[petsc-users] MatGetRow for global rows of a parallel matrix
Eda Oktay
eda.oktay at metu.edu.tr
Thu Jul 2 04:30:51 CDT 2020
Thank you so much!
Eda
Zhang, Hong <hongzhang at anl.gov>, 2 Tem 2020 Per, 07:29 tarihinde şunu yazdı:
> Dense matrix is stored in column-major order, so you might want to use MatGetColumnVector() to access columns of the matrix instead of the rows. For instance, you can get the n-th column out of the matrix and place it into a vector that shares the same parallel layout as the matrix with the following:
> MatDenseGetColumn(J,n,&xarr);
> VecPlaceArray(vec,xarr);
> VecResetArray(vec);
> MatDenseRestoreColumn(J,&xarr);
> Hong (Mr.)
> On Jun 10, 2020, at 8:08 AM, Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Dear Matt,
> Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 16:03 tarihinde
> şunu yazdı:
> On Wed, Jun 10, 2020 at 8:56 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Hi all,
> I am trying to get all the rows of a parallel matrix as individual
> vectors. For instance, if I have 72*4 matrix, I want to get 72
> different vectors having size 4.
> As far as I understood, MatGetRow is only for local rows, so
> MatGetOwnershipRange is used, however, when I tried this one, I
> couldn't get the whole and desired row vectors.
> In MatGetRow explanation, it is written that I should use
> MatCreateSubMatrices first, then use MatGetRow. But I couldn't
> understand to which extent I should create submatrices. I just need to
> have all 72 rows as 72 different vectors each having 4 elements.
> 1) For sparse matrices, the storage is always divided by row, so that values can only be retrieved for local rows with MatGetRow()
> 2) Is this matrix sparse? It sounds like it is dense.
> Matrix is dense.
> 3) Are you asking to get all matrix values on all processes? If so, I think the easiest thing to do is first wrap a Vec around the
> values, then use VecScatterToAll(), then wrap each one in a MatDense again.
> Yes, I want all row vectors on all processes. In a dense matrix,
> should I still wrap a Vec around the values? I know I should use
> scatter but I couldn't even wrap a Vec around them.
> Thanks so much!
> Eda
> Thanks,
> Matt
> Thanks!
> Eda
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
