331e-09
177 KSP Residual norm 5.284810157636e-09
178 KSP Residual norm 5.181682253831e-09
179 KSP Residual norm 5.079062113803e-09
180 KSP Residual norm 4.907732809675e-09
181 KSP Residual norm 4.689165836644e-09
182 KSP Residual norm 4.477432934657e-09
183 KSP Residual norm 4.274579304073e-09
184 KSP Residual norm 4.080754560317e-09
185 KSP Residual norm 3.909231279140e-09
186 KSP Residual norm 3.763564973943e-09
187 KSP Residual norm 3.641962564658e-09
188 KSP Residual norm 3.516920751152e-09
189 KSP Residual norm 3.389269728129e-09
190 KSP Residual norm 3.277260135540e-09
191 KSP Residual norm 3.165775394956e-09
192 KSP Residual norm 3.053176229190e-09
193 KSP Residual norm 2.938518224745e-09
194 KSP Residual norm 2.832842208693e-09
195 KSP Residual norm 2.739856640695e-09
196 KSP Residual norm 2.653290329877e-09
197 KSP Residual norm 2.570737110048e-09
198 KSP Residual norm 2.493264869458e-09
199 KSP Residual norm 2.424384579319e-09
200 KSP Residual norm 2.358265778793e-09
201 KSP Residual norm 2.294403466020e-09
202 KSP Residual norm 2.240316088106e-09
203 KSP Residual norm 2.201795318095e-09
204 KSP Residual norm 2.203948520194e-09
205 KSP Residual norm 2.249519089973e-09
206 KSP Residual norm 2.161749808175e-09
207 KSP Residual norm 2.031432417332e-09
208 KSP Residual norm 1.957316101660e-09
209 KSP Residual norm 1.911772322815e-09
210 KSP Residual norm 1.869332190629e-09
211 KSP Residual norm 1.821536274290e-09
212 KSP Residual norm 1.772929460354e-09
213 KSP Residual norm 1.726733323635e-09
214 KSP Residual norm 1.677458089120e-09
215 KSP Residual norm 1.623752684266e-09
216 KSP Residual norm 1.567353275456e-09
217 KSP Residual norm 1.515810016644e-09
218 KSP Residual norm 1.469844738185e-09
219 KSP Residual norm 1.428798138430e-09
220 KSP Residual norm 1.384599195625e-09
221 KSP Residual norm 1.345135997535e-09
222 KSP Residual norm 1.317350812667e-09
223 KSP Residual norm 1.280179631069e-09
224 KSP Residual norm 1.219817992763e-09
225 KSP Residual norm 1.168741349260e-09
226 KSP Residual norm 1.129319505228e-09
227 KSP Residual norm 1.091894141922e-09
228 KSP Residual norm 1.054404007978e-09
229 KSP Residual norm 1.019691822696e-09
230 KSP Residual norm 9.830919581199e-10
231 KSP Residual norm 9.475584941591e-10
232 KSP Residual norm 9.135918075261e-10
233 KSP Residual norm 8.851703554255e-10
234 KSP Residual norm 8.559978989743e-10
235 KSP Residual norm 8.244451504296e-10
236 KSP Residual norm 7.964205229658e-10
237 KSP Residual norm 7.757937917120e-10
238 KSP Residual norm 7.604996727901e-10
239 KSP Residual norm 7.418948986654e-10
240 KSP Residual norm 7.139731311976e-10
241 KSP Residual norm 6.838042297533e-10
242 KSP Residual norm 6.579583153158e-10
243 KSP Residual norm 6.376413895988e-10
244 KSP Residual norm 6.232148733423e-10
245 KSP Residual norm 6.148191486676e-10
246 KSP Residual norm 6.062911779447e-10
247 KSP Residual norm 5.889366289316e-10
248 KSP Residual norm 5.671570779055e-10
249 KSP Residual norm 5.492384315320e-10
250 KSP Residual norm 5.366210969971e-10
