[petsc-users] Calling MATLAB code within a parallel C/C++ code
Mon Jun 8 20:39:00 CDT 2020
there is src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
also, src/vec/vec/tests/ex31.c has matlab calls - but isn't getting tested - so likely broken.
Satish
On Mon, 8 Jun 2020, Amneet Bhalla wrote:
> Great!
> Clicking on some of the functions pointed me to this example
> https://www.mcs.anl.gov/petsc/petsc-3.13/src/snes/tutorials/ex5.c.html
> Are there more examples, which are perhaps simpler than the above, which I
> can refer to?
> On Mon, Jun 8, 2020 at 5:51 PM Barry Smith <bsmith at petsc.dev> wrote:
> >   You should use the PetscMatlabEngine
> > https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscMatlabEngine.html
> >   Barry
> > On Jun 8, 2020, at 7:09 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> > Hi Folks,
> > My parallel application written in C++ (which also uses PETSc library for
> > linear solvers) requires calling control and optimization toolbox of MATLAB
> > at every time step to get a small number of double values. Likewise the
> > MATLAB function will need to know some values from the parallel C++
> > application to return those doubles. I'm wondering if there is a
> > recommended way of calling MATLAB from parallel C/C++/Fortran codes, and if
> > PETSc has some interface that could be leveraged for this exchange.
> > Thanks,
> > --Amneet
