[petsc-users] TSAdjoint not working correctly when using TSThetaSetEndpoint(true)
Salazar De Troya, Miguel
salazardetro1 at llnl.gov
Tue Jun 2 14:36:10 CDT 2020
Hello,
I am attaching a simple example that uses TSAdjoint to calculate the sensitivity of a 1 degree of freedom ODE. When using theta methods, it returns the right sensitivity as given by the analytical solution. When I set `ts.setThetaEndpoint(True)`, it does not work. Is there a theoretical reason why? I was using this option because using the options
ts.setType(ts.Type.THETA)
ts.setTheta(0.5)
is equivalent to using ts.Type.CN
Thanks
Miguel
Miguel A. Salazar de Troya
Postdoctoral Researcher, Lawrence Livermore National Laboratory
B141
Rm: 1085-5
Ph: 1(925) 422-6411
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200602/52f1ecf9/attachment-0001.html>
Type: text/x-python-script
Desc: petsc_question_2.py
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200602/52f1ecf9/attachment-0001.bin>
