[petsc-users] PetscLogFlops Error
    Karl Yang
    y.juntao at hotmail.com
    Sat Jul 18 23:27:30 CDT 2020
Hello,
I was using FGMRES solver with fieldsplit preconditioner for solving a fluid equation.
I have the code ran for coarser meshes and it works fine. But when I got it to run for very fine meshes I encountered the PetscLogFlops error.
The following is the output of error and the output from kspview.
[7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[7]PETSC ERROR: Argument out of range
[7]PETSC ERROR: Cannot log negative flops
[7]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[7]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
[7]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named hsw222 by yjuntao Sat Jul 18 20:30:05 2020
[7]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
[7]PETSC ERROR: #1 PetscLogFlops() line 232 in /usr/local/petsc/petsc-3.12.5/include/petsclog.h
[7]PETSC ERROR: #2 MatSolve_SeqAIJ() line 3200 in /usr/local/petsc/petsc-3.12.5/src/mat/impls/aij/seq/aijfact.c
[7]PETSC ERROR: #3 MatSolve() line 3290 in /usr/local/petsc/petsc-3.12.5/src/mat/interface/matrix.c
[7]PETSC ERROR: #4 PCApply_LU() line 177 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/factor/lu/lu.c
[7]PETSC ERROR: #5 PCApply() line 444 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[7]PETSC ERROR: #6 KSP_PCApply() line 281 in /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
[7]PETSC ERROR: #7 KSPInitialResidual() line 65 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itres.c
[7]PETSC ERROR: #8 KSPSolve_GMRES() line 236 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/gmres.c
[7]PETSC ERROR: #9 KSPSolve() line 760 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
[7]PETSC ERROR: #10 PCApply_FieldSplit_Schur() line 1180 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[7]PETSC ERROR: #11 PCApply() line 444 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[7]PETSC ERROR: #12 KSP_PCApply() line 281 in /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
[7]PETSC ERROR: #13 KSPFGMRESCycle() line 166 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
[7]PETSC ERROR: #14 KSPSolve_FGMRES() line 291 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
[7]PETSC ERROR: #15 KSPSolve() line 760 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
There is some issues during kspview if PCLSC is used as shown below. But the code could be ran if I do not show ksp details.
In order to show the whole ksp setup, I also attached another kspview output without PCLSC.
======================kspview output ==============================
KSP Object: 1 MPI processes
type: fgmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
right preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: fieldsplit
FieldSplit with Schur preconditioner, blocksize = 1, factorization FULL
Preconditioner for the Schur complement formed from S itself
Split info:
Split number 0 Defined by IS
Split number 1 Defined by IS
KSP solver for A00 block
KSP Object: (fieldsplit_0_) 1 MPI processes
type: gmres
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using DEFAULT norm type for convergence test
PC Object: (fieldsplit_0_) 1 MPI processes
type: lu
PC has not been set up so information may be incomplete
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
linear system matrix = precond matrix:
Mat Object: (fieldsplit_0_) 1 MPI processes
type: seqaijcusparse
rows=8396802, cols=8396802
total: nonzeros=75440146, allocated nonzeros=75440146
total number of mallocs used during MatSetValues calls=0
not using I-node routines
KSP solver for S = A11 - A10 inv(A00) A01
KSP Object: (fieldsplit_1_) 1 MPI processes
type: gmres
PC Object: (fieldsplit_1_) 1 MPI processes
type: lsc
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 1
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
[0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named hsw221 by yjuntao Sat Jul 18 21:08:42 2020
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
[0]PETSC ERROR: #1 KSPView() line 111 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #2 PCView_LSC() line 142 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/lsc/lsc.c
[0]PETSC ERROR: #3 PCView() line 1588 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #4 KSPView() line 217 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #5 PCView_FieldSplit_Schur() line 238 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #6 PCView() line 1588 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #7 KSPView() line 217 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itcreate.c
=====================KSP without PCLSC======================================
type: fgmres
type: fieldsplit
Split info:
type: gmres
type: lu
matrix ordering: nd
type: gmres
type: none
Mat Object: (fieldsplit_1_) 1 MPI processes
type: schurcomplement
rows=1050625, cols=1050625
Schur complement A11 - A10 inv(A00) A01
A11
total: nonzeros=0, allocated nonzeros=0
A10
Mat Object: 1 MPI processes
rows=1050625, cols=8396802
total: nonzeros=44060674, allocated nonzeros=44060674
KSP of A00
type: gmres
type: lu
matrix ordering: nd
A01
rows=8396802, cols=1050625
total: nonzeros=43995146, allocated nonzeros=43995146
rows=9447427, cols=9447427
total: nonzeros=163495966, allocated nonzeros=163643398
Regards
JT
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200719/e2b19a9d/attachment.html>
