[petsc-users] PETSc Make error
Matthew Knepley
knepley at gmail.com
Fri Jul 31 05:20:45 CDT 2020
On Fri, Jul 31, 2020 at 4:15 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Dear Satish,
> I configured petsc-3.13.2. Is this still the same problem?
Yes, you need the distutils package installed.
Matt
> Thanks!
> Eda
> On Fri, Jul 31, 2020, 10:50 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> File "./config/gmakegen.py", line 4, in <module>
>> from distutils.sysconfig import parse_makefile
>> ModuleNotFoundError: No module named 'distutils.sysconfig'
>> For one - if you used petsc-3.13.3 - it would have also tried python2 -
>> or given a reasonable error message.
>> If you have python2 - you can try:
>> python2 ./configure ...
>> Or you can ask sysadmin on this machine to install python3-distutils or
>> equivalent package.
>> Satish
>> On Fri, 31 Jul 2020, Eda Oktay wrote:
>> > Hi all,
>> > I configured petsc-3.13.2 with following options:
>> > ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
>> > --download-mpich --download-openblas --download-metis
>> > --download-parmetis --download-chaco --download-slepc --with-X=1
>> > However, I got a make error.
>> > I attached make.log and configure.log, how can I fix that problem?
>> > Thanks!
>> > Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200731/50a0f606/attachment.html>
