[petsc-users] Errors encountered with KSPsolver with MATNEST and VECNEST
Matthew Knepley
knepley at gmail.com
Thu Jul 16 06:43:31 CDT 2020
On Thu, Jul 16, 2020 at 6:54 AM Yang Juntao <Y.Juntao at hotmail.com> wrote:
> Hi, Matt,
> In case, I want to put blocks of matrices(assembled independently)
> together as the system matrix just as in the example. What would be your
> recommended approach?
> I first looked into MatCreateBlockMat, but it only supports sequential and
> then I was directed to MATNEST. Do I have to assemble directly on “system
> matrix”.
The idea is that you use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSubMatrix.html
This does require the extra step of calling
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetLocalToGlobalMapping.html#MatSetLocalToGlobalMapping
but you must already have this in order to get the global indices.
If you use that, then you can assemble locally into AIJ or Nest with the
same code.
Matt
> Matrices of this type are nominally-sparse matrices in which each "entry"
> is a Mat
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
> object. Each Mat
> must have the same size and be sequential. The local and global sizes must
> be compatible with this decomposition. For matrices containing parallel
> submatrices and variable block sizes, see MATNEST
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATNEST.html#MATNEST>.
> Regards
> Juntao
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Thursday, July 16, 2020 5:56 PM
> *To:* Karl Yang <y.juntao at hotmail.com>
> *Cc:* Junchao Zhang <junchao.zhang at gmail.com>; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Errors encountered with KSPsolver with
> MATNEST and VECNEST
> On Thu, Jul 16, 2020 at 5:43 AM Karl Yang <y.juntao at hotmail.com> wrote:
> Hi, Matt,
> Sorry for the confusion. The error shows as below without SetIS().
> I see the problem now. It is about the interface for MatNest.
> MatNest is intended _only_ as an optimization. I think you should never
> have MatNest in user code. Here the
> problem is that MatNest only supports extraction using the ISes it was
> created with, whereas detection is
> finding a different IS. I recommend getting everything working with AIJ,
> and then use MatSetType() or
> -mat_type at the end to try out Nest. The interfaces are the same.
> Thanks,
> Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Could not find index set
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
> [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named ae3f0ab5a8c4 by
> Unknown Thu Jul 16 17:36:52 2020
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
> [0]PETSC ERROR: #1 MatNestFindIS() line 365 in
> /usr/local/petsc/petsc-3.12.5/src/mat/impls/nest/matnest.c
> [0]PETSC ERROR: #2 MatNestFindSubMat() line 425 in
> [0]PETSC ERROR: #3 MatCreateSubMatrix_Nest() line 456 in
> [0]PETSC ERROR: #4 MatCreateSubMatrix() line 7859 in
> /usr/local/petsc/petsc-3.12.5/src/mat/interface/matrix.c
> [0]PETSC ERROR: #5 PCSetUp_FieldSplit() line 676 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #6 PCSetUp() line 894 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: Corrupt argument:
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
> [0]PETSC ERROR: #7 MatDestroy() line 1266 in
> [0]PETSC ERROR: #8 PCSetUp_FieldSplit() line 697 in
> [0]PETSC ERROR: #9 PCSetUp() line 894 in
> [0]PETSC ERROR: #10 KSPSetUp() line 376 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
> KSP Object: 1 MPI processes
> type: fgmres
> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> right preconditioning
> using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: fieldsplit
> PC has not been set up so information may be incomplete
> FieldSplit with Schur preconditioner, blocksize = 1, factorization FULL
> Preconditioner for the Schur complement formed from S itself
> Split info:
> Split number 0 Defined by IS
> Split number 1 Defined by IS
> KSP solver for A00 block
> KSP Object: (fieldsplit_0_) 1 MPI processes
> type: preonly
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: (fieldsplit_0_) 1 MPI processes
> type not yet set
> KSP solver for upper A00 in upper triangular factor
> not yet available
> KSP solver for S = A11 - A10 inv(A00) A01
> not yet available
> linear system matrix = precond matrix:
> Mat Object: 1 MPI processes
> type: nest
> rows=15, cols=15
> Matrix object:
> type=nest, rows=3, cols=3
> MatNest structure:
> (0,0) : type=seqaij, rows=5, cols=5
> (0,1) : NULL
> (0,2) : type=seqaij, rows=5, cols=5
> (1,0) : NULL
> (1,1) : type=seqaij, rows=5, cols=5
> (1,2) : type=seqaij, rows=5, cols=5
> (2,0) : type=seqaij, rows=5, cols=5
> (2,1) : type=seqaij, rows=5, cols=5
> (2,2) : NULL
> Segmentation fault (core dumped)
> Attached is the test code.
