[petsc-users] Installation failure
Matthew Knepley
knepley at gmail.com
Mon Jul 27 05:34:00 CDT 2020
On Mon, Jul 27, 2020 at 3:08 AM Rubem Mondaini <rmondaini at csrc.ac.cn> wrote:
> Dears,
> I have tried to install the PETSc library on my machine and I am
> failing. I have managed to install it on another one, which possess
> similar configurations for the compilers, and there things do seem to be
> very much fine.
> I am attaching the corresponding configure.log. Is there something
> simple that I am missing?
Your configuration does not need C++, so you can use
--with-cxx=0
If you want to fix it, the first thing to try is turning off autodetection
--with-cxxlib-autodetect=0
which usually means you need something like
--LIBS=-lstdc++
Matt
> Best,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200727/8d8dd43d/attachment.html>
