[petsc-users] Tough to reproduce petsctablefind error
Fande Kong
fdkong.jd at gmail.com
Mon Jul 20 11:34:56 CDT 2020
Hi Mark,
Thanks for your reply.
On Mon, Jul 20, 2020 at 7:13 AM Mark Adams <mfadams at lbl.gov> wrote:
> Fande,
> do you know if your 45226154 was out of range in the real matrix?
I do not know since it was in building the AMG hierarchy. The size of the
original system is 1,428,284,880
> What size integers do you use?
We are using 64-bit via "--with-64-bit-indices"
I am trying to catch the cause of this issue by running more simulations
with different configurations.
Fande,
> Mark
> On Mon, Jul 20, 2020 at 1:17 AM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Trace could look like this:
>> [640]PETSC ERROR: --------------------- Error Message
>> [640]PETSC ERROR: Argument out of range
>> [640]PETSC ERROR: key 45226154 is greater than largest key allowed 740521
>> [640]PETSC ERROR: See
>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> [640]PETSC ERROR: Petsc Release Version 3.13.3, unknown
>> [640]PETSC ERROR: ../../griffin-opt on a arch-moose named r6i5n18 by
>> wangy2 Sun Jul 19 17:14:28 2020
>> [640]PETSC ERROR: Configure options --download-hypre=1
>> --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1
>> --download-metis=1 --download-ptscotch=1 --download-parmetis=1
>> --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1
>> --download-slepc=1 --with-mpi=1 --with-cxx-dialect=C++11
>> --with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices
>> --download-mumps=0
>> [640]PETSC ERROR: #1 PetscTableFind() line 132 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/include/petscctable.h
>> [640]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mmaij.c
>> [640]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 876 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiaij.c
>> [640]PETSC ERROR: #4 MatAssemblyEnd() line 5347 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matrix.c
>> [640]PETSC ERROR: #5 MatPtAPNumeric_MPIAIJ_MPIXAIJ_allatonce() line 901
>> in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiptap.c
>> [640]PETSC ERROR: #6 MatPtAPNumeric_MPIAIJ_MPIMAIJ_allatonce() line 3180
>> in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/maij/maij.c
>> [640]PETSC ERROR: #7 MatProductNumeric_PtAP() line 704 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matproduct.c
>> [640]PETSC ERROR: #8 MatProductNumeric() line 759 in
>> [640]PETSC ERROR: #9 MatPtAP() line 9199 in
>> [640]PETSC ERROR: #10 MatGalerkin() line 10236 in
>> [640]PETSC ERROR: #11 PCSetUp_MG() line 745 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/mg/mg.c
>> [640]PETSC ERROR: #12 PCSetUp_HMG() line 220 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/hmg/hmg.c
>> [640]PETSC ERROR: #13 PCSetUp() line 898 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/interface/precon.c
>> [640]PETSC ERROR: #14 KSPSetUp() line 376 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/ksp/interface/itfunc.c
>> [640]PETSC ERROR: #15 KSPSolve_Private() line 633 in
>> [640]PETSC ERROR: #16 KSPSolve() line 853 in
>> [640]PETSC ERROR: #17 SNESSolve_NEWTONLS() line 225 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/impls/ls/ls.c
>> [640]PETSC ERROR: #18 SNESSolve() line 4519 in
>> /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/interface/snes.c
>> On Sun, Jul 19, 2020 at 11:13 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> I am not entirely sure what is happening, but we encountered similar
>>> issues recently. It was not reproducible. It might occur at different
>>> stages, and errors could be weird other than "ctable stuff." Our code was
>>> Valgrind clean since every PR in moose needs to go through rigorous
>>> Valgrind checks before it reaches the devel branch. The errors happened
>>> when we used mvapich.
>>> We changed to use HPE-MPT (a vendor stalled MPI), then everything was
>>> smooth. May you try a different MPI? It is better to try a system carried
>>> one.
>>> We did not get the bottom of this problem yet, but we at least know this
>>> is kind of MPI-related.
>>> Thanks,
>>> Fande,
>>> On Sun, Jul 19, 2020 at 3:28 PM Chris Hewson <chris at resfrac.com> wrote:
>>>> Hi,
>>>> I am having a bug that is occurring in PETSC with the return string:
>>>> [7]PETSC ERROR: PetscTableFind() line 132 in
>>>> /home/chewson/petsc-3.13.2/include/petscctable.h key 7556 is greater than
>>>> largest key allowed 5693
>>>> This is using petsc-3.13.2, compiled and running using mpich with -O3
>>>> and debugging turned off tuned to the haswell architecture and
>>>> occurring either before or during a KSPBCGS solve/setup or during a MUMPS
>>>> factorization solve (I haven't been able to replicate this issue with the
>>>> same set of instructions etc.).
>>>> This is a terrible way to ask a question, I know, and not very helpful
>>>> from your side, but this is what I have from a user's run and can't
>>>> reproduce on my end (either with the optimization compilation or with
>>>> debugging turned on). This happens when the code has run for quite some
>>>> time and is happening somewhat rarely.
>>>> More than likely I am using a static variable (code is written in c++)
>>>> that I'm not updating when the matrix size is changing or something silly
>>>> like that, but any help or guidance on this would be appreciated.
>>>> *Chris Hewson*
>>>> Senior Reservoir Simulation Engineer
>>>> ResFrac
>>>> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/954aa27c/attachment.html>
