[petsc-users] Calling MATLAB code within a parallel C/C++ code
Amneet Bhalla mail2amneet at gmail.com
Tue Jun 9 17:09:42 CDT 2020
That's where I also found it. Thanks, Sanjay!
(This path is included in my .profile file
export DYLD_FALLBACK_LIBRARY_PATH=
/Applications/MATLAB_R2019b.app/bin/maci64:/Applications/MATLAB_R2019b.app/sys/os/maci64:
$DYLD_FALLBACK_LIBRARY_PATH
export DYLD_LIBRARY_PATH=
$DYLD_LIBRARY_PATH
Do I need to tell PETSc about this path as well? Something like:
--with-matlab-engine-lib=/Applications/MATLAB_R2019b.app/bin/maci64/libeng.dylib
On Tue, Jun 9, 2020 at 2:56 PM Sanjay Govindjee <s_g at berkeley.edu> wrote:
> Try looking in:
> $(MLROOT)/bin/maci64
> where MLROOT = /Applications/MATLAB_R2019a.app or the like
> On 6/9/20 2:51 PM, Junchao Zhang wrote:
> Find recursively where is libeng.dylib under
> /Applications/MATLAB_R2019b.app/extern/engines/
> --Junchao Zhang
> On Tue, Jun 9, 2020 at 4:27 PM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> Forgot to mention that configure found the following about MATLAB
>> Matlab:
>>   Includes: -I/Applications/MATLAB_R2019b.app/extern/include
>> MatlabEngine:
>>   Library:  -L/Applications/MATLAB_R2019b.app/bin/maci64
>> -L/Applications/MATLAB_R2019b.app/extern/lib/maci64 -leng -lmex -lmx -lmat
>> -lut -licudata -licui18n -licuuc
>> On Tue, Jun 9, 2020 at 2:20 PM Amneet Bhalla <mail2amneet at gmail.com>
>> wrote:
>>> Do these additional configure flags for MATLAB look OK?
>>> --with-matlab=1 --with-matlab-dir=/Applications/MATLAB_R2019b.app
>>> --with-matlab-engine=1
>>> --with-matlab-engine-dir=/Applications/MATLAB_R2019b.app/extern/engines/
>>> With this configuration make compiled files like:
>>>           CC darwin-dbg/obj/sys/classes/viewer/impls/matlab/vmatlab.o
>>>           CC
>>> darwin-dbg/obj/sys/classes/viewer/impls/matlab/ftn-custom/zvmatlabf.o
>>>           CC darwin-dbg/obj/sys/classes/matlabengine/matlab.o
>>>           CC darwin-dbg/obj/sys/classes/matlabengine/ftn-auto/matlabf.o
>>>           CC
>>> darwin-dbg/obj/sys/classes/matlabengine/ftn-custom/zmatlabf.o
>>>           CC darwin-dbg/obj/vec/pf/impls/matlab/cmatlab.o
>>>           CC darwin-dbg/obj/vec/vec/utils/matlab/gcreatev.o
>>> make[2]: Leaving directory `/Users/amneetb/Softwares/PETSc-Gitlab/PETSc'
>>> BEGINNING TO COMPILE MATLAB INTERFACE
>>> Building with 'Xcode with Clang'.
>>> ld: warning: cannot export hidden symbol _mexfilerequiredapiversion from
>>> c_mexapi_version.o
>>> c_mexapi_version.o
>>> MEX completed successfully.
>>> c_mexapi_version.o
>>> c_mexapi_version.o
>>> c_mexapi_version.o
>>> c_mexapi_version.o
>>> c_mexapi_version.o
>>> However, make check gives error
>>> amneetb at Amneets-MBP:~/Softwares/PETSc-Gitlab/PETSc$ make
>>> PETSC_DIR=/Users/amneetb/Softwares/PETSc-Gitlab/PETSc PETSC_ARCH=darwin-dbg
>>> check
>>> Running test examples to verify correct installation
>>> Using PETSC_DIR=/Users/amneetb/Softwares/PETSc-Gitlab/PETSc and
>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
>>> process
>>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> dyld: Library not loaded: @rpath/libeng.dylib
>>>   Referenced from:
>>> /Users/amneetb/Softwares/PETSc-Gitlab/PETSc/src/snes/examples/tutorials/./ex19
>>>   Reason: image not found
>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>> =   PID 14057 RUNNING AT Amneets-MBP
>>> =   EXIT CODE: 6
>>> =   CLEANING UP REMAINING PROCESSES
>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Abort trap: 6 (signal
>>> 6)
>>> This typically refers to a problem with your application.
