[petsc-users] Norm_2 calculation
Fazlul Huq huq2090 at gmail.com
Fri Jun 5 11:32:44 CDT 2020
Input string:
mpiexec -np 1 ./poisson_m -n 10000000 -pc_type cholesky  -ksp_view
-ksp_converged_reason -ksp_monitor_true_residual
Output is attached herewith.
Thank you.
Sincerely,
Huq
On Fri, Jun 5, 2020 at 10:16 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 5, 2020 at 11:04 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Hello All,
>> I'm trying to calculate the norm_2 error of a solution.
>> Here, vector s: Analytical solution
>>           vector x: Numerical solution
>> ierr = VecView(s,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>> ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>  ierr = VecAXPY(x,-1.0,s);CHKERRQ(ierr);
>>  ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
>>  ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
>>  if (norm > tol) {
>>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Second Norm of error %g\n",
>> double)norm);CHKERRQ(ierr);
>>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Iterations
>> %D\n",its);CHKERRQ(ierr);
>> Am I calculating the "Norm_2" error correctly or making any mistake?
>> Unfortunately, for large sized matrix, say 10^6, I am getting very high
>> value of "Norm_2" error.
> 1) I am guessing x comes from a KSPSolve(). It is only as accurate as your
> tolerance
> 2) This is the l_2 norm, not the L_2 norm, so if you are using a continuum
> method like FEM, this is likely wrong.
>   Thanks,
>      Matt
>> Thank you.
>> Sincerely,
>> Huq
>> Fazlul Huq
>> Graduate Research Assistant
>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>> University of Illinois at Urbana-Champaign (UIUC)
>> E-mail: huq2090 at gmail.com
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/45066bb8/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/45066bb8/attachment.bin>
