[petsc-users] VecLoad into a SubVector ?
    Sajid Ali
    sajidsyed2021 at u.northwestern.edu
    Mon Jul 27 23:34:33 CDT 2020
Hi Barry/Matt,
The fix to this bug would be to disable replacearray op on a subvector. I
modified the source code for vecio.c forcing VecLoad_HDF5 to always perform
an array copy and the above test passes for both binary and hdf5 viewers in
serial and parallel.
I can open a PR that adds a line Z->ops->replacearray = NULL; at line 1286
in the rvector.c file if one of you can confirm that the above logic is
correct. The example attached in the last email could be used as a test for
the same if necessary.
Thank You,
Sajid Ali | PhD Candidate
Applied Physics
Northwestern University
s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200727/89875cdc/attachment.html>
