[petsc-users] EPSGetEigenpair Error
Eda Oktay
eda.oktay at metu.edu.tr
Mon Jul 6 04:21:32 CDT 2020
Thanks!
Jose E. Roman <jroman at dsic.upv.es>, 6 Tem 2020 Pzt, 12:10 tarihinde şunu yazdı:
> The index i should be a value between 0 and nconv-1
> https://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSGetEigenpair.html
> Jose
> > El 6 jul 2020, a las 11:06, Eda Oktay <eda.oktay at metu.edu.tr> escribió:
> > Hello,
> > I am using EPSGetEigenpair to find some matrices' eigenpairs:
> > ierr = EPSGetType(eps,&type);CHKERRQ(ierr)
> > ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRQ(ierr);
> > ierr = MatCreateVecs(L,&vr,NULL);CHKERRQ(ierr);
> > Vec *V;
> > VecDuplicateVecs(vr,nev,&V);
> > for (i=0; i<nev;i++){
> > ierr = EPSGetEigenpair(eps,i,&kr,NULL,V[i],NULL);
> > However, for some matrices, even though nev = 2, I am getting the
> > following error:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Argument out of range
> > [0]PETSC ERROR: Argument 2 out of range
> > [0]PETSC ERROR: See
> > https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> > shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.13.2, Jun 02, 2020
> > [0]PETSC ERROR: ./deneme_new_vecscatter_arastep on a
> > arch-linux2-c-debug named b342.wls.metu.edu.tr by edaoktay Mon Jul 6
> > 12:01:14 2020
> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> > --download-mpich --download-openblas --download-slepc --download-metis
> > --download-parmetis --download-chaco --with-X=1
> > [0]PETSC ERROR: #1 EPSGetEigenpair() line 411 in
> > /home/edaoktay/petsc-3.13.2/arch-linux2-c-debug/externalpackages/git.slepc/src/eps/interface/epssolve.c
> > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > = PID 8635 RUNNING AT b342.wls.metu.edu.tr
> > = EXIT CODE: 134
> > = CLEANING UP REMAINING PROCESSES
> > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
> > This typically refers to a problem with your application.
> > Please see the FAQ page for debugging suggestions
> > What can be the reason? I am getting this message when i = 0, so how
> > can 0 be out of range for nev = 2?
> > And why am I getting this message for 2 matrices out of 16?
> > Thanks!