251 KSP Residual norm 5.297906387601e-10
252 KSP Residual norm 5.265147828732e-10
253 KSP Residual norm 5.189619927955e-10
254 KSP Residual norm 5.040048270784e-10
255 KSP Residual norm 4.914648180642e-10
256 KSP Residual norm 4.866970545132e-10
257 KSP Residual norm 4.887664623481e-10
258 KSP Residual norm 4.792827075614e-10
259 KSP Residual norm 4.557298378587e-10
260 KSP Residual norm 4.349800706061e-10
261 KSP Residual norm 4.190247647471e-10
262 KSP Residual norm 4.055901060724e-10
263 KSP Residual norm 3.928969788696e-10
264 KSP Residual norm 3.785956588835e-10
265 KSP Residual norm 3.643146911449e-10
266 KSP Residual norm 3.513474693823e-10
267 KSP Residual norm 3.412157387791e-10
268 KSP Residual norm 3.326667035225e-10
269 KSP Residual norm 3.232125579129e-10
270 KSP Residual norm 3.133102795927e-10
271 KSP Residual norm 3.026632262759e-10
272 KSP Residual norm 2.909828915848e-10
273 KSP Residual norm 2.796229289184e-10
274 KSP Residual norm 2.691012993276e-10
275 KSP Residual norm 2.593834711805e-10
276 KSP Residual norm 2.517516589658e-10
277 KSP Residual norm 2.444875470619e-10
278 KSP Residual norm 2.363485887332e-10
279 KSP Residual norm 2.280970317344e-10
280 KSP Residual norm 2.203444111335e-10
281 KSP Residual norm 2.132475594425e-10
282 KSP Residual norm 2.068717873433e-10
283 KSP Residual norm 2.011425044935e-10
284 KSP Residual norm 1.959536251398e-10
285 KSP Residual norm 1.902712153566e-10
286 KSP Residual norm 1.834351329789e-10
287 KSP Residual norm 1.759854644892e-10
288 KSP Residual norm 1.683808022058e-10
289 KSP Residual norm 1.609261691001e-10
290 KSP Residual norm 1.551687339918e-10
291 KSP Residual norm 1.500126123031e-10
292 KSP Residual norm 1.458020450038e-10
293 KSP Residual norm 1.430334599943e-10
294 KSP Residual norm 1.406822426822e-10
295 KSP Residual norm 1.365080545823e-10
296 KSP Residual norm 1.316655716550e-10
297 KSP Residual norm 1.276763158409e-10
298 KSP Residual norm 1.241488596867e-10
299 KSP Residual norm 1.210267782396e-10
300 KSP Residual norm 1.182724105866e-10
301 KSP Residual norm 1.161034850476e-10
302 KSP Residual norm 1.140866621614e-10
303 KSP Residual norm 1.122511781736e-10
304 KSP Residual norm 1.102567560492e-10
305 KSP Residual norm 1.079962206357e-10
306 KSP Residual norm 1.072641690569e-10
307 KSP Residual norm 1.061070894777e-10
308 KSP Residual norm 1.003227388291e-10
309 KSP Residual norm 9.484310216962e-11
310 KSP Residual norm 9.106526260323e-11
311 KSP Residual norm 8.828962336522e-11
312 KSP Residual norm 8.623673235114e-11
313 KSP Residual norm 8.493242053450e-11
314 KSP Residual norm 8.335770449570e-11
315 KSP Residual norm 8.088450294360e-11
316 KSP Residual norm 7.831600277588e-11
317 KSP Residual norm 7.573062541830e-11
318 KSP Residual norm 7.318374440856e-11
319 KSP Residual norm 7.125665708661e-11
320 KSP Residual norm 6.985674106500e-11
321 KSP Residual norm 6.866150612056e-11
322 KSP Residual norm 6.751415322244e-11
323 KSP Residual norm 6.615757162111e-11
324 KSP Residual norm 6.463248708028e-11