>>> Please see the FAQ page for debugging suggestions
>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
>>> processes
>>>   Referenced from:
>>>   Referenced from:
>>> =   PID 14062 RUNNING AT Amneets-MBP
>>> =   EXIT CODE: 6
>>> 6)
>>> 1,5c1,17
>>> < lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>>> <   0 SNES Function norm 0.0406612
>>> <   1 SNES Function norm 4.12227e-06
>>> <   2 SNES Function norm 6.098e-11
>>> < Number of SNES iterations = 2
>>> >   Referenced from:
>>> >   Referenced from:
>>> > =   PID 14072 RUNNING AT Amneets-MBP
>>> > =   EXIT CODE: 6
>>> (signal 6)
>>> Possible problem with ex19 running with hypre, diffs above
>>> Possible error running Fortran example src/snes/examples/tutorials/ex5f
>>> with 1 MPI process
>>>   Referenced from:
>>> /Users/amneetb/Softwares/PETSc-Gitlab/PETSc/src/snes/examples/tutorials/./ex5f
>>> =   PID 14211 RUNNING AT Amneets-MBP
>>> =   EXIT CODE: 6
>>> 6)
>>> Completed test examples
>>> I have added the following paths in my .profile and sourced it before
>>> make all and make check
>>> $DYLD_LIBRARY_PATH
>>> On Mon, Jun 8, 2020 at 6:39 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Looks like the tool to list the examples in the manual pages is
>>>> broken since it didn't find these other examples, I'll take a look at it.
>>>>   There is also a discussion in the users manual
>>>> $ git grep MatlabEngine | grep ex
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineCreate(MPI_Comm
>>>> comm,char *machine,PetscMatlabEngine *e);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEnginePut(PetscMatlabEngine
>>>> e,PetscObject obj);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineGet(PetscMatlabEngine
>>>> e,PetscObject obj);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEnginePutArray(PetscMatlabEngine
>>>> e,int m,int n,PetscScalar *array,char *name);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineGetArray(PetscMatlabEngine
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineEvaluate(PetscMatlabEngine,"format",...);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineEvaluate(PetscMatlabEngine,"x
>>>> = \%g *y + z;",avalue);
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEngineGetOutput(PetscMatlabEngine,char
>>>> src/docs/tex/manual/part2.tex:PetscMatlabEnginedPrintOutput(PetscMatlabEngine,FILE*).
>>>> src/snes/tutorials/ex5.c:  ierr =
>>>> PetscMatlabEnginePut(PETSC_MATLAB_ENGINE_(comm),(PetscObject)localX);CHKERRQ(ierr);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(comm),"localF=ex5m(localX,%18.16e,%18.16e,%18.16e)",hx,hy,lambda);CHKERRQ(ierr);
>>>> PetscMatlabEngineGet(PETSC_MATLAB_ENGINE_(comm),(PetscObject)localF);CHKERRQ(ierr);
>>>> src/sys/tests/ex16.c:static char help[] = "Demonstrates
>>>> PetscMatlabEngineXXX()\n";
>>>> src/sys/tests/ex16.c:  ierr =
>>>> PetscMatlabEngineGetOutput(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),&output);CHKERRQ(ierr);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),"MPI_Comm_rank");CHKERRQ(ierr);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),user);CHKERRQ(ierr);
>>>> src/vec/vec/tests/ex31.c:static const char help[] = "Demonstrates
>>>> src/vec/vec/tests/ex31.c:  ierr =
>>>> PetscMatlabEngineGetOutput(PETSC_MATLAB_ENGINE_WORLD,&output);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"MPI_Comm_rank");
>>>> PetscMatlabEnginePut(PETSC_MATLAB_ENGINE_WORLD,(PetscObject)x);CHKERRQ(ierr);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"x = x +
>>>> MPI_Comm_rank;\n");
>>>> PetscMatlabEngineGet(PETSC_MATLAB_ENGINE_WORLD,(PetscObject)x);CHKERRQ(ierr);
>>>> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"whos\n");CHKERRQ(ierr);
>>>> On Jun 8, 2020, at 8:26 PM, Amneet Bhalla <mail2amneet at gmail.com>
>>>> wrote:
>>>> Great!
>>>> Clicking on some of the functions pointed me to this example
>>>> https://www.mcs.anl.gov/petsc/petsc-3.13/src/snes/tutorials/ex5.c.html
>>>> Are there more examples, which are perhaps simpler than the above,
>>>> which I can refer to?
>>>> On Mon, Jun 8, 2020 at 5:51 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>   You should use the PetscMatlabEngine
>>>>> https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscMatlabEngine.html
>>>>>   Barry
>>>>> On Jun 8, 2020, at 7:09 PM, Amneet Bhalla <mail2amneet at gmail.com>
>>>>> wrote:
>>>>> Hi Folks,
>>>>> My parallel application written in C++ (which also uses PETSc library
>>>>> for linear solvers) requires calling control and optimization toolbox of
>>>>> MATLAB at every time step to get a small number of double values. Likewise
>>>>> the MATLAB function will need to know some values from the parallel C++
>>>>> application to return those doubles. I'm wondering if there is a
>>>>> recommended way of calling MATLAB from parallel C/C++/Fortran codes, and if
>>>>> PETSc has some interface that could be leveraged for this exchange.
>>>>> Thanks,
>>>>> --Amneet
>>>> --Amneet
>>> --Amneet
>> --Amneet
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200609/681dd966/attachment-0001.html>
