[petsc-users] Terminating a process running petsc via petsc4py without mpi_abort
Junchao Zhang
junchao.zhang at gmail.com
Thu Jun 4 15:50:16 CDT 2020
Hi, Steve,
Try this branch jczhang/let-signal-handler-call-exit to see if it fixed
your problem. If yes, vote for it at
https://gitlab.com/petsc/petsc/-/merge_requests/2745 :)
--Junchao Zhang
On Thu, Jun 4, 2020 at 3:40 PM Hudson, Stephen Tobias P via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Lisandro,
> I don't see an interface to set this through petsc4py. Is it possible?
> Thanks,
> Steve
> *From:* Hudson, Stephen Tobias P <shudson at anl.gov>
> *Sent:* Thursday, June 4, 2020 2:47 PM
> *To:* Balay, Satish <balay at mcs.anl.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Lisandro Dalcin <
> dalcinl at gmail.com>
> *Subject:* Re: Terminating a process running petsc via petsc4py without
> mpi_abort
> Sounds good. I will have a look at how to set this through petsc4py.
> Thanks
> Steve
> *From:* Satish Balay <balay at mcs.anl.gov>
> *Sent:* Thursday, June 4, 2020 2:32 PM
> *To:* Hudson, Stephen Tobias P <shudson at anl.gov>
> mpi_abort
> I don't completely understand the issue here. How is sequential run
> different than parallel run?
> In both cases - a PetscErrorHandler is likely getting invoked. One can
> change this behavior with:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscPushErrorHandler.html
> And there are a few default error handlers to choose
> PETSC_EXTERN PetscErrorCode PetscTraceBackErrorHandler(MPI_Comm,int,const
> char*,const char*,PetscErrorCode,PetscErrorType,const char*,void*);
> PETSC_EXTERN PetscErrorCode PetscIgnoreErrorHandler(MPI_Comm,int,const
> PetscEmacsClientErrorHandler(MPI_Comm,int,const char*,const
> PETSC_EXTERN PetscErrorCode PetscMPIAbortErrorHandler(MPI_Comm,int,const
> PETSC_EXTERN PetscErrorCode PetscAbortErrorHandler(MPI_Comm,int,const
> PetscAttachDebuggerErrorHandler(MPI_Comm,int,const char*,const
> PETSC_EXTERN PetscErrorCode PetscReturnErrorHandler(MPI_Comm,int,const
> Some of the are accessible via command line option. for ex:
> -on_error_abort or -on_error_mpiabort
> Or perhaps you want to completely disable error handler with:
> -no_signal_handler
> cc: petsc-users
> Satish
> On Thu, 4 Jun 2020, Hudson, Stephen Tobias P wrote:
> > Satish,
> > We are having issues caused by MPI_abort getting called when we try to
> terminate a sub-process running petsc4py. Ideally we would always use a
> serial build of petsc/petsc4py in this mode, but many users will have a
> parallel build. We need to be able to send a terminate signal that just
> kills the process.
> > Is there a way to turn off the mpi_abort?
> > Thanks,
> > Steve
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/d01148f3/attachment.html>
