[petsc-users] Parallel sort in Petsc
Antoine Côté Antoine.Cote3 at USherbrooke.ca
Tue Jul 7 08:14:21 CDT 2020
I need to compute the permutations to sort scalar values of a Vec object in decreasing order. I've been developing on a single process for now, using VecGetArrayRead() to extract the values and PetscSortRealWithPermutation() to get the permutations.
I would like to run the code on multiple processes. From these links, I can see it's an issue :
https://lists.mcs.anl.gov/pipermail/petsc-users/2013-November/019628.html
https://lists.mcs.anl.gov/pipermail/petsc-users/2009-June/004621.html
One work around I've been considering : get the max scalar value using VecMax() ; compute a scaling factor that makes this max value equals the largest integer value tolerated by PetscInt ; scale all values of Vec and convert them to integers ; use PetscParallelSortInt() ; inverse the scaling on (now sorted) integers values and convert them back to scalars.
This is only a patch really, the main issues being : (1) I would get a sorted Vec, not the permutations and (2) there would be a lost of information when converting scalars to int values.
Isn't there a way to parallel sort real values using Petsc?
Thank you very much!
Antoine Côté
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200707/64add698/attachment-0001.html>
