[petsc-users] Regarding DM Labels
Jed Brown
jed at jedbrown.org
Mon Jun 8 15:18:06 CDT 2020
Re-adding the list.
MUKKUND SUNJII <mukkundsunjii at gmail.com> writes:
> Apologies, I understand your point about the non-wall domain.
> However, I am interested in what is happening on the other side of the dam (the reservoir).
> Furthermore, I suppose in the non-wall domain, the boundary condition would change with respect to the height of the water in the reservoir.
Oh, you want this to be a wall that water can slosh over? I'd recommend
using a formulation with variable bathymetry and looking at
well-balanced schemes. Also read up on Riemann solvers capable of
wetting and drying. I wouldn't treat it as a "boundary".
> Regards,
> Mukkund
>> On 8 Jun 2020, at 22:05, MUKKUND SUNJII <mukkundsunjii at gmail.com> wrote:
>> I am not familiar with the non-wall domain.
>> Would you be kind enough to direct me to an tutorial or a test file in the repo?
>> Regards,
>> Mukkund
>>>> Greetings,
>>>> I am working on modifying the shallow water model in ex11 for the purpose of my thesis.
>>>> I wish to run a specific dam break scenario using this model. In the scenario, the velocity fields of certain cells must be constrained. That is I want to create an “artificial wall” inside the domain by constraining the value [uh] to not change.
>>> Why not make your unstructured mesh be the non-wall domain? That way
>>> you don't have to constrain cell values and you can (correctly) make the
>>> (reconstructed) zero velocity occur at the cell boundary rather than the
>>> cell interior.
>>>> For this purpose, I tried creating a separate label in the DM. Further, I added the cells whose velocity values I wanted to constrain to the label using the routine : DMLabelSetValue(labelWall, c, 100);
>>>> Next, in the routine where the boundary conditions are set, I pass a separate command :
>>>> PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "wall", "DamWall", 0, 1, &comp, (void (*)(void)) PhysicsBoundary_Dam_Wall, sizeof(damWallids), &damWallids, phys);
>>>> Ofcourse, in the function PhysicsBoundary_Dam_Wall() I set the vector value of [uh] to 0. When I do run the program, I do not see any of this in play (i.e., the values are not being constrained).
>>>> Is there a smarter way to go about this or would you suggest a correction in my current method?
>>>> Thank you in advance for your wonderful suggestions and work!
>>>> Regards,
>>>> Mukkund Sunjii