> Regards
> JT
> On Jul 16 2020, at 5:30 pm, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jul 16, 2020 at 1:23 AM Karl Yang <y.juntao at hotmail.com
> <https://link.getmailspring.com/link/1D2D2990-B215-4510-B196-F29BD06D4684@getmailspring.com/0?redirect=mailto%3Ay.juntao%40hotmail.com&recipient=a25lcGxleUBnbWFpbC5jb20%3D>>
> wrote:
> [image: Sent from Mailspring]
> Hi, Junchao,
> Thank you. It works. :)
> May I ask some follow up question regarding the same example about
> fieldsplit. I am trying to learn about matnest with fieldsplit
> preconditioner on manual page 94. But I get a bit lost trying to understand
> fields, ISs once it is not eactly the same on the manual.
> In this same example, I tried to use PCFIELDSPLIT and
> PCFieldSplitSetDetectSaddlePoint as follows.
> You cannot mix DetectSaddlePoint() with SetIS() since the detection tries
> to make the proper ISes. Maybe we should check that.
> Thanks,
> Matt
> IS rows[3];
> IS cols[3];
> MatNestGetISs(testMesh->system, rows, cols);
> KSP ksp;
> PC pc;
> KSPCreate(PETSC_COMM_WORLD, &ksp);
> KSPSetType(ksp, KSPFGMRES);
> KSPSetOperators(ksp, testMesh->system, testMesh->system);
> KSPGetPC(ksp, &pc);
> PCFieldSplitSetIS(pc, "u", rows[0]);
> PCFieldSplitSetIS(pc, "v", rows[1]);
> PCFieldSplitSetIS(pc, "p", rows[2]);
> PCSetType(pc, PCFIELDSPLIT);
> PCFieldSplitSetDetectSaddlePoint(pc, PETSC_TRUE);
> KSPSetUp(ksp);
> KSPSolve(ksp, testMesh->rhs, testMesh->solution);
> But I will get the following error,
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble shooting.
> [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by
> Unknown Thu Jul 16 13:08:39 2020
> [0]PETSC ERROR: #7 KSPSetUp() line 376 in
> trouble shooting.
> [0]PETSC ERROR: #8 MatDestroy() line 1266 in
> [0]PETSC ERROR: #9 PCSetUp_FieldSplit() line 697 in
> [0]PETSC ERROR: #10 PCSetUp() line 894 in
> [0]PETSC ERROR: #11 KSPSetUp() line 376 in
> [0]PETSC ERROR: #12 KSPSolve() line 703 in
> I read about the examples on the manual and mostly are based on 2*2
> blocks but still cannot figure out how pcfieldsplit should be set in this 3*
> **3 blocks, and how IS should be set accordingly. I read about
> -fieldsplit_1_pc_type none option suggested on the documentation, but I am
> not sure is it still valid in a 33 blocks.*
> *Regards*
> *JT*
> On Jul 16 2020, at 6:57 am, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Adding the MatNestSetVecType() line fixed the problem. But I don't know
> why petsc had this weird design originally.
> MatCreateNest(PETSC_COMM_WORLD, 3, NULL, 3, NULL, mblock,
> &testMesh->system);
> + MatNestSetVecType(testMesh->system,VECNEST);
> --Junchao Zhang
> On Wed, Jul 15, 2020 at 2:16 PM Karl Yang <y.juntao at hotmail.com> wrote:
> Hi, Barry,
> I created a minimum example to reproduce the error. The example code is
> attached.
> type: nest
> Matrix object:
> MatNest structure:
> (0,1) : NULL
> (1,0) : NULL
> (2,2) : NULL
> Vec Object: 1 MPI processes
> type: nest
> VecNest, rows=3, structure:
> (0) : type=seq, rows=5
> type: seq
> 1.
> 1.
> 1.
> 1.
> 1.
> (1) : type=seq, rows=5
> type: seq
> 1.
> 1.
> 1.
> 1.
> 1.
> (2) : type=seq, rows=5
> type: seq
> 1.
> 1.
> 1.
> 1.
> 1.
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Nest vector argument 2 not setup.
> trouble shooting.
