[petsc-users] Agglomeration for Multigrid on Unstructured Meshes
Tue Jun 2 03:54:32 CDT 2020
On Tue, Jun 2, 2020 at 4:49 AM Lawrence Mitchell <wence at gmx.li> wrote:
> > On 2 Jun 2020, at 09:35, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Jun 2, 2020 at 4:25 AM Lawrence Mitchell <wencel at gmail.com>
> wrote:
> > Hi Dave,
> > > On 2 Jun 2020, at 05:43, Dave May <dave.mayhem23 at gmail.com> wrote:
> > > On Tue 2. Jun 2020 at 03:30, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Mon, Jun 1, 2020 at 7:03 PM Danyang Su <danyang.su at gmail.com>
> wrote:
> > > Thanks Jed for the quick response. Yes I am asking about the
> repartitioning of coarse grids in geometric multigrid for unstructured
> mesh. I am happy with AMG. Thanks for letting me know.
> > > All the pieces are there, we just have not had users asking for this,
> and it will take some work to put together.
> > > Matt - I created a branch for you and Lawrence last year which added
> full support for PLEX within Telescope. This implementation was not a fully
> automated algmoeration strategy - it utilized the partition associated with
> the DM returned from DMGetCoarseDM. Hence the job of building the
> distributed coarse hierarchy was let to the user.
> > > I’m pretty sure that code got merged into master as the branch also
> contained several bug mixes for Telescope. Or am I mistaken?
> > I think you're right. I didn't manage to get the redistribution of the
> DMPlex object done last summer (it's bubbling up again).
> > As I see it, for redistributed geometric multigrid on plexes, the
> missing piece is a function:
> > DMPlexRedistributeOntoComm(DM old, MPI_Comm comm, DM *new)
> > I went down a rabbit hole of trying to do this, since I actually think
> this replaced the current interface to DMPlexDistribute, which is
> > DMPlexDistribute(DM old, PetscInt overlap, PetscSF *pointDistSF, DM *new)
> > Where the new DM comes out on the same communicator as the old DM, just
> with a different partition.
> > This has lots of follow-on consequences, for example, one can't easily
> load on P processes and then compute on Q.
> > Unfortunately, collectiveness over MPI_Comm(old) is baked into the
> redistribution routines everywhere, and I didn't manage to finish things.
> > Yes, I remember thinking this out. I believe the conclusion was that
> redistribution should happen on the large comm, which
> > some fraction of processes getting no cells. Then at the end we call one
> new function which copies that DM onto the smaller comm.
> I think this kind of works, but I worry that it makes the following
> usecase really painful.
> 1. Parallel load on P processes
> 2. Redistribute onto Q > P processes
> ... Compute
> 3. (Occasionally), checkpoint by mapping onto P processes and dumping
> Perhaps I don't understand your proposal properly, but I think you're
> saying that the _input_ DM in redistribute defines the processes that
> participate in the redistribution (and the _output_ DM just controls the
> size).
> This would then require me in my example to load on Q processes (not P) or
> else do some futzing around.
> Or do I have the wrong end of the stick?
> I think I would prefer an interface where I go from
> commOld -> commNew
> with the number of partitions determined by size(commNew)
> Then the restriction you have on the two communicators is one of:
> i. commOld \subseteq commNew
> ii. commOld \supseteq commNew
> I guess if you wanted to be really fancy you could make an
> intercommunicator of commOld \cap commNew, but now you have to carry
> another communicator around with you for data transfer etc...
> Perhaps internally you do this by making a DM on whichever the smaller of
> the two communicators is that is empty on a bunch of ranks and then copying
> in (or copying out) appropriately.
> I think a first step here is to break the assumption everywhere in the
> redistribution interface that the size of commOld determines the number of
> partitions you want, and instead move to using size(commNew). Then for now
> we just pass commNew=commOld.
I almost agree. I still think we do not change Distribute(), since it is
really convenient, but we do check sizes on input as you say.
We either,
  1) Copy the DM to a larger comm with empty slots on input
or
  2) Copy the DM to a smaller comm eliminating empty slots on output
depending on P_in < P_out, or the reverse.
  THanks,
    Matt
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200602/13393dbb/attachment.html>
