[petsc-users] MatSeqBAIJSetPreallocation
Sanjay Govindjee
s_g at berkeley.edu
Thu Jun 4 18:13:04 CDT 2020
Thanks Mark.
Very helpful and explains why my other PETSC_NULL_INTEGER uses are still
functioning
and why in some places I have PETSC_NULL_INTEGER(1). I guess I can
replace the latter with PETSC_DEFAULT_INTEGER for a cleaner look.
On 6/4/20 3:58 PM, Mark Adams wrote:
> On Thu, Jun 4, 2020 at 6:41 PM Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
> thanks, that did it. now I am wondering about all the other
> PETSC_NULL_INTEGER instances in
> my code. how should I be thinking about PETSC_NULL_INTEGER
> I would think it's an integer array/pointer in C.
> and
> PETSC_DEFAULT_INTEGER,
> and an integer in C.
> so that I know that I am using the correct one?
> On 6/4/20 3:16 PM, Satish Balay wrote:
> > On Thu, 4 Jun 2020, Sanjay Govindjee wrote:
> >> I'm moving from 3.10 to 3.13 and ran into a compilation problem
> with
> >> MatSeqBAIJSetPreallocation( ).
> >> The manual page shows:
> >> PetscErrorCode
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSeqBAIJSetPreallocation.html#MatSeqBAIJSetPreallocation>(Mat
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
> >> B,PetscInt
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
> >> bs,PetscInt
> >> nz,const PetscInt
> >> nnz[])
> >> Which I think is the way it was before but my code is now
> tossing a compile
> >> error
> >> 65 | & PETSC_NULL_INTEGER,mr(np(246)),
> >> | 1
> >> Error: Rank mismatch in argument 'c' at (1) (scalar and rank-1)
> >> The full line looks like:
> >> call MatSeqBAIJSetPreallocation(Mmat,nsbk,
> > I think this should be PETSC_DEFAULT_INTEGER.
> > Previously there were no Interface definitions - so no error
> checks by the compiler.
> > Satish
> >> & ierr)
> >> Any suggestions on what I've messed up?
> >> -sanjay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/dc4a4b4f/attachment-0001.html>
