[petsc-users] MatSeqBAIJSetPreallocation
Sanjay Govindjee s_g at berkeley.edu
Thu Jun 4 17:40:21 CDT 2020
thanks, that did it.  now I am wondering about all the other
PETSC_NULL_INTEGER instances in
my code.  how should I be thinking about PETSC_NULL_INTEGER and
PETSC_DEFAULT_INTEGER,
so that I know that I am using the correct one?
On 6/4/20 3:16 PM, Satish Balay wrote:
> On Thu, 4 Jun 2020, Sanjay Govindjee wrote:
>> I'm moving from 3.10 to 3.13 and ran into a compilation problem with
>> MatSeqBAIJSetPreallocation( ).
>> The manual page shows:
>> PetscErrorCode
>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSeqBAIJSetPreallocation.html#MatSeqBAIJSetPreallocation>(Mat
>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
>> B,PetscInt
>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
>> bs,PetscInt
>> nz,const PetscInt
>> nnz[])
>> Which I think is the way it was before but my code is now tossing a compile
>> error
>>     65 |      & PETSC_NULL_INTEGER,mr(np(246)),
>>        |                                     1
>> Error: Rank mismatch in argument 'c' at (1) (scalar and rank-1)
>> The full line looks like:
>>          call MatSeqBAIJSetPreallocation(Mmat,nsbk,
> I think this should be PETSC_DEFAULT_INTEGER.
> Previously there were no Interface definitions - so no error checks by the compiler.
> Satish
>>      & ierr)
>> Any suggestions on what I've messed up?
>> -sanjay