325 KSP Residual norm 6.286711804082e-11
326 KSP Residual norm 6.096111963032e-11
327 KSP Residual norm 5.890372557945e-11
328 KSP Residual norm 5.718678066119e-11
329 KSP Residual norm 5.582420401208e-11
330 KSP Residual norm 5.468074876868e-11
331 KSP Residual norm 5.345415382175e-11
332 KSP Residual norm 5.214487087053e-11
333 KSP Residual norm 5.058930718248e-11
334 KSP Residual norm 4.921643376406e-11
335 KSP Residual norm 4.810793595634e-11
336 KSP Residual norm 4.697180054668e-11
337 KSP Residual norm 4.566266022384e-11
338 KSP Residual norm 4.454469025936e-11
339 KSP Residual norm 4.342256170290e-11
340 KSP Residual norm 4.213570214152e-11
341 KSP Residual norm 4.096798779532e-11
342 KSP Residual norm 3.984521359720e-11
343 KSP Residual norm 3.866358144610e-11
344 KSP Residual norm 3.738477641292e-11
345 KSP Residual norm 3.594287109627e-11
346 KSP Residual norm 3.471194312667e-11
347 KSP Residual norm 3.363443745520e-11
348 KSP Residual norm 3.272447171236e-11
349 KSP Residual norm 3.192681887246e-11
350 KSP Residual norm 3.131890479593e-11
351 KSP Residual norm 3.089643377485e-11
352 KSP Residual norm 3.069599301476e-11
353 KSP Residual norm 3.052179997762e-11
354 KSP Residual norm 2.961012724752e-11
355 KSP Residual norm 2.855330076094e-11
356 KSP Residual norm 2.754778539422e-11
357 KSP Residual norm 2.644171068235e-11
358 KSP Residual norm 2.540813750713e-11
359 KSP Residual norm 2.471737921463e-11
360 KSP Residual norm 2.447355622305e-11
361 KSP Residual norm 2.418398556535e-11
362 KSP Residual norm 2.334092777508e-11
363 KSP Residual norm 2.225970624139e-11
364 KSP Residual norm 2.141099151863e-11
365 KSP Residual norm 2.065738632012e-11
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 365
stx: 0., fx: 0.0691388, dgx: -1.46624e-10
sty: 0., fy: 0.0691388, dgy: -1.46624e-10
43 TAO, Function value: 0.0691388, Residual: 8.31462e-07
0 KSP Residual norm 8.314618436927e-07
1 KSP Residual norm 6.864412890377e-07
2 KSP Residual norm 4.529453262313e-07
3 KSP Residual norm 3.598243165972e-07
4 KSP Residual norm 2.715637599571e-07
5 KSP Residual norm 2.160694323527e-07
6 KSP Residual norm 1.850562496988e-07
7 KSP Residual norm 1.608460601183e-07
8 KSP Residual norm 1.404216416894e-07
9 KSP Residual norm 1.279934418718e-07
10 KSP Residual norm 1.197673404693e-07
11 KSP Residual norm 1.106770827802e-07
12 KSP Residual norm 1.040435478899e-07
13 KSP Residual norm 9.943878394315e-08
14 KSP Residual norm 9.542265989249e-08
15 KSP Residual norm 9.239718581728e-08
16 KSP Residual norm 9.055108767144e-08
17 KSP Residual norm 9.006283167976e-08
18 KSP Residual norm 8.976300438292e-08
19 KSP Residual norm 9.043763342857e-08
20 KSP Residual norm 9.242369072720e-08
21 KSP Residual norm 9.513828068986e-08
22 KSP Residual norm 9.862985257694e-08
23 KSP Residual norm 1.022139860486e-07
24 KSP Residual norm 1.067610067994e-07
25 KSP Residual norm 1.122866563334e-07
26 KSP Residual norm 1.184979456499e-07
27 KSP Residual norm 1.255843858334e-07
28 KSP Residual norm 1.342922098564e-07
29 KSP Residual norm 1.451276587399e-07
