[petsc-users] SUPERLU_DIST in single precision
Barry Smith
bsmith at petsc.dev
Tue Jul 21 19:21:40 CDT 2020
Felix,
What are your needs, do you want this for CPUs or for GPUs? Do you wish to run all your code in single precision or just the SuperLU_Dist solver while the rest of your code double?
If you want to run everything on CPUs using single precision then adding the support is very easy, we can provide that for you any time. The other cases will require more thought.
Barry
> On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
> Dear PETSc support team,
> some time ago you told me that you are planning on releasing a version that supports SUPERLU_DIST in single-precision soon. Can you tell me roughly what time frame you had in mind?
> Best regards,
> Felix
