[petsc-users] Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Jan 31 18:23:36 CST 2020
You might find this option useful.
--with-packages-download-dir=<dir>
Skip network download of package tarballs and locate them in specified dir. If not found in dir, print package URL - so it can be obtained manually.
This generates a list of URLs to download so you don't need to look through the xxx.py files for that information. Conceivably a script could gather this information from the run of configure and get the tarballs for you.
Barry
> On Jan 31, 2020, at 11:58 AM, Tomas Mondragon <tom.alex.mondragon at gmail.com> wrote:
> Hypre problem resolved. PETSc commit 05f86fb made in August 05, 2019 added the line 'self.installwithbatch = 0' to the __init__ method of the Configure class in the file petsc/config/BuildSystem/config/packages/hypre.py to fix a bug with hypre installation on Cray KNL systems. Since the machine I was installing os was an SGI system, I decided to try switching to 'self.installwithbatch = 1' and it worked! The configure script was finally able to run to completion.
> Perhaps there can be a Cray flag for configure that can control this, since it is only Cray's that have this problem with Hypre?
> For my benefit when I have to do this again -
> To get moose/petsc/scripts/update_and_rebuild_petsc.sh to run on an SGI system as a batch job, I had to:
> Make sure the git (gnu version) module was loaded
> git clone moose
> cd to the petsc directory and git clone the petsc submodule, but make sure to pull the latest commit. The commit that the moose repo refers to is outdated.
> cd back to the moose directory, git add petsc and git commit so that the newest petsc commit gets used by the update script. otherwise the old commit will be used.
> download the tarballs for fblaspack, hypre, metis, mumps, parmetis, scalapack, (PT)scotch, slepc, and superLU_dist. The URLS are in the __init__ methods of the relevant files inmost/petsc/config/BuildSystem/config/packages/
> alter moose/scripts/update_and_rebuild_petsc.sh script so that it is a working PBS batch job. Be sure to module swap to the gcc compiler and module load git (gnu version) and alter the ./configure command arguments
> adding
> --with-cudac=0
> --with-batch=1
> changing
> --download-<package>=/path/to/thirdparty/package/tarball
> If the supercomputer is not a Cray KNL system, change line 26 of moose/petsc/config/BuildSystem/config/packages/hypre.py from 'self.installwithbath = 0' to 'self.installwithbatch = 1', otherwise, install hypre on its own and use --with-hypre-dir=/path/to/hypre in the ./configure command
> On Fri, Jan 31, 2020 at 10:06 AM Tomas Mondragon <tom.alex.mondragon at gmail.com> wrote:
> Thanks for the change to base.py. Pulling the commit, confirm was able to skip over lgrind and c2html. I did have a problem with Parmetis, but that was because I was using an old ParMetis commit accidentally. Fixed by downloading the right commit of ParMetis.
> My current problem is with Hypre. Apparently --download-hypre cannot be used with --with-batch=1 even if the download URL is on the local machine. The configuration.log that resulted is attached for anyone who may be interested.
> You received this message because you are subscribed to a topic in the Google Groups "moose-users" group.
> To unsubscribe from this topic, visit https://groups.google.com/d/topic/moose-users/2xZsBpG-DtY/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to moose-users+unsubscribe at googlegroups.com.
> To view this discussion on the web visit https://groups.google.com/d/msgid/moose-users/a34fa09e-a4f5-4225-8933-34eb36759260%40googlegroups.com.
