[petsc-users] Petsc configure error (cmake)
Matthew Knepley
knepley at gmail.com
Tue Jul 28 09:48:56 CDT 2020
On Tue, Jul 28, 2020 at 10:45 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> I am trying to download Petsc with slepc,openblas,mpich,meti,parmetis
> and chaco to a linux computer (probably
> ubuntu, I don't know because I am using it via ssh).
> Due to an error, for metis, I needed to download cmake, so I added
> this option, too. However, I got an error telling me that "Error
> running configure on cmake". I attached configure.log.
> What should I do? Where is the problem and how can ı fix it?
> Thank you so much for answering,
It looks like you do not have 'make' in your path, and CMake is feaking out:
CMAKE was just downloaded, forcing a rebuild because cannot determine if
package has changed
Running configure on CMAKE; this may take
several minutes
Running Executable WITHOUT threads to time it out
Executing: ./configure --prefix=/home/eda/petsc-3.13.2/arch-linux-c-debug
--parallel=40
stdout:
CMake 3.15.6, Copyright 2000-2019 Kitware, Inc. and Contributors
Found GNU toolchain
C compiler on this system is: gcc
C++ compiler on this system is: g++
Error when bootstrapping CMake:
Cannot find appropriate Makefile processor on this system.
Please specify one using environment variable MAKE.
Log of errors:
/home/eda/petsc-3.13.2/arch-linux-c-debug/externalpackages/cmake-3.15.6/Bootstrap.cmk/cmake_bootstrap.log
Matt
> Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/f2016dc9/attachment.html>