30 KSP Residual norm 1.533220665690e-07
31 KSP Residual norm 1.586516993027e-07
32 KSP Residual norm 1.647278611956e-07
33 KSP Residual norm 1.715067725467e-07
34 KSP Residual norm 1.778769539885e-07
35 KSP Residual norm 1.831720298791e-07
36 KSP Residual norm 1.861254772787e-07
37 KSP Residual norm 1.857384589017e-07
38 KSP Residual norm 1.822797884411e-07
39 KSP Residual norm 1.766443421437e-07
40 KSP Residual norm 1.696910795236e-07
41 KSP Residual norm 1.619660962824e-07
42 KSP Residual norm 1.532674978996e-07
43 KSP Residual norm 1.439040714749e-07
44 KSP Residual norm 1.355436811157e-07
45 KSP Residual norm 1.299153492459e-07
46 KSP Residual norm 1.252919186986e-07
47 KSP Residual norm 1.164460489248e-07
48 KSP Residual norm 1.068070255892e-07
49 KSP Residual norm 9.931802054881e-08
50 KSP Residual norm 9.296822779447e-08
51 KSP Residual norm 8.730865506666e-08
52 KSP Residual norm 8.294901170109e-08
53 KSP Residual norm 8.069688382649e-08
54 KSP Residual norm 7.811274681984e-08
55 KSP Residual norm 7.193003350944e-08
56 KSP Residual norm 6.612041233088e-08
57 KSP Residual norm 6.190408273901e-08
58 KSP Residual norm 5.881565392739e-08
59 KSP Residual norm 5.658394346136e-08
60 KSP Residual norm 5.497996637779e-08
61 KSP Residual norm 5.380321272862e-08
62 KSP Residual norm 5.294497100604e-08
63 KSP Residual norm 5.181337015768e-08
64 KSP Residual norm 5.018598002733e-08
65 KSP Residual norm 4.859640846535e-08
66 KSP Residual norm 4.729066220478e-08
67 KSP Residual norm 4.619660514026e-08
68 KSP Residual norm 4.547733675710e-08
69 KSP Residual norm 4.496428838958e-08
70 KSP Residual norm 4.366786930914e-08
71 KSP Residual norm 4.161198256544e-08
72 KSP Residual norm 3.979827129423e-08
73 KSP Residual norm 3.823124005822e-08
74 KSP Residual norm 3.666231571214e-08
75 KSP Residual norm 3.509780684297e-08
76 KSP Residual norm 3.331877359622e-08
77 KSP Residual norm 3.150739200868e-08
78 KSP Residual norm 2.983341112510e-08
79 KSP Residual norm 2.810138115279e-08
80 KSP Residual norm 2.668129348603e-08
81 KSP Residual norm 2.557013062441e-08
82 KSP Residual norm 2.409670134194e-08
83 KSP Residual norm 2.238020959298e-08
84 KSP Residual norm 2.076706503625e-08
85 KSP Residual norm 1.928262771561e-08
86 KSP Residual norm 1.793353946620e-08
87 KSP Residual norm 1.654064265195e-08
88 KSP Residual norm 1.527350393351e-08
89 KSP Residual norm 1.419475313040e-08
90 KSP Residual norm 1.323238207208e-08
91 KSP Residual norm 1.227264212020e-08
92 KSP Residual norm 1.135116581233e-08
93 KSP Residual norm 1.047003865130e-08
94 KSP Residual norm 9.664251235207e-09
95 KSP Residual norm 9.004748453242e-09
96 KSP Residual norm 8.463870058529e-09
97 KSP Residual norm 8.046871889327e-09
98 KSP Residual norm 7.663643093877e-09
99 KSP Residual norm 7.204741504539e-09
100 KSP Residual norm 6.799043623059e-09
101 KSP Residual norm 6.461365495858e-09
102 KSP Residual norm 6.258538500919e-09
103 KSP Residual norm 6.184222737384e-09
104 KSP Residual norm 6.207945214311e-09
105 KSP Residual norm 5.937208571458e-09
