[petsc-users] PETSc Make error
Satish Balay
balay at mcs.anl.gov
Fri Jul 31 11:00:44 CDT 2020
You still get this error message - so its likely not installed. To confirm you [and the admin] can run:
python3 -c "import distutils.sysconfig"
[and see if you get an error or not]
You can also try python2 as I suggested in my earlier e-mail [if distutils is installed for python2]
python2 -c "import distutils.sysconfig"
python2 ./configure ...
Satish
On Fri, 31 Jul 2020, Eda Oktay wrote:
> Dear Matt,
> Administrator installed python3-dib-utils but still I am getting the
> same error message. I attached configure.log and make.log again.
> Thanks!
> Eda
> Matthew Knepley <knepley at gmail.com>, 31 Tem 2020 Cum, 13:20 tarihinde
> şunu yazdı:
> > On Fri, Jul 31, 2020 at 4:15 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> >> Dear Satish,
> >> I configured petsc-3.13.2. Is this still the same problem?
> > Yes, you need the distutils package installed.
> > Thanks,
> > Matt
> >> Thanks!
> >> Eda
> >> On Fri, Jul 31, 2020, 10:50 AM Satish Balay <balay at mcs.anl.gov> wrote:
> >>> File "./config/gmakegen.py", line 4, in <module>
> >>> from distutils.sysconfig import parse_makefile
> >>> ModuleNotFoundError: No module named 'distutils.sysconfig'
> >>> For one - if you used petsc-3.13.3 - it would have also tried python2 - or given a reasonable error message.
> >>> If you have python2 - you can try:
> >>> Or you can ask sysadmin on this machine to install python3-distutils or equivalent package.
> >>> Satish
> >>> > Hi all,
> >>> > I configured petsc-3.13.2 with following options:
> >>> > ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> >>> > --download-mpich --download-openblas --download-metis
> >>> > --download-parmetis --download-chaco --download-slepc --with-X=1
> >>> > However, I got a make error.
> >>> > I attached make.log and configure.log, how can I fix that problem?
> >>> > Thanks!
> >>> > Eda
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
