[petsc-users] Petsc configure error (cmake)
Eda Oktay
eda.oktay at metu.edu.tr
Tue Jul 28 15:28:17 CDT 2020
Dear Barry,
Thank you so much for answering. So, I downloaded the tar.gz file and
now, should I configure this file with my previous options? I am
using the following line:
./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-make --download-mpich --download-openblas --download-metis
--download-parmetis --download-chaco
--download-slepc=/home/eda/slepc-v3.13.2.tar.gz --download-cmake
--with-X=1
Thanks so much again!
Eda
Barry Smith <bsmith at petsc.dev>, 28 Tem 2020 Sal, 20:55 tarihinde şunu yazdı:
> Eda,
> The branch barry/2020-07-28/cmake-use-make-if-given/maint should resolve the problem. It will force the cmake build to use the make obtained with --download-make
> Barry
> On Jul 28, 2020, at 9:48 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 28, 2020 at 10:45 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
>> I am trying to download Petsc with slepc,openblas,mpich,meti,parmetis
>> and chaco to a linux computer (probably
>> ubuntu, I don't know because I am using it via ssh).
>> Due to an error, for metis, I needed to download cmake, so I added
>> this option, too. However, I got an error telling me that "Error
>> running configure on cmake". I attached configure.log.
>> What should I do? Where is the problem and how can ı fix it?
>> Thank you so much for answering,
> It looks like you do not have 'make' in your path, and CMake is feaking out:
> CMAKE was just downloaded, forcing a rebuild because cannot determine if package has changed
> Running configure on CMAKE; this may take several minutes
> Running Executable WITHOUT threads to time it out
> Executing: ./configure --prefix=/home/eda/petsc-3.13.2/arch-linux-c-debug --parallel=40
> stdout:
> CMake 3.15.6, Copyright 2000-2019 Kitware, Inc. and Contributors
> Found GNU toolchain
> C compiler on this system is: gcc
> C++ compiler on this system is: g++
> Error when bootstrapping CMake:
> Cannot find appropriate Makefile processor on this system.
> Please specify one using environment variable MAKE.
> Log of errors: /home/eda/petsc-3.13.2/arch-linux-c-debug/externalpackages/cmake-3.15.6/Bootstrap.cmk/cmake_bootstrap.log
> Thanks,
> Matt
>> Eda
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
