[petsc-users] DM_BOUNDARY_GHOSTED
David Scott
d.scott at epcc.ed.ac.uk
Thu Jul 9 10:53:12 CDT 2020
Hello Matt,
I am sorry that I have not replied before now.
I think that the reason you did not understand the question was that the
question was silly but I'll try to explain my thought process anyway.
If you have a periodic boundary condition then when you construct a
matrix to be used by a KSP it can address the ghost points corresponding
to the periodic boundaries. So, I wondered if when you have ghosted
boundary conditions you could refer to those ghosted points too when
constructing the matrix. This led on to the question of how those values
would be obtained when the linear solver came to be executed.
At this point I expect you are asking why on earth I would want to do
that and I do not have an adequate response.
I am sorry I wasted your time and thanks for your help,
David
On 18/02/2020 20:23, Matthew Knepley wrote:
> On Tue, Feb 18, 2020 at 10:23 AM SCOTT David <d.scott at epcc.ed.ac.uk
> <mailto:d.scott at epcc.ed.ac.uk>> wrote:
> Hello Matt,
> Thanks for the quick response.
> Sorry to be dense but I want the ghost(ed) values to be used by
> KSPSolve where the KSP has an associated DM. I can, of course
> create a local vector using DMGetLocalVector and then populate the
> ghosted locations but I do not know how to get the KSPSolve to use
> these values in the way that automatically generated periodic,
> ghost values would be.
> Let me try and understand. We normally distinguish between
> global vectors and local vectors. Global vectors, used in the solver,
> describe the entire space. Local vectors, used in assembly, describe
> overlapping patches of the space. The ghost values would only be used
> in assembly, not in the solver, since they help make the correct
> value, but have no equation associated with themselves. Am I
> misunderstanding something?
> Thanks,
> Matt
> Thanks,
> David
> On 18/02/2020 12:42, Matthew Knepley wrote:
>> On Tue, Feb 18, 2020 at 6:03 AM David Scott
>> <d.scott at epcc.ed.ac.uk <mailto:d.scott at epcc.ed.ac.uk>> wrote:
>> Hello,
>> I wish to solve a channel flow problem with different boundary
>> conditions. In the streamwise direction I may have periodic or
>> inlet/outlet BCs. I would like to make my code for the two
>> cases as
>> similar as possible. If I use DM_BOUNDARY_PERIODIC then when
>> performing
>> a linear solve the ghost values will be set automatically.
>> For the
>> inlet/outlet case can I use DM_BOUNDARY_GHOSTED instead and
>> somehow
>> arrange for values that I specify to be placed in the ghost
>> locations?
>> Yes, that is the intent.
>> Thanks,
>> Matt
>> Thanks,
>> David
>> The University of Edinburgh is a charitable body, registered
>> in Scotland, with registration number SC005336.
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200709/bcdbbb96/attachment.html>