106 KSP Residual norm 5.629382494595e-09
107 KSP Residual norm 5.468097194723e-09
108 KSP Residual norm 5.363802075736e-09
109 KSP Residual norm 5.284907294762e-09
110 KSP Residual norm 5.246387246630e-09
111 KSP Residual norm 5.206146089638e-09
112 KSP Residual norm 5.165936322159e-09
113 KSP Residual norm 5.124972664082e-09
114 KSP Residual norm 5.087227173476e-09
115 KSP Residual norm 5.030038290020e-09
116 KSP Residual norm 4.938277181757e-09
117 KSP Residual norm 4.826054035040e-09
118 KSP Residual norm 4.745095337552e-09
119 KSP Residual norm 4.687787645792e-09
120 KSP Residual norm 4.636642002831e-09
121 KSP Residual norm 4.560978146292e-09
122 KSP Residual norm 4.471135343900e-09
123 KSP Residual norm 4.376703382670e-09
124 KSP Residual norm 4.293856995579e-09
125 KSP Residual norm 4.216269411820e-09
126 KSP Residual norm 4.136519138383e-09
127 KSP Residual norm 4.079991920989e-09
128 KSP Residual norm 4.049099145713e-09
129 KSP Residual norm 3.960361883269e-09
130 KSP Residual norm 3.775287662028e-09
131 KSP Residual norm 3.597849478955e-09
132 KSP Residual norm 3.435809334619e-09
133 KSP Residual norm 3.274423617108e-09
134 KSP Residual norm 3.115056491378e-09
135 KSP Residual norm 2.957125695873e-09
136 KSP Residual norm 2.795406497332e-09
137 KSP Residual norm 2.646654030058e-09
138 KSP Residual norm 2.528257264914e-09
139 KSP Residual norm 2.419625824199e-09
140 KSP Residual norm 2.257883152503e-09
141 KSP Residual norm 2.084417519227e-09
142 KSP Residual norm 1.941698130138e-09
143 KSP Residual norm 1.825299382286e-09
144 KSP Residual norm 1.724007064945e-09
145 KSP Residual norm 1.630693857630e-09
146 KSP Residual norm 1.532382321832e-09
147 KSP Residual norm 1.436726125736e-09
148 KSP Residual norm 1.358530745156e-09
149 KSP Residual norm 1.308552447132e-09
150 KSP Residual norm 1.264347298618e-09
151 KSP Residual norm 1.190696763772e-09
152 KSP Residual norm 1.109763002756e-09
153 KSP Residual norm 1.045305434600e-09
154 KSP Residual norm 1.003597261101e-09
155 KSP Residual norm 9.972858114212e-10
156 KSP Residual norm 9.871097339157e-10
157 KSP Residual norm 9.134164870245e-10
158 KSP Residual norm 8.541887575655e-10
159 KSP Residual norm 8.172422442037e-10
160 KSP Residual norm 7.879250394455e-10
161 KSP Residual norm 7.569486375147e-10
162 KSP Residual norm 7.257168725861e-10
163 KSP Residual norm 7.001958086670e-10
164 KSP Residual norm 6.795286207251e-10
165 KSP Residual norm 6.610592891362e-10
166 KSP Residual norm 6.384205532868e-10
167 KSP Residual norm 6.083051498339e-10
168 KSP Residual norm 5.774833363890e-10
169 KSP Residual norm 5.515927614815e-10
170 KSP Residual norm 5.305354287614e-10
171 KSP Residual norm 5.122480536377e-10
172 KSP Residual norm 4.969708054914e-10
173 KSP Residual norm 4.835143799388e-10
174 KSP Residual norm 4.698356360220e-10
175 KSP Residual norm 4.561172649206e-10
176 KSP Residual norm 4.435998760575e-10
177 KSP Residual norm 4.332595677192e-10
178 KSP Residual norm 4.237385420024e-10
179 KSP Residual norm 4.151567397209e-10
