[petsc-users] matcreate and assembly issue
Thu Jul 2 20:10:45 CDT 2020
On Thu, Jul 2, 2020 at 7:30 PM Karl Lin <karl.linkui at gmail.com> wrote:
> Hi, Matt
> Thanks for the tip last time. We just encountered another issue with large
> data sets. This time the behavior is the opposite from last time. The data
> is 13.5TB, the total number of matrix columns is 2.4 billion. Our program
> crashed during matrix loading due to memory overflow in one node. As said
> before, we have a little memory check during loading the matrix to keep
> track of rss. The printout of rss in the log shows normal increase in many
> nodes, i.e., if we load in a portion of the matrix that is 1GB, after
> MatSetValues for that portion, rss will increase roughly about 1GB. On the
> node that has memory overflow, the rss increased by 2GB after only 1GB of
> matrix is loaded through MatSetValues. We are very puzzled by this. What
> could make the memory footprint twice as much as needed? Thanks in advance
> for any insight.
The only way I can imagine this happening is that you have not preallocated
correctly, so that some values are causing additional mallocs.
     Matt
> Regards,
> Karl
> On Thu, Jun 11, 2020 at 12:00 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Jun 11, 2020 at 12:52 PM Karl Lin <karl.linkui at gmail.com> wrote:
>>> Hi, Matthew
>>> Thanks for the suggestion, just did another run and here are some
>>> detailed stack traces, maybe will provide some more insight:
>>>  *** Process received signal ***
>>> Signal: Aborted (6)
>>> Signal code:  (-6)
>>> /lib64/libpthread.so.0(+0xf5f0)[0x2b56c46dc5f0]
>>>  [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b56c5486337]
>>>  [ 2] /lib64/libc.so.6(abort+0x148)[0x2b56c5487a28]
>>>  [ 3] /libpetsc.so.3.10(PetscTraceBackErrorHandler+0xc4)[0x2b56c1e6a2d4]
>>>  [ 4] /libpetsc.so.3.10(PetscError+0x1b5)[0x2b56c1e69f65]
>>>  [ 5]
>>> /libpetsc.so.3.10(PetscCommBuildTwoSidedFReq+0x19f0)[0x2b56c1e03cf0]
>>>  [ 6] /libpetsc.so.3.10(+0x77db17)[0x2b56c2425b17]
>>>  [ 7] /libpetsc.so.3.10(+0x77a164)[0x2b56c2422164]
>>>  [ 8] /libpetsc.so.3.10(MatAssemblyBegin_MPIAIJ+0x36)[0x2b56c23912b6]
>>>  [ 9] /libpetsc.so.3.10(MatAssemblyBegin+0xca)[0x2b56c1feccda]
>>> By reconfiguring, you mean recompiling petsc with that option, correct?
>> Reconfiguring.
>>   Thanks,
>>     Matt
>>> Thank you.
>>> Karl
>>> On Thu, Jun 11, 2020 at 10:56 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jun 11, 2020 at 11:51 AM Karl Lin <karl.linkui at gmail.com>
>>>> wrote:
>>>>> Hi, there
>>>>> We have written a program using Petsc to solve large sparse matrix
>>>>> system. It has been working fine for a while. Recently we encountered a
>>>>> problem when the size of the sparse matrix is larger than 10TB. We used
>>>>> several hundred nodes and 2200 processes. The program always crashes during
>>>>> MatAssemblyBegin.Upon a closer look, there seems to be something unusual.
>>>>> We have a little memory check during loading the matrix to keep track of
>>>>> rss. The printout of rss in the log shows normal increase up to rank 2160,
>>>>> i.e., if we load in a portion of matrix that is 1GB, after MatSetValues for
>>>>> that portion, rss will increase roughly about that number. From rank 2161
>>>>> onwards, the rss in every rank doesn't increase after matrix loaded. Then
>>>>> comes MatAssemblyBegin, the program crashed on rank 2160.
>>>>> Is there a upper limit on the number of processes Petsc can handle?
>>>>> or is there a upper limit in terms of the size of the matrix petsc can
>>>>> handle? Thank you very much for any info.
>>>> It sounds like you overflowed int somewhere. We try and check for this,
>>>> but catching every place is hard. Try reconfiguring with
>>>>   --with-64-bit-indices
>>>>   Thanks,
>>>>      Matt
>>>>> Regards,
>>>>> Karl
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200702/7e4260dc/attachment.html>
