[petsc-users] Running example problem
Fazlul Huq
huq2090 at gmail.com
Thu Jun 4 08:12:07 CDT 2020
Somehow, make is not working.
Please find the attachment herewith for the terminal readout.
Thank you.
Sincerely,
Huq
On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Hello,
>> I have a very preliminary question!
>> I think I have installed PETSc correctly cause I got following on the
>> terminal:
>> Command:
>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>> Response:
>> Running check examples to verify correct installation
>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>> processes
>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>> process
>> Completed test examples
>> Now, I am trying to run an example from the list of provided examples.
>> Can you please help me out, how to run an example problem from the list
>> of examples?
>> I mean, how to make executable and run the executable?
> cd $PETSC_DIR
> cd src/snes/tutorials
> make ex5
> ./ex5 -snes_monitor
> Thanks,
> Matt
>> Thank you.
>> Sincerely,
>> Huq
>> Fazlul Huq
>> Graduate Research Assistant
>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>> University of Illinois at Urbana-Champaign (UIUC)
>> E-mail: huq2090 at gmail.com
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/f12a5c9b/attachment-0001.html>
Name: Screenshot from 2020-06-04 08-10-33.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/f12a5c9b/attachment-0001.png>