180 KSP Residual norm 4.070923301760e-10
181 KSP Residual norm 3.997656616008e-10
182 KSP Residual norm 3.925268825279e-10
183 KSP Residual norm 3.843927476700e-10
184 KSP Residual norm 3.752364591899e-10
185 KSP Residual norm 3.655397078531e-10
186 KSP Residual norm 3.562150975095e-10
187 KSP Residual norm 3.476264757424e-10
188 KSP Residual norm 3.390173764025e-10
189 KSP Residual norm 3.301332966245e-10
190 KSP Residual norm 3.222883391542e-10
191 KSP Residual norm 3.154336074632e-10
192 KSP Residual norm 3.105707199731e-10
193 KSP Residual norm 3.100649697513e-10
194 KSP Residual norm 3.113809852407e-10
195 KSP Residual norm 3.068875529889e-10
196 KSP Residual norm 2.988243271258e-10
197 KSP Residual norm 2.934700163031e-10
198 KSP Residual norm 2.901077138294e-10
199 KSP Residual norm 2.877331174443e-10
200 KSP Residual norm 2.879076486224e-10
201 KSP Residual norm 2.952206626099e-10
202 KSP Residual norm 3.011046729465e-10
203 KSP Residual norm 2.879042090239e-10
204 KSP Residual norm 2.767072031479e-10
205 KSP Residual norm 2.722352183143e-10
206 KSP Residual norm 2.701443973573e-10
207 KSP Residual norm 2.682666210594e-10
208 KSP Residual norm 2.655536862858e-10
209 KSP Residual norm 2.615749240364e-10
210 KSP Residual norm 2.542148041308e-10
211 KSP Residual norm 2.460903653249e-10
212 KSP Residual norm 2.401903572646e-10
213 KSP Residual norm 2.367695877160e-10
214 KSP Residual norm 2.329092694799e-10
215 KSP Residual norm 2.258048929823e-10
216 KSP Residual norm 2.172756784844e-10
217 KSP Residual norm 2.098276379823e-10
218 KSP Residual norm 2.036036433968e-10
219 KSP Residual norm 1.985286768002e-10
220 KSP Residual norm 1.942208420029e-10
221 KSP Residual norm 1.895912383595e-10
222 KSP Residual norm 1.830624523451e-10
223 KSP Residual norm 1.758883323166e-10
224 KSP Residual norm 1.694098343395e-10
225 KSP Residual norm 1.631403608913e-10
226 KSP Residual norm 1.565437160993e-10
227 KSP Residual norm 1.501643026227e-10
228 KSP Residual norm 1.442149468657e-10
229 KSP Residual norm 1.386554689218e-10
230 KSP Residual norm 1.332227209875e-10
231 KSP Residual norm 1.281287222543e-10
232 KSP Residual norm 1.230410218486e-10
233 KSP Residual norm 1.183387170528e-10
234 KSP Residual norm 1.134126813880e-10
235 KSP Residual norm 1.082066363028e-10
236 KSP Residual norm 1.030718179079e-10
237 KSP Residual norm 9.862905833962e-11
238 KSP Residual norm 9.472022365292e-11
239 KSP Residual norm 9.100300801669e-11
240 KSP Residual norm 8.741917436944e-11
241 KSP Residual norm 8.397741340016e-11
242 KSP Residual norm 8.066346387157e-11
243 KSP Residual norm 7.758082374933e-11
244 KSP Residual norm 7.480967093304e-11
245 KSP Residual norm 7.254548361159e-11
246 KSP Residual norm 7.091442653920e-11
247 KSP Residual norm 6.907401734025e-11
248 KSP Residual norm 6.585244834758e-11
249 KSP Residual norm 6.258933799150e-11
250 KSP Residual norm 6.081826826289e-11
251 KSP Residual norm 6.066816348515e-11
252 KSP Residual norm 5.861081250884e-11
253 KSP Residual norm 5.463747721766e-11
