[petsc-users] Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Alexander Lindsay
alexlindsay239 at gmail.com
Thu Jan 30 15:57:58 CST 2020
Tomas, make sure you're always using "reply all" when the PETSc users list
is involved...
On Thu, Jan 30, 2020 at 1:52 PM Tomas Mondragon <
tom.alex.mondragon at gmail.com> wrote:
> I altered the problematic part of the getExecutable method in
> petsc/config/BuildSystem/config/base.py just to get over this obstacle.
> def getExecutable(self, names, path = [], getFullPath = 0,
> useDefaultPath = 0, resultName = '', setMakeMacro = 1):
> '''Search for an executable in the list names
> - Each name in the list is tried for each entry in the path until a
> name is located, then it stops
> - If found, the path is stored in the variable "name", or
> "resultName" if given
> - By default, a make macro "resultName" will hold the path'''
> found = 0
> if isinstance(names,str) and names.startswith('/'):
> path = os.path.dirname(names)
> names = os.path.basename(names)
> if isinstance(names, str):
> names = [names]
> if isinstance(path, str):
> path = path.split(os.path.pathsep)
> if not len(path):
> useDefaultPath = 1
> def getNames(name, resultName):
> import re
> prog = re.match(r'(.*?)(?<!\\)(\s.*)',name)
> if prog:
> name = prog.group(1)
> options = prog.group(2)
> else:
> options = ''
> if not resultName:
> varName = name
> else:
> varName = resultName
> return name, options, varName
> varName = names[0]
> varPath = ''
> for d in path:
> for name in names:
> name, options, varName = getNames(name, resultName)
> if self.checkExecutable(d, name):
> found = 1
> getFullPath = 1
> varPath = d
> break
> if found: break
> if useDefaultPath and not found:
> for d in os.environ['PATH'].split(os.path.pathsep):
> for name in names:
> found = 1
> varPath = d
> break
> if found: break
> if not found:
> dirs = self.argDB['with-executables-search-path']
> if not isinstance(dirs, list): dirs = [dirs]
> for d in dirs:
> for name in names:
> found = 1
> getFullPath = 1
> varPath = d
> break
> if found: break
> if found:
> if getFullPath:
> setattr(self, varName, os.path.abspath(os.path.join(varPath,
> name))+options)
> else:
> setattr(self, varName, name+options)
> if setMakeMacro:
> self.addMakeMacro(varName.upper(), getattr(self, varName))
> else:
> self.logWrite(' Unable to find programs '+str(names)+' providing
> listing of each search directory to help debug\n')
> self.logWrite(' Path provided in Python program\n')
> for d in path:
> if os.path.isdir(d):
> try:
> self.logWrite(' '+str(os.listdir(d))+'\n')
> except OSError as e:
> self.logWrite(' '+e.strerror+'\n')
> else:
> self.logWrite(' Warning '+d+' is not a directory\n')
> if useDefaultPath:
> if os.environ['PATH'].split(os.path.pathsep):
> self.logWrite(' Path provided by default path\n')
> try:
> else:
> if dirs:
> self.logWrite(' Path provided by --with-executables-search-path
> \n')
> for d in dirs:
> try:
> else:
> return found
> I wasn't able to figure out why lgrind was being searched for, but running
> configure that wasn't just lgrind that sets of this bit of code, c2html
> does as well.
> Anyhow, with this fix, I was able to get configure to continue on until it
> failed to compile parmetis. Looking at configure.log it looks like it's
> because of a bad path to libmetis.
> On Thursday, January 30, 2020 at 10:54:21 AM UTC-6, Tomas Mondragon wrote:
>> Configuration log is attached
> You received this message because you are subscribed to the Google Groups
> "moose-users" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to moose-users+unsubscribe at googlegroups.com.
> To view this discussion on the web visit
> https://groups.google.com/d/msgid/moose-users/4d3bfd39-d68b-40d1-af4a-536f24860035%40googlegroups.com
> <https://groups.google.com/d/msgid/moose-users/4d3bfd39-d68b-40d1-af4a-536f24860035%40googlegroups.com?utm_medium=email&utm_source=footer>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200130/2fd5852c/attachment-0001.html>