> Unknown Thu Jul 16 03:11:02 2020
> [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
> /usr/local/petsc/petsc-3.12.5/src/vec/vec/impls/nest/vecnest.c
> [0]PETSC ERROR: #2 VecCopy() line 1577 in
> /usr/local/petsc/petsc-3.12.5/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #3 KSPInitialResidual() line 61 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #5 KSPSolve() line 760 in
> On Jul 16 2020, at 2:39 am, Barry Smith <bsmith at petsc.dev> wrote:
> Could be a bug in PETSc, please send a sample program that produces the
> problem.
> Barry
> On Jul 15, 2020, at 1:28 PM, Karl Yang <y.juntao at hotmail.com
> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/0?redirect=mailto%3Ay.juntao%40hotmail.com&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
> wrote:
> Hi, Barry,
> Thanks for your reply. I output the matrix and vec with matview and
> vecview. And I think I do have the values set as it has been shown.
> type: nest
> Matrix object:
> MatNest structure:
> (0,0) : type=seqaij, rows=25, cols=25
> (0,1) : NULL
> (0,2) : type=seqaij, rows=25, cols=25
> (1,0) : NULL
> (1,1) : type=seqaij, rows=25, cols=25
> (1,2) : type=seqaij, rows=25, cols=25
> (2,0) : type=seqaij, rows=25, cols=25
> (2,1) : type=seqaij, rows=25, cols=25
> (2,2) : NULL
> type: nest
> (0) : type=seq, rows=25
> type: seq
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 75.8279
> -51.0776
> -75.8279
> 0.
> 0.
> -90.8404
> 58.7011
> 90.8404
> 0.
> 0.
> -75.8279
> 51.0776
> 75.8279
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> (1) : name="Vec_0x84000000_0", type=seq, rows=25
> Vec Object: Vec_0x84000000_0 1 MPI processes
> type: seq
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 75.8279
> -51.0776
> -75.8279
> 0.
> 0.
> -90.8404
> 58.7011
> 90.8404
> 0.
> 0.
> -75.8279
> 51.0776
> 75.8279
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> (2) : type=seq, rows=25
> type: seq
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> [0]PETSC ERROR: Nest vector argument 4 not setup.
> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/1?redirect=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D> for
> trouble shooting.
> Unknown Thu Jul 16 02:15:26 2020
> [0]PETSC ERROR: #1 VecPointwiseMult_Nest() line 245 in
> [0]PETSC ERROR: #2 VecPointwiseMult() line 1107 in
> [0]PETSC ERROR: #3 PCApply_Jacobi() line 272 in
> /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/jacobi/jacobi.c
> [0]PETSC ERROR: #4 PCApply() line 444 in
> [0]PETSC ERROR: #5 KSP_PCApply() line 281 in
> /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #6 KSPInitialResidual() line 65 in
> [0]PETSC ERROR: #7 KSPSolve_GMRES() line 236 in
> [0]PETSC ERROR: #8 KSPSolve() line 760 in
> On Jul 16 2020, at 2:13 am, Barry Smith <bsmith at petsc.dev
> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/2?redirect=mailto%3Absmith%40petsc.dev&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
> wrote:
> From the error message the second vector you are using to form the nest
> vector has not been completely created/set up. Make sure you called either
> VecCreateSeq(), VecCreateMPI() or did VecCreate(), VecSetType(), VecSetUp()
> and if it is the right hand side make sure you put numerical values in it.
> Barry
> On Jul 15, 2020, at 1:05 PM, Karl Yang <y.juntao at hotmail.com
> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/3?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F0%3Fredirect%3Dmailto%253Ay.juntao%2540hotmail.com%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
> wrote:
> Hello,
> I'm trying to solve a 2*2 block matrix system.
> I managed to form a 2*2 MatNest and a 21 VecNest. However when I try to
> make use of ksp solve, I encounter the following error. There is only one
> or two examples on MatNest and VecNest. I could not figure out what could
> be the trouble.
> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/4?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F1%3Fredirect%3Dhttps%253A%252F%252Fwww.mcs.anl.gov%252Fpetsc%252Fdocumentation%252Ffaq.html%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D> for
> trouble shooting.
> Unknown Thu Jul 16 01:56:11 2020
> Regards
> JT
> experiments lead.
> -- Norbert Wiener
> <https://link.getmailspring.com/link/1D2D2990-B215-4510-B196-F29BD06D4684@getmailspring.com/1?redirect=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&recipient=a25lcGxleUBnbWFpbC5jb20%3D>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200716/0eec520f/attachment-0001.html>