254 KSP Residual norm 5.194828349101e-11
255 KSP Residual norm 5.045609492854e-11
256 KSP Residual norm 4.928263359758e-11
257 KSP Residual norm 4.740277863796e-11
258 KSP Residual norm 4.500936041627e-11
259 KSP Residual norm 4.292836905264e-11
260 KSP Residual norm 4.141470583909e-11
261 KSP Residual norm 4.026013240501e-11
262 KSP Residual norm 3.935784889184e-11
263 KSP Residual norm 3.838478647806e-11
264 KSP Residual norm 3.673417475689e-11
265 KSP Residual norm 3.485643899688e-11
266 KSP Residual norm 3.331517712794e-11
267 KSP Residual norm 3.216374850494e-11
268 KSP Residual norm 3.119376003012e-11
269 KSP Residual norm 3.017214667816e-11
270 KSP Residual norm 2.903664916035e-11
271 KSP Residual norm 2.780112142402e-11
272 KSP Residual norm 2.671007385360e-11
273 KSP Residual norm 2.579426932725e-11
274 KSP Residual norm 2.499123994272e-11
275 KSP Residual norm 2.417813674097e-11
276 KSP Residual norm 2.339386701821e-11
277 KSP Residual norm 2.266842341447e-11
278 KSP Residual norm 2.195635182278e-11
279 KSP Residual norm 2.134858429123e-11
280 KSP Residual norm 2.081519901917e-11
281 KSP Residual norm 2.031213518348e-11
282 KSP Residual norm 1.983821973670e-11
283 KSP Residual norm 1.958690761899e-11
284 KSP Residual norm 1.953193528809e-11
285 KSP Residual norm 1.907141191467e-11
286 KSP Residual norm 1.835461166454e-11
287 KSP Residual norm 1.790294126744e-11
288 KSP Residual norm 1.764335555866e-11
289 KSP Residual norm 1.736241555712e-11
290 KSP Residual norm 1.711090045573e-11
291 KSP Residual norm 1.674715879719e-11
292 KSP Residual norm 1.636576391299e-11
293 KSP Residual norm 1.598267988283e-11
294 KSP Residual norm 1.557158881270e-11
295 KSP Residual norm 1.514871524125e-11
296 KSP Residual norm 1.470575765366e-11
297 KSP Residual norm 1.431475129077e-11
298 KSP Residual norm 1.396369174567e-11
299 KSP Residual norm 1.365830701302e-11
300 KSP Residual norm 1.363716771840e-11
301 KSP Residual norm 1.401729868322e-11
302 KSP Residual norm 1.367828540634e-11
303 KSP Residual norm 1.286371167325e-11
304 KSP Residual norm 1.245609928631e-11
305 KSP Residual norm 1.224491267818e-11
306 KSP Residual norm 1.210067967374e-11
307 KSP Residual norm 1.194263081399e-11
308 KSP Residual norm 1.168490747703e-11
309 KSP Residual norm 1.137991380064e-11
310 KSP Residual norm 1.107556185417e-11
311 KSP Residual norm 1.087577301355e-11
312 KSP Residual norm 1.072064209421e-11
313 KSP Residual norm 1.044809099089e-11
314 KSP Residual norm 1.004301895662e-11
315 KSP Residual norm 9.717907274149e-12
316 KSP Residual norm 9.504928783962e-12
317 KSP Residual norm 9.332772961888e-12
318 KSP Residual norm 9.001598862699e-12
319 KSP Residual norm 8.549624333577e-12
320 KSP Residual norm 8.145697219656e-12
Linear tao_nls_ solve converged due to CONVERGED_RTOL iterations 320
stx: 0., fx: 0.0691388, dgx: -2.67456e-12
sty: 0., fy: 0.0691388, dgy: -2.67456e-12
44 TAO, Function value: 0.0691388, Residual: 6.20283e-09
TAO solve converged due to CONVERGED_GATOL iterations 44
Tao solve required 44 iterations
